Audio Crackling After Installing Manjaro-PipeWire
Hey all! I’m having an issue that I can’t seem to find a resolution to, I’ve looked at a few threads but I haven’t found any that resolve my issue specifically.
When I first installed Manjaro XFCE I had some serious audio delay, about 1-2 seconds delayed from video. Last time I ran into this on a previous install it was because both Pulse Audio and Pipe Wire was installed, which why does Manjaro install both of these audio servers? Seems kind of odd… But anyways.
 ██████████████████  ████████     jorogumo4@leo-x470aorusultragaming
 ██████████████████  ████████     OS: Manjaro 23.0.0 UltimaThule
 ██████████████████  ████████     Kernel: x86_64 Linux 6.1.31-2-MANJARO
 ██████████████████  ████████     Uptime: 24m
 ████████            ████████     Packages: 1173
 ████████  ████████  ████████     Shell: bash 5.1.16
 ████████  ████████  ████████     Resolution: 7680x1440
 ████████  ████████  ████████     DE: Xfce4
 ████████  ████████  ████████     WM: Xfwm4
 ████████  ████████  ████████     WM Theme: Matcha-sea
 ████████  ████████  ████████     GTK Theme: Matcha-dark-sea [GTK2]
 ████████  ████████  ████████     Icon Theme: Papirus-Maia
 ████████  ████████  ████████     Font: Noto Sans 10
 ████████  ████████  ████████     Disk: 13G / 962G (2%)
                                  CPU: AMD Ryzen 7 2700X Eight-Core @ 16x 3.7GHz
                                  GPU: AMD Radeon RX 7900 XT (gfx1100, LLVM 15.0.7, DRM 3.49, 6.1.31-2-MANJARO)
                                  RAM: 3433MiB / 48124MiB
  Device-1: AMD driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0d:00.3
    chip-ID: 1022:1457 class-ID: 0403
  Device-3: Yamaha Steinberg UR24C driver: snd-usb-audio type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-3:2 chip-ID: 0499:174d
    class-ID: 0103
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
I’ve completely removed pulse audio and have installed Manjaro-PipeWire. Though seems there’s still two audio servers, not sure if this is the issue.
Any ideas on how to fix this crackling at the start of the audio? Once things have gotten going the crackling goes away and everything is fine. It’s just on the start of any audio.
Thanks in advance!!
Here you go:
https://wiki.archlinux.org/title/PipeWire#Noticeable_audio_delay_or_audible_pop/crack_when_starting_playback
Looks like alsactl init has resolved it. Interesting! If it continues though I’ll be sure to read into the rest of it. For now everything seems fine. Thank you so much for the post!!
Manjaro does not have both PulseAudio and Pipewire installed as audio servers
pulseaudio is installed as default audio server
pipewire is installed by default as a video server for Wayland
pipewire-pulse and pw-jack to replace PulseAudio and JACK are not installed by default
