Hi, kinda a newbie here, so I will try to explain this as clear as I can.
A couple of days ago, I just ran the package manager to update my system (I use Manjaro Gnome), I rebooted and then noticed that the speakers, headphones, and internal laptop mic wasn’t working properly.
If I plugged in my headphones, it will output sound on them and the speakers at the same time unless I go to sound config and change it. Before, it will pop up a window and tell me that if I wanted to use them as headphones or headset, and just switch the output only to them.
Also, the internal mic just straight stop working. I tried to go into alsamixer settings, but it also doesn’t keep my config.
Here is what inxi -Fx outputs:
Host: aspire3 Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 10.2.0 Desktop: GNOME 3.38.1 Distro: Manjaro Linux
Type: Laptop System: Acer product: Aspire A315-42 v: V1.06
serial: <superuser/root required>
Mobo: PK model: Sleepy_PK v: V1.06 serial: <superuser/root required>
UEFI: Insyde v: 1.06 date: 09/26/2019
ID-1: BAT1 charge: 31.9 Wh condition: 31.9/37.0 Wh (86%)
model: PANASONIC 0x41,0x50,0x31,0x36,0x4D,0x35,0x0013 status: Full
Device-1: hidpp_battery_0 model: Logitech M215
charge: 55% (should be ignored) status: Discharging
Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB
bogomips: 33551
Speed: 1262 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1223 2: 1288 3: 1225 4: 1234 5: 1257 6: 1277 7: 1225 8: 1332
Device-1: AMD Picasso vendor: Acer Incorporated ALI driver: amdgpu
v: kernel bus ID: 05:00.0
Device-2: Chicony VGA WebCam type: USB driver: uvcvideo bus ID: 1-1:2
Display: x11 server: X.org 1.20.9 driver: amdgpu,ati
unloaded: modesetting,radeon resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.18-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.2.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 05:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Acer Incorporated ALI driver: snd_rn_pci_acp3x v: kernel
bus ID: 05:00.5
Device-3: AMD Family 17h HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus ID: 05:00.6
Sound Server: ALSA v: k5.8.18-1-MANJARO
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000
bus ID: 03:00.0
IF: enp3s0 state: down mac: 08:97:98:83:ae:81
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel port: 2000 bus ID: 04:00.0
IF: wlp4s0 state: up mac: 10:63:c8:be:df:85
Device-3: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB
driver: btusb bus ID: 1-4:4
Local Storage: total: 1.03 TiB used: 48.54 GiB (4.6%)
ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3128GJ1
ID-2: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
ID-1: / size: 107.92 GiB used: 29.37 GiB (27.2%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /home size: 915.89 GiB used: 19.17 GiB (2.1%) fs: ext4 dev: /dev/sda
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 68.2 C mobo: N/A gpu: amdgpu temp: 68.0 C
Processes: 271 Uptime: 10m Memory: 5.81 GiB used: 1.64 GiB (28.3%)
Init: systemd Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1363
Shell: fish v: 3.1.2 inxi: 3.1.08
Also, I check what packages updated with pacman log viewer, and I think these are relevant:
libpulse 13.0-3 -> 13.99.3-1
pulseaudio 13.0-3 -> 13.99.3-1
pulseaudio-bluetooth 13.0-3 -> 13.99.3-1
lib32-libpulse 13.0-1 -> 13.99.3-1
pulseaudio-equalizer 13.0-3 -> 13.99.3-1
pulseaudio-jack 13.0-3 -> 13.99.3-1
pulseaudio-lirc 13.0-3 -> 13.99.3-1
pulseaudio-zeroconf 13.0-3 -> 13.99.3-1
alsa-firmware 1.2.1-2 -> 1.2.4-2
alsa-topology-conf 1.2.3-1 -> 1.2.4-2
alsa-ucm-conf 1.2.3-2 -> 1.2.4-2
alsa-lib 1.2.3.2-1 -> 1.2.4-3
alsa-utils 1.2.3-2 -> 1.2.4-2
alsa-card-profiles 13.99.3-1
lib32-alsa-lib 1.2.3.2-1 -> 1.2.4-2
And what arecord -l outputs:
**** List of CAPTURE Hardware Devices ****
card 1: Generic_1 [HD-Audio Generic], device 0: ALC255 Analog [ALC255 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 2: acp [acp], device 0: DMIC capture dmic-hifi-0 []
Subdevices: 1/1
Thank you in advance!
