I apologize for a separate comment with this information, but the post has a limit.
dmesg
[ 0.000000] Linux version 6.14.4-1-MANJARO (linux614@manjaro) (gcc (GCC) 14.2.1 20250207, GNU ld (GNU Binutils) 2.44) #1 SMP PREEMPT_DYNAMIC Sat, 26 Apr 2025 05:52:09 +0000
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64 root=UUID=a72d381b-e8cb-4965-9e6b-856be8c46f14 rw zswap.enabled=0 quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.000000] x86/split lock detection: #DB: warning on user-space bus_locks
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009b7efff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009b7f000-0x0000000009ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a23bfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000a23c000-0x000000006797efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000006797f000-0x000000006d97efff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000006d97f000-0x000000006da7efff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000006da7f000-0x000000006fa7efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000006fa7f000-0x0000000077bfefff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000077bff000-0x0000000079ff6fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000079ff7000-0x0000000079ffcfff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000079ffd000-0x0000000079ffefff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000079fff000-0x000000007bffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007d675000-0x000000007d6fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007d800000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000085e17ffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000085f1c0000-0x00000008a01fffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] e820: update [mem 0x51960018-0x51964457] usable ==> usable
[ 0.000000] extended physical RAM map:
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x0000000009b7efff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000009b7f000-0x0000000009ffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000000a200000-0x000000000a23bfff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x000000000a23c000-0x0000000051960017] usable
[ 0.000000] reserve setup_data: [mem 0x0000000051960018-0x0000000051964457] usable
[ 0.000000] reserve setup_data: [mem 0x0000000051964458-0x000000006797efff] usable
[ 0.000000] reserve setup_data: [mem 0x000000006797f000-0x000000006d97efff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000006d97f000-0x000000006da7efff] ACPI data
[ 0.000000] reserve setup_data: [mem 0x000000006da7f000-0x000000006fa7efff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x000000006fa7f000-0x0000000077bfefff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000077bff000-0x0000000079ff6fff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000079ff7000-0x0000000079ffcfff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000079ffd000-0x0000000079ffefff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000079fff000-0x000000007bffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000007d675000-0x000000007d6fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000007d800000-0x000000007fffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fd000000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000085e17ffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000085f1c0000-0x00000008a01fffff] reserved
[ 0.000000] efi: EFI v2.9 by American Megatrends
[ 0.000000] efi: ACPI=0x6da7e000 ACPI 2.0=0x6da7e014 TPMFinalLog=0x6fa32000 SMBIOS=0x77760000 SMBIOS 3.0=0x7775f000 MEMATTR=0x61d05018 ESRT=0x6414e818 INITRD=0x5a752518 RNG=0x6da16018 TPMEventLog=0x6da13018
[ 0.000000] random: crng init done
[ 0.000000] efi: Remove mem63: MMIO range=[0xe0000000-0xefffffff] (256MB) from e820 map
[ 0.000000] e820: remove [mem 0xe0000000-0xefffffff] reserved
[ 0.000000] efi: Remove mem64: MMIO range=[0xfd000000-0xfedfffff] (30MB) from e820 map
[ 0.000000] e820: remove [mem 0xfd000000-0xfedfffff] reserved
[ 0.000000] efi: Not removing mem65: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[ 0.000000] efi: Remove mem66: MMIO range=[0xfee01000-0xffffffff] (17MB) from e820 map
[ 0.000000] e820: remove [mem 0xfee01000-0xffffffff] reserved
[ 0.000000] efi: Remove mem68: MMIO range=[0x880000000-0x8a01fffff] (514MB) from e820 map
[ 0.000000] e820: remove [mem 0x880000000-0x8a01fffff] reserved
[ 0.000000] SMBIOS 3.7.0 present.
[ 0.000000] DMI: ASUSTeK COMPUTER INC. ASUS Vivobook S 15 M5506WA_M5506WA/M5506WA, BIOS M5506WA.313 03/19/2025
[ 0.000000] DMI: Memory slots populated: 4/4
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 1996.122 MHz processor
[ 0.000062] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000063] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000068] last_pfn = 0x85e180 max_arch_pfn = 0x400000000
[ 0.000074] MTRR map: 6 entries (3 fixed + 3 variable; max 20), built from 9 variable MTRRs
[ 0.000076] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000213] last_pfn = 0x79fff max_arch_pfn = 0x400000000
[ 0.003396] esrt: Reserving ESRT space from 0x000000006414e818 to 0x000000006414e8a0.
[ 0.003402] e820: update [mem 0x6414e000-0x6414efff] usable ==> reserved
[ 0.003414] Using GB pages for direct mapping
[ 0.003721] Secure boot disabled
[ 0.003722] RAMDISK: [mem 0x51965000-0x54659fff]
[ 0.003740] ACPI: Early table checksum verification disabled
[ 0.003743] ACPI: RSDP 0x000000006DA7E014 000024 (v02 _ASUS_)
[ 0.003745] ACPI: XSDT 0x000000006DA7D728 00016C (v01 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.003750] ACPI: FACP 0x000000006DA72000 000114 (v06 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.003754] ACPI: DSDT 0x000000006DA64000 00DDA2 (v02 _ASUS_ Notebook 01072009 INTL 20230331)
[ 0.003756] ACPI: FACS 0x000000006F217000 000040
[ 0.003757] ACPI: SSDT 0x000000006DA74000 0083FE (v02 AMD AmdTable 00000002 MSFT 04000000)
[ 0.003759] ACPI: SSDT 0x000000006DA73000 000309 (v02 _ASUS_ CPUSSDT 01072009 AMI 01072009)
[ 0.003760] ACPI: FIDT 0x000000006DA63000 00009C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.003761] ACPI: MCFG 0x000000006DA62000 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00010013)
[ 0.003762] ACPI: HPET 0x000000006DA61000 000038 (v01 _ASUS_ Notebook 01072009 AMI 00000005)
[ 0.003764] ACPI: UEFI 0x000000006F215000 000048 (v01 _ASUS_ Notebook 01072009 AMI 01000013)
[ 0.003765] ACPI: FPDT 0x000000006DA60000 000044 (v01 _ASUS_ A M I 01072009 AMI 01000013)
[ 0.003766] ACPI: ABLT 0x000000006DA5F000 0002C2 (v00 00000000 00000000)
[ 0.003767] ACPI: VFCT 0x000000006DA5A000 004484 (v01 _ASUS_ Notebook 00000001 AMD 33504F47)
[ 0.003769] ACPI: BGRT 0x000000006DA59000 000038 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.003770] ACPI: SSDT 0x000000006DA58000 00021A (v02 AMD Hetero 00000001 INTL 20230331)
[ 0.003771] ACPI: PCCT 0x000000006DA57000 0000D4 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.003772] ACPI: SSDT 0x000000006DA4F000 007EA6 (v02 AMD AMD CPU 00000001 AMD 00000001)
[ 0.003773] ACPI: SDEV 0x000000006DA4E000 000144 (v01 AMD SdevTble 00000001 ACPI 00000002)
[ 0.003774] ACPI: TPM2 0x000000006DA4D000 000050 (v05 _ASUS_ Notebook 00000001 AMI 00000000)
[ 0.003776] ACPI: SSDT 0x000000006DA4C000 000CA9 (v02 AMD CPMDFIG4 00000001 INTL 20230331)
[ 0.003777] ACPI: SSDT 0x000000006DA49000 002AA6 (v02 AMD CDFAAIG2 00000001 INTL 20230331)
[ 0.003778] ACPI: SSDT 0x000000006DA47000 001DB7 (v02 AMD CPMPMF 00000001 INTL 20230331)
[ 0.003779] ACPI: SSDT 0x000000006DA46000 000EA4 (v02 AMD OEMACP 00000001 INTL 20230331)
[ 0.003780] ACPI: SSDT 0x000000006DA45000 000A70 (v02 AMD OEMPMF 00000001 INTL 20230331)
[ 0.003782] ACPI: SSDT 0x000000006DA3B000 009A53 (v02 AMD CPMCMN 00000001 INTL 20230331)
[ 0.003783] ACPI: WSMT 0x000000006DA3A000 000028 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.003784] ACPI: APIC 0x000000006DA39000 000128 (v06 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.003785] ACPI: SSDT 0x000000006DA38000 00010D (v02 MSFT MHSP 00000004 INTL 20230331)
[ 0.003786] ACPI: SSDT 0x000000006DA36000 001B4C (v02 AMD AOD 00000001 INTL 20230331)
[ 0.003788] ACPI: SSDT 0x000000006DA35000 000051 (v02 AMD DRTM 00000001 INTL 20230331)
[ 0.003789] ACPI: IVRS 0x000000006DA34000 0001F6 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.003790] ACPI: SSDT 0x000000006DA33000 00096A (v02 AMD CPMMSOSC 00000001 INTL 20230331)
[ 0.003791] ACPI: SSDT 0x000000006DA32000 000F5C (v02 AMD CPMACPV8 00000001 INTL 20230331)
[ 0.003792] ACPI: SSDT 0x000000006DA31000 000500 (v02 AMD MEMTOOL0 00000002 INTL 20230331)
[ 0.003793] ACPI: SSDT 0x000000006DA2F000 00101C (v02 AMD GPP_PME_ 00000001 INTL 20230331)
[ 0.003795] ACPI: SSDT 0x000000006DA25000 00972B (v02 AMD INTGPPC_ 00000001 INTL 20230331)
[ 0.003796] ACPI: SSDT 0x000000006DA20000 004608 (v02 AMD INTGPPA_ 00000001 INTL 20230331)
[ 0.003797] ACPI: SSDT 0x000000006DA1F000 000ABF (v02 AMD CPMGPIO0 00000001 INTL 20230331)
[ 0.003798] ACPI: SSDT 0x000000006DA1E000 00008D (v02 AMD CPMMSLPI 00000001 INTL 20230331)
[ 0.003799] ACPI: SSDT 0x000000006DA1D000 000BA4 (v02 AMD CPMUCSI 00000001 INTL 20230331)
[ 0.003800] ACPI: SSDT 0x000000006DA1C000 000A06 (v02 AMD WLAN 00000001 INTL 20230331)
[ 0.003802] ACPI: SSDT 0x000000006DA1B000 000CAE (v02 AMD NVME 00000001 INTL 20230331)
