Hi. Trying to install librewolf-bin from the AUR. After it downloads using pamac, It comes with this, which is where the error is found:
source ... Skipped
default192x192.png ... Passed
librewolf.desktop ... Passed
==> Validating source_x86_64 files with sha256sums...
librewolf-115.0.2-2-linux-x86_64-package.tar.bz2 ... Passed
librewolf-115.0.2-2-linux-x86_64-package.tar.bz2.sig ... Skipped
==> Verifying source file signatures with gpg...
librewolf-115.0.2-2-linux-x86_64-package.tar.bz2 ... cat: write error: Broken pipe
FAILED
==> ERROR: One or more PGP signatures could not be verified!
Finished with result: exit-code
Main processes terminated with: code=exited/status=1
I cannot find a fix where it says Broken pipe. I can’t see what PGP signature was not verified and no signature is listed so add to my keychain anyway. Is it possible to install this on Manjaro because nobody else seems to have this issue?
Could this be a problem because I installed the Manjaro Sway Window Manager version?
Thanks for reading and looking forward to your reply
