Fairly fresh install of Manjaro (Just migrated from Zorin)
I have a 3 monitor setup, 2 normal monitors and the third is a TV that I use for watching movies and general audio. It completely powers itself down after 15 minutes of no signal so I have to manually power it on when I want to use it. This has always worked for me since I usually only use my 2 main monitors and only sometimes want audio
With the Manjaro install I’m having to manually change the sound settings (almost) every time I power on the tv. It defaults to digital output (presumably on the mobo) and I have to set it to HDMI 3 to get audio. I’d like to not have to change the setting
Often times the HDMI settings disappear and I have to restart
Is there a way to lock the settings in place even if the system believes a device has been removed? I think thats whats going on here. It no longer sees the tv and tries to autocorrect. How can I prevent this? My assessment could also be wrong so help in diagnosing the actual issue would be appreciated too
Thanks