[ 0.003803] ACPI: SSDT 0x000000006DA19000 0013E2 (v02 AMD GpMsSsdt 00000001 INTL 20230331)
[ 0.003804] ACPI: SSDT 0x000000006DA17000 001616 (v02 AMD UPEP 00000001 INTL 20230331)
[ 0.003805] ACPI: Reserving FACP table memory at [mem 0x6da72000-0x6da72113]
[ 0.003805] ACPI: Reserving DSDT table memory at [mem 0x6da64000-0x6da71da1]
[ 0.003806] ACPI: Reserving FACS table memory at [mem 0x6f217000-0x6f21703f]
[ 0.003806] ACPI: Reserving SSDT table memory at [mem 0x6da74000-0x6da7c3fd]
[ 0.003806] ACPI: Reserving SSDT table memory at [mem 0x6da73000-0x6da73308]
[ 0.003806] ACPI: Reserving FIDT table memory at [mem 0x6da63000-0x6da6309b]
[ 0.003807] ACPI: Reserving MCFG table memory at [mem 0x6da62000-0x6da6203b]
[ 0.003807] ACPI: Reserving HPET table memory at [mem 0x6da61000-0x6da61037]
[ 0.003807] ACPI: Reserving UEFI table memory at [mem 0x6f215000-0x6f215047]
[ 0.003807] ACPI: Reserving FPDT table memory at [mem 0x6da60000-0x6da60043]
[ 0.003807] ACPI: Reserving ABLT table memory at [mem 0x6da5f000-0x6da5f2c1]
[ 0.003808] ACPI: Reserving VFCT table memory at [mem 0x6da5a000-0x6da5e483]
[ 0.003808] ACPI: Reserving BGRT table memory at [mem 0x6da59000-0x6da59037]
[ 0.003808] ACPI: Reserving SSDT table memory at [mem 0x6da58000-0x6da58219]
[ 0.003808] ACPI: Reserving PCCT table memory at [mem 0x6da57000-0x6da570d3]
[ 0.003809] ACPI: Reserving SSDT table memory at [mem 0x6da4f000-0x6da56ea5]
[ 0.003809] ACPI: Reserving SDEV table memory at [mem 0x6da4e000-0x6da4e143]
[ 0.003809] ACPI: Reserving TPM2 table memory at [mem 0x6da4d000-0x6da4d04f]
[ 0.003809] ACPI: Reserving SSDT table memory at [mem 0x6da4c000-0x6da4cca8]
[ 0.003810] ACPI: Reserving SSDT table memory at [mem 0x6da49000-0x6da4baa5]
[ 0.003810] ACPI: Reserving SSDT table memory at [mem 0x6da47000-0x6da48db6]
[ 0.003810] ACPI: Reserving SSDT table memory at [mem 0x6da46000-0x6da46ea3]
[ 0.003810] ACPI: Reserving SSDT table memory at [mem 0x6da45000-0x6da45a6f]
[ 0.003811] ACPI: Reserving SSDT table memory at [mem 0x6da3b000-0x6da44a52]
[ 0.003811] ACPI: Reserving WSMT table memory at [mem 0x6da3a000-0x6da3a027]
[ 0.003811] ACPI: Reserving APIC table memory at [mem 0x6da39000-0x6da39127]
[ 0.003811] ACPI: Reserving SSDT table memory at [mem 0x6da38000-0x6da3810c]
[ 0.003811] ACPI: Reserving SSDT table memory at [mem 0x6da36000-0x6da37b4b]
[ 0.003812] ACPI: Reserving SSDT table memory at [mem 0x6da35000-0x6da35050]
[ 0.003812] ACPI: Reserving IVRS table memory at [mem 0x6da34000-0x6da341f5]
[ 0.003812] ACPI: Reserving SSDT table memory at [mem 0x6da33000-0x6da33969]
[ 0.003812] ACPI: Reserving SSDT table memory at [mem 0x6da32000-0x6da32f5b]
[ 0.003813] ACPI: Reserving SSDT table memory at [mem 0x6da31000-0x6da314ff]
[ 0.003813] ACPI: Reserving SSDT table memory at [mem 0x6da2f000-0x6da3001b]
[ 0.003813] ACPI: Reserving SSDT table memory at [mem 0x6da25000-0x6da2e72a]
[ 0.003813] ACPI: Reserving SSDT table memory at [mem 0x6da20000-0x6da24607]
[ 0.003814] ACPI: Reserving SSDT table memory at [mem 0x6da1f000-0x6da1fabe]
[ 0.003814] ACPI: Reserving SSDT table memory at [mem 0x6da1e000-0x6da1e08c]
[ 0.003814] ACPI: Reserving SSDT table memory at [mem 0x6da1d000-0x6da1dba3]
[ 0.003814] ACPI: Reserving SSDT table memory at [mem 0x6da1c000-0x6da1ca05]
[ 0.003815] ACPI: Reserving SSDT table memory at [mem 0x6da1b000-0x6da1bcad]
[ 0.003815] ACPI: Reserving SSDT table memory at [mem 0x6da19000-0x6da1a3e1]
[ 0.003815] ACPI: Reserving SSDT table memory at [mem 0x6da17000-0x6da18615]
[ 0.003868] No NUMA configuration found
[ 0.003868] Faking a node at [mem 0x0000000000000000-0x000000085e17ffff]
[ 0.003872] NODE_DATA(0) allocated [mem 0x85e1552c0-0x85e17ffff]
[ 0.003969] Zone ranges:
[ 0.003969] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.003970] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.003970] Normal [mem 0x0000000100000000-0x000000085e17ffff]
[ 0.003971] Device empty
[ 0.003972] Movable zone start for each node
[ 0.003973] Early memory node ranges
[ 0.003973] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.003974] node 0: [mem 0x0000000000100000-0x0000000009b7efff]
[ 0.003974] node 0: [mem 0x000000000a000000-0x000000000a1fffff]
[ 0.003974] node 0: [mem 0x000000000a23c000-0x000000006797efff]
[ 0.003975] node 0: [mem 0x0000000077bff000-0x0000000079ff6fff]
[ 0.003975] node 0: [mem 0x0000000079ffd000-0x0000000079ffefff]
[ 0.003975] node 0: [mem 0x0000000100000000-0x000000085e17ffff]
[ 0.003977] Initmem setup node 0 [mem 0x0000000000001000-0x000000085e17ffff]
[ 0.003981] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.003989] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.004041] On node 0, zone DMA32: 1153 pages in unavailable ranges
[ 0.004689] On node 0, zone DMA32: 60 pages in unavailable ranges
[ 0.004810] On node 0, zone DMA32: 33408 pages in unavailable ranges
[ 0.004811] On node 0, zone DMA32: 6 pages in unavailable ranges
[ 0.020393] On node 0, zone Normal: 24577 pages in unavailable ranges
[ 0.020418] On node 0, zone Normal: 7808 pages in unavailable ranges
[ 0.020700] ACPI: PM-Timer IO Port: 0x808
[ 0.020709] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.020722] IOAPIC[0]: apic_id 33, version 33, address 0xfec00000, GSI 0-23
[ 0.020726] IOAPIC[1]: apic_id 34, version 33, address 0xfec01000, GSI 24-55
[ 0.020727] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.020729] ACPI: INT_SRC_OVR (bus 0 bus_irq 1 global_irq 1 low edge)
[ 0.020729] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.020732] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.020733] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.020742] e820: update [mem 0x61a34000-0x61a96fff] usable ==> reserved
[ 0.020754] CPU topo: Max. logical packages: 1
[ 0.020754] CPU topo: Max. logical dies: 1
[ 0.020754] CPU topo: Max. dies per package: 1
[ 0.020756] CPU topo: Max. threads per core: 2
[ 0.020757] CPU topo: Num. cores per package: 12
[ 0.020757] CPU topo: Num. threads per package: 24
[ 0.020758] CPU topo: Allowing 24 present CPUs plus 0 hotplug CPUs
[ 0.020769] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.020770] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.020771] PM: hibernation: Registered nosave memory: [mem 0x09b7f000-0x09ffffff]
[ 0.020771] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a23bfff]
[ 0.020772] PM: hibernation: Registered nosave memory: [mem 0x61a34000-0x61a96fff]
[ 0.020772] PM: hibernation: Registered nosave memory: [mem 0x6414e000-0x6414efff]
[ 0.020773] PM: hibernation: Registered nosave memory: [mem 0x6797f000-0x77bfefff]
[ 0.020774] PM: hibernation: Registered nosave memory: [mem 0x79ff7000-0x79ffcfff]
[ 0.020774] PM: hibernation: Registered nosave memory: [mem 0x79fff000-0xffffffff]
[ 0.020775] [mem 0x80000000-0xfedfffff] available for PCI devices
[ 0.020776] Booting paravirtualized kernel on bare hardware
[ 0.020778] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[ 0.024233] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:24 nr_cpu_ids:24 nr_node_ids:1
[ 0.024724] percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
[ 0.024729] pcpu-alloc: s237568 r8192 d28672 u524288 alloc=1*2097152
[ 0.024730] pcpu-alloc: [0] 00 01 02 03 [0] 04 05 06 07
[ 0.024732] pcpu-alloc: [0] 08 09 10 11 [0] 12 13 14 15
[ 0.024734] pcpu-alloc: [0] 16 17 18 19 [0] 20 21 22 23
[ 0.024743] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64 root=UUID=a72d381b-e8cb-4965-9e6b-856be8c46f14 rw zswap.enabled=0 quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 0.024800] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64", will be passed to user space.
[ 0.024811] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.024812] printk: log_buf_len total cpu_extra contributions: 94208 bytes
[ 0.024812] printk: log_buf_len min size: 131072 bytes
[ 0.024875] printk: log buffer data + meta data: 262144 + 917504 = 1179648 bytes
[ 0.024876] printk: early log buf free: 113272(86%)
[ 0.025900] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.026398] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.026489] Fallback order for Node 0: 0
[ 0.026493] Built 1 zonelists, mobility grouping on. Total pages: 8157659
[ 0.026494] Policy zone: Normal
[ 0.026579] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.026617] software IO TLB: area num 32.
[ 0.054876] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=24, Nodes=1
[ 0.054911] ftrace: allocating 55510 entries in 217 pages
[ 0.081596] ftrace: allocated 217 pages with 5 groups
[ 0.081651] Dynamic Preempt: full
[ 0.081700] rcu: Preemptible hierarchical RCU implementation.
[ 0.081700] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=24.
[ 0.081701] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.081702] Trampoline variant of Tasks RCU enabled.
[ 0.081703] Rude variant of Tasks RCU enabled.
[ 0.081703] Tracing variant of Tasks RCU enabled.
[ 0.081703] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[ 0.081704] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=24
[ 0.081712] RCU Tasks: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=24.
[ 0.081713] RCU Tasks Rude: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=24.
[ 0.081715] RCU Tasks Trace: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=24.
