i use moondrop may earphones, type-c port, i connect them but i just hear a slight hiss sound while i connect and disconnect, i shifted to linux recently, hope i could get some help, my laptop’s port is working properly and also my earphones, i am sure its not a hardware problem
Hello @kitty and welcome to the Manjaro Community! ![]()
I’m no audio guru, but we do have at least one member here who (at least I think) is.
But, to begin with, you would be wise to provide some system information, so we know where to start.
To this end, please provide the output of:
inxi -zv8
… please use the code formatting (the </> button at the top of the Reply window or the three backticks ``` on lines above and below the pasted output).
Note: This output is privacy-filtered using the above command.
inxi -zv8 ✔
Kernel: 6.18.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=edfe1e63-cdd5-4203-ae7d-afc5bfad0dc5 rw rootflags=subvol=@
quiet splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 49.3 tk: GTK v: 3.24.51 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 82NC v: YG Slim 7 Pro 14IHU5
serial: <superuser required> Chassis: type: 10 v: YG Slim 7 Pro 14IHU5
Mobo: LENOVO model: VIUU4 v: SDK0K17763 WIN serial: <superuser required>
part-nu: LENOVO_MT_82NC_BU_idea_FM_ uuid: <superuser required>
Firmware: UEFI vendor: LENOVO v: FJCN75WW date: 03/17/2023
ID-1: BAT1 charge: 36.7 Wh (74%) condition: 49.6/61 Wh (81.3%) power: 7.4 W
volts: 16.01 min: 15.44 model: Celxpert L19C4PH3 type: Li-poly
serial: <filter> charging: status: discharging type: standard
avail: long_life,standard cycles: N/A
System RAM: total: 16 GiB available: 15.4 GiB used: 10.57 GiB (68.6%)
Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
max-module-size: 2 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR4 detail: synchronous
size: 2 GiB speed: 4267 MT/s volts: curr: 0.6 width (bits): data: 16
total: 16 manufacturer: Samsung part-no: UBE3D4AA-MGCR serial: N/A
Device-2: Controller0-ChannelB type: LPDDR4 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR4 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR4 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR4 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR4 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR4 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR4 detail: synchronous
Info: model: 11th Gen Intel Core i5-11320H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
microcode: 0x3C
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 400 min/max: 400/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 50995
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: indirect_target_selection mitigation: Aligned branch/return thunks
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Type: vmscape status: Not affected
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Xe process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:5419
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model-id: CSO 0x140c built: 2021 res: 2880x1800 dpi: 242
gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue:
x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 302x188mm (11.89x7.4")
diag: 356mm (14") ratio: 16:10 modes: 2880x1800
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
GT2) device-ID: 8086:9a49 memory: 15.04 GiB unified: yes display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
API: ALSA v: k6.18.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 476.94 GiB used: 55.52 GiB (11.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X084N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41010C22 temp: 41.9 C
scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
used: 55.52 GiB (11.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: edfe1e63-cdd5-4203-ae7d-afc5bfad0dc5
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4D00-13B5
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-4: /var/cache raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-5: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: IMC Networks Integrated Camera type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:5419 class-ID: fe01
serial: <filter>
Device-2: 3-10:3 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1328 libs: 348 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
3: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
4: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
5: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
7: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
8: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
9: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
10: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
11: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
12: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
13: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
14: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
15: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
16: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
17: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
19: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
20: https://mirrors.manjaro.org/repo/stable/$repo/$arch
21: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
22: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
23: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
24: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
25: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
26: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
27: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
28: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
29: https://manjaro.kurdy.org/stable/$repo/$arch
30: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
31: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
32: https://mirror.easyname.at/manjaro/stable/$repo/$arch
33: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://mirror.23m.com/manjaro/stable/$repo/$arch
35: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
36: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
37: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
38: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
39: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
40: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
41: https://manjaro.ynh.ovh/stable/$repo/$arch
42: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
43: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
44: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
45: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
