So, after the last update my audio is totally broken.
Firstly I need to restart pulseaudio after I play other audio file, after i switch tab in browser. Playing sound on two separate tabs/apps is imposible now at all.
My pc is HP VICTUS 16-d0050nc
My processor is Intel Core i5-11400H Tiger Lake
I don’t know what info to add, I’m really new to manjaro
UPD:
> System:
> Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
> parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
> root=UUID=9177158e-9d5f-467c-aa16-8951f0076492 rw quiet splash apparmor=1
> security=apparmor udev.log_priority=3
> Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
> Distro: Manjaro Linux base: Arch Linux
> Machine:
> Type: Laptop System: HP product: Victus by HP Laptop 16-d0xxx v: N/A
> serial: <superuser required> Chassis: type: 10 serial: <superuser required>
> Mobo: HP model: 88F9 v: 88.53 serial: <superuser required> UEFI: AMI
> v: F.13 date: 01/07/2022
> Battery:
> ID-1: BAT0 charge: 66.5 Wh (97.1%) condition: 68.5/70.1 Wh (97.8%)
> volts: 16.4 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
> status: discharging cycles: 51
> Memory:
> RAM: total: 15.27 GiB used: 3.1 GiB (20.3%)
> RAM Report: permissions: Unable to run dmidecode. Root privileges
> required.
> CPU:
> Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP
> arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
> process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
> microcode: 0x42
> Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
> L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
> L3: 12 MiB desc: 1x12 MiB
> Speed (MHz): avg: 1123 high: 2336 min/max: 800/4500 scaling:
> driver: intel_pstate governor: powersave cores: 1: 872 2: 1065 3: 1088
> 4: 795 5: 809 6: 1362 7: 2336 8: 1019 9: 987 10: 1072 11: 1007 12: 1072
> bogomips: 64536
> Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat
> arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
> avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
> avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
> cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
> cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
> flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
> hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
> invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
> movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
> pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
> rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect
> ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
> tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
> vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
> xtpr
> Vulnerabilities:
> Type: itlb_multihit status: Not affected
> Type: l1tf status: Not affected
> Type: mds status: Not affected
> Type: meltdown status: Not affected
> Type: mmio_stale_data status: Not affected
> Type: retbleed status: Not affected
> Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
> prctl and seccomp
> Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
> sanitization
> Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
> Type: srbds status: Not affected
> Type: tsx_async_abort status: Not affected
> Graphics:
> Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Hewlett-Packard
> driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
> ports: active: eDP-1 empty: DP-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a68
> class-ID: 0300
> Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
> vendor: Hewlett-Packard driver: nouveau v: kernel non-free: 525.xx+
> status: current (as of 2022-12) arch: Ampere code: GAxxx
> process: TSMC n7 (7nm) built: 2020-22 ports: active: none empty: HDMI-A-1
> bus-ID: 0000:01:00.0 chip-ID: 10de:25a0 class-ID: 0300
> Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
> bus-ID: 3-6:3 chip-ID: 0408:5425 class-ID: fe01 serial: <filter>
> Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
> compositor: gnome-shell driver: X: loaded: modesetting,nvidia
> unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
> display-ID: 0
> Monitor-1: eDP-1 model: BOE Display 0x0aad built: 2021 res: 1920x1080
> dpi: 137 gamma: 1.2 size: 355x200mm (13.98x7.87") diag: 407mm (16")
> ratio: 16:9 modes: 1920x1080
> API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel UHD Graphics (TGL GT1)
> direct render: Yes
> Audio:
> Device-1: Intel Tiger Lake-H HD Audio vendor: Hewlett-Packard
> driver: sof-audio-pci-intel-tgl
> alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
> chip-ID: 8086:43c8 class-ID: 0401
> Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
> bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
> Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
> Sound Server-1: JACK v: 1.9.21 running: no
> Sound Server-2: PulseAudio v: 16.1 running: yes
> Sound Server-3: PipeWire v: 0.3.63 running: yes
> Network:
> Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
> bus-ID: 0000:00:14.3 chip-ID: 8086:43f0 class-ID: 0280
> IF: wlo1 state: up mac: <filter>
> IP v4: <filter> type: dynamic noprefixroute scope: global
> broadcast: <filter>
> IP v6: <filter> type: noprefixroute scope: link
> Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
> vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000
> bus-ID: 0000:02:00.0 chip-ID: 10ec:8168 class-ID: 0200
> IF: eno1 state: down mac: <filter>
> Device-3: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter type: USB
> driver: hid-generic,usbhid bus-ID: 3-3:2 chip-ID: 0458:6001 class-ID: 0301
> WAN IP: <filter>
> Bluetooth:
> Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
> bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
> Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
> Logical:
> Message: No logical block device data found.
> RAID:
> Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
> v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
> Drives:
> Local Storage: total: 476.94 GiB used: 34.7 GiB (7.3%)
> SMART Message: Required tool smartctl not installed. Check --recommends
> ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung
> model: MZVL2512HCJQ-00BH1 size: 476.94 GiB block-size: physical: 512 B
> logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
> rev: HPS2NGXH temp: 31.9 C scheme: GPT
> Message: No optical or floppy data found.
> Partition:
> ID-1: / raw-size: 223.15 GiB size: 218.59 GiB (97.96%)
> used: 34.67 GiB (15.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
> label: N/A uuid: 9177158e-9d5f-467c-aa16-8951f0076492
> ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
> used: 29.4 MiB (9.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
> label: NO_LABEL uuid: 07A6-B5BB
> Swap:
> Alert: No swap data was found.
> Unmounted:
> ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 253.49 GiB fs: ntfs label: WIN
> uuid: 6C27730264A2E00A
> USB:
> Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
> speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
> Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
> chip-ID: 1d6b:0003 class-ID: 0900
> Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
> Device-1: 3-3:2 info: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter
> type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 1.1
> speed: 12 Mb/s power: 100mA chip-ID: 0458:6001 class-ID: 0301
> Device-2: 3-6:3 info: Quanta HP Wide Vision HD Camera type: Video
> driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
> Device-3: 3-14:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
> interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
> class-ID: e001
> Hub-4: 4-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 20 Gb/s
> Sensors:
> System Temperatures: cpu: 34.0 C mobo: N/A
> Fan Speeds (RPM): N/A
> Info:
> Processes: 358 Uptime: 1m wakeups: 2 Init: systemd v: 252 default: graphical
> tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1397
> pm: pacman pkgs: 1386 libs: 386 tools: gnome-software,pamac,yay pm: flatpak
> pkgs: 0 pm: snap pkgs: 11 Shell: Zsh v: 5.9 running-in: gnome-terminal
> inxi: 3.3.24