[ 0.084106] NR_IRQS: 524544, nr_irqs: 1160, preallocated irqs: 16
[ 0.084285] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.084382] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.084406] Console: colour dummy device 80x25
[ 0.084408] printk: legacy console [tty0] enabled
[ 0.084435] ACPI: Core revision 20240827
[ 0.084591] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.084608] APIC: Switch to symmetric I/O mode setup
[ 0.084800] AMD-Vi: ivrs, add hid:AMDI0020, uid:ID00, rdevid:0xa0
[ 0.084802] AMD-Vi: ivrs, add hid:AMDI0020, uid:ID01, rdevid:0xa0
[ 0.084802] AMD-Vi: ivrs, add hid:AMDI0020, uid:ID02, rdevid:0xa0
[ 0.084803] AMD-Vi: ivrs, add hid:AMDI0020, uid:ID03, rdevid:0x98
[ 0.084803] AMD-Vi: ivrs, add hid:MSFT0201, uid:1, rdevid:0x60
[ 0.084804] AMD-Vi: ivrs, add hid:AMDI0020, uid:ID04, rdevid:0x98
[ 0.084804] AMD-Vi: Using global IVHD EFR:0x246577efa2254afa, EFR2:0x10
[ 0.085949] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.090613] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x398bbdb7b9b, max_idle_ns: 881590756752 ns
[ 0.090615] Calibrating delay loop (skipped), value calculated using timer frequency.. 3992.24 BogoMIPS (lpj=1996122)
[ 0.090630] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.090684] LVT offset 1 assigned for vector 0xf9
[ 0.090879] LVT offset 2 assigned for vector 0xf4
[ 0.090935] Last level iTLB entries: 4KB 64, 2MB 64, 4MB 32
[ 0.090935] Last level dTLB entries: 4KB 128, 2MB 128, 4MB 64, 1GB 0
[ 0.090937] process: using mwait in idle threads
[ 0.090939] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.090941] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[ 0.090941] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.090943] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.090943] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.090945] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.090946] Speculative Return Stack Overflow: Mitigation: IBPB on VMEXIT only
[ 0.090950] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.090951] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.090952] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.090952] x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
[ 0.090953] x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
[ 0.090953] x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
[ 0.090953] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.090954] x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
[ 0.090955] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.090955] x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
[ 0.090956] x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
[ 0.090956] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[ 0.090957] x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
[ 0.090957] x86/fpu: xstate_offset[11]: 2440, xstate_sizes[11]: 16
[ 0.090958] x86/fpu: Enabled xstate features 0xae7, context size is 2456 bytes, using 'compacted' format.
[ 0.107875] Freeing SMP alternatives memory: 48K
[ 0.107877] pid_max: default: 32768 minimum: 301
[ 0.109514] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor
[ 0.109562] landlock: Up and running.
[ 0.109564] Yama: becoming mindful.
[ 0.109692] LSM support for eBPF active
[ 0.109728] AppArmor: AppArmor initialized
[ 0.109760] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.109775] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.213021] smpboot: CPU0: AMD Ryzen AI 9 HX 370 w/ Radeon 890M (family: 0x1a, model: 0x24, stepping: 0x0)
[ 0.213124] Performance Events: Fam17h+ 16-deep LBR, core perfctr, AMD PMU driver.
[ 0.213146] ... version: 2
[ 0.213146] ... bit width: 48
[ 0.213147] ... generic registers: 6
[ 0.213147] ... value mask: 0000ffffffffffff
[ 0.213147] ... max period: 00007fffffffffff
[ 0.213148] ... fixed-purpose events: 0
[ 0.213148] ... event mask: 000000000000003f
[ 0.213219] signal: max sigframe size: 3376
[ 0.213240] rcu: Hierarchical SRCU implementation.
[ 0.213240] rcu: Max phase no-delay instances is 400.
[ 0.213266] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[ 0.213390] MCE: In-kernel MCE decoding enabled.
[ 0.213413] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.213484] smp: Bringing up secondary CPUs ...
[ 0.213524] smpboot: x86: Booting SMP configuration:
[ 0.213525] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15 #16 #17 #18 #19 #20 #21 #22 #23
[ 0.218189] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.219697] smp: Brought up 1 node, 24 CPUs
[ 0.219697] smpboot: Total of 24 processors activated (95813.85 BogoMIPS)
[ 0.220758] Memory: 31855508K/32630636K available (19185K kernel code, 2903K rwdata, 16264K rodata, 4532K init, 4964K bss, 742288K reserved, 0K cma-reserved)
[ 0.221717] devtmpfs: initialized
[ 0.221717] x86/mm: Memory block size: 128MB
[ 0.222774] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a23bfff] (245760 bytes)
[ 0.222774] ACPI: PM: Registering ACPI NVS region [mem 0x6da7f000-0x6fa7efff] (33554432 bytes)
[ 0.222774] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.222778] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.222826] pinctrl core: initialized pinctrl subsystem
[ 0.222911] PM: RTC time: 09:51:10, date: 2025-05-10
[ 0.223119] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.223298] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.223435] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.223760] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.223765] audit: initializing netlink subsys (disabled)
[ 0.223769] audit: type=2000 audit(1746870670.138:1): state=initialized audit_enabled=0 res=1
[ 0.223769] thermal_sys: Registered thermal governor 'fair_share'
[ 0.223769] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.223769] thermal_sys: Registered thermal governor 'step_wise'
[ 0.223769] thermal_sys: Registered thermal governor 'user_space'
[ 0.223769] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.223769] cpuidle: using governor ladder
[ 0.223769] cpuidle: using governor menu
[ 0.223769] Detected 1 PCC Subspaces
[ 0.223769] Registering PCC driver as Mailbox controller
[ 0.223835] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.223835] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[ 0.223835] PCI: Using configuration type 1 for base access
[ 0.223835] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.223835] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.223835] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.223835] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.223835] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.224698] raid6: skipped pq benchmark and selected avx512x4
[ 0.224698] raid6: using avx512x2 recovery algorithm
[ 0.224698] ACPI: Added _OSI(Module Device)
[ 0.224698] ACPI: Added _OSI(Processor Device)
[ 0.224698] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.224698] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.236132] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP5.WLAN._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
[ 0.236138] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240827/psobject-220)
[ 0.236737] ACPI: 27 ACPI AML tables successfully acquired and loaded
[ 0.240820] ACPI: USB4 _OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.240821] ACPI: USB4 _OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.241758] ACPI: EC: EC started
[ 0.241759] ACPI: EC: interrupt blocked
[ 0.241944] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.241945] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC used to handle transactions
[ 0.241946] ACPI: Interpreter enabled
[ 0.241955] ACPI: PM: (supports S0 S4 S5)
[ 0.241956] ACPI: Using IOAPIC for interrupt routing
[ 0.242403] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.242404] PCI: Ignoring E820 reservations for host bridge windows
[ 0.242563] ACPI: Enabled 3 GPEs in block 00 to 1F
[ 0.243629] ACPI: \_SB_.PCI0.GPP0.PWRS: New power resource
[ 0.244090] ACPI: \_SB_.PCI0.GPP0.SWUS.PWRS: New power resource
[ 0.244238] ACPI: \_SB_.PCI0.GPP1.PWRS: New power resource
[ 0.244238] ACPI: \_SB_.PCI0.GPP1.SWUS.PWRS: New power resource
[ 0.244238] ACPI: \_SB_.PCI0.GPP3.P0NV: New power resource
[ 0.244485] ACPI: \_SB_.PCI0.GPP5.PWSR: New power resource
[ 0.244697] ACPI: \_SB_.PCI0.GPP5.WLAN.WRST: New power resource
[ 0.244871] ACPI: \_SB_.PCI0.GPPA.PWRS: New power resource
[ 0.244962] ACPI: \_SB_.PCI0.GPPA.VGA_.PWRS: New power resource
[ 0.245095] ACPI: \_SB_.PCI0.GPPA.ACP_.PWRS: New power resource
[ 0.245280] ACPI: \_SB_.PCI0.GPPA.AZAL.PWRS: New power resource
[ 0.245418] ACPI: \_SB_.PCI0.GPPA.HDAU.PWRS: New power resource
[ 0.245575] ACPI: \_SB_.PCI0.GPPA.XHC1.PWRS: New power resource
[ 0.245995] ACPI: \_SB_.PCI0.GPPC.XHC0.PWRS: New power resource
[ 0.296644] ACPI: \_SB_.DBTP: New power resource
[ 0.296740] ACPI: \_SB_.PCI0.GPPC.XHC0.RHUB.PRT4.BTRT: New power resource
[ 0.297199] ACPI: \_SB_.PCI0.GPPC.XHC3.PWRS: New power resource
[ 0.297672] ACPI: \_SB_.PCI0.GPPC.XHC4.PWRS: New power resource
[ 0.298147] ACPI: \_SB_.PCI0.GPPC.NHI0.PWRS: New power resource
[ 0.298434] ACPI: \_SB_.PCI0.GPPC.NHI1.PWRS: New power resource
[ 0.300724] ACPI: \_TZ_.QFAN: New power resource
[ 0.300963] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.300967] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.301000] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug AER LTR DPC]
[ 0.301052] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME PCIeCapability]
[ 0.301299] PCI host bridge to bus 0000:00