46: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
47: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
48: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
49: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
50: https://muug.ca/mirror/manjaro/stable/$repo/$arch
51: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
52: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
53: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
54: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
55: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
56: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
57: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
58: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
59: https://mirror.init7.net/manjaro/stable/$repo/$arch
60: https://mirror.koddos.net/manjaro/stable/$repo/$arch
61: https://mirrors2.manjaro.org/stable/$repo/$arch
62: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
63: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
64: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
65: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
66: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
67: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
68: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
69: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
70: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
71: https://linorg.usp.br/manjaro/stable/$repo/$arch
72: https://mirror.fcix.net/manjaro/stable/$repo/$arch
73: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
74: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
75: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
76: https://manjaro.grena.ge/stable/$repo/$arch
77: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
78: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
79: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
80: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
81: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
82: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
83: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
84: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
85: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
86: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
87: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
88: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
89: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
90: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
91: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
92: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
93: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
94: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
95: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
96: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
97: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
98: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 357
1: cpu: 100% command: ps pid: 323598 mem: 4.17 MiB (0.0%)
2: cpu: 43.4% command: kgx pid: 323500 mem: 153.6 MiB (0.9%)
3: cpu: 9.4% command: brave pid: 321519 mem: 440.6 MiB (2.7%)
4: cpu: 4.3% command: zsh pid: 323508 mem: 8.54 MiB (0.0%)
5: cpu: 3.9% command: brave pid: 320449 mem: 595.5 MiB (3.7%)
Memory top: 5 of 357
1: mem: 938.8 MiB (5.9%) command: brave pid: 257623 cpu: 0.1%
2: mem: 702.2 MiB (4.4%) command: brave pid: 257256 cpu: 1.1%
3: mem: 605.5 MiB (3.8%) command: brave pid: 257387 cpu: 0.0%
4: mem: 595.5 MiB (3.7%) command: brave pid: 320449 cpu: 3.9%
5: mem: 560.3 MiB (3.5%) command: gnome-shell pid: 2201 cpu: 2.0%
Processes: 357 Power: uptime: 15d 13h 41m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 87 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.14 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kgx inxi: 3.3.40
Thanks, I don’t see anything amiss with the audio info there; hopefully @nikgnomic will be able to assist.
I do see though that a lot of your RAM is in use and you have no swap defined; this may not be related to the issue but is worth tending to. Also the 15-day uptime suggests you haven’t updated to the latest packages, or at least rebooted following such. ![]()
yeah, i dont shutsdown my laptop, i close the lid and it goes to hybernate, i do update from terminal once a month or so, my work is mostly reading pdfs and writing on gdocs, so i dont need any cutting edge software or something like that, using windows for some reason is overheating my laptop and it feels bloated, that is the main reason why i shifted to linux
If you are not rebooting after a major update, including e.g. a kernel update, you are still running off (some of) the old versions of software.
This is bound to cause issues as libraries etc. may have changed on-disk, whereas the program still in RAM needs the previous version(s).
ETA:
For “minor software updates” e.g. Firefox, just restart the browser or whatever. Sometimes it’s helpful to log-out and back in again, but for major system components eg. the Kernel, a reboot is always recommended.
But that’s not the point. Manjaro is a rolling-release distribution, and it must be kept up-to-date.
Please read the following short essay… ![]()
ok, but what to do wtih my earphones not working??
Hi @kitty,
Could you try two things with your earphones plugged in?
Go to Settings → Sound → Output and check if you see a USB audio device listed there. If so, try selecting it. If this is not working, step 2.
Open a terminal and run and show the output :
The sink part is important.
wpctl status
from that output you’ll see:
- Whether the Moondrop shows up as a sink at all
- What sink ID it has
- Whether it’s set as default or not
That should give us a clear picture of what’s going on.
EDIT: example. I just bought a set of Adam active desktop speakers using DAC. Youre moondrop is using DAC too.
Should look something like this. * 55.
Sinks:
│ 34. Built-in Audio Digital Stereo (HDMI) [vol: 0.60]
│ * 55. PCM2704 16-bit stereo audio DAC Analog Stereo [vol: 0.65]
Found 2 git projects for the moondrops.
First of all, update your system and reboot. If you don’t do that, then your system is in an unsupported state, and then we cannot help you.
thanks @musdus , it worked, it did show up in the sinks at first but not on the output section and didnt know why but it after running the command and i restarted the laptop now and just to check and its working, dont know why ¯_(ツ)_/¯
So after reboot the system did the final steps after update and system is reacting as normal. Something like this ![]()
Nice you get it to work…
