My KDE Audio Panel just has a red line through the speaker icon.
When I click on it, I don’t see any volume controls or devices or applications.
I was trying to debug a Zoom microphone issue and I did edit one of the alsa or pulse config files. Now the microphone and the speaker are working but I can’t control the volume from the KDE panel. Also I can’t use headphones with my machine.
So it’s quite possible I need to reinstall pulse or alsa?
Any advice would be appreciated.
Thanks
Below is my ALSA information
!!ALSA Information Script v 0.5.1
!!Script ran on: Fri Jul 8 15:13:03 UTC 2022
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: LENOVO
Product Name: 20QRS00100
Product Version: ThinkPad P73
Firmware Version: N2NET35W (1.20 )
System SKU: LENOVO_MT_20QR_BU_Think_FM_ThinkPad P73
Board Vendor: LENOVO
Board Name: 20QRS00100
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/INT0E0C:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:00/status 15
/sys/bus/acpi/devices/INT3403:01/status 15
/sys/bus/acpi/devices/INT3403:02/status 15
/sys/bus/acpi/devices/INT3403:03/status 15
/sys/bus/acpi/devices/INT3450:00/status 15
/sys/bus/acpi/devices/INT3515:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LEN0100:00/status 15
/sys/bus/acpi/devices/LEN0268:00/status 15
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 15
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/LNXPOWER:07/status 1
/sys/bus/acpi/devices/LNXPOWER:09/status 1
/sys/bus/acpi/devices/LNXPOWER:0a/status 1
/sys/bus/acpi/devices/LNXPOWER:0b/status 1
/sys/bus/acpi/devices/LNXPOWER:0c/status 1
/sys/bus/acpi/devices/LNXVIDEO:00/status 15
/sys/bus/acpi/devices/NTC0702:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0B00:00/status 15
/sys/bus/acpi/devices/PNP0C02:00/status 3
/sys/bus/acpi/devices/PNP0C02:01/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C04:00/status 31
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PRP00001:00/status 11
/sys/bus/acpi/devices/USBC000:00/status 15
/sys/bus/acpi/devices/device:21/status 15
/sys/bus/acpi/devices/device:30/status 15
/sys/bus/acpi/devices/device:31/status 15
!!Kernel Information
Kernel release: 5.10.126-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.10.126-1-MANJARO
Library version: 1.2.7.1
Utilities version: 1.2.7
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - No
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0x6041108000 irq 180
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xce000000 irq 17
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10) (prog-if 80)
Subsystem: Lenovo Device [17aa:229b]
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:10fa] (rev a1)
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 1
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Card: /sys/class/sound/card1
Tree:
!!HDA-Intel Codec information
–startcollapse–
Codec: Conexant CX8070
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x14f11f86
Subsystem Id: 0x17aa229b
Revision Id: 0x100100
No Modem Function Group found
Default PCM:
rates [0x540]: 48000 96000 192000
bits [0xa]: 16 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 D3cold S3D3cold CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=5, o=0, i=0, unsolicited=1, wake=1
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[4]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x10 [Audio Output] wcaps 0xc1d: Stereo Amp-Out R/L
Control: name=“Headphone Playback Volume”, index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Control: name=“Headphone Playback Switch”, index=0, device=0
Device: name=“CX8070 Analog”, type=“Audio”, device=0
Amp-Out caps: ofs=0x4a, nsteps=0x4a, stepsize=0x03, mute=1
Amp-Out vals: [0x80 0x80]
Converter: stream=0, channel=0
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x11 [Audio Output] wcaps 0xc1d: Stereo Amp-Out R/L
Control: name=“Speaker Playback Volume”, index=0, device=0
Control: name=“Speaker Playback Switch”, index=0, device=0
Amp-Out vals: [0x4a 0x4a]
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Node 0x12 [Beep Generator Widget] wcaps 0x70000c: Mono Amp-Out
Control: name=“Beep Playback Volume”, index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name=“Beep Playback Switch”, index=0, device=0
Amp-Out caps: ofs=0x07, nsteps=0x07, stepsize=0x0f, mute=0
Amp-Out vals: [0x03]
Node 0x13 [Audio Input] wcaps 0x100d1b: Stereo Amp-In R/L
Control: name=“Capture Volume”, index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name=“Capture Switch”, index=0, device=0
Amp-In caps: ofs=0x4a, nsteps=0x50, stepsize=0x03, mute=1
Amp-In vals: [0x80 0x80] [0x50 0x50] [0x50 0x50] [0x80 0x80]