[ 0.301301] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.301302] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.301302] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.301303] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.301303] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[ 0.301304] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.301305] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfcffffff window]
[ 0.301305] pci_bus 0000:00: root bus resource [mem 0x880000000-0x7fffffffff window]
[ 0.301306] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.301318] pci 0000:00:00.0: [1022:1507] type 00 class 0x060000 conventional PCI endpoint
[ 0.301391] pci 0000:00:00.2: [1022:1508] type 00 class 0x080600 conventional PCI endpoint
[ 0.301462] pci 0000:00:01.0: [1022:1509] type 00 class 0x060000 conventional PCI endpoint
[ 0.301518] pci 0000:00:01.1: [1022:150a] type 01 class 0x060400 PCIe Root Port
[ 0.301574] pci 0000:00:01.1: PCI bridge to [bus 01-60]
[ 0.301579] pci 0000:00:01.1: bridge window [io 0xb000-0xefff]
[ 0.301581] pci 0000:00:01.1: bridge window [mem 0xc4000000-0xdbffffff]
[ 0.301600] pci 0000:00:01.1: bridge window [mem 0x5800000000-0x77ffffffff 64bit pref]
[ 0.301615] pci 0000:00:01.1: enabling Extended Tags
[ 0.301771] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.302220] pci 0000:00:02.0: [1022:1509] type 00 class 0x060000 conventional PCI endpoint
[ 0.302268] pci 0000:00:02.1: [1022:150b] type 01 class 0x060400 PCIe Root Port
[ 0.302284] pci 0000:00:02.1: PCI bridge to [bus 61]
[ 0.302289] pci 0000:00:02.1: bridge window [mem 0xdcd00000-0xdcdfffff]
[ 0.302302] pci 0000:00:02.1: enabling Extended Tags
[ 0.302357] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[ 0.302483] pci 0000:00:02.3: [1022:150b] type 01 class 0x060400 PCIe Root Port
[ 0.302499] pci 0000:00:02.3: PCI bridge to [bus 62]
[ 0.302504] pci 0000:00:02.3: bridge window [mem 0xdcc00000-0xdccfffff]
[ 0.302510] pci 0000:00:02.3: bridge window [mem 0xfcf00000-0xfcffffff 64bit pref]
[ 0.302570] pci 0000:00:02.3: PME# supported from D0 D3hot D3cold
[ 0.302688] pci 0000:00:03.0: [1022:1509] type 00 class 0x060000 conventional PCI endpoint
[ 0.302744] pci 0000:00:08.0: [1022:1509] type 00 class 0x060000 conventional PCI endpoint
[ 0.302792] pci 0000:00:08.1: [1022:150c] type 01 class 0x060400 PCIe Root Port
[ 0.302817] pci 0000:00:08.1: PCI bridge to [bus 63]
[ 0.302819] pci 0000:00:08.1: bridge window [io 0xf000-0xffff]
[ 0.302821] pci 0000:00:08.1: bridge window [mem 0xdc000000-0xdc4fffff]
[ 0.302825] pci 0000:00:08.1: bridge window [mem 0x7800000000-0x78107fffff 64bit pref]
[ 0.302830] pci 0000:00:08.1: enabling Extended Tags
[ 0.302862] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.302937] pci 0000:00:08.2: [1022:150c] type 01 class 0x060400 PCIe Root Port
[ 0.302957] pci 0000:00:08.2: PCI bridge to [bus 64]
[ 0.302960] pci 0000:00:08.2: bridge window [mem 0xdca00000-0xdcbfffff]
[ 0.302964] pci 0000:00:08.2: bridge window [mem 0x7810900000-0x78109fffff 64bit pref]
[ 0.302969] pci 0000:00:08.2: enabling Extended Tags
[ 0.303002] pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
[ 0.303068] pci 0000:00:08.3: [1022:150c] type 01 class 0x060400 PCIe Root Port
[ 0.303080] pci 0000:00:08.3: PCI bridge to [bus 65]
[ 0.303083] pci 0000:00:08.3: bridge window [mem 0xdc600000-0xdc9fffff]
[ 0.303092] pci 0000:00:08.3: enabling Extended Tags
[ 0.303125] pci 0000:00:08.3: PME# supported from D0 D3hot D3cold
[ 0.303265] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500 conventional PCI endpoint
[ 0.303337] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100 conventional PCI endpoint
[ 0.303417] pci 0000:00:18.0: [1022:16f8] type 00 class 0x060000 conventional PCI endpoint
[ 0.303435] pci 0000:00:18.1: [1022:16f9] type 00 class 0x060000 conventional PCI endpoint
[ 0.303454] pci 0000:00:18.2: [1022:16fa] type 00 class 0x060000 conventional PCI endpoint
[ 0.303471] pci 0000:00:18.3: [1022:16fb] type 00 class 0x060000 conventional PCI endpoint
[ 0.303490] pci 0000:00:18.4: [1022:16fc] type 00 class 0x060000 conventional PCI endpoint
[ 0.303507] pci 0000:00:18.5: [1022:16fd] type 00 class 0x060000 conventional PCI endpoint
[ 0.303524] pci 0000:00:18.6: [1022:16fe] type 00 class 0x060000 conventional PCI endpoint
[ 0.303542] pci 0000:00:18.7: [1022:16ff] type 00 class 0x060000 conventional PCI endpoint
[ 0.303629] pci 0000:00:01.1: PCI bridge to [bus 01-60]
[ 0.303723] pci 0000:61:00.0: [1344:5413] type 00 class 0x010802 PCIe Endpoint
[ 0.303754] pci 0000:61:00.0: BAR 0 [mem 0xdcd00000-0xdcd03fff 64bit]
[ 0.304040] pci 0000:00:02.1: PCI bridge to [bus 61]
[ 0.304093] pci 0000:62:00.0: [14c3:0616] type 00 class 0x028000 PCIe Endpoint
[ 0.304138] pci 0000:62:00.0: BAR 0 [mem 0xfcf00000-0xfcffffff 64bit pref]
[ 0.304141] pci 0000:62:00.0: BAR 2 [mem 0xdcc00000-0xdcc07fff 64bit]
[ 0.304216] pci 0000:62:00.0: PME# supported from D0 D3hot D3cold
[ 0.304483] pci 0000:00:02.3: PCI bridge to [bus 62]
[ 0.304536] pci 0000:63:00.0: [1002:150e] type 00 class 0x038000 PCIe Legacy Endpoint
[ 0.304564] pci 0000:63:00.0: BAR 0 [mem 0x7800000000-0x780fffffff 64bit pref]
[ 0.304566] pci 0000:63:00.0: BAR 2 [mem 0xdc000000-0xdc1fffff 64bit pref]
[ 0.304567] pci 0000:63:00.0: BAR 4 [io 0xf000-0xf0ff]
[ 0.304568] pci 0000:63:00.0: BAR 5 [mem 0xdc400000-0xdc47ffff]
[ 0.304573] pci 0000:63:00.0: enabling Extended Tags
[ 0.304627] pci 0000:63:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.304734] pci 0000:63:00.1: [1002:1640] type 00 class 0x040300 PCIe Legacy Endpoint
[ 0.304756] pci 0000:63:00.1: BAR 0 [mem 0xdc4c8000-0xdc4cbfff]
[ 0.304764] pci 0000:63:00.1: enabling Extended Tags
[ 0.304795] pci 0000:63:00.1: PME# supported from D1 D2 D3hot D3cold
[ 0.304850] pci 0000:63:00.2: [1022:17e0] type 00 class 0x108000 PCIe Endpoint
[ 0.304912] pci 0000:63:00.2: BAR 2 [mem 0xdc300000-0xdc3fffff]
[ 0.304914] pci 0000:63:00.2: BAR 5 [mem 0xdc4cc000-0xdc4cdfff]
[ 0.304919] pci 0000:63:00.2: enabling Extended Tags
[ 0.305007] pci 0000:63:00.4: [1022:151e] type 00 class 0x0c0330 PCIe Endpoint
[ 0.305031] pci 0000:63:00.4: BAR 0 [mem 0xdc200000-0xdc2fffff 64bit]
[ 0.305038] pci 0000:63:00.4: enabling Extended Tags
[ 0.305072] pci 0000:63:00.4: PME# supported from D0 D3hot D3cold
[ 0.305129] pci 0000:63:00.5: [1022:15e2] type 00 class 0x048000 PCIe Endpoint
[ 0.305151] pci 0000:63:00.5: BAR 0 [mem 0xdc480000-0xdc4bffff]
[ 0.305153] pci 0000:63:00.5: BAR 2 [mem 0x7810000000-0x78107fffff 64bit pref]
[ 0.305159] pci 0000:63:00.5: enabling Extended Tags
[ 0.305190] pci 0000:63:00.5: PME# supported from D0 D3hot D3cold
[ 0.305247] pci 0000:63:00.6: [1022:15e3] type 00 class 0x040300 PCIe Endpoint
[ 0.305269] pci 0000:63:00.6: BAR 0 [mem 0xdc4c0000-0xdc4c7fff]
[ 0.305276] pci 0000:63:00.6: enabling Extended Tags
[ 0.305307] pci 0000:63:00.6: PME# supported from D0 D3hot D3cold
[ 0.305375] pci 0000:00:08.1: PCI bridge to [bus 63]
[ 0.305404] pci 0000:64:00.0: [1022:150d] type 00 class 0x130000 PCIe Endpoint
[ 0.305432] pci 0000:64:00.0: enabling Extended Tags
[ 0.305550] pci 0000:64:00.1: [1022:17f0] type 00 class 0x118000 PCIe Endpoint
[ 0.305576] pci 0000:64:00.1: BAR 0 [mem 0xdca00000-0xdcafffff]
[ 0.305577] pci 0000:64:00.1: BAR 1 [mem 0xdcb00000-0xdcb01fff]
[ 0.305579] pci 0000:64:00.1: BAR 2 [mem 0x7810900000-0x781097ffff 64bit pref]
[ 0.305580] pci 0000:64:00.1: BAR 4 [mem 0xdcb03000-0xdcb03fff]
[ 0.305581] pci 0000:64:00.1: BAR 5 [mem 0xdcb02000-0xdcb02fff]
[ 0.305585] pci 0000:64:00.1: enabling Extended Tags
[ 0.305692] pci 0000:00:08.2: PCI bridge to [bus 64]
[ 0.305730] pci 0000:65:00.0: [1022:151f] type 00 class 0x0c0330 PCIe Endpoint
[ 0.305754] pci 0000:65:00.0: BAR 0 [mem 0xdc800000-0xdc8fffff 64bit]
[ 0.305760] pci 0000:65:00.0: enabling Extended Tags
[ 0.305803] pci 0000:65:00.0: PME# supported from D0 D3hot D3cold
[ 0.305890] pci 0000:65:00.3: [1022:151a] type 00 class 0x0c0330 PCIe Endpoint
[ 0.305914] pci 0000:65:00.3: BAR 0 [mem 0xdc700000-0xdc7fffff 64bit]
[ 0.305920] pci 0000:65:00.3: enabling Extended Tags
[ 0.305954] pci 0000:65:00.3: PME# supported from D0 D3hot D3cold
[ 0.306012] pci 0000:65:00.4: [1022:151b] type 00 class 0x0c0330 PCIe Endpoint
[ 0.306036] pci 0000:65:00.4: BAR 0 [mem 0xdc600000-0xdc6fffff 64bit]
[ 0.306043] pci 0000:65:00.4: enabling Extended Tags
[ 0.306076] pci 0000:65:00.4: PME# supported from D0 D3hot D3cold
[ 0.306135] pci 0000:65:00.5: [1022:151c] type 00 class 0x0c0340 PCIe Endpoint
[ 0.306162] pci 0000:65:00.5: BAR 0 [mem 0xdc900000-0xdc97ffff 64bit]
[ 0.306168] pci 0000:65:00.5: enabling Extended Tags
[ 0.306202] pci 0000:65:00.5: PME# supported from D0 D3hot D3cold
[ 0.306265] pci 0000:00:08.3: PCI bridge to [bus 65]
[ 0.358675] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.358697] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.358715] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.358738] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.358758] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.358775] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.358791] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.358807] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.360247] Low-power S0 idle used by default for system suspend
[ 0.360319] ACPI: EC: interrupt unblocked
[ 0.360320] ACPI: EC: event unblocked
[ 0.360615] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.360615] ACPI: EC: GPE=0x4
[ 0.360615] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC initialization complete
[ 0.360615] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 0.360622] iommu: Default domain type: Translated
[ 0.360622] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.360680] SCSI subsystem initialized
[ 0.360683] libata version 3.00 loaded.
