A few updates ago, I lost my ability to use my microphone. Currently running, KDE Plasma. Kernel 5.14 on my Lenovo X1 Carbon Gen4.
I resolved that issue and today found my bluetooth headphones where choppy/static/not working. I messed with some files and the speakers are now not working/showing in the tray (speaker has red line through it).
inxi -Fazy
Kernel: 5.14.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=ba48b89c-d965-49d5-9cfa-d421ba0820a7 ro quiet apparmor=1
security=apparmor resume=UUID=63ba662d-72f0-443e-b5dd-f2bd535cafa1
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20FC002YAU v: ThinkPad X1 Carbon 4th
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20FC002YAU v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: N1FET74W (1.48 ) date: 11/12/2020
ID-1: BAT0 charge: 38.3 Wh (100.0%) condition: 38.3/52.0 Wh (73.7%)
volts: 16.5 min: 15.2 model: LGC 00HW028 type: Li-poly serial: <filter>
status: Full
Info: Dual Core model: Intel Core i7-6600U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: EA cache:
L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 22408
Speed: 579 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 579 2: 596 3: 573
4: 576
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:4 chip-ID: 13d3:5248 class-ID: 0e02 serial: <filter>
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 157 size: 310x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: efa0
bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
bus-ID: 1-7:3 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 476.94 GiB used: 284.58 GiB (59.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNLN512HMJP-000L7
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2L6Q scheme: GPT
ID-1: / raw-size: 30 GiB size: 29.4 GiB (98.01%) used: 20.8 GiB (70.7%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 237.29 GiB size: 232.57 GiB (98.01%)
used: 139.29 GiB (59.9%) fs: ext4 dev: /dev/sda9 maj-min: 8:9
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 205 Uptime: 28m wakeups: 1 Memory: 15.37 GiB
used: 2.3 GiB (15.0%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1466 apt: 0 pacman: 1459 lib: 432
flatpak: 0 snap: 7 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
pulseaudio -v
I: [pulseaudio] main.c: setrlimit(RLIMIT_NICE, (31, 31)) failed: Operation not permitted
I: [pulseaudio] main.c: setrlimit(RLIMIT_RTPRIO, (9, 9)) failed: Operation not permitted
I: [pulseaudio] core-util.c: Successfully gained nice level -11.
I: [pulseaudio] main.c: This is PulseAudio 15.0
I: [pulseaudio] main.c: Page size is 4096 bytes
I: [pulseaudio] main.c: Machine ID is 8cd9cd2604a548c98a7cb2edfd0fafd6.
I: [pulseaudio] main.c: Session ID is 2.
I: [pulseaudio] main.c: Using runtime directory /run/user/1000/pulse.
I: [pulseaudio] main.c: Using state directory /home/duncan/.config/pulse.
I: [pulseaudio] main.c: Using modules directory /usr/lib/pulse-15.0/modules.
I: [pulseaudio] main.c: Running in system mode: no
E: [pulseaudio] pid.c: Daemon already running.
E: [pulseaudio] main.c: pa_pid_file_create() failed.
