I sincerely apologies for opening a new thread for my audio issues.
Few days ago i installed pipewire using this command pamac install manjaro-pipewire wireplumber
Just yesterday i was in a meeting and no one could hear me, I use the Xbox One headset and Live sound card (bluetooth enabled).
The Major reason for moving to pipewire was so i could automatically switch between A2DP and HSP. which seem to be all working perfectly, I could set playback device to use A2DP and Recording to use HFP.
However i recntly noticed that once i change playback device to High Fidelity Playback (A2DP) the recording device disappear.
Another issue, my V8 sound card is not longer detected as mic. Although i can connect to it via bluetooth
inxi -Aa
Device-1: Intel CM238 HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171
class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.15.53-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.54 running: yes
pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 251
Tile Size: 65472
User Name: swift
Host Name: swift
Server Name: PulseAudio (on PipeWire 0.3.54)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_01_00.1.hdmi-stereo
Default Source: bluez_input.1C_1A_DF_AC_5D_45.headset-head-unit
Cookie: a43d:f9cd
pactl list cards ✔
Card #39
Driver: alsa
Owner Module: n/a
Properties:
api.acp.auto-port = "false"
api.alsa.card = "2"
api.alsa.card.longname = "HDA NVidia at 0xa4000000 irq 17"
api.alsa.card.name = "HDA NVidia"
api.alsa.path = "hw:2"
api.alsa.use-acp = "true"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:01:00.1"
device.description = "GP106 High Definition Audio Controller"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_01_00.1"
device.nick = "HDA NVidia"
device.plugged.usec = "4968513"
device.product.id = "0x10f1"
device.product.name = "GP106 High Definition Audio Controller"
device.subsystem = "sound"
sysfs.path = "/sys/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2"
device.vendor.id = "0x10de"
device.vendor.name = "NVIDIA Corporation"
media.class = "Audio/Device"
factory.id = "14"
client.id = "32"
object.id = "39"
object.serial = "39"
object.path = "alsa:pcm:2"
alsa.card = "2"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xa4000000 irq 17"
device.string = "2"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: yes)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: yes)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
Active Profile: output:hdmi-stereo
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 1"
card.profile.port = "0"
device.product.name = "S34J55x
Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 2"
card.profile.port = "1"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 3"
card.profile.port = "2"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 4"
card.profile.port = "3"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Card #40
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "1"
api.alsa.card.longname = "HDA Intel PCH at 0xa4620000 irq 141"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.path = "hw:1"
device.api = "alsa"
device.bus = "pci"
device.description = "Built-in Audio"
device.name = "alsa_card.pci-0000_00_1f.3"
device.nick = "HDA Intel PCH"
device.plugged.usec = "5100408"
device.product.id = "0xa171"
device.product.name = "CM238 HD Audio Controller"
sysfs.path = "/sys/devices/pci0000:00/0000:00:1f.3/sound/card1"
device.vendor.id = "0x8086"
factory.id = "14"
client.id = "32"
object.id = "40"
object.serial = "40"
object.path = "alsa:pcm:1"
alsa.card = "1"
alsa.long_card_name = "HDA Intel PCH at 0xa4620000 irq 141"
device.string = "1"
Profiles:
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
pro-audio: Pro Audio (sinks: 1, sources: 1, priority: 1, available: yes)
Active Profile: output:analog-stereo
Ports:
analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, latency offset: 0 usec, availability group: Legacy 1, availability unknown)
Properties:
port.type = "mic"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo
analog-input-headset-mic: Headset Microphone (type: Headset, priority: 8800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "headset"
analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability group: Legacy 3, availability unknown)