[ 0.360683] ACPI: bus type USB registered
[ 0.360683] usbcore: registered new interface driver usbfs
[ 0.360683] usbcore: registered new interface driver hub
[ 0.360683] usbcore: registered new device driver usb
[ 0.364867] EDAC MC: Ver: 3.0.0
[ 0.364941] efivars: Registered efivars operations
[ 0.365735] NetLabel: Initializing
[ 0.365735] NetLabel: domain hash size = 128
[ 0.365736] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.365742] NetLabel: unlabeled traffic allowed by default
[ 0.365744] mctp: management component transport protocol core
[ 0.365745] NET: Registered PF_MCTP protocol family
[ 0.365751] PCI: Using ACPI for IRQ routing
[ 0.372974] PCI: pci_cache_line_size set to 64 bytes
[ 0.373022] e820: reserve RAM buffer [mem 0x09b7f000-0x0bffffff]
[ 0.373024] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 0.373024] e820: reserve RAM buffer [mem 0x51960018-0x53ffffff]
[ 0.373025] e820: reserve RAM buffer [mem 0x61a34000-0x63ffffff]
[ 0.373025] e820: reserve RAM buffer [mem 0x6414e000-0x67ffffff]
[ 0.373025] e820: reserve RAM buffer [mem 0x6797f000-0x67ffffff]
[ 0.373026] e820: reserve RAM buffer [mem 0x79ff7000-0x7bffffff]
[ 0.373026] e820: reserve RAM buffer [mem 0x79fff000-0x7bffffff]
[ 0.373026] e820: reserve RAM buffer [mem 0x85e180000-0x85fffffff]
[ 0.373654] vgaarb: loaded
[ 0.373663] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.373663] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.375662] clocksource: Switched to clocksource tsc-early
[ 0.375738] VFS: Disk quotas dquot_6.6.0
[ 0.375743] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.375778] AppArmor: AppArmor Filesystem Enabled
[ 0.375797] pnp: PnP ACPI init
[ 0.375914] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.375916] system 00:02: [io 0x040b] has been reserved
[ 0.375916] system 00:02: [io 0x04d6] has been reserved
[ 0.375917] system 00:02: [io 0x0c00-0x0c01] has been reserved
[ 0.375917] system 00:02: [io 0x0c14] has been reserved
[ 0.375918] system 00:02: [io 0x0c50-0x0c51] has been reserved
[ 0.375918] system 00:02: [io 0x0c52] has been reserved
[ 0.375918] system 00:02: [io 0x0c6c] has been reserved
[ 0.375919] system 00:02: [io 0x0c6f] has been reserved
[ 0.375919] system 00:02: [io 0x0cd0-0x0cd1] has been reserved
[ 0.375920] system 00:02: [io 0x0cd2-0x0cd3] has been reserved
[ 0.375920] system 00:02: [io 0x0cd4-0x0cd5] has been reserved
[ 0.375920] system 00:02: [io 0x0cd6-0x0cd7] has been reserved
[ 0.375921] system 00:02: [io 0x0cd8-0x0cdf] has been reserved
[ 0.375921] system 00:02: [io 0x0800-0x089f] has been reserved
[ 0.375922] system 00:02: [io 0x0b00-0x0b0f] has been reserved
[ 0.375922] system 00:02: [io 0x0b20-0x0b3f] has been reserved
[ 0.375922] system 00:02: [io 0x0900-0x090f] has been reserved
[ 0.375923] system 00:02: [io 0x0910-0x091f] has been reserved
[ 0.375924] system 00:02: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.375924] system 00:02: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.375925] system 00:02: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.375926] system 00:02: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.375926] system 00:02: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.375927] system 00:02: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.375928] system 00:02: [mem 0xff000000-0xffffffff] has been reserved
[ 0.376946] system 00:03: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.377216] pnp: PnP ACPI: found 4 devices
[ 0.382752] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.382778] NET: Registered PF_INET protocol family
[ 0.382852] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.389790] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.389801] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.389844] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.389982] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.390020] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.390084] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[ 0.390139] UDP hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[ 0.390206] UDP-Lite hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[ 0.390271] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.390276] NET: Registered PF_XDP protocol family
[ 0.390286] pci 0000:00:01.1: PCI bridge to [bus 01-60]
[ 0.390295] pci 0000:00:01.1: bridge window [io 0xb000-0xefff]
[ 0.390306] pci 0000:00:01.1: bridge window [mem 0xc4000000-0xdbffffff]
[ 0.390329] pci 0000:00:01.1: bridge window [mem 0x5800000000-0x77ffffffff 64bit pref]
[ 0.390333] pci 0000:00:02.1: PCI bridge to [bus 61]
[ 0.390336] pci 0000:00:02.1: bridge window [mem 0xdcd00000-0xdcdfffff]
[ 0.390340] pci 0000:00:02.3: PCI bridge to [bus 62]
[ 0.390343] pci 0000:00:02.3: bridge window [mem 0xdcc00000-0xdccfffff]
[ 0.390345] pci 0000:00:02.3: bridge window [mem 0xfcf00000-0xfcffffff 64bit pref]
[ 0.390349] pci 0000:00:08.1: PCI bridge to [bus 63]
[ 0.390354] pci 0000:00:08.1: bridge window [io 0xf000-0xffff]
[ 0.390356] pci 0000:00:08.1: bridge window [mem 0xdc000000-0xdc4fffff]
[ 0.390357] pci 0000:00:08.1: bridge window [mem 0x7800000000-0x78107fffff 64bit pref]
[ 0.390360] pci 0000:00:08.2: PCI bridge to [bus 64]
[ 0.390361] pci 0000:00:08.2: bridge window [mem 0xdca00000-0xdcbfffff]
[ 0.390363] pci 0000:00:08.2: bridge window [mem 0x7810900000-0x78109fffff 64bit pref]
[ 0.390365] pci 0000:00:08.3: PCI bridge to [bus 65]
[ 0.390367] pci 0000:00:08.3: bridge window [mem 0xdc600000-0xdc9fffff]
[ 0.390371] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.390372] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.390373] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.390373] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.390374] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[ 0.390374] pci_bus 0000:00: resource 9 [mem 0x80000000-0xdfffffff window]
[ 0.390375] pci_bus 0000:00: resource 10 [mem 0xf0000000-0xfcffffff window]
[ 0.390376] pci_bus 0000:00: resource 11 [mem 0x880000000-0x7fffffffff window]
[ 0.390376] pci_bus 0000:01: resource 0 [io 0xb000-0xefff]
[ 0.390377] pci_bus 0000:01: resource 1 [mem 0xc4000000-0xdbffffff]
[ 0.390377] pci_bus 0000:01: resource 2 [mem 0x5800000000-0x77ffffffff 64bit pref]
[ 0.390378] pci_bus 0000:61: resource 1 [mem 0xdcd00000-0xdcdfffff]
[ 0.390379] pci_bus 0000:62: resource 1 [mem 0xdcc00000-0xdccfffff]
[ 0.390379] pci_bus 0000:62: resource 2 [mem 0xfcf00000-0xfcffffff 64bit pref]
[ 0.390380] pci_bus 0000:63: resource 0 [io 0xf000-0xffff]
[ 0.390380] pci_bus 0000:63: resource 1 [mem 0xdc000000-0xdc4fffff]
[ 0.390381] pci_bus 0000:63: resource 2 [mem 0x7800000000-0x78107fffff 64bit pref]
[ 0.390381] pci_bus 0000:64: resource 1 [mem 0xdca00000-0xdcbfffff]
[ 0.390382] pci_bus 0000:64: resource 2 [mem 0x7810900000-0x78109fffff 64bit pref]
[ 0.390382] pci_bus 0000:65: resource 1 [mem 0xdc600000-0xdc9fffff]
[ 0.390519] pci 0000:63:00.1: D0 power state depends on 0000:63:00.0
[ 0.390790] PCI: CLS 64 bytes, default 64
[ 0.390823] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.390861] platform MSFT0201:00: Adding to iommu group 0
[ 0.390862] Trying to unpack rootfs image as initramfs...