SDI-Select: 0
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Connection: 4
0x18 0x19 0x1a* 0x15
Node 0x14 [Audio Input] wcaps 0x100d1b: Stereo Amp-In R/L
Amp-In vals: [0x4a 0x4a] [0x4a 0x4a]
SDI-Select: 0
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Connection: 2
0x1a* 0x15
Node 0x15 [Vendor Defined Widget] wcaps 0xf0050b: Stereo Amp-In
Amp-In caps: ofs=0x4a, nsteps=0x4a, stepsize=0x03, mute=1
Connection: 2
0x10* 0x11
Node 0x16 [Pin Complex] wcaps 0x400581: Stereo
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x04211040: [Jack] HP Out at Ext Right
Conn = 1/8, Color = Black
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 2
0x10* 0x11
Node 0x17 [Pin Complex] wcaps 0x400501: Stereo
Pincap 0x00010010: OUT EAPD
EAPD 0x2: EAPD
Pin Default 0x91170110: [Fixed] Speaker at Int Rear
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 2
0x10 0x11*
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x2f, mute=0
Amp-In vals: [0x00 0x00]
Pincap 0x00001324: IN Detect
Vref caps: HIZ 50 80
Pin Default 0x40f001f0: [N/A] Other at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00: VREF_HIZ
Unsolicited: tag=00, enabled=0
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name=“Mic Boost Volume”, index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Pin Default 0x04a11030: [Jack] Mic at Ext Right
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name=“Internal Mic Boost Volume”, index=0, device=0
Pincap 0x00000024: IN Detect
Pin Default 0x95a60120: [Fixed] Mic at Int Top
Conn = Digital, Color = Unknown
DefAssociation = 0x2, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Vendor Defined Widget] wcaps 0xf0058b: Stereo Amp-In
Amp-In caps: N/A
Amp-In vals:
Power states:
Connection: 0
Node 0x1e [Vendor Defined Widget] wcaps 0xf0058b: Stereo Amp-In
Amp-In caps: N/A
Amp-In vals:
Power states:
Connection: 0
Node 0x1f [Vendor Defined Widget] wcaps 0xf0058b: Stereo Amp-In
Amp-In caps: N/A
Amp-In vals:
Power states:
Connection: 0
Node 0x20 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
bits [0xe]: 16 20 24
formats [0x5]: PCM AC3
Node 0x21 [Pin Complex] wcaps 0x400701: Stereo Digital
Pincap 0x00000010: OUT
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 1
0x20
Codec: Intel Kabylake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280b
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled KAE
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
Codec: Nvidia GPU 94 HDMI/DP
Address: 0
Vendor Id: 0x10de0094
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
Dev 00: PD = 0, ELDV = 0, IA = 0
Dev 01: PD = 0, ELDV = 0, IA = 0
Dev 02: PD = 0, ELDV = 0, IA = 0
Dev 03: PD = 0, ELDV = 0, IA = 0
Connection: 4
0x08 0x09 0x0a 0x0b
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=05, enabled=1
Devices: 4
Connection: 4
0x08 0x09 0x0a 0x0b
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=09, enabled=1
Devices: 4
Connection: 4
0x08 0x09 0x0a 0x0b
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=0d, enabled=1
Devices: 4
Connection: 4
0x08 0x09 0x0a 0x0b
Node 0x08 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x09 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
–endcollapse–
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 11 Jul 8 10:51 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 20 Jul 8 10:51 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 9 Jul 8 10:51 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 10 Jul 8 10:51 /dev/snd/hwC0D2
crw-rw---- 1 root audio 116, 19 Jul 8 10:51 /dev/snd/hwC1D0
crw-rw---- 1 root audio 116, 3 Jul 8 10:51 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 2 Jul 8 11:09 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 8 Jul 8 10:51 /dev/snd/pcmC0D10p
crw-rw---- 1 root audio 116, 4 Jul 8 10:51 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 5 Jul 8 10:51 /dev/snd/pcmC0D7p
crw-rw---- 1 root audio 116, 6 Jul 8 10:51 /dev/snd/pcmC0D8p
crw-rw---- 1 root audio 116, 7 Jul 8 10:51 /dev/snd/pcmC0D9p
crw-rw---- 1 root audio 116, 16 Jul 8 10:51 /dev/snd/pcmC1D10p
crw-rw---- 1 root audio 116, 17 Jul 8 10:51 /dev/snd/pcmC1D11p
crw-rw---- 1 root audio 116, 18 Jul 8 10:51 /dev/snd/pcmC1D12p
crw-rw---- 1 root audio 116, 12 Jul 8 10:51 /dev/snd/pcmC1D3p
crw-rw---- 1 root audio 116, 13 Jul 8 10:51 /dev/snd/pcmC1D7p
crw-rw---- 1 root audio 116, 14 Jul 8 10:51 /dev/snd/pcmC1D8p
crw-rw---- 1 root audio 116, 15 Jul 8 10:51 /dev/snd/pcmC1D9p
crw-rw---- 1 root audio 116, 1 Jul 8 10:51 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Jul 8 10:51 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Jul 8 10:51 .
