Hi,
Yesterday was my first time installing linux and I have a problem with my audio. When I plug the headphones to the mini-jack input at the back of the motherboard it works just fine until I also plug the speakers with the jack input at the front of my PC case. When I do that the speakers work normally but when I change the source back to headphones no sound comes out. They start working again when I unplug the speakers.
The kernel version I run: 5.15.32
Below is the response I get after typing inxi -v7azy into the terminal.
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=36091d95-4dbd-4549-9f05-00ee3e8be138 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: Z170 Gaming K4
serial: <superuser required> UEFI: American Megatrends v: P1.90
date: 09/18/2015
RAM: total: 23.43 GiB used: 2.74 GiB (11.7%)
RAM Report:
Info: model: Intel Core i5-6600K bits: 64 type: MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEC
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 3900 min/max: 800/3900:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 3900 2: 3900 3: 3900
4: 3900 bogomips: 28009
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: eVga.com. driver: nvidia
v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Device-2: Sunplus Innovation Streaming Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-14:6 chip-ID: 1bcf:2283
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 90 s-size: 542x301mm (21.34x11.85")
s-diag: 620mm (24.41")
Monitor-1: DP-4 res: 1920x1080 hz: 60 dpi: 90
size: 544x303mm (21.42x11.93") diag: 623mm (24.52") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: eVga.com.
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: Sunplus Innovation Streaming Webcam type: USB
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: ASRock
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 06:00.0 chip-ID: 1969:e0a1 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.75 TiB used: 1.62 TiB (34.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: ECFM22.5 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: IRIDIUM PRO size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 01.7 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU800 size: 953.87 GiB
serial: <filter> rev: 4A scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM003-1SB102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Toshiba model: MQ04UBD200
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: HDD
rpm: 5400 serial: <filter> scheme: MBR
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 13.49 GiB (6.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 36091d95-4dbd-4549-9f05-00ee3e8be138
used: 292 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 6C7D-E687
ID-3: /run/media/akip/4E3698C03698AA8B raw-size: 893.62 GiB
size: 893.62 GiB (100.00%) used: 291.96 GiB (32.7%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: 4E3698C03698AA8B
ID-4: /run/media/akip/SSD 1000 raw-size: 953.87 GiB
size: 953.87 GiB (100.00%) used: 687.31 GiB (72.1%) fs: ntfs dev: /dev/sdb1
maj-min: 8:17 label: SSD 1000 uuid: 9A00068800066C17
ID-5: /run/media/akip/TOSHIBA EXT raw-size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 327.58 GiB (17.6%) fs: ntfs dev: /dev/sdd1
maj-min: 8:49 label: TOSHIBA EXT uuid: B06E2E676E2E2696
ID-6: /run/media/akip/daneHDD raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 334.67 GiB (35.9%) fs: ntfs dev: /dev/sdc1
maj-min: 8:33 label: daneHDD uuid: 72FECF3DFECEF7FD
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: N/A
uuid: 44561021561015F0
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
uuid: 4E1D-B8E7
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-7:3 info: Corsair Gaming GLAIVE RGB Mouse type: Mouse,HID
driver: corsair,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 1b1c:1b34 class-ID: 0300 serial: <filter>
Device-2: 1-8:4 info: Corsair K95 RGB Platinum Keyboard [RGP0056]
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b2d class-ID: 0300
serial: <filter>
Device-3: 1-9:5 info: Microsoft Xbox One S Controller
type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 045e:02ea class-ID: ff00 serial: <filter>
Device-4: 1-14:6 info: Sunplus Innovation Streaming Webcam
type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1bcf:2283 class-ID: 0102
serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Device-1: 2-6:2 info: Toshiba America EXTERNAL_USB type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0480:0901 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 43.0 C pch: 46.5 C mobo: N/A gpu: nvidia
temp: 44 C
Processes: 212 Uptime: 11m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1201 lib: 330
flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
Is there a way to get the headphones to work while speakers are connected?
I’m completely new to linux so I would appreciate it if you could explain in simple terms what I should do.
Thanks in advance!