[ 0.390962] pci 0000:00:00.0: Adding to iommu group 1
[ 0.390981] pci 0000:00:01.0: Adding to iommu group 2
[ 0.390988] pci 0000:00:01.1: Adding to iommu group 3
[ 0.390998] pci 0000:00:02.0: Adding to iommu group 4
[ 0.391006] pci 0000:00:02.1: Adding to iommu group 5
[ 0.391013] pci 0000:00:02.3: Adding to iommu group 6
[ 0.391020] pci 0000:00:03.0: Adding to iommu group 7
[ 0.391035] pci 0000:00:08.0: Adding to iommu group 8
[ 0.391041] pci 0000:00:08.1: Adding to iommu group 9
[ 0.391047] pci 0000:00:08.2: Adding to iommu group 10
[ 0.391053] pci 0000:00:08.3: Adding to iommu group 11
[ 0.391063] pci 0000:00:14.0: Adding to iommu group 12
[ 0.391068] pci 0000:00:14.3: Adding to iommu group 12
[ 0.391092] pci 0000:00:18.0: Adding to iommu group 13
[ 0.391097] pci 0000:00:18.1: Adding to iommu group 13
[ 0.391103] pci 0000:00:18.2: Adding to iommu group 13
[ 0.391108] pci 0000:00:18.3: Adding to iommu group 13
[ 0.391114] pci 0000:00:18.4: Adding to iommu group 13
[ 0.391120] pci 0000:00:18.5: Adding to iommu group 13
[ 0.391125] pci 0000:00:18.6: Adding to iommu group 13
[ 0.391130] pci 0000:00:18.7: Adding to iommu group 13
[ 0.391142] pci 0000:61:00.0: Adding to iommu group 14
[ 0.391148] pci 0000:62:00.0: Adding to iommu group 15
[ 0.391177] pci 0000:63:00.0: Adding to iommu group 16
[ 0.391183] pci 0000:63:00.1: Adding to iommu group 17
[ 0.391191] pci 0000:63:00.2: Adding to iommu group 18
[ 0.391198] pci 0000:63:00.4: Adding to iommu group 19
[ 0.391205] pci 0000:63:00.5: Adding to iommu group 20
[ 0.391213] pci 0000:63:00.6: Adding to iommu group 21
[ 0.391220] pci 0000:64:00.0: Adding to iommu group 22
[ 0.391229] pci 0000:64:00.1: Adding to iommu group 23
[ 0.391238] pci 0000:65:00.0: Adding to iommu group 24
[ 0.391245] pci 0000:65:00.3: Adding to iommu group 25
[ 0.391252] pci 0000:65:00.4: Adding to iommu group 26
[ 0.391259] pci 0000:65:00.5: Adding to iommu group 27
[ 0.393363] AMD-Vi: Extended features (0x246577efa2254afa, 0x10): PPR NX GT [5] IA GA PC GA_vAPIC
[ 0.393369] AMD-Vi: Interrupt remapping enabled
[ 0.393469] AMD-Vi: Virtual APIC enabled
[ 0.393504] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.393527] software IO TLB: mapped [mem 0x000000005677e000-0x000000005a77e000] (64MB)
[ 0.393556] LVT offset 0 assigned for vector 0x400
[ 0.394475] perf: AMD IBS detected (0x00081bff)
[ 0.394495] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.407591] Initialise system trusted keyrings
[ 0.407600] Key type blacklist registered
[ 0.407633] workingset: timestamp_bits=36 max_order=23 bucket_order=0
[ 0.407776] fuse: init (API version 7.42)
[ 0.407871] integrity: Platform Keyring initialized
[ 0.407872] integrity: Machine keyring initialized
[ 0.412291] xor: automatically using best checksumming function avx
[ 0.412293] Key type asymmetric registered
[ 0.412294] Asymmetric key parser 'x509' registered
[ 0.412305] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.412346] io scheduler mq-deadline registered
[ 0.412347] io scheduler kyber registered
[ 0.412352] io scheduler bfq registered
[ 0.413540] amd_gpio AMDI0030:00: Failed to request GPIO for pin 0x0000, err -16
[ 0.420368] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.420585] pcieport 0000:00:01.1: PME: Signaling with IRQ 32
[ 0.420620] pcieport 0000:00:01.1: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.420940] pcieport 0000:00:02.1: PME: Signaling with IRQ 33
[ 0.421080] pcieport 0000:00:02.3: PME: Signaling with IRQ 34
[ 0.421212] pcieport 0000:00:08.1: PME: Signaling with IRQ 35
[ 0.421376] pcieport 0000:00:08.2: PME: Signaling with IRQ 36
[ 0.421488] pcieport 0000:00:08.3: PME: Signaling with IRQ 37
[ 0.421554] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.422520] ACPI: AC: AC Adapter [ACAD] (on-line)
[ 0.422552] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.422561] ACPI: button: Power Button [PWRB]
[ 0.422572] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.423339] ACPI: button: Lid Switch [LID0]
[ 0.423587] Monitor-Mwait will be used to enter C-1 state
[ 0.425912] Estimated ratio of average max frequency by base frequency (times 1024): 1832
[ 0.426277] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.426278] ACPI: thermal: Thermal Zone [THRM] (26 C)
[ 0.426402] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.426813] ACPI: battery: Slot [BAT1] (battery present)
[ 0.427298] Non-volatile memory driver v1.3
[ 0.427299] Linux agpgart interface v0.103
[ 0.510633] Freeing initrd memory: 46036K
[ 1.397370] tsc: Refined TSC clocksource calibration: 1996.257 MHz
[ 1.397390] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x398cbd36cd9, max_idle_ns: 881590608122 ns
[ 1.397793] clocksource: Switched to clocksource tsc
[ 1.989627] tpm_crb MSFT0101:00: Disabling hwrng
[ 1.990456] ACPI: bus type drm_connector registered
[ 1.993698] xhci_hcd 0000:63:00.4: xHCI Host Controller
[ 1.993706] xhci_hcd 0000:63:00.4: new USB bus registered, assigned bus number 1
[ 1.994147] xhci_hcd 0000:63:00.4: hcc params 0x0118ffc5 hci version 0x120 quirks 0x0000000200000010
[ 1.994500] xhci_hcd 0000:63:00.4: xHCI Host Controller
[ 1.994503] xhci_hcd 0000:63:00.4: new USB bus registered, assigned bus number 2
[ 1.994505] xhci_hcd 0000:63:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.994560] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 1.994563] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.994564] usb usb1: Product: xHCI Host Controller
[ 1.994565] usb usb1: Manufacturer: Linux 6.14.4-1-MANJARO xhci-hcd
[ 1.994567] usb usb1: SerialNumber: 0000:63:00.4
[ 1.994656] hub 1-0:1.0: USB hub found
[ 1.994680] hub 1-0:1.0: 1 port detected
[ 1.994896] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.994915] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[ 1.994917] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.994919] usb usb2: Product: xHCI Host Controller
[ 1.994919] usb usb2: Manufacturer: Linux 6.14.4-1-MANJARO xhci-hcd
[ 1.994920] usb usb2: SerialNumber: 0000:63:00.4
[ 1.994976] hub 2-0:1.0: USB hub found
[ 1.994994] hub 2-0:1.0: 1 port detected
[ 1.995692] xhci_hcd 0000:65:00.0: xHCI Host Controller
[ 1.995696] xhci_hcd 0000:65:00.0: new USB bus registered, assigned bus number 3
[ 1.996136] xhci_hcd 0000:65:00.0: hcc params 0x0128ffc5 hci version 0x120 quirks 0x0000000200000010
[ 1.996396] xhci_hcd 0000:65:00.0: xHCI Host Controller
[ 1.996398] xhci_hcd 0000:65:00.0: new USB bus registered, assigned bus number 4
[ 1.996399] xhci_hcd 0000:65:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.996425] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 1.996427] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.996428] usb usb3: Product: xHCI Host Controller
[ 1.996429] usb usb3: Manufacturer: Linux 6.14.4-1-MANJARO xhci-hcd
[ 1.996430] usb usb3: SerialNumber: 0000:65:00.0
[ 1.996500] hub 3-0:1.0: USB hub found
[ 1.996516] hub 3-0:1.0: 5 ports detected
[ 1.999114] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.999131] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[ 1.999133] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.999134] usb usb4: Product: xHCI Host Controller
[ 1.999135] usb usb4: Manufacturer: Linux 6.14.4-1-MANJARO xhci-hcd
[ 1.999136] usb usb4: SerialNumber: 0000:65:00.0
[ 1.999188] hub 4-0:1.0: USB hub found
[ 1.999206] hub 4-0:1.0: 2 ports detected
[ 2.000338] xhci_hcd 0000:65:00.3: xHCI Host Controller
[ 2.000341] xhci_hcd 0000:65:00.3: new USB bus registered, assigned bus number 5
[ 2.000708] xhci_hcd 0000:65:00.3: hcc params 0x0118ffc5 hci version 0x120 quirks 0x0000000200000010
[ 2.001064] xhci_hcd 0000:65:00.3: xHCI Host Controller
[ 2.001066] xhci_hcd 0000:65:00.3: new USB bus registered, assigned bus number 6
[ 2.001067] xhci_hcd 0000:65:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.001092] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 2.001094] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.001095] usb usb5: Product: xHCI Host Controller
[ 2.001096] usb usb5: Manufacturer: Linux 6.14.4-1-MANJARO xhci-hcd
[ 2.001097] usb usb5: SerialNumber: 0000:65:00.3
[ 2.001149] hub 5-0:1.0: USB hub found
[ 2.001170] hub 5-0:1.0: 1 port detected
[ 2.001754] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.001771] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[ 2.001772] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.001773] usb usb6: Product: xHCI Host Controller
[ 2.001774] usb usb6: Manufacturer: Linux 6.14.4-1-MANJARO xhci-hcd
[ 2.001775] usb usb6: SerialNumber: 0000:65:00.3
[ 2.001824] hub 6-0:1.0: USB hub found
[ 2.001842] hub 6-0:1.0: 1 port detected
[ 2.002609] xhci_hcd 0000:65:00.4: xHCI Host Controller
[ 2.002612] xhci_hcd 0000:65:00.4: new USB bus registered, assigned bus number 7
[ 2.002953] xhci_hcd 0000:65:00.4: hcc params 0x0118ffc5 hci version 0x120 quirks 0x0000000200000010
[ 2.003291] xhci_hcd 0000:65:00.4: xHCI Host Controller
[ 2.003293] xhci_hcd 0000:65:00.4: new USB bus registered, assigned bus number 8
[ 2.003294] xhci_hcd 0000:65:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.003326] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 2.003327] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.003328] usb usb7: Product: xHCI Host Controller
[ 2.003329] usb usb7: Manufacturer: Linux 6.14.4-1-MANJARO xhci-hcd
[ 2.003330] usb usb7: SerialNumber: 0000:65:00.4
[ 2.003380] hub 7-0:1.0: USB hub found
[ 2.003398] hub 7-0:1.0: 1 port detected
[ 2.003969] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.003986] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[ 2.003987] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.003988] usb usb8: Product: xHCI Host Controller
[ 2.003989] usb usb8: Manufacturer: Linux 6.14.4-1-MANJARO xhci-hcd
[ 2.003990] usb usb8: SerialNumber: 0000:65:00.4
[ 2.004038] hub 8-0:1.0: USB hub found
[ 2.004056] hub 8-0:1.0: 1 port detected
[ 2.004793] usbcore: registered new interface driver usbserial_generic
[ 2.004799] usbserial: USB Serial support registered for generic
[ 2.004858] rtc_cmos 00:00: RTC can wake from S4
[ 2.005110] rtc_cmos 00:00: registered as rtc0
[ 2.005145] rtc_cmos 00:00: setting system clock to 2025-05-10T09:51:12 UTC (1746870672)
[ 2.005173] rtc_cmos 00:00: alarms up to one month, y3k, 114 bytes nvram
[ 2.007825] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[ 2.007827] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[ 2.009709] fbcon: Deferring console take-over
[ 2.009711] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 2.009750] hid: raw HID events driver (C) Jiri Kosina
[ 2.009809] drop_monitor: Initializing network drop monitor service
[ 2.009901] NET: Registered PF_INET6 protocol family
[ 2.014719] Segment Routing with IPv6
[ 2.014720] RPL Segment Routing with IPv6
[ 2.014725] In-situ OAM (IOAM) with IPv6
[ 2.014740] NET: Registered PF_PACKET protocol family
[ 2.015970] microcode: Current revision: 0x0b20401b
[ 2.016547] resctrl: L3 allocation detected
[ 2.016548] resctrl: MB allocation detected
[ 2.016549] resctrl: SMBA allocation detected
[ 2.016550] resctrl: L3 monitoring detected
[ 2.016567] IPI shorthand broadcast: enabled
[ 2.017414] sched_clock: Marking stable (2016010140, 1304043)->(2019930528, -2616345)
[ 2.017561] registered taskstats version 1
[ 2.018047] Loading compiled-in X.509 certificates
[ 2.022031] Loaded X.509 cert 'Build time autogenerated kernel key: 3c69816a6d996ccda03a79223cbb51ec68e73707'
[ 2.022898] Demotion targets for Node 0: null
[ 2.023016] Key type .fscrypt registered
[ 2.023017] Key type fscrypt-provisioning registered
[ 2.023357] Btrfs loaded, zoned=yes, fsverity=yes
[ 2.023379] AppArmor: AppArmor sha256 policy hashing enabled
[ 2.023656] PM: Magic number: 9:38:879
[ 2.023724] acpi ITE5570:00: hash matches
[ 2.025800] RAS: Correctable Errors collector initialized.