drwxr-xr-x 3 root root 480 Jul 8 10:51 …
lrwxrwxrwx 1 root root 12 Jul 8 10:51 pci-0000:00:1f.3 → …/controlC0
lrwxrwxrwx 1 root root 12 Jul 8 10:51 pci-0000:01:00.1 → …/controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: CX8070 Analog [CX8070 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 ‘PCH’/‘HDA Intel PCH at 0x6041108000 irq 180’
Mixer name : ‘Conexant CX8070’
Components : ‘HDA:14f11f86,17aa229b,00100100 HDA:8086280b,80860101,00100000’
Controls : 58
Simple ctrls : 17
Simple mixer control ‘Master’,0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 74
Mono: Playback 74 [100%] [0.00dB] [on]
Simple mixer control ‘Headphone’,0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-74.00dB] [off]
Front Right: Playback 0 [0%] [-74.00dB] [off]
Simple mixer control ‘Speaker’,0
Mono:
Front Left: Playback 74 [100%] [0.00dB] [on]
Front Right: Playback 74 [100%] [0.00dB] [on]
Simple mixer control ‘PCM’,0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 254 [100%] [-0.20dB]
Front Right: Playback 254 [100%] [-0.20dB]
Simple mixer control ‘Mic Boost’,0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control ‘Mic Mute-LED Mode’,0
Capabilities: enum
Items: ‘On’ ‘Off’ ‘Follow Capture’ ‘Follow Mute’
Item0: ‘Follow Mute’
Simple mixer control ‘IEC958’,0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control ‘IEC958’,1
Mono: Playback [on]
Simple mixer control ‘IEC958’,2
Mono: Playback [on]
Simple mixer control ‘IEC958’,3
Mono: Playback [on]
Simple mixer control ‘IEC958’,4
Mono: Playback [on]
Simple mixer control ‘Beep’,0
Mono: Playback 3 [43%] [-16.00dB] [on]
Simple mixer control ‘Capture’,0
Capabilities: cvolume cswitch
Limits: Capture 0 - 80
Front Left: Capture 80 [100%] [6.00dB] [on]
Front Right: Capture 80 [100%] [6.00dB] [on]
Simple mixer control ‘Auto-Mute Mode’,0
Capabilities: enum
Items: ‘Disabled’ ‘Enabled’
Item0: ‘Disabled’
Simple mixer control ‘Digital’,0
Limits: Capture 0 - 120
Front Left: Capture 60 [50%] [0.00dB]
Front Right: Capture 60 [50%] [0.00dB]
Simple mixer control ‘Internal Mic Boost’,0
Limits: 0 - 3
Simple mixer control ‘Mute-LED Mode’,0
Capabilities: enum
Items: ‘On’ ‘Off’ ‘Follow Master’
Item0: ‘Follow Master’
!!-------Mixer controls for card NVidia
Card sysdefault:1 ‘NVidia’/‘HDA NVidia at 0xce000000 irq 17’
Mixer name : ‘Nvidia GPU 94 HDMI/DP’
Components : ‘HDA:10de0094,17aa229b,00100100’
Controls : 49
Simple ctrls : 7
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Simple mixer control ‘IEC958’,5
Mono: Playback [on]
Simple mixer control ‘IEC958’,6
Mono: Playback [on]
!!Alsactl output
–startcollapse–
state.PCH {
control.1 {
iface MIXER
name ‘Headphone Playback Volume’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 74’
dbmin -7400
dbmax 0
dbvalue.0 -7400
dbvalue.1 -7400
control.2 {
iface MIXER
name ‘Headphone Playback Switch’
value.0 false
value.1 false
comment {
access ‘read write’
type BOOLEAN
count 2
control.3 {
iface MIXER
name ‘Speaker Playback Volume’
value.0 74
value.1 74
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 74’
dbmin -7400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name ‘Speaker Playback Switch’
value.0 true
value.1 true
comment {
access ‘read write’
type BOOLEAN
count 2
control.5 {
iface MIXER
name ‘Auto-Mute Mode’
value Disabled
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name ‘Capture Volume’
value.0 80
value.1 80
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 80’
dbmin -7400
dbmax 600
dbvalue.0 600
dbvalue.1 600
control.7 {
iface MIXER
name ‘Capture Switch’
value.0 true
value.1 true
comment {
access ‘read write’
type BOOLEAN
count 2
control.8 {
iface MIXER
name ‘Internal Mic Boost Volume’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 3’
dbmin 0
dbmax 3600
dbvalue.0 0
dbvalue.1 0
control.9 {
iface MIXER
name ‘Mic Boost Volume’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 3’
dbmin 0
dbmax 3600
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
name ‘Beep Playback Volume’
value 3
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 7’
dbmin -2800
dbmax 0
dbvalue.0 -1600
control.11 {
iface MIXER
name ‘Beep Playback Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.12 {
iface MIXER
name ‘Mic Mute-LED Mode’
value ‘Follow Mute’
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 On
item.1 Off
item.2 ‘Follow Capture’
item.3 ‘Follow Mute’
control.13 {
iface MIXER
name ‘Master Playback Volume’
value 74
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 74’
dbmin -7400
dbmax 0
dbvalue.0 0
control.14 {
iface MIXER
name ‘Master Playback Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.15 {
iface MIXER
name ‘Mute-LED Mode’
value ‘Follow Master’
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 On
item.1 Off
item.2 ‘Follow Master’
control.16 {
iface CARD
name ‘Internal Mic Phantom Jack’
value true
comment {
access read
type BOOLEAN
count 1
control.17 {
iface CARD
name ‘Mic Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.18 {
