Audio not working after a recent update
I was having this same issue and I fixed it by disabling pluseaudio.service. However while this works, I now can’t control the audio through my keyboard keys. Also if you go into Settings > Sound it shows no output devices.
Is there a better way to fix this issue that doesnt break things?
EDIT: commenting out load-module module-suspend-on-idle seems to have fixed things.
Your post has been moved to a dedicated topic.
Please do not post your issue in another Member’s topic. This is commonly referred to as hijacking a thread, and is not encouraged.
If you wish Support for your issue, start with providing your full system information (as described below) and give as much detail as possible to help others help you.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources
To create a custom default.pa configuration for PulseAudio in home folder
cp /etc/pulse/default.pa ~/.config/pulse/default.pa
To comment out module-suspend-on-idle in custom configuration
sed -i '/load-module module-suspend-on-idle/s/^/#/' ~/.config/pulse/default.pa
This worked for me. Thanks a ton!