[ 2.034055] clk: Disabling unused clocks
[ 2.034058] PM: genpd: Disabling unused power domains
[ 2.034664] Freeing unused decrypted memory: 2028K
[ 2.035054] Freeing unused kernel image (initmem) memory: 4532K
[ 2.035063] Write protecting the kernel read-only data: 36864k
[ 2.035344] Freeing unused kernel image (text/rodata gap) memory: 1292K
[ 2.035414] Freeing unused kernel image (rodata/data gap) memory: 120K
[ 2.061582] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 2.061587] rodata_test: all tests were successful
[ 2.061592] Run /init as init process
[ 2.061592] with arguments:
[ 2.061593] /init
[ 2.061594] splash
[ 2.061594] with environment:
[ 2.061595] HOME=/
[ 2.061595] TERM=linux
[ 2.061595] BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
[ 2.146931] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 2.147186] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/LNXVIDEO:00/input/input2
[ 2.148898] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 2.148906] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 2.152167] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.158261] nvme 0000:61:00.0: platform quirk: setting simple suspend
[ 2.158327] nvme nvme0: pci function 0000:61:00.0
[ 2.198367] nvme nvme0: allocated 64 MiB host memory buffer (1 segment).
[ 2.223111] nvme nvme0: 16/0/0 default/read/poll queues
[ 2.231339] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 2.234861] nvme0n1: p1 p2 p3 p4 p5
[ 2.238371] usb 5-1: new full-speed USB device number 2 using xhci_hcd
[ 2.240322] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[ 2.248547] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 2.357362] usb 5-1: device descriptor read/64, error -71
[ 2.361635] usb 1-1: New USB device found, idVendor=3277, idProduct=0060, bcdDevice= 1.01
[ 2.361640] usb 1-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.361643] usb 1-1: Product: USB2.0 FHD UVC WebCam
[ 2.361645] usb 1-1: Manufacturer: Shinetech
[ 2.361646] usb 1-1: SerialNumber: 200901010001
[ 2.379220] usb 3-1: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 0.01
[ 2.379223] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.379224] usb 3-1: Product: USB2.1 Hub
[ 2.379225] usb 3-1: Manufacturer: Generic
[ 2.413441] hub 3-1:1.0: USB hub found
[ 2.415237] hub 3-1:1.0: 4 ports detected
[ 2.482966] usb 4-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 2.506428] usb 4-1: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 0.01
[ 2.506429] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.506430] usb 4-1: Product: USB3.2 Hub
[ 2.506431] usb 4-1: Manufacturer: Generic
[ 2.525320] hub 4-1:1.0: USB hub found
[ 2.526676] hub 4-1:1.0: 4 ports detected
[ 2.580342] usb 5-1: device descriptor read/64, error -71
[ 2.612315] usb 3-4: new high-speed USB device number 3 using xhci_hcd
[ 2.738842] usb 3-4: New USB device found, idVendor=0489, idProduct=e0f5, bcdDevice= 1.00
[ 2.738844] usb 3-4: New USB device strings: Mfr=5, Product=6, SerialNumber=7
[ 2.738845] usb 3-4: Product: Wireless_Device
[ 2.738845] usb 3-4: Manufacturer: MediaTek Inc.
[ 2.738846] usb 3-4: SerialNumber: 000000000
[ 2.797314] usb 5-1: new full-speed USB device number 3 using xhci_hcd
[ 2.810334] usb 3-1.1: new high-speed USB device number 4 using xhci_hcd
[ 2.916341] usb 5-1: device descriptor read/64, error -71
[ 2.929109] usb 3-1.1: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 0.02
[ 2.929114] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.929117] usb 3-1.1: Product: USB2.1 Hub
[ 2.929118] usb 3-1.1: Manufacturer: Generic
[ 2.989147] hub 3-1.1:1.0: USB hub found
[ 2.990359] hub 3-1.1:1.0: 4 ports detected
[ 2.990881] usb 4-1.1: new SuperSpeed USB device number 3 using xhci_hcd
[ 3.013825] usb 4-1.1: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 0.02
[ 3.013829] usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.013831] usb 4-1.1: Product: USB3.2 Hub
[ 3.013833] usb 4-1.1: Manufacturer: Generic
[ 3.069380] hub 4-1.1:1.0: USB hub found
[ 3.070840] hub 4-1.1:1.0: 4 ports detected
[ 3.140346] usb 5-1: device descriptor read/64, error -71
[ 3.145333] usb 3-1.4: new high-speed USB device number 5 using xhci_hcd
[ 3.202421] [drm] amdgpu kernel modesetting enabled.
[ 3.203670] amdgpu: Virtual CRAT table created for CPU
[ 3.203677] amdgpu: Topology: Add CPU node
[ 3.203768] amdgpu 0000:63:00.0: enabling device (0006 -> 0007)
[ 3.203798] [drm] initializing kernel modesetting (IP DISCOVERY 0x1002:0x150E 0x1043:0x38B8 0xC1).
[ 3.203896] [drm] register mmio base: 0xDC400000
[ 3.203897] [drm] register mmio size: 524288
[ 3.206628] amdgpu 0000:63:00.0: amdgpu: detected ip block number 0 <soc21_common>
[ 3.206629] amdgpu 0000:63:00.0: amdgpu: detected ip block number 1 <gmc_v11_0>
[ 3.206631] amdgpu 0000:63:00.0: amdgpu: detected ip block number 2 <ih_v6_1>
[ 3.206631] amdgpu 0000:63:00.0: amdgpu: detected ip block number 3 <psp>
[ 3.206632] amdgpu 0000:63:00.0: amdgpu: detected ip block number 4 <smu>
[ 3.206633] amdgpu 0000:63:00.0: amdgpu: detected ip block number 5 <dm>
[ 3.206634] amdgpu 0000:63:00.0: amdgpu: detected ip block number 6 <gfx_v11_0>
[ 3.206634] amdgpu 0000:63:00.0: amdgpu: detected ip block number 7 <sdma_v6_0>
[ 3.206635] amdgpu 0000:63:00.0: amdgpu: detected ip block number 8 <vcn_v4_0_5>
[ 3.206636] amdgpu 0000:63:00.0: amdgpu: detected ip block number 9 <jpeg_v4_0_5>
[ 3.206636] amdgpu 0000:63:00.0: amdgpu: detected ip block number 10 <mes_v11_0>
[ 3.206637] amdgpu 0000:63:00.0: amdgpu: detected ip block number 11 <vpe_v6_1>
[ 3.206638] amdgpu 0000:63:00.0: amdgpu: detected ip block number 12 <isp_ip>
[ 3.206660] amdgpu 0000:63:00.0: amdgpu: Fetched VBIOS from VFCT
[ 3.206661] amdgpu: ATOM BIOS: 113-STRIXEMU-001
[ 3.211412] amdgpu 0000:63:00.0: amdgpu: VPE: collaborate mode false
[ 3.211422] amdgpu 0000:63:00.0: amdgpu: [drm] Optional firmware "amdgpu/isp_4_1_0.bin" was not found
[ 3.243597] amdgpu 0000:63:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[ 3.243644] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 3.243663] amdgpu 0000:63:00.0: amdgpu: VRAM: 512M 0x0000008000000000 - 0x000000801FFFFFFF (512M used)
[ 3.243664] amdgpu 0000:63:00.0: amdgpu: GART: 512M 0x00007FFF00000000 - 0x00007FFF1FFFFFFF
[ 3.243684] [drm] Detected VRAM RAM=512M, BAR=512M
[ 3.243684] [drm] RAM width 128bits LPDDR5
[ 3.244087] [drm] amdgpu: 512M of VRAM memory ready
[ 3.244088] [drm] amdgpu: 15596M of GTT memory ready.
[ 3.244098] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 3.244452] [drm] PCIE GART of 512M enabled (table at 0x0000008001300000).
[ 3.244849] [drm] Loading DMUB firmware via PSP: version=0x09001B00
[ 3.245063] [drm] Found VCN firmware Version ENC: 1.23 DEC: 9 VEP: 0 Revision: 9
[ 3.245374] usb usb5-port1: attempt power cycle
[ 3.268218] amdgpu 0000:63:00.0: amdgpu: reserve 0x8900000 from 0x8010000000 for PSP TMR
[ 3.476014] amdgpu 0000:63:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 3.479913] amdgpu 0000:63:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 3.479914] amdgpu 0000:63:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[ 3.505952] amdgpu 0000:63:00.0: amdgpu: SMU is initialized successfully!
[ 3.505954] [drm] Seamless boot condition check passed
[ 3.507068] [drm] Display Core v3.2.316 initialized on DCN 3.5
[ 3.507069] [drm] DP-HDMI FRL PCON supported
[ 3.509759] [drm] DMUB hardware initialized: version=0x09001B00
[ 3.601404] [drm] PSR support 1, DC PSR ver 0, sink PSR ver 1 DPCD caps 0x38 su_y_granularity 4
[ 3.624336] usb 5-1: new full-speed USB device number 4 using xhci_hcd
[ 3.624430] usb 5-1: Device not responding to setup address.
[ 3.750364] usb 3-1.4: New USB device found, idVendor=3142, idProduct=0031, bcdDevice= 0.02
[ 3.750369] usb 3-1.4: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 3.750371] usb 3-1.4: Product: FIFINE 683 Microphone
[ 3.750373] usb 3-1.4: Manufacturer: FIFINE 683 Microphone
[ 3.765244] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 3.765251] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[ 3.765876] amdgpu: Virtual CRAT table created for GPU
[ 3.765973] amdgpu: Topology: Add dGPU node [0x150e:0x1002]
[ 3.765974] kfd kfd: amdgpu: added device 1002:150e
[ 3.765983] amdgpu 0000:63:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 8, active_cu_number 16
[ 3.765986] amdgpu 0000:63:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 3.765987] amdgpu 0000:63:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 3.765987] amdgpu 0000:63:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 3.765988] amdgpu 0000:63:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[ 3.765988] amdgpu 0000:63:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[ 3.765988] amdgpu 0000:63:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[ 3.765989] amdgpu 0000:63:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[ 3.765989] amdgpu 0000:63:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[ 3.765989] amdgpu 0000:63:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[ 3.765990] amdgpu 0000:63:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[ 3.765990] amdgpu 0000:63:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[ 3.765991] amdgpu 0000:63:00.0: amdgpu: ring jpeg_dec_0 uses VM inv eng 1 on hub 8
[ 3.765991] amdgpu 0000:63:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
[ 3.765992] amdgpu 0000:63:00.0: amdgpu: ring vpe uses VM inv eng 4 on hub 8
[ 3.766892] [drm] ring gfx_32768.1.1 was added
[ 3.767161] [drm] ring compute_32768.2.2 was added
[ 3.767416] [drm] ring sdma_32768.3.3 was added
[ 3.767436] [drm] ring gfx_32768.1.1 ib test pass
[ 3.767460] [drm] ring compute_32768.2.2 ib test pass
[ 3.767477] [drm] ring sdma_32768.3.3 ib test pass
[ 3.768904] amdgpu 0000:63:00.0: amdgpu: Runtime PM not available
[ 3.769357] amdgpu 0000:63:00.0: [drm] Registered 4 planes with drm panic
[ 3.769358] [drm] Initialized amdgpu 3.61.0 for 0000:63:00.0 on minor 1
[ 3.773551] fbcon: Deferring console take-over
[ 3.773553] amdgpu 0000:63:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 3.829788] usb 5-1: Device not responding to setup address.
