Audio "pop" with any audio source or application
Just installed 17.1.11 KDE flavour
I hear random “pops” in audio playback in VLC, Chrome, Firefox.
I suspect that this is related to the audio driver installed automatically on the system.
The specs for this MB say “Realtek ALC887 codec”
Below are the system specs:
  Host: Manjaro-Office Kernel: 4.16.15-rt7-MANJARO x86_64 bits: 64
  compiler: gcc v: 8.1.1 Desktop: KDE Plasma 5.13.2 tk: Qt 5.11.1
  Distro: Manjaro Linux 17.1.11 Hakoila
  Type: Desktop System: Gigabyte product: AB350M-Gaming 3 v: N/A
  serial: <filter>
  Mobo: Gigabyte model: AB350M-Gaming 3-CF v: x.x serial: <filter>
  UEFI: American Megatrends v: F23d date: 04/17/2018
  Topology: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP
  arch: Zen rev: 1 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 76672
  Speed: 2802 MHz min/max: 1550/3200 MHz Core speeds (MHz): 1: 2848
  2: 2819 3: 3213 4: 3164 5: 2715 6: 2722 7: 3124 8: 2726 9: 2715
  10: 3354 11: 2830 12: 2642
  Card-1: NVIDIA GM204 [GeForce GTX 970] driver: nvidia v: 396.24
  bus ID: 07:00.0
  Display: x11 server: X.Org 1.19.6 driver: nvidia
  resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 396.24
  direct render: Yes
  Card-1: NVIDIA GM204 High Definition Audio driver: snd_hda_intel
  v: kernel bus ID: 07:00.1
  Card-2: AMD Family 17h HD Audio driver: snd_hda_intel v: kernel
  bus ID: 09:00.3
  Card-3: Microsoft LifeCam Cinema type: USB
  driver: uvcvideo,snd-usb-audio bus ID: 1:2
  Sound Server: ALSA v: k4.16.15-rt7-MANJARO
  Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  driver: r8168 v: 8.045.08-NAPI port: f000 bus ID: 04:00.0
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  HDD Total Size: 6.56 TiB used: 9.75 GiB (0.1%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 960 EVO 250GB
  ID-2: /dev/sda vendor: SanDisk model: SDSSDHII960G size: 894.25 GiB
  ID-3: /dev/sdb vendor: Seagate model: ST6000DX000-1H217Z size: 5.46 TiB
  ID-1: / size: 210.96 GiB used: 9.75 GiB (4.6%) fs: ext4
  dev: /dev/nvme0n1p2
  ID-2: swap-1 size: 17.25 GiB used: 0 KiB (0.0%) fs: swap
  dev: /dev/nvme0n1p3
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 63 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 6%
  Processes: 350 Uptime: 26m Memory: 15.68 GiB used: 3.17 GiB (20.2%)
  Init: systemd Compilers: gcc: 8.1.1 Shell: bash v: 4.4.23 inxi: 3.0.12
Tips for posting
Use a “keyword search” to make sure your question has not already been asked. For example “failed to verify key” or “sound is muted”.
Make sure you include enough detail so people know what you are running. A useful command is inxi -Fxz; copy and paste the text and format as “code” (e.g. use the </> button above).
If possible, paste text rather than upload a photo. Text is easier to read, searchable, and takes up less space on the server. Please don’t upload high-resolution photos.
For more information read this post: How to provide good information in your posts
Remember to remove all of this help text before you post.
https://wiki.archlinux.org/index.php/Advanced_Linux_Sound_Architecture/Troubleshooting#Pops_when_starting_and_stopping_playback
Thanks.
Checked the audio power save, the file modprobe.conf was not there - /etc/modprobe.d/
I started playing around with the kernel governors
I changed (echo performance | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor) them to performance, but cpupower frequency-info still shows that the CPU frequency jumps around, which is probably what is causing the skips, or pop in the audio played.
I will keep messing with this to see if I can get it right.
Thanks again for the help lojze
