Hi!
When playing a playlist of songs with audacious and the screen gets locked, audacious continues to play the current song till the end, but then pauses the playlist. When I log in again, audacious continues playing.
I haven’t found any settings, where I could control this.
inxi -Fxxxz
Kernel: 5.4.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Desktop Mobo: Gigabyte model: GA-890GPA-UD3H v: x.x serial: <filter>
BIOS: Award v: F9 date: 09/09/2011
Info: 6-Core model: AMD Phenom II X6 1075T bits: 64 type: MCP arch: K10
rev: 0 cache: L2: 3 MiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 36169
Speed: 1502 MHz min/max: 800/3000 MHz boost: enabled Core speeds (MHz):
1: 1502 2: 803 3: 804 4: 804 5: 804 6: 803
Device-1: AMD RS880 [Radeon HD 4290] vendor: Gigabyte driver: radeon
v: kernel bus-ID: 01:05.0 chip-ID: 1002:9714 class-ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: ati,radeon
unloaded: modesetting alternate: fbdev,vesa resolution: 1920x1080~60Hz
s-dpi: 96
OpenGL: renderer: AMD RS880 (DRM 2.50.0 / 5.4.105-1-MANJARO LLVM 11.1.0)
v: 3.3 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte GA-880GMA-USB3
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383
class-ID: 0403
Device-2: AMD RS880 HDMI Audio [Radeon HD 4200 Series] vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:05.1 chip-ID: 1002:970f
class-ID: 0403
Sound Server-1: ALSA v: k5.4.105-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
vendor: Gigabyte driver: r8169 v: kernel port: ee00 bus-ID: 03:00.0
Local Storage: total: 12.73 TiB used: 10.12 TiB (79.5%)
ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 023 scheme: MBR
ID-2: /dev/sdb vendor: Seagate model: ST10000DM0004-1ZC101 size: 9.1 TiB
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: DN01 scheme: GPT
ID-3: /dev/sdc vendor: Hitachi model: HDS723020BLA642 size: 1.82 TiB
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A5C0 scheme: MBR
ID-4: /dev/sdd vendor: Seagate model: ST31500341AS size: 1.36 TiB
speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC1H scheme: MBR
ID-1: / size: 359.02 GiB used: 208.27 GiB (58.0%) fs: ext4 dev: /dev/sda3
System Temperatures: cpu: 30.0 C mobo: 30.0 C
Fan Speeds (RPM): cpu: 1280 fan-2: 0 fan-3: 566 fan-5: 0
Power: 12v: N/A 5v: 2.96 3.3v: N/A vbat: 3.09
Processes: 237 Uptime: 33m wakeups: 0 Memory: 13.18 GiB
used: 2.23 GiB (16.9%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1379 Shell: Bash v: 5.1.0 running-in: xfce4-terminal
inxi: 3.3.03
inxi -Fxxxz
s-dpi: 96
class-ID: 0403
class-ID: 0403
inxi: 3.3.03
Any hints? Thanks in advance and regards!
