Hello there!
I have an ASUS H470-I motherboard. So I’ve tried to catch a sound from analog/audio type-c (works nice in win10-11), but it seems like in all GNU/Linux it works unexpectedly.
When earphones connected to standart “green” 3,5mm port (or front) - it’s okay, all work fine and in the setting appears option “Line Out”.
But when plug-in only type-c - only one option appears - “Digital output S/PDIF”. I presume, as in win1X, that type-c also may appear as “Line Out”. Maybe there is some loop from green 3,5mm to audio type-c, cause when smthing is plugged-in to green 3,5mm i can choose in audio settings instead of Line out - Headphones, and yes, there is a music on type-c. But when 3,5 is free again - magic is gone.
What I need to do to get rid of that dummy plug (some 3,5-to-3,5 cable) in 3,5mm (back or forward) in order to work audio type-c separately? Or should i just… live with it?
P.S. Why it is so important to me? Cable of earphones is too short, and this “extension analog type-c cable” was in the box, so i found this very convinient to use.
Thank you!
P.P.S. There is some code beneath, seen this in some other themes about audio.
inxi -Fazy ✔
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=f444809f-4fa0-42b6-ab72-917d16686caf rw rootflags=subvol=@ quiet
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: ROG STRIX H470-I GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2601
date: 10/29/2021
Device-1: hid-f4:73:35:15:10:2e-battery model: Keyboard K380 serial: N/A
charge: N/A status: discharging
Info: model: Intel Core i5-10400F bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 3 microcode: 0xEC
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4300 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 69629
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Gigabyte driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, DVI-D-1, HDMI-A-1
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: DP-1 mapped: DisplayPort-0 model: HP Z23n G2 serial: <filter>
built: 2020 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.42.0
5.15.32-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.8 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:06c8 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-3: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid bus-ID: 1-3.1:12
chip-ID: 0d8c:0014 class-ID: 0300
Device-4: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:3 chip-ID: 0c76:161e
class-ID: 0300
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.49 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4d class-ID: 0200
IF: eno2 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 86.14 GiB (18.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Transcend model: TS512GMTE110S
lanes: 4 type: SSD serial: <filter> rev: S0905C0 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 75 GiB size: 75 GiB (100.00%) used: 21.28 GiB (28.4%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 393.65 GiB size: 393.65 GiB (100.00%)
used: 64.86 GiB (16.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 75 GiB size: 75 GiB (100.00%)
used: 21.28 GiB (28.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 674
Processes: 470 Uptime: 10h 27m wakeups: 173 Memory: 31.24 GiB
used: 6.23 GiB (19.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1312 pacman: 1308 lib: 359 flatpak: 4
Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
pacmd dump ✔ 22s
### Configuration dump generated at Tue Apr 19 19:16:43 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="2" name="usb-0c76_USB_PnP_Audio_Device-00" card_name="alsa_card.usb-0c76_USB_PnP_Audio_Device-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0 xauthority=/home/potip/.Xauthority
load-module module-x11-xsmp display=:0 xauthority=/home/potip/.Xauthority session_manager=local/big-brother:@/tmp/.ICE-unix/906,unix/big-brother:/tmp/.ICE-unix/906
load-module module-alsa-card device_id="3" name="usb-C-Media_Electronics_Inc._USB_Audio_Device-00" card_name="alsa_card.usb-C-Media_Electronics_Inc._USB_Audio_Device-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-cli-protocol-unix
set-sink-volume alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo 0x4ccd
set-sink-mute alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo no
suspend-sink alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo yes
set-sink-volume alsa_output.pci-0000_00_1f.3.analog-stereo 0x428f
set-sink-mute alsa_output.pci-0000_00_1f.3.analog-stereo no
suspend-sink alsa_output.pci-0000_00_1f.3.analog-stereo no
set-source-volume alsa_input.usb-0c76_USB_PnP_Audio_Device-00.mono-fallback 0xa5a5
set-source-mute alsa_input.usb-0c76_USB_PnP_Audio_Device-00.mono-fallback no
suspend-source alsa_input.usb-0c76_USB_PnP_Audio_Device-00.mono-fallback yes
set-source-volume alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo.monitor 0x10000
set-source-mute alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo.monitor no
suspend-source alsa_output.usb-C-Media_Electronics_Inc._USB_Audio_Device-00.analog-stereo.monitor yes
set-source-volume alsa_output.pci-0000_00_1f.3.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1f.3.analog-stereo.monitor no
set-card-profile alsa_card.pci-0000_01_00.1 off
set-card-profile alsa_card.usb-0c76_USB_PnP_Audio_Device-00 input:mono-fallback
set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-stereo
set-card-profile alsa_card.usb-C-Media_Electronics_Inc._USB_Audio_Device-00 output:analog-stereo
set-default-sink alsa_output.pci-0000_00_1f.3.analog-stereo
set-default-source alsa_input.usb-0c76_USB_PnP_Audio_Device-00.mono-fallback
### EOF
amixer --card=0 ✔
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 40 [46%] [-35.25dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [off]
Front Right: Playback 87 [100%] [0.00dB] [off]
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Center',0
Mono: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
Mono:
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 39 [62%] [12.00dB] [on]
Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Rear Mic' 'Front Mic' 'Rear Mic 1' 'Line'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Rear Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic',1
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