Properties:
port.type = "speaker"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "headphones"
Card #41
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "0"
api.alsa.card.longname = "Loopback 1"
api.alsa.card.name = "Loopback"
api.alsa.path = "hw:0"
device.api = "alsa"
device.bus_path = "platform-snd_aloop.0"
device.icon_name = "audio-card-analog"
device.name = "alsa_card.platform-snd_aloop.0"
device.nick = "Loopback"
device.plugged.usec = "3334354"
sysfs.path = "/sys/devices/platform/snd_aloop.0/sound/card0"
factory.id = "14"
client.id = "32"
object.id = "41"
object.serial = "41"
object.path = "alsa:pcm:0"
alsa.card = "0"
alsa.card_name = "Loopback"
alsa.long_card_name = "Loopback 1"
alsa.driver_name = "snd_aloop"
device.string = "0"
Profiles:
output:analog-stereo+input:analog-surround-21: Analog Stereo Output + Analog Surround 2.1 Input (sinks: 1, sources: 1, priority: 6513, available: yes)
output:analog-stereo+input:analog-surround-41: Analog Stereo Output + Analog Surround 4.1 Input (sinks: 1, sources: 1, priority: 6513, available: yes)
output:analog-stereo+input:analog-surround-51: Analog Stereo Output + Analog Surround 5.1 Input (sinks: 1, sources: 1, priority: 6513, available: yes)
output:analog-stereo+input:analog-surround-40: Analog Stereo Output + Analog Surround 4.0 Input (sinks: 1, sources: 1, priority: 6512, available: yes)
output:analog-stereo+input:analog-surround-50: Analog Stereo Output + Analog Surround 5.0 Input (sinks: 1, sources: 1, priority: 6512, available: yes)
output:analog-stereo+input:analog-surround-71: Analog Stereo Output + Analog Surround 7.1 Input (sinks: 1, sources: 1, priority: 6512, available: yes)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
output:analog-surround-21+input:analog-surround-21: Analog Surround 2.1 Output + Analog Surround 2.1 Input (sinks: 1, sources: 1, priority: 1313, available: yes)
output:analog-surround-21+input:analog-surround-41: Analog Surround 2.1 Output + Analog Surround 4.1 Input (sinks: 1, sources: 1, priority: 1313, available: yes)
output:analog-surround-21+input:analog-surround-51: Analog Surround 2.1 Output + Analog Surround 5.1 Input (sinks: 1, sources: 1, priority: 1313, available: yes)
output:analog-surround-41+input:analog-surround-21: Analog Surround 4.1 Output + Analog Surround 2.1 Input (sinks: 1, sources: 1, priority: 1313, available: yes)
output:analog-surround-41+input:analog-surround-41: Analog Surround 4.1 Output + Analog Surround 4.1 Input (sinks: 1, sources: 1, priority: 1313, available: yes)
output:analog-surround-41+input:analog-surround-51: Analog Surround 4.1 Output + Analog Surround 5.1 Input (sinks: 1, sources: 1, priority: 1313, available: yes)
output:analog-surround-51+input:analog-surround-21: Analog Surround 5.1 Output + Analog Surround 2.1 Input (sinks: 1, sources: 1, priority: 1313, available: yes)
output:analog-surround-51+input:analog-surround-41: Analog Surround 5.1 Output + Analog Surround 4.1 Input (sinks: 1, sources: 1, priority: 1313, available: yes)
output:analog-surround-51+input:analog-surround-51: Analog Surround 5.1 Output + Analog Surround 5.1 Input (sinks: 1, sources: 1, priority: 1313, available: yes)
output:analog-surround-21+input:analog-surround-40: Analog Surround 2.1 Output + Analog Surround 4.0 Input (sinks: 1, sources: 1, priority: 1312, available: yes)
output:analog-surround-21+input:analog-surround-50: Analog Surround 2.1 Output + Analog Surround 5.0 Input (sinks: 1, sources: 1, priority: 1312, available: yes)
output:analog-surround-21+input:analog-surround-71: Analog Surround 2.1 Output + Analog Surround 7.1 Input (sinks: 1, sources: 1, priority: 1312, available: yes)
output:analog-surround-41+input:analog-surround-40: Analog Surround 4.1 Output + Analog Surround 4.0 Input (sinks: 1, sources: 1, priority: 1312, available: yes)
output:analog-surround-41+input:analog-surround-50: Analog Surround 4.1 Output + Analog Surround 5.0 Input (sinks: 1, sources: 1, priority: 1312, available: yes)
output:analog-surround-41+input:analog-surround-71: Analog Surround 4.1 Output + Analog Surround 7.1 Input (sinks: 1, sources: 1, priority: 1312, available: yes)