iface CARD
name ‘Headphone Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.19 {
iface CARD
name ‘Speaker Phantom Jack’
value true
comment {
access read
type BOOLEAN
count 1
control.20 {
iface PCM
name ‘Playback Channel Map’
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range ‘0 - 36’
control.21 {
iface PCM
name ‘Capture Channel Map’
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range ‘0 - 36’
control.22 {
iface CARD
name ‘HDMI/DP,pcm=3 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.23 {
iface MIXER
name ‘IEC958 Playback Con Mask’
value ‘0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000’
comment {
access read
type IEC958
count 1
control.24 {
iface MIXER
name ‘IEC958 Playback Pro Mask’
value ‘0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000’
comment {
access read
type IEC958
count 1
control.25 {
iface MIXER
name ‘IEC958 Playback Default’
value ‘0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000’
comment {
access ‘read write’
type IEC958
count 1
control.26 {
iface MIXER
name ‘IEC958 Playback Switch’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.27 {
iface PCM
device 3
name ELD
value ‘’
comment {
access ‘read volatile’
type BYTES
count 0
control.28 {
iface CARD
name ‘HDMI/DP,pcm=7 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.29 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.30 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.31 {
iface MIXER
index 1
value ‘0482000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000’
comment {
access ‘read write’
type IEC958
count 1
control.32 {
iface MIXER
index 1
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.33 {
iface PCM
device 7
name ELD
value ‘’
comment {
type BYTES
count 0
control.34 {
iface CARD
name ‘HDMI/DP,pcm=8 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.35 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.36 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.37 {
iface MIXER
index 2
comment {
access ‘read write’
type IEC958
count 1
control.38 {
iface MIXER
index 2
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.39 {
iface PCM
device 8
name ELD
value ‘’
comment {
type BYTES
count 0
control.40 {
iface CARD
name ‘HDMI/DP,pcm=9 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.41 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.42 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.43 {
iface MIXER
index 3
comment {
access ‘read write’
type IEC958
count 1
control.44 {
iface MIXER
index 3
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.45 {
iface PCM
device 9
name ELD
value ‘’
comment {
type BYTES
count 0
control.46 {
iface CARD
name ‘HDMI/DP,pcm=10 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.47 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.48 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.49 {
iface MIXER
index 4
comment {
access ‘read write’
type IEC958
count 1
control.50 {
iface MIXER
index 4
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.51 {
iface PCM
device 10
name ELD
value ‘’
comment {
type BYTES
count 0
control.52 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.53 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.54 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.55 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.56 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.57 {
iface MIXER
name ‘PCM Playback Volume’
value.0 254
value.1 254
comment {
access ‘read write user’
type INTEGER
count 2
range ‘0 - 255’
tlv ‘0000000100000008ffffec1400000014’
dbmin -5100
dbmax 0
dbvalue.0 -20
dbvalue.1 -20
control.58 {
iface MIXER
name ‘Digital Capture Volume’
value.0 60
value.1 60
comment {
type INTEGER
count 2
range ‘0 - 120’
tlv ‘0000000100000008fffff44800000032’
dbmin -3000
dbmax 3000
dbvalue.0 0
dbvalue.1 0
state.NVidia {
control.1 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access ‘read write’
type IEC958
count 1
control.5 {
iface MIXER
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ‘’
comment {
type BYTES
count 0
control.7 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access ‘read write’
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ‘’
comment {
type BYTES
count 0
control.13 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access ‘read write’
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ‘’
comment {
type BYTES
count 0
control.19 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access ‘read write’
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ‘’
comment {
type BYTES
count 0
control.25 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access ‘read write’
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ‘’
comment {
type BYTES
count 0
control.31 {
iface CARD
name ‘HDMI/DP,pcm=11 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access ‘read write’
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ‘’
comment {
type BYTES
