Hey all,
I reinstalled Manjaro in my SSD after I fixed my corrupted CMOS, since it corrupted the drive where the OS was. It’s all good and dandy, I didn’t lose much data, but I get this weird stuttering audio bug at random intervals. It’s not really laggy, it’s more like the audio mutes itself for a few miliseconds at a time. I checked the audio configuration and noticed something weird, one of my audio devices (the integrated audio device, IEC958) blinks in and out of the config, like it’s being disconnected very very quickly. It’s weird, since I’m using the other audio device (HDMI output from my nVidia card, GP106 High Def audio).
I honestly don’t know how to fix this.
Inxi output:
System: Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: CROSSHAIR V FORMULA-Z v: Rev 1.xx serial: <filter>
BIOS: American Megatrends v: 2201 date: 03/23/2015
CPU: Info: 8-Core model: AMD FX-8350 bits: 64 type: MCP arch: Bulldozer rev: 0 cache:
L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 64220
Speed: 3531 MHz min/max: N/A Core speeds (MHz): 1: 3531 2: 2804 3: 2589 4: 2088 5: 3078
6: 1873 7: 2695 8: 2341
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 460.73.01
bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia
resolution: 1920x1080~60Hz s-dpi: 69
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
Audio: Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Network: Device-1: Intel 82583V Gigabit Network vendor: ASUSTeK driver: e1000e v: kernel
port: c000 bus-ID: 03:00.0 chip-ID: 8086:150c class-ID: 0200
Device-2: TP-Link Archer T9UH v1 [Realtek RTL8814AU] type: USB driver: 8814au
bus-ID: 12-1:2 chip-ID: 2357:0106 class-ID: 0000 serial: <filter>
IF: wlp6s0u1 state: up mac: <filter>
Drives: Local Storage: total: 1.47 TiB used: 180.77 GiB (12.0%)
ID-1: /dev/sda vendor: Western Digital model: WDS120G2G0A-00JH30 size: 111.8 GiB
speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0000 scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WD5000AAKS-00V1A0 size: 465.76 GiB
speed: 3.0 Gb/s serial: <filter> rev: 1D05 scheme: GPT
ID-3: /dev/sdc vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A02 scheme: GPT
Partition: ID-1: / size: 109.48 GiB used: 10.43 GiB (9.5%) fs: ext4 dev: /dev/sda1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 18.8 C mobo: N/A gpu: nvidia temp: 32 C
Info: Processes: 224 Uptime: 4h 00m wakeups: 0 Memory: 19.45 GiB used: 2.3 GiB (11.8%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1205 Shell: Bash v: 5.1.4
running-in: konsole inxi: 3.3.04