output:analog-surround-51+input:analog-surround-40: Analog Surround 5.1 Output + Analog Surround 4.0 Input (sinks: 1, sources: 1, priority: 1312, available: yes)
output:analog-surround-51+input:analog-surround-50: Analog Surround 5.1 Output + Analog Surround 5.0 Input (sinks: 1, sources: 1, priority: 1312, available: yes)
output:analog-surround-51+input:analog-surround-71: Analog Surround 5.1 Output + Analog Surround 7.1 Input (sinks: 1, sources: 1, priority: 1312, available: yes)
output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: yes)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: yes)
output:analog-surround-71+input:analog-stereo: Analog Surround 7.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: yes)
output:analog-surround-40+input:analog-surround-21: Analog Surround 4.0 Output + Analog Surround 2.1 Input (sinks: 1, sources: 1, priority: 1213, available: yes)
output:analog-surround-40+input:analog-surround-41: Analog Surround 4.0 Output + Analog Surround 4.1 Input (sinks: 1, sources: 1, priority: 1213, available: yes)
output:analog-surround-40+input:analog-surround-51: Analog Surround 4.0 Output + Analog Surround 5.1 Input (sinks: 1, sources: 1, priority: 1213, available: yes)
output:analog-surround-50+input:analog-surround-21: Analog Surround 5.0 Output + Analog Surround 2.1 Input (sinks: 1, sources: 1, priority: 1213, available: yes)
output:analog-surround-50+input:analog-surround-41: Analog Surround 5.0 Output + Analog Surround 4.1 Input (sinks: 1, sources: 1, priority: 1213, available: yes)
output:analog-surround-50+input:analog-surround-51: Analog Surround 5.0 Output + Analog Surround 5.1 Input (sinks: 1, sources: 1, priority: 1213, available: yes)
output:analog-surround-71+input:analog-surround-21: Analog Surround 7.1 Output + Analog Surround 2.1 Input (sinks: 1, sources: 1, priority: 1213, available: yes)
output:analog-surround-71+input:analog-surround-41: Analog Surround 7.1 Output + Analog Surround 4.1 Input (sinks: 1, sources: 1, priority: 1213, available: yes)
output:analog-surround-71+input:analog-surround-51: Analog Surround 7.1 Output + Analog Surround 5.1 Input (sinks: 1, sources: 1, priority: 1213, available: yes)
output:analog-surround-40+input:analog-surround-40: Analog Surround 4.0 Output + Analog Surround 4.0 Input (sinks: 1, sources: 1, priority: 1212, available: yes)
output:analog-surround-40+input:analog-surround-50: Analog Surround 4.0 Output + Analog Surround 5.0 Input (sinks: 1, sources: 1, priority: 1212, available: yes)
output:analog-surround-40+input:analog-surround-71: Analog Surround 4.0 Output + Analog Surround 7.1 Input (sinks: 1, sources: 1, priority: 1212, available: yes)
output:analog-surround-50+input:analog-surround-40: Analog Surround 5.0 Output + Analog Surround 4.0 Input (sinks: 1, sources: 1, priority: 1212, available: yes)
output:analog-surround-50+input:analog-surround-50: Analog Surround 5.0 Output + Analog Surround 5.0 Input (sinks: 1, sources: 1, priority: 1212, available: yes)
output:analog-surround-50+input:analog-surround-71: Analog Surround 5.0 Output + Analog Surround 7.1 Input (sinks: 1, sources: 1, priority: 1212, available: yes)
output:analog-surround-71+input:analog-surround-40: Analog Surround 7.1 Output + Analog Surround 4.0 Input (sinks: 1, sources: 1, priority: 1212, available: yes)
output:analog-surround-71+input:analog-surround-50: Analog Surround 7.1 Output + Analog Surround 5.0 Input (sinks: 1, sources: 1, priority: 1212, available: yes)
output:analog-surround-71+input:analog-surround-71: Analog Surround 7.1 Output + Analog Surround 7.1 Input (sinks: 1, sources: 1, priority: 1212, available: yes)
output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: yes)
output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: yes)
output:analog-surround-71: Analog Surround 7.1 Output (sinks: 1, sources: 0, priority: 1200, available: yes)
input:analog-surround-21: Analog Surround 2.1 Input (sinks: 0, sources: 1, priority: 13, available: yes)
input:analog-surround-41: Analog Surround 4.1 Input (sinks: 0, sources: 1, priority: 13, available: yes)
input:analog-surround-51: Analog Surround 5.1 Input (sinks: 0, sources: 1, priority: 13, available: yes)
