Audacity stuck with gdk_wayland... error
Audacity 2.4.1 on a newly installed Manjaro with Gnome 3.38.2 and Wayland window manager crashes. The problem is:
Gdk-Message: 22:45:33.639: Unable to load sb_left_arrow from the cursor theme
Gdk-Message: 22:45:33.639: Unable to load sb_right_arrow from the cursor theme
Gdk-Message: 22:51:35.986: Window 0x55fa344af1e0 is a temporary window without parent, application will not be able to position it on screen.
(audacity:15347): Gdk-CRITICAL **: 22:51:35.989: gdk_wayland_window_handle_configure_popup: assertion 'impl->transient_for' failed
Gdk-Message: 22:51:44.796: Window 0x55fa34f0a0a0 is a temporary window without parent, application will not be able to position it on screen.
(audacity:15347): Gdk-CRITICAL **: 22:51:44.816: gdk_wayland_window_handle_configure_popup: assertion 'impl->transient_for' failed
Gdk-Message: 22:51:47.509: Window 0x55fa34f1cc20 is a temporary window without parent, application will not be able to position it on screen.
(audacity:15347): Gdk-CRITICAL **: 22:51:47.529: gdk_wayland_window_handle_configure_popup: assertion 'impl->transient_for' failed
What did I do wrong? I installed Audacity via Pamac.
CPU: Quad Core Intel Core i5-8250U (-MT MCP-) speed/min/max: 700/400/3400 MHz
Kernel: 5.9.11-3-MANJARO x86_64 Up: 4h 16m
Mem: 2424.2/7835.3 MiB (30.9%) Storage: 238.47 GiB (54.7% used) Procs: 248 Shell: Zsh inxi: 3.1.08
