i deleted and reinstalled pulse audio from my pc but now everything related to audio is gone. the audio section is no longer within my settings and most other things that have to do with sound have disappeared too. is there any way to get it back or do i have to reinstall everything?
plasma-pa
Perhaps you should also install other packages - you’ll find them in pamac history.
You should be happy that this didn’t delete half your system. In the future, read messages and simply reinstall the program instead of removing and reinstalling. It’s safer and doesn’t remove other packages. You can do it in GUI or with command:
pamac reinstall package_name
thanks for your help but shortly here after my whole installation went the way of the dodo after updating the kernel so my problem has been indirectly solved.