input:analog-surround-40: Analog Surround 4.0 Input (sinks: 0, sources: 1, priority: 12, available: yes)
input:analog-surround-50: Analog Surround 5.0 Input (sinks: 0, sources: 1, priority: 12, available: yes)
input:analog-surround-71: Analog Surround 7.1 Input (sinks: 0, sources: 1, priority: 12, available: yes)
pro-audio: Pro Audio (sinks: 2, sources: 2, priority: 1, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input: Analog Input (type: Analog, priority: 10000, latency offset: 0 usec, availability unknown)
Properties:
port.type = "analog"
Part of profile(s): input:analog-stereo, input:analog-surround-21, input:analog-surround-40, input:analog-surround-41, input:analog-surround-50, input:analog-surround-51, input:analog-surround-71, output:analog-stereo+input:analog-stereo, output:analog-stereo+input:analog-surround-21, output:analog-stereo+input:analog-surround-40, output:analog-stereo+input:analog-surround-41, output:analog-stereo+input:analog-surround-50, output:analog-stereo+input:analog-surround-51, output:analog-stereo+input:analog-surround-71, output:analog-surround-21+input:analog-stereo, output:analog-surround-21+input:analog-surround-21, output:analog-surround-21+input:analog-surround-40, output:analog-surround-21+input:analog-surround-41, output:analog-surround-21+input:analog-surround-50, output:analog-surround-21+input:analog-surround-51, output:analog-surround-21+input:analog-surround-71, output:analog-surround-40+input:analog-stereo, output:analog-surround-40+input:analog-surround-21, output:analog-surround-40+input:analog-surround-40, output:analog-surround-40+input:analog-surround-41, output:analog-surround-40+input:analog-surround-50, output:analog-surround-40+input:analog-surround-51, output:analog-surround-40+input:analog-surround-71, output:analog-surround-41+input:analog-stereo, output:analog-surround-41+input:analog-surround-21, output:analog-surround-41+input:analog-surround-40, output:analog-surround-41+input:analog-surround-41, output:analog-surround-41+input:analog-surround-50, output:analog-surround-41+input:analog-surround-51, output:analog-surround-41+input:analog-surround-71, output:analog-surround-50+input:analog-stereo, output:analog-surround-50+input:analog-surround-21, output:analog-surround-50+input:analog-surround-40, output:analog-surround-50+input:analog-surround-41, output:analog-surround-50+input:analog-surround-50, output:analog-surround-50+input:analog-surround-51, output:analog-surround-50+input:analog-surround-71, output:analog-surround-51+input:analog-stereo, output:analog-surround-51+input:analog-surround-21, output:analog-surround-51+input:analog-surround-40, output:analog-surround-51+input:analog-surround-41, output:analog-surround-51+input:analog-surround-50, output:analog-surround-51+input:analog-surround-51, output:analog-surround-51+input:analog-surround-71, output:analog-surround-71+input:analog-stereo, output:analog-surround-71+input:analog-surround-21, output:analog-surround-71+input:analog-surround-40, output:analog-surround-71+input:analog-surround-41, output:analog-surround-71+input:analog-surround-50, output:analog-surround-71+input:analog-surround-51, output:analog-surround-71+input:analog-surround-71
analog-output: Analog Output (type: Analog, priority: 9900, latency offset: 0 usec, availability unknown)
Properties:
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-stereo+input:analog-surround-21, output:analog-stereo+input:analog-surround-40, output:analog-stereo+input:analog-surround-41, output:analog-stereo+input:analog-surround-50, output:analog-stereo+input:analog-surround-51, output:analog-stereo+input:analog-surround-71, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-21+input:analog-surround-21, output:analog-surround-21+input:analog-surround-40, output:analog-surround-21+input:analog-surround-41, output:analog-surround-21+input:analog-surround-50, output:analog-surround-21+input:analog-surround-51, output:analog-surround-21+input:analog-surround-71, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-40+input:analog-surround-21, output:analog-surround-40+input:analog-surround-40, output:analog-surround-40+input:analog-surround-41, output:analog-surround-40+input:analog-surround-50