At first boot stuck on uboot on rp3-a+
#21
Yes. the rpi3 image which is aarch64 based and has uboot+mainline kernel is the supported one.
#22
rpi-3a+ is also aarch64 , why you are telling it is not?
if with the latest kernel from the offical rpi will help the rpi-3a+ boot then problem solved, right?
or if some one work to boot the rpi-3a+ in uboot then the board will be supported by manjaro arm?
#23
I do not build the raspberry pi kernel for aarch64.
#24
new uboot is released . so anything that can help to solve the issue?
also can to report this issue in the uboot website?
also should report in pi froum?
