There is no sound coming out of the speakers. No matter whether via Bluetooth or Airplay. Although it looks like everything works
pactl list sinks ✔
Sink #43
State: SUSPENDED
Description: Internes Audio Analog Stereo
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 62259 / 95% / -1,34 dB, front-right: 62259 / 95% / -1,34 dB
balance 0,00
Base Volume: 60694 / 93% / -2,00 dB
Monitor Source: alsa_output.pci-0000_00_1b.0.analog-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.card = "0"
alsa.card_name = "HDA Intel"
alsa.class = "generic"
alsa.device = "0"
alsa.id = "ALC889 Analog"
alsa.long_card_name = "HDA Intel at 0xf9ed8000 irq 51"
alsa.name = "ALC889 Analog"
alsa.resolution_bits = "16"
alsa.subclass = "generic-mix"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
api.alsa.card.longname = "HDA Intel at 0xf9ed8000 irq 51"
api.alsa.card.name = "HDA Intel"
api.alsa.path = "front:0"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
card.profile.device = "5"
device.api = "alsa"
device.class = "sound"
device.id = "41"
device.profile.description = "Analog Stereo"
device.profile.name = "analog-stereo"
device.routes = "2"
factory.name = "api.alsa.pcm.sink"
media.class = "Audio/Sink"
device.description = "Internes Audio"
node.name = "alsa_output.pci-0000_00_1b.0.analog-stereo"
node.nick = "ALC889 Analog"
node.pause-on-idle = "false"
object.path = "alsa:pcm:0:front:0:playback"
priority.driver = "1009"
priority.session = "1009"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "34"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "43"
object.serial = "43"
node.max-latency = "16384/48000"
api.alsa.period-size = "1024"
api.alsa.period-num = "32"
api.alsa.headroom = "0"
api.acp.auto-port = "false"
api.alsa.card = "0"
api.alsa.use-acp = "true"
device.bus = "pci"
device.bus_path = "pci-0000:00:1b.0"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_00_1b.0"
device.nick = "HDA Intel"
device.plugged.usec = "4788436"
device.product.id = "0x3a3e"
device.product.name = "82801JI (ICH10 Family) HD Audio Controller"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
device.vendor.id = "0x8086"
device.string = "0"
Ports:
analog-output-lineout: Line-Ausgang (type: Line, priority: 9000, availability group: Legacy 4, available)
analog-output-headphones: Kopfhörer (type: Headphones, priority: 9900, availability group: Legacy 5, not available)
Active Port: analog-output-lineout
Formats:
pcm
Sink #54
State: RUNNING
Description: KEF (IPv4)
Driver: PipeWire
Sample Specification: s16le 2ch 44100Hz
Mute: no
Volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
Base Volume: 65536 / 100% / 0,00 dB
Monitor Source: raop_sink.KEF-LSX.local.ipv4.monitor
Flags: DECIBEL_VOLUME LATENCY
Properties:
node.name = "raop_sink.KEF-LSX.local.ipv4"
device.description = "KEF (IPv4)"
node.latency = "352/44100"
node.virtual = "true"
media.name = "RAOP sink"
stream.is-live = "true"
node.want-driver = "true"
adapt.follower.spa-node = ""
object.register = "false"
factory.id = "18"
client.id = "53"
object.id = "54"
object.serial = "54"
Formats:
pcm
Sink #69
State: SUSPENDED
Description: KEF LSX
Driver: PipeWire
Sample Specification: s24le 2ch 48000Hz
Mute: no
Volume: front-left: 25802 / 39% / -24,29 dB, front-right: 25802 / 39% / -24,29 dB
balance 0,00
Monitor Source: bluez_output.84_17_15_11_3E_27.1.monitor
Flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
api.bluez5.address = "84:17:15:11:3E:27"
api.bluez5.codec = "aptx"
api.bluez5.profile = "a2dp-sink"
api.bluez5.transport = ""
card.profile.device = "1"
device.id = "66"
device.routes = "1"
factory.name = "api.bluez5.a2dp.sink"
device.description = "KEF LSX"
node.name = "bluez_output.84_17_15_11_3E_27.1"
priority.driver = "1010"
priority.session = "1010"
factory.id = "8"
device.api = "bluez5"
media.name = "KEF LSX"
object.id = "67"
object.serial = "69"
client.id = "34"
api.bluez5.class = "0x200428"
api.bluez5.connection = "disconnected"
api.bluez5.device = ""
api.bluez5.icon = "audio-card"
api.bluez5.path = "/org/bluez/hci0/dev_84_17_15_11_3E_27"
bluez5.auto-connect = "[ hfp_hf hsp_hs a2dp_sink ]"
bluez5.profile = "off"
device.alias = "KEF LSX"
device.bus = "bluetooth"
device.form_factor = "hifi"
device.icon_name = "audio-card-bluetooth"
device.name = "bluez_card.84_17_15_11_3E_27"
device.product.id = "0xffff"
device.string = "84:17:15:11:3E:27"
device.vendor.id = "bluetooth:000a"
Ports:
hifi-output: HiFi (type: HiFi, priority: 0, available)
Active Port: hifi-output
Formats:
pcm
As you can see, the Raop Sink status is Running but no sound.
pactl info ✔
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 108
Tile Size: 65472
User Name: weingeist
Host Name: weingeist-PC
Server Name: PulseAudio (on PipeWire 0.3.70)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1b.0.analog-stereo
Default Source: alsa_input.pci-0000_00_1b.0.analog-stereo
Cookie: aef5:88e9
systemctl --user status pipewire pipewire-pulse wireplumber ✔
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: enabled)
Active: active (running) since Mon 2023-06-05 19:13:29 CEST; 26min ago
TriggeredBy: ● pipewire.socket
Main PID: 1513 (pipewire)
Tasks: 2 (limit: 14157)
Memory: 18.4M
CPU: 4.137s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─1513 /usr/bin/pipewire
Jun 05 19:13:29 weingeist-PC systemd[1289]: Started PipeWire Multimedia Service.
Jun 05 19:13:29 weingeist-PC pipewire[1513]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Jun 05 19:13:29 weingeist-PC pipewire[1513]: mod.rt: found session bus but no portal
Jun 05 19:17:58 weingeist-PC pipewire[1513]: mod.raop-sink: missing Session header
Jun 05 19:21:15 weingeist-PC pipewire[1513]: mod.raop-sink: missing Session header
Jun 05 19:31:28 weingeist-PC pipewire[1513]: mod.raop-sink: missing Session header
● pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; preset: enabled)
Active: active (running) since Mon 2023-06-05 19:13:30 CEST; 26min ago
TriggeredBy: ● pipewire-pulse.socket
Main PID: 1674 (pipewire-pulse)
Memory: 4.0M
CPU: 49ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
└─1674 /usr/bin/pipewire-pulse
Jun 05 19:13:30 weingeist-PC systemd[1289]: Started PipeWire PulseAudio.
● wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
Main PID: 1514 (wireplumber)
Tasks: 6 (limit: 14157)
Memory: 46.6M
CPU: 7.153s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
└─1514 /usr/bin/wireplumber
Jun 05 19:13:29 weingeist-PC systemd[1289]: Started Multimedia Service Session Manager.
Jun 05 19:13:29 weingeist-PC wireplumber[1514]: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Jun 05 19:13:29 weingeist-PC wireplumber[1514]: found session bus but no portal
Jun 05 19:13:29 weingeist-PC wireplumber[1514]: [0:00:09.051384599] [1514] INFO Camera camera_manager.cpp:298 libcamera v0.0.5
thats new since the last Update
Does anyone have a tip or know advice? I can no longer get on
