Audio intermittently cuts off under Pipewire
I’ve been having this problem ever since I switched to Pipewire on my computer, and none of the troubleshooting steps I found helped mitigate it (including the crackling troubleshooting guide, if anyone was wondering).
The main problem is that, once every few minutes, for no discernible reason, the audio on my system gets cut off for about half a second, and then continues playing. It doesn’t reset my audio devices or anything of the sort, everything looks fine from my end, there’s just a strange, really short break on the audio I hear.
I have also had crackling, which the troubleshooting guide did fix, but this problem has remained despite my attempts to fix it. I’m using my monitor’s audio jack for this, but it seems to happen regardless of which audio output I use.
For completeness, here’s the inxi output:
inxi -Fza
  Kernel: 6.12.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=4b8c4244-710c-44f9-8640-442d9fdd303f rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.13.0
  Type: Desktop Mobo: ASRock model: B550M-HDV serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: P1.90
    date: 08/09/2021
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
    desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3867 min/max: 550/4208 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3867 2: 3867 3: 3867
    4: 3867 5: 3867 6: 3867 7: 3867 8: 3867 9: 3867 10: 3867 11: 3867 12: 3867
    bogomips: 86269
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nvidia
    v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 05:00.0
    chip-ID: 10de:1c82 class-ID: 0300
  Device-2: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
    chip-ID: 0c45:8006 class-ID: 0301
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
    s-diag: 554mm (21.82")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Philips PHL 221V8
    serial: <filter> built: 2021 res: N/A dpi: 102 gamma: 1.2
    size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
    drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
    memory: 3.91 GiB
  API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1050 Ti driver: nvidia v: 570.144 device-ID: 10de:1c82
    surfaces: xcb,xlib
  Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
    bus-ID: 05:00.1 chip-ID: 10de:0fb9 class-ID: 0403
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: JMTek LLC. USB PnP Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0c76:161e class-ID: 0300
  API: ALSA v: k6.12.25-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek 802.11ac NIC driver: rtl8821cu type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 0bda:c811
    class-ID: 0000 serial: <filter>
  IF: wlp7s0f3u2 state: down mac: <filter>
  IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  Info: services: NetworkManager, smbd, sshd, systemd-timesyncd
  Local Storage: total: 953.87 GiB used: 838.46 GiB (87.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX6000LNP
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: V9002s45 temp: 47.9 C
    scheme: GPT
  ID-1: / raw-size: 149.62 GiB size: 146.21 GiB (97.72%)
    used: 120.02 GiB (82.1%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-2: /boot/efi raw-size: 1 GiB size: 1023 MiB (99.80%)
    used: 296 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 782 GiB size: 768.66 GiB (98.29%)
    used: 716.63 GiB (93.2%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  Kernel: swappiness: 20 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: partition size: 21.25 GiB used: 1.81 GiB (8.5%)
    priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
  System Temperatures: cpu: 62.5 C mobo: N/A gpu: nvidia temp: 41 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 25%
  Memory: total: 32 GiB available: 31.27 GiB used: 8.7 GiB (27.8%)
  Processes: 395 Power: uptime: 1h 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1878 pm: pacman pkgs: 1824 libs: 464 tools: pamac,yay
    pm: flatpak pkgs: 54 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
Did you disable suspend? I think I explained it in the guide.
You also have 3 audio devices listed:
Which one has the problem? and is the problem present on the other ones or not?
@rabcor
Similar problem here. You mentioned disable suspend. Link to the guide, please.
Thanks
It is in the first post:
@scotty65 many thanks!!
Pipewire Wiki - Troubleshooting - Xruns
There are 2 causes of xruns:
  1. Application’s can’t complete the cycle in time. It can be because the kernel didn’t wake them up in time or that they didn’t get enough time allocated.
  2. Driver timing are too tight. The driver is not woken up fast enough to keep the buffer filled.
1 can cause 2. 2 can be improved by adding more buffering (increasing headroom). Adding headroom does not improve 1.
With pw-top you can see what causes the xruns. If the application xruns are increasing, it’s 1. If it’s only the driver increasing xruns, it’s 2. If both are increasing it’s 1 causing 2
To add more buffering - Pipewire Wiki - Troubleshooting - Stuttering Audio (in Virtual Machine)
I genuinely completely forgot I had made this post, so apologies for the very late reply.
Which [device] has the problem?
I use the first device in the list, which is the one that I’ve noticed the problem on. Device #3 is just my microphone, so it doesn’t really have anything to do with the audio output issues as far as I understand.
I also did disable suspend, and that didn’t help with the problem at all.
The difficulty I’ve encountered with this issue is that it seems to come and go, and right now it’s not happening at all unless I have several different audio streams active at the same time (say, from several streams running in the background, a game and a music player), and, weirdly, also sometimes from certain Minecraft modpacks, which I haven’t been able to figure out the reason for.
I did follow every single instruction written in the guide, and didn’t encounter any fixes for my problems, but I really just kind of gave up chasing it after it half-fixed itself. I’m not entirely sure whether or not the issue happens on the second device (my computer case’s audio output, as opposed to the monitor output I currently use), since I didn’t test it very thoroughly before the issue disappeared again.
I will note that the issue just completely vanished about 3 or 4 days after I tried to troubleshoot everything. Notably, I reverted every single change, since they didn’t seem to help in the slightest (and some seemed to make the problem worse), so I’m reasonably confident in saying that none of them contributed to fixing the problem. However, I can still sometimes trigger it, but only in very specific circumstances.