, output:analog-surround-40+input:analog-surround-51, output:analog-surround-40+input:analog-surround-71, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-41+input:analog-surround-21, output:analog-surround-41+input:analog-surround-40, output:analog-surround-41+input:analog-surround-41, output:analog-surround-41+input:analog-surround-50, output:analog-surround-41+input:analog-surround-51, output:analog-surround-41+input:analog-surround-71, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-50+input:analog-surround-21, output:analog-surround-50+input:analog-surround-40, output:analog-surround-50+input:analog-surround-41, output:analog-surround-50+input:analog-surround-50, output:analog-surround-50+input:analog-surround-51, output:analog-surround-50+input:analog-surround-71, output:analog-surround-51, output:analog-surround-51+input:analog-stereo, output:analog-surround-51+input:analog-surround-21, output:analog-surround-51+input:analog-surround-40, output:analog-surround-51+input:analog-surround-41, output:analog-surround-51+input:analog-surround-50, output:analog-surround-51+input:analog-surround-51, output:analog-surround-51+input:analog-surround-71, output:analog-surround-71, output:analog-surround-71+input:analog-stereo, output:analog-surround-71+input:analog-surround-21, output:analog-surround-71+input:analog-surround-40, output:analog-surround-71+input:analog-surround-41, output:analog-surround-71+input:analog-surround-50, output:analog-surround-71+input:analog-surround-51, output:analog-surround-71+input:analog-surround-71
Card #244
Driver: module-bluez5-device.c
Owner Module: n/a
Properties:
api.bluez5.address = "BB:AA:C7:06:06:87"
api.bluez5.class = "0x2c0404"
api.bluez5.connection = "disconnected"
api.bluez5.device = ""
api.bluez5.icon = "audio-headset"
api.bluez5.path = "/org/bluez/hci0/dev_BB_AA_C7_06_06_87"
bluez5.auto-connect = "[ hfp_hf hsp_hs a2dp_sink ]"
bluez5.profile = "off"
device.alias = "V8"
device.api = "bluez5"
device.bus = "bluetooth"
device.description = "V8"
device.form_factor = "headset"
device.icon_name = "audio-headset-bluetooth"
device.name = "bluez_card.BB_AA_C7_06_06_87"
device.string = "BB:AA:C7:06:06:87"
factory.id = "14"
client.id = "32"
object.id = "69"
object.serial = "244"
Profiles:
a2dp-sink: High Fidelity Playback (A2DP Sink) (sinks: 1, sources: 0, priority: 16, available: yes)
a2dp-sink-sbc: High Fidelity Playback (A2DP Sink, codec SBC) (sinks: 1, sources: 0, priority: 18, available: yes)
a2dp-sink-sbc_xq: High Fidelity Playback (A2DP Sink, codec SBC-XQ) (sinks: 1, sources: 0, priority: 17, available: yes)
Active Profile: a2dp-sink-sbc_xq
Ports:
headset-output: Headset (type: Headset, priority: 0, latency offset: 0 usec, available)
Properties:
Part of profile(s): a2dp-sink, a2dp-sink-sbc, a2dp-sink-sbc_xq
Card #252
Owner Module: n/a
Properties:
api.bluez5.address = "1C:1A:DF:AC:5D:45"
api.bluez5.class = "0x24041c"
api.bluez5.icon = "audio-card"
api.bluez5.path = "/org/bluez/hci0/dev_1C_1A_DF_AC_5D_45"
device.alias = "Xbox Wireless Headset"
device.description = "Xbox Wireless Headset"
device.form_factor = "portable"
device.icon_name = "multimedia-player-bluetooth"
device.name = "bluez_card.1C_1A_DF_AC_5D_45"
device.product.id = "0x0b16"
device.string = "1C:1A:DF:AC:5D:45"
device.vendor.id = "bluetooth:045e"
factory.id = "14"
client.id = "32"
object.id = "87"
object.serial = "252"
Profiles:
headset-head-unit: Headset Head Unit (HSP/HFP) (sinks: 1, sources: 1, priority: 1, available: yes)
headset-head-unit-cvsd: Headset Head Unit (HSP/HFP, codec CVSD) (sinks: 1, sources: 1, priority: 2, available: yes)
headset-head-unit-msbc: Headset Head Unit (HSP/HFP, codec mSBC) (sinks: 1, sources: 1, priority: 3, available: yes)
Active Profile: headset-head-unit-msbc
Ports:
portable-input: Portable (type: Portable, priority: 0, latency offset: 0 usec, available)
Properties:
port.type = "portable"
Part of profile(s): headset-head-unit, headset-head-unit-cvsd, headset-head-unit-msbc
portable-output: Portable (type: Portable, priority: 0, latency offset: 0 usec, available)
Properties:
Part of profile(s): a2dp-sink, headset-head-unit, a2dp-sink-sbc, a2dp-sink-sbc_xq, headset-head-unit-cvsd, headset-head-unit-msbc
