Asus X370 prime pro sensors
#1
I was trying to get my system’s sensors to work at last, but I’m not sure what to do.
I installed it87-dkms-git, rebooted and run # sensors-detect, then $ sensors and got
k10temp-pci-00c3
Adapter: PCI adapter
Tdie:         +22.0°C  (high = +70.0°C)
Tctl:         +22.0°C
asus-isa-0000
Adapter: ISA adapter
cpu_fan:        0 RPM
Which is exactly what I was getting before. Am I missing something? I was waiting to see if kernel 420 would fix it, but I’m using it right now and it still doesn’t work.
Related post:(Lm-sensors with AMD Ryzen / X370 / B350)
Machine:   Type: Desktop Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x serial: <filter>
           UEFI: American Megatrends v: 4207 date: 12/08/2018
#2
My mobo is PRIME Z370-A. Try this:
sudo modprobe nct6775
followed by
sudo sensors-detect
#3
modprobe: ERROR: could not insert 'nct6775': No such device
That’s what I got. Maybe the device is named differently?? what can I run to find the name?
#4
Post output of
sudo sensors-detect
#5
$sudo sensors-detect
# sensors-detect revision $Revision$
# Board: ASUSTeK COMPUTER INC. PRIME X370-PRO
# Kernel: 4.20.0-1-MANJARO x86_64
# Processor: AMD Ryzen 5 1600 Six-Core Processor (23/1/1)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no):
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595...                       No
VIA VT82C686 Integrated Sensors...                          No
VIA VT8231 Integrated Sensors...                            No
AMD K8 thermal sensors...                                   No
AMD Family 10h thermal sensors...                           No
AMD Family 11h thermal sensors...                           No
AMD Family 12h and 14h thermal sensors...                   No
AMD Family 15h thermal sensors...                           No
AMD Family 16h thermal sensors...                           No
AMD Family 17h thermal sensors...                           Success!
    (driver `k10temp')
AMD Family 15h power sensors...                             No
AMD Family 16h power sensors...                             No
Intel digital thermal sensor...                             No
Intel AMB FB-DIMM thermal sensor...                         No
Intel 5500/5520/X58 thermal sensor...                       No
VIA C7 thermal sensor...                                    No
VIA Nano thermal sensor...                                  No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no):
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor/ITE'...               No
Trying family `SMSC'...                                     No
Trying family `VIA/Winbond/Nuvoton/Fintek'...               No
Trying family `ITE'...                                      Yes
Found `ITE IT8665E Super IO Sensors'                        Success!
    (address 0x290, driver `to-be-written')
Probing for Super-I/O at 0x4e/0x4f
Trying family `ITE'...                                      No
Some systems (mainly servers) implement IPMI, a set of common interfaces
through which system health data may be retrieved, amongst other things.
We first try to get the information from SMBIOS. If we don't find it
there, we have to read from arbitrary I/O ports to probe for such
interfaces. This is normally safe. Do you want to scan for IPMI
interfaces? (YES/no):
# DMI data unavailable, please consider installing dmidecode 2.7
# or later for better results.
Probing for `IPMI BMC KCS' at 0xca0...                      No
Probing for `IPMI BMC SMIC' at 0xca8...                     No
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (yes/NO): yes
Probing for `National Semiconductor LM78' at 0x290...       No
Probing for `National Semiconductor LM79' at 0x290...       No
Probing for `Winbond W83781D' at 0x290...                   No
Probing for `Winbond W83782D' at 0x290...                   No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no):
Using driver `i2c-piix4' for device 0000:00:14.0: AMD KERNCZ SMBus
Module i2c-dev loaded successfully.
Next adapter: SMBus PIIX4 adapter port 0 at 0b00 (i2c-0)
Do you want to scan it? (YES/no/selectively):
Client found at address 0x52
Probing for `Analog Devices ADM1033'...                     No
Probing for `Analog Devices ADM1034'...                     No
Probing for `SPD EEPROM'...                                 Yes
    (confidence 8, not a hardware monitoring chip)
Client found at address 0x53
Next adapter: SMBus PIIX4 adapter port 2 at 0b00 (i2c-1)
Do you want to scan it? (YES/no/selectively): yes
Next adapter: SMBus PIIX4 adapter port 3 at 0b00 (i2c-2)
Next adapter: SMBus PIIX4 adapter port 4 at 0b00 (i2c-3)
Next adapter: NVIDIA i2c adapter 4 at a:00.0 (i2c-4)
Do you want to scan it? (yes/NO/selectively): yes
Next adapter: NVIDIA i2c adapter 6 at a:00.0 (i2c-5)
Next adapter: NVIDIA i2c adapter 7 at a:00.0 (i2c-6)
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `to-be-written':
  * ISA bus, address 0x290
    Chip `ITE IT8665E Super IO Sensors' (confidence: 9)
Driver `k10temp' (autoloaded):
  * Chip `AMD Family 17h thermal sensors' (confidence: 9)
Note: there is no driver for ITE IT8665E Super IO Sensors yet.
Check https://hwmon.wiki.kernel.org/device_support_status for updates.
No modules to load, skipping modules configuration.
Unloading i2c-dev... OK
Unloading cpuid... OK
~ $ sensors
k10temp-pci-00c3
Tdie:         +19.0°C  (high = +70.0°C)
Tctl:         +19.0°C
asus-isa-0000
cpu_fan:        0 RPM
Edit: I just saw the “Z” in Z370… I don’t think the sensors work similarly between our mobos. Need someone with an X370
#6
Oh well, it was a shot. This rings out, though:
Do a google search on ITE IT8665E. Some of the results may help you.
#7
Solution:
install:
https://aur.archlinux.org/packages/it87-dkms-git/
then,
sudo modprobe it87 , to load the driver.
sudo sensors-detect and done!
Useful link:(https://github.com/lm-sensors/lm-sensors/issues/134)
To make the change permanent:
create
/etc/modules-load.d/it87.conf
and add the line:
it87
source
@merlock Thanks for pointing me to the right direction with modprobe.
#8
After rebooting I need to run modprobe again. How did you make the change permanent? I must update the solution.
#9
Add “it87” to /etc/modules-load.d/modules.conf.
