Audio only works the first time I play something. Then I have to restart to get it working again
I installed Manjaro on my Lenovo IdeaPad Slim 7 about a month and a half ago and the audio has worked perfectly this whole time. Then, the other day, I wanted to see if I could get the fingerprint reader working. I installed fprintd and fingerprint-gui. Shortly after that I realized the audio wasn’t working right. It will only play sound the first time I play something and then I get no audio output until I restart the computer. I can see the output level indicator on the volume control fluctuating indicating it is outputting audio, but there is silence from the speakers. I am not sure if installing those packages is related but that was the only thing I’ve changed on my system between when the audio worked and when it didn’t. Uninstalling those two packages and removing all orphan packages didn’t fix it.
inxi -Fazy
  Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=a8ebec8f-6667-4d65-9090-4184d4999155 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 82A6 v: IdeaPad Slim 7 14ITL05
    serial: <superuser required> Chassis: type: 10 v: IdeaPad Slim 7 14ITL05
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76465 WIN
    serial: <superuser required> UEFI: LENOVO v: FBCN25WW date: 05/26/2021
  ID-1: BAT1 charge: 11.4 Wh (19.2%) condition: 59.3/60.7 Wh (97.7%)
    volts: 14.9 min: 15.4 model: Sunwoda L19D4PF4 type: Li-poly serial: <filter>
    status: discharging cycles: 58
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xA6
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 764 high: 1048 min/max: 400/4200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 889 2: 619 3: 503 4: 843
    5: 462 6: 768 7: 982 8: 1048 bogomips: 38720
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
    bus-ID: 3-6:3 chip-ID: 04f2:b6cb class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP1 model: InfoVision Optronics/Kunshan 0x8c42
    built: 2019 res: 1920x1080 hz: 60 dpi: 157 gamma: 1.2
    size: 310x170mm (12.2x6.69") diag: 355mm (14") ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.61 running: yes
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
    chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 18.33 GiB (3.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: HFS512GD9TNI-L2A0B size: 476.94 GiB block-size: physical: 512 B
    rev: 11020C10 temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 18.31 GiB (3.9%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 16.3 MiB (5.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 37.0 C mobo: N/A
  Processes: 236 Uptime: 3h 32m wakeups: 1668 Memory: 7.56 GiB
  used: 2.69 GiB (35.6%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1226 libs: 317 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
pacmd dump
### Configuration dump generated at Sat Dec 10 11:37:15 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_00_1f.3-platform-skl_hda_dsp_generic" card_name="alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-combine
load-module module-combine-sink
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink 0x10000
set-sink-mute alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink no
suspend-sink alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink yes
set-sink-volume alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink 0x10000
set-sink-mute alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink no
suspend-sink alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink yes
set-sink-volume alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink 0x10000
set-sink-mute alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink no
suspend-sink alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink yes
set-sink-volume alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink 0x10000
set-sink-mute alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink no
suspend-sink alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink yes
set-sink-volume combined 0x10000
set-sink-mute combined no
suspend-sink combined yes
set-source-volume alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor no
suspend-source alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor yes
set-source-volume alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor no
suspend-source alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor yes
set-source-volume alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor no
suspend-source alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor yes
set-source-volume alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor no
suspend-source alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor yes
set-source-volume alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__source 0x276d
set-source-mute alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__source no
suspend-source alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__source yes
set-source-volume alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source 0xffff
set-source-mute alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source no
suspend-source alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source yes
set-source-volume combined.monitor 0x10000
set-source-mute combined.monitor no
suspend-source combined.monitor yes
set-card-profile alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic HiFi
set-default-sink combined
set-default-source alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source
### EOF
amixer --card=0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [off]
  Front Right: Playback 87 [100%] [0.00dB] [off]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 38 [60%] [11.25dB] [on]
  Front Right: Capture 38 [60%] [11.25dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Dmic0',0
  Limits: Capture 0 - 70
  Front Left: Capture 70 [100%] [20.00dB] [on]
  Front Right: Capture 70 [100%] [20.00dB] [on]
Simple mixer control 'Dmic1 2nd',0
  Front Left: Capture 50 [71%] [0.00dB]
  Front Right: Capture 50 [71%] [0.00dB]
Simple mixer control 'PGA1.0 1 Master',0
  Limits: Playback 0 - 32
  Mono:
  Front Left: Playback 32 [100%] [0.00dB]
  Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA2.0 2 Master',0
  Limits: Capture 0 - 80
  Front Left: Capture 50 [62%] [0.00dB]
  Front Right: Capture 50 [62%] [0.00dB]
Simple mixer control 'PGA30.0 30',0
  Mono:
Simple mixer control 'PGA31.0 31',0
  Mono:
Simple mixer control 'PGA7.0 7 Master',0
  Mono:
Simple mixer control 'PGA8.0 8 Master',0
  Mono:
Simple mixer control 'PGA9.0 9 Master',0
  Mono:
  Front Right: Playback 32 [100%] [0.00dB]```
Welcome to Manjaro forum
There are lot of similar reports about audio problems with kernel update including some ALSA related bug for Intel Skylake and later generations including TigerLake
A lot of users have confirmed that the best, simple solution for this is to install kernel v6.0 using either Manjaro Settings Manager GUI tool, or copy/paste this to terminal
sudo mhwd-kernel -i linux60
Thank you, that has appeared to have fix it!
A post was split to a new topic: The v6 kernel does not work on my PC
