Audio is not working at all but bluetooth is
‘’‘System:
Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=8788a815-df1f-43cb-b722-66bc2bd5eb99 rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Info: model: Intel Core i3-8130U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF6
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_soc_skl v: kernel
alternate: snd_hda_intel,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0401’‘’
Did you use duel boot?
If so, when you boot from Windows to Manjaro, reboot to the BIOS, then boot directly to Manjaro. Or make sure the path is “other OS → BIOS → Manjaro”.
I meet the problem a few weeks ago, had a hard time to figure it out.
Hope it helps.
Note: you only need to do that once when you boot from Windows, meaning after that, “Manjaro → reboot → Manjaro” would just work.
Perfect, thanks!
In both your cases this may indicate that windoze is not shutting down all the way.
This is how it works by default - it hibernates when you ‘shut down’.
(This makes windoze appear to shut down and start up more quickly because in truth it does neither. It also has the side effect of causing problems with any other OS being booted.)
Make sure to disable ‘Fast startup’ under windoze settings, or otherwise create a special shortcut for a true shutdown, etc. Consult a search engine if you need help.
I think I’ve disabled “fast startup” on Windwos from the day I installed it. Would check it later.
[Windows 11/10] How to disable Fast Startup in Windows | ASUS Global
How to Disable Fast Startup in Windows 11/10 (And Why You Should) | helpdeskgeek.com
How to disable Windows 10 fast startup (and why you’d want to) | Windows Central
