I can not get to work my Mic from my headphones, I only can listen but the Mic is not recognized. There are to connectors on my Lap, one for the Speakers and one for the Mic. I want to find a solution for this, I also inform you that I consider myself as an average user with Linux and Terminal use.
I used an external USB sound card and it works, but I am sure that there is something I can do to fix the issue.
Thanks in advance
System: Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=adfe44a1-25d0-449c-8377-44759bb9f874 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3 Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Manjaro Linux base: Arch Linux Machine: Type: Portable System: Dell product: Dell System Inspiron N4110 v: N/A serial: <filter> Chassis: type: 8 v: 0.1 serial: <filter> Mobo: Dell model: 05TM8C v: A00 serial: <filter> UEFI-[Legacy]: Dell v: A12 date: 09/07/2012 Battery: ID-1: BAT0 charge: 15.2 Wh (100.0%) condition: 15.2/48.8 Wh (31.1%) volts: 12.4 min: 11.1 model: SIMPLO Dell type: Li-ion serial: <filter> status: Full CPU: Info: Dual Core model: Intel Core i3-2310M bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F cache: L2: 3 MiB flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 16755 Speed: 798 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 798 2: 853 3: 809 4: 834 Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable Type: mds mitigation: Clear CPU buffers; SMT vulnerable Type: meltdown mitigation: PTI Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300 Device-2: Sunplus Innovation Dell HD Webcam type: USB driver: uvcvideo bus-ID: 1-1.4:4 chip-ID: 1bcf:2880 class-ID: 0e02 Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver: loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0 resolution: <missing: xdpyinfo> OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 21.1.6 compat-v: 3.0 direct render: Yes Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403 Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes Sound Server-2: JACK v: 1.9.19 running: no Sound Server-3: PulseAudio v: 15.0 running: yes Sound Server-4: PipeWire v: 0.3.33 running: no Network: Device-1: Intel Centrino Wireless-N 1030 [Rainbow Peak] driver: iwlwifi v: kernel port: efa0 bus-ID: 01:00.0 chip-ID: 8086:008a class-ID: 0280 IF: wlp1s0 state: down mac: <filter> Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200 IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter> Bluetooth: Device-1: Intel Centrino Advanced-N 6230 Bluetooth adapter type: USB driver: btusb v: 0.8 bus-ID: 2-1.5:4 chip-ID: 8086:0189 class-ID: e001 Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends Drives: Local Storage: total: 111.79 GiB used: 14.17 GiB (12.7%) SMART Message: Required tool smartctl not installed. Check --recommends ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37120G size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0007 scheme: MBR Partition: ID-1: / raw-size: 111.79 GiB size: 109.47 GiB (97.93%) used: 14.17 GiB (12.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 Swap: Alert: No swap data was found. Sensors: System Temperatures: cpu: 58.0 C mobo: 40.0 C sodimm: SODIMM C Fan Speeds (RPM): cpu: 0 Info: Processes: 234 Uptime: 1h 39m wakeups: 1 Memory: 7.66 GiB used: 2.85 GiB (37.2%) Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1138 lib: 294 flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
