Think I found a bug (not sure how to report):
Situation:
Play audio (source does not matter, tested with mutliple sources) → Audio is playing → press mute button (Fn + F9) → Audio Muted → Audio is Still Playing According to Browser (everything normal, this is anticipated) → Press Unmute → Audio is still muted but browser is playing.
Replicatable even upon restart. Happens every time.
The only thing that resets this is to kill browser or clementine process and then play audio again.
System Specs:
Host: MidnightStarSign Kernel: 5.11.14-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 10.2.0 Desktop: KDE Plasma 5.21.4 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3001
date: 12/04/2020
Info: 16-Core model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3
rev: 0 cache: L2: 8 MiB
bogomips: 217677
Speed: 3274 MHz min/max: 2200/3400 MHz boost: enabled Core speeds (MHz):
1: 3274 2: 3006 3: 3695 4: 3693 5: 4618 6: 3771 7: 3691 8: 3690 9: 2258
10: 2803 11: 2767 12: 2874 13: 2647 14: 2796 15: 2834 16: 2865 17: 2738
18: 3685 19: 3688 20: 3684 21: 3685 22: 4603 23: 3764 24: 2704 25: 3696
26: 3697 27: 2697 28: 2258 29: 2731 30: 2819 31: 3691 32: 3696
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: ASRock driver: amdgpu v: kernel bus-ID: 0c:00.0
Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 7-1:2
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
3: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.40.0 5.11.14-1-MANJARO
LLVM 11.1.0)
v: 4.6 Mesa 21.0.2 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 0c:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0e:00.4
Device-3: JMTek LLC. Plugable USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2
Device-4: Schiit Audio Schiit Modi 3+ type: USB driver: snd-usb-audio
bus-ID: 3-2:3
Device-5: ASUSTek ASUS AI Noise-Cancelling Mic Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-5:3
Device-6: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 7-1:2
Sound Server-1: ALSA v: k5.11.14-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: f000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: 24:4b:fe:5b:08:2a
driver: btusb v: 0.8 bus-ID: 3-5.3:6
Local Storage: total: 3.66 TiB used: 2.46 TiB (67.2%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T3X0C-00SJG0
size: 931.51 GiB temp: 49.9 C
ID-2: /dev/nvme1n1 vendor: Western Digital model: WDS100T2B0C-00PXH0
size: 931.51 GiB temp: 39.9 C
ID-3: /dev/sda vendor: Seagate model: ST2000LM015-2E8174 size: 1.82 TiB
ID-4: /dev/sdb type: USB vendor: Toshiba model: TransMemory size: 14.92 GiB
ID-5: /dev/sdc type: USB vendor: SanDisk model: Gaming Xbox 360 size: 7.48 GiB
ID-1: / size: 767 GiB used: 653.55 GiB (85.2%) fs: btrfs dev: /dev/dm-0
mapped: luks-466d5812-64c7-4a28-bcc4-a1a5adfa9450
ID-2: /boot/efi size: 511 MiB used: 26.1 MiB (5.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 767 GiB used: 653.55 GiB (85.2%) fs: btrfs dev: /dev/dm-0
ID-1: swap-1 type: partition size: 64 GiB used: 0 KiB (0.0%) dev: /dev/dm-1
mapped: luks-81b2dc57-06f5-4471-b484-77c3a516f307
System Temperatures: cpu: 52.5 C mobo: 0 C gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 768 Uptime: 18m Memory: 62.79 GiB used: 13.54 GiB (21.6%)
Init: systemd Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1929 Shell: Bash
v: 5.1.0 inxi: 3.3.04
