Hi guys
I have two users (recently created second one) and have same problem with both of them. On startup sometimes audio is not working Built-in Audio Analog Stereo is disabled have to re enable it manually, sometimes enabling is not available from Audi System Settings.
Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=f3ea9f0a-64af-4f49-900f-ed76bf207bf4 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: HP product: HP ProBook 450 G6 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 8538 v: KBC Version 51.27.00 serial: <filter> UEFI: HP
v: R71 Ver. 01.10.00 date: 01/03/2020
ID-1: BAT0 charge: 15.9 Wh condition: 41.3/41.3 Wh (100%) volts: 11.1/11.6
model: Hewlett-Packard Primary type: Li-ion serial: <filter>
status: Discharging
Topology: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: C (12) microcode: D6
L2 cache: 6144 KiB
bogomips: 28808
Speed: 800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo bus ID: 1-2:2
chip ID: 04f2:b669 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.1.6
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k5.7.17-2-MANJARO
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
port: 4000 bus ID: 00:14.3 chip ID: 8086:9df0
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 01:00.0
chip ID: 10ec:8168
IF: enp1s0 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 704.24 GiB used: 54.88 GiB (7.8%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC501 HFM256GDJTNG-8310A
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 serial: <filter> rev: 80002C00 scheme: GPT
ID-2: /dev/sda vendor: Hitachi model: HTS545050A7E380 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: A6C0 scheme: GPT
ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 54.88 GiB (23.5%) fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: file size: 16.00 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 42.0 C mobo: 0.0 C
Processes: 267 Uptime: 12m Memory: 7.65 GiB used: 1.69 GiB (22.0%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1351 pacman: 1333
lib: 360 flatpak: 10 snap: 8 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05
