Since I started up this morning I seem to have several issues with audio.
Initially I noticed that trying to convert some downloaded WAVs to FLAC files was failing - Then I tried playing the files to see if there was an issue with them and they wouldn’t play at all.
I then tried some other (known good) files and had the same result.
I plugged in some cheap speakers into my headphones socket and I have sound output from there working OK. My main audio outputs via USB to an external DAC and that has just completely stopped working.
Can anyone point me in the right direction as to what’s been changed in the last week that could impact this?
I found that killing and restarting pulseaudio seems to bring it back, but then track skipping or trying a different file to play will just make it die again.
pulseaudio --kill
pulseaudio --start
PulseAudio seems really unstable - PA Volume Control is now hanging for me on “Establishing connection to PulseAudio. Please wait…”
I’ve thought about playing around with pipewire but I but so much effort into getting pulseaudio working with my DAC properly the idea doesn’t fill me with joy.
Something to try out when I have a spare few days at least. I have noticed recently that more and more distros seem to be switching over to pipewire as standard so I need to factor it in at some point.
I did that @banjo - No joys. If I try and play music I’m getting nothing at all through the DAC output (This is actually worse than before, as it would work sometimes and then cut out). My tiny little plug in speakers that I use for zoom calls etc. seem to work fine if I switch the audio output over there but I’m getting nothing out of the main output at all. Same with a game - No audio at all.
This was all working fine before the recent raft of updates and is still working fine on my Windows and Ubuntu Studio partitions.
Just checked my System Monitor and PipeWire is still running - doesn’t look like it wants to be disabled fully.
Edit: manjaro-pulse is default, at least here on xfce. If you install manjaro-pulse it will conflict with manjaro-pipewire and vice versa. There should only be one.
The behaviour is VERY odd. My audio just came back after playing a YouTube video in my browser, switching the Output from speakers back again to the Digital and Audio outputs for the DAC, and opening pavcontrol again.
In the end @mithrial 's suggestion of installing manjaro-pipewire seems to have got everything working again, in a basic sense anyway.
I am now getting fairly reliable output from my DAC but it seems everything is outputting at 48kHz, so my configuration to allow for multiple bitrates and sample rates is no longer being honoured (This was for pulse so this is expected anyway). I now have an “Azur DacMagic Pro” playback option which is new but it seems no different from the other two I had before in terms of the output.
I shall dig into PipeWire and look at how I can get my DAC working optimally and update my DAC setup article with PipeWire config over the next few weeks, hopefully.