count 0
control.37 {
iface CARD
name ‘HDMI/DP,pcm=12 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.39 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.40 {
iface MIXER
index 6
comment {
access ‘read write’
type IEC958
count 1
control.41 {
iface MIXER
index 6
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.42 {
iface PCM
device 12
name ELD
value ‘’
comment {
type BYTES
count 0
control.43 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.44 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.45 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.46 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.47 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.48 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.49 {
iface PCM
device 12
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
–endcollapse–
!!All Loaded Modules
8250_dw
ac97_bus
acpi_pad
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
e1000e
ecc
ecdh_generic
ee1004
elan_i2c
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
i2c_algo_bit
i2c_i801
i2c_smbus
i915
iTCO_vendor_support
iTCO_wdt
idma64
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_spi
intel_spi_pci
intel_uncore
intel_wmi_thunderbolt
ip_tables
ipmi_devintf
ipmi_msghandler
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
loop
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mmc_core
mousedev
mtd
ns
nvidia
nvidia_drm
nvidia_modeset
nvidia_uvm
pcspkr
processor_thermal_device
psmouse
qrtr
rapl
rfcomm
rfkill
rng_core
rtsx_pci
rtsx_pci_sdmmc
serio_raw
sg
snd
snd_compress
snd_hda_codec
snd_hda_codec_conexant
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_byt
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_intel_ipc
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
spi_nor
squashfs
syscopyarea
sysfillrect
sysimgblt
thinkpad_acpi
thunderbolt
tpm
tpm_crb
tpm_tis
tpm_tis_core
typec
typec_ucsi
ucsi_acpi
uinput
uvcvideo
vboxdrv
vboxnetadp
vboxnetflt
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x16 0x04211040
0x17 0x91170110
0x18 0x40f001f0
0x19 0x04a11030
0x1a 0x95a60120
0x21 0x40f001f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x185600f0
0x06 0x185600f0
0x07 0x185600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[ 0.427183] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.427186] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.427189] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 6.505491] psmouse serio1: elantech: Trying to set up SMBus access
[ 6.556616] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ 6.560867] dw-apb-uart.2: ttyS4 at MMIO 0x604110f000 (irq = 20, base_baud = 115200) is a 16550A
[ 6.562529] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 6.562803] snd_hda_intel 0000:01:00.1: enabling device (0000 → 0002)
[ 6.565010] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 6.565018] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 6.577123] ee1004 2-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 6.694124] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 6.695162] snd_hda_codec_conexant hdaudioC0D0: CX8070: BIOS auto-probing.
[ 6.696979] snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX8070: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 6.696981] snd_hda_codec_conexant hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 6.696982] snd_hda_codec_conexant hdaudioC0D0: hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
[ 6.696983] snd_hda_codec_conexant hdaudioC0D0: mono: mono_out=0x0
[ 6.696984] snd_hda_codec_conexant hdaudioC0D0: inputs:
[ 6.696985] snd_hda_codec_conexant hdaudioC0D0: Internal Mic=0x1a
[ 6.696986] snd_hda_codec_conexant hdaudioC0D0: Mic=0x19
[ 6.726738] elan_i2c 2-0015: supply vcc not found, using dummy regulator
[ 6.734444] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[ 6.734481] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[ 6.734513] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 6.734545] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 6.734576] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 6.734607] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 6.734639] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 6.736744] elan_i2c 2-0015: unexpected iap version 0x00 (ic type: 0x29), firmware update will not work
[ 6.736879] input: Elan TrackPoint as /devices/pci0000:00/0000:00:1f.4/i2c-2/2-0015/input/input25
[ 6.780874] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[ 6.780932] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[ 6.780982] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[ 6.781031] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[ 6.781078] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[ 6.781127] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[ 6.781175] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[ 6.789233] mousedev: PS/2 mouse device common for all mice