[ 4.037693] usb 5-1: device not accepting address 4, error -71
[ 4.037813] usb 5-1: WARN: invalid context state for evaluate context command.
[ 4.149772] usb 5-1: new full-speed USB device number 5 using xhci_hcd
[ 4.149923] usb 5-1: Device not responding to setup address.
[ 4.357867] usb 5-1: Device not responding to setup address.
[ 4.565670] usb 5-1: device not accepting address 5, error -71
[ 4.565780] usb 5-1: WARN: invalid context state for evaluate context command.
[ 4.565828] usb usb5-port1: unable to enumerate USB device
[ 4.641797] [drm] pre_validate_dsc:1601 MST_DSC dsc precompute is not needed
[ 5.778081] EXT4-fs (nvme0n1p4): mounted filesystem a72d381b-e8cb-4965-9e6b-856be8c46f14 r/w with ordered data mode. Quota mode: none.
[ 5.939274] systemd[1]: systemd 257.5-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[ 5.939280] systemd[1]: Detected architecture x86-64.
[ 5.941145] systemd[1]: Hostname set to <lilmighty>.
[ 6.019141] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[ 6.184979] zram: Added device: zram0
[ 6.280592] systemd[1]: Queued start job for default target Graphical Interface.
[ 6.298753] systemd[1]: Created slice CUPS Slice.
[ 6.298983] systemd[1]: Created slice Slice /system/dirmngr.
[ 6.299174] systemd[1]: Created slice Slice /system/getty.
[ 6.299370] systemd[1]: Created slice Slice /system/gpg-agent.
[ 6.299562] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[ 6.299747] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[ 6.299936] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[ 6.300117] systemd[1]: Created slice Slice /system/keyboxd.
[ 6.300390] systemd[1]: Created slice Slice /system/modprobe.
[ 6.300586] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 6.300771] systemd[1]: Created slice Slice /system/systemd-zram-setup.
[ 6.300887] systemd[1]: Created slice User and Session Slice.
[ 6.300913] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.301018] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.301029] systemd[1]: Expecting device /dev/disk/by-uuid/34FC-2D27...
[ 6.301033] systemd[1]: Expecting device /dev/zram0...
[ 6.301041] systemd[1]: Reached target Login Prompts.
[ 6.301047] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 6.301061] systemd[1]: Reached target Remote File Systems.
[ 6.301066] systemd[1]: Reached target Slice Units.
[ 6.301082] systemd[1]: Reached target Local Verity Protected Volumes.
[ 6.301123] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 6.301169] systemd[1]: Listening on LVM2 poll daemon socket.
[ 6.301874] systemd[1]: Listening on Process Core Dump Socket.
[ 6.302334] systemd[1]: Listening on Credential Encryption/Decryption.
[ 6.302383] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.302416] systemd[1]: Listening on Journal Sockets.
[ 6.302445] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 6.302452] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 6.302481] systemd[1]: Listening on udev Control Socket.
[ 6.302508] systemd[1]: Listening on udev Kernel Socket.
[ 6.302531] systemd[1]: Listening on User Database Manager Socket.
[ 6.303268] systemd[1]: Mounting Huge Pages File System...
[ 6.303761] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.304300] systemd[1]: Mounting Kernel Debug File System...
[ 6.304829] systemd[1]: Mounting Kernel Trace File System...
[ 6.305459] systemd[1]: Starting Load AppArmor profiles...
[ 6.307072] systemd[1]: Starting Create List of Static Device Nodes...
[ 6.308066] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 6.308577] systemd[1]: Starting Load Kernel Module configfs...
[ 6.309030] systemd[1]: Starting Load Kernel Module dm_mod...
[ 6.309558] systemd[1]: Starting Load Kernel Module drm...
[ 6.310078] systemd[1]: Starting Load Kernel Module fuse...
[ 6.310690] systemd[1]: Starting Load Kernel Module loop...
[ 6.311254] systemd[1]: Starting Mullvad early boot network blocker...
[ 6.311301] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 6.311342] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[ 6.312442] systemd[1]: Starting Journal Service...
[ 6.313768] systemd[1]: Starting Load Kernel Modules...
[ 6.313782] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 6.314336] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.314372] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 6.314992] systemd[1]: Starting Load udev Rules from Credentials...
[ 6.315909] systemd[1]: Starting Coldplug All udev Devices...
[ 6.317026] systemd[1]: Starting Virtual Console Setup...
[ 6.319136] systemd[1]: Mounted Huge Pages File System.
[ 6.319225] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.319276] systemd[1]: Mounted Kernel Debug File System.
[ 6.319332] systemd[1]: Mounted Kernel Trace File System.
[ 6.319565] systemd[1]: Finished Create List of Static Device Nodes.
[ 6.319809] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 6.319934] systemd[1]: Finished Load Kernel Module configfs.
[ 6.320143] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 6.320248] systemd[1]: Finished Load Kernel Module drm.
[ 6.320397] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 6.320497] systemd[1]: Finished Load Kernel Module fuse.
[ 6.321734] systemd[1]: Mounting FUSE Control File System...
[ 6.322166] device-mapper: uevent: version 1.0.3
[ 6.322167] loop: module loaded
[ 6.322228] device-mapper: ioctl: 4.49.0-ioctl (2025-01-17) initialised: dm-devel@lists.linux.dev
[ 6.322564] systemd[1]: Mounting Kernel Configuration File System...
[ 6.323459] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 6.323721] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 6.323862] systemd[1]: Finished Load Kernel Module dm_mod.
[ 6.324064] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 6.324167] systemd[1]: Finished Load Kernel Module loop.
[ 6.324303] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 6.325652] systemd[1]: Finished Virtual Console Setup.
[ 6.325977] systemd[1]: Mounted FUSE Control File System.
[ 6.327050] systemd[1]: Mounted Kernel Configuration File System.
[ 6.327324] systemd-journald[514]: Collecting audit messages is disabled.
[ 6.330732] systemd[1]: Finished Load udev Rules from Credentials.
[ 6.336444] EXT4-fs (nvme0n1p4): re-mounted a72d381b-e8cb-4965-9e6b-856be8c46f14 r/w. Quota mode: none.
[ 6.337234] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 6.339722] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[ 6.340650] systemd[1]: Starting Load/Save OS Random Seed...
[ 6.340675] systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 6.346823] mc: Linux media interface: v0.10
[ 6.352491] audit: type=1400 audit(1746870676.846:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=541 comm="apparmor_parser"
[ 6.352519] audit: type=1400 audit(1746870676.846:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="foliate" pid=565 comm="apparmor_parser"
[ 6.352544] audit: type=1400 audit(1746870676.846:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="evolution" pid=561 comm="apparmor_parser"
[ 6.352571] audit: type=1400 audit(1746870676.846:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="epiphany" pid=560 comm="apparmor_parser"
[ 6.352612] audit: type=1400 audit(1746870676.846:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=551 comm="apparmor_parser"
[ 6.352649] audit: type=1400 audit(1746870676.846:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=542 comm="apparmor_parser"
[ 6.352680] audit: type=1400 audit(1746870676.846:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="devhelp" pid=558 comm="apparmor_parser"
[ 6.352704] audit: type=1400 audit(1746870676.846:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="vscode" pid=556 comm="apparmor_parser"
[ 6.352740] audit: type=1400 audit(1746870676.846:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=543 comm="apparmor_parser"
[ 6.352777] audit: type=1400 audit(1746870676.846:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="chrome" pid=554 comm="apparmor_parser"
[ 6.357549] systemd[1]: Started Journal Service.
[ 6.359480] videodev: Linux video capture interface: v2.00
[ 6.388093] systemd-journald[514]: Received client request to flush runtime journal.
[ 6.410198] v4l2loopback: loading out-of-tree module taints kernel.
[ 6.410209] v4l2loopback: module verification failed: signature and/or required key missing - tainting kernel
[ 6.413851] v4l2-loopback driver version 0.14.0 loaded
[ 6.616955] zram0: detected capacity change from 0 to 63883264
[ 6.622733] ccp 0000:63:00.2: enabling device (0000 -> 0002)
[ 6.624261] ccp 0000:63:00.2: tee enabled
[ 6.624267] ccp 0000:63:00.2: psp enabled
[ 6.626861] ACPI: bus type thunderbolt registered
[ 6.627025] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 6.629257] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
[ 6.629260] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 6.629260] RAPL PMU: hw unit of domain core 2^-16 Joules
[ 6.650238] amdxdna 0000:64:00.1: enabling device (0000 -> 0002)
[ 6.676391] Bluetooth: Core ver 2.22
[ 6.676411] NET: Registered PF_BLUETOOTH protocol family
[ 6.676412] Bluetooth: HCI device and connection manager initialized
[ 6.676416] Bluetooth: HCI socket layer initialized
[ 6.676418] Bluetooth: L2CAP socket layer initialized
[ 6.676420] Bluetooth: SCO socket layer initialized
[ 6.752504] [drm] Initialized amdxdna_accel_driver 0.0.0 for 0000:64:00.1 on minor 0
[ 6.756652] Adding 31941628k swap on /dev/zram0. Priority:100 extents:1 across:31941628k SSDsc
[ 6.762233] input: ASCP1201:00 093A:3017 Mouse as /devices/platform/AMDI0010:00/i2c-0/i2c-ASCP1201:00/0018:093A:3017.0001/input/input5
[ 6.762273] input: ASCP1201:00 093A:3017 Touchpad as /devices/platform/AMDI0010:00/i2c-0/i2c-ASCP1201:00/0018:093A:3017.0001/input/input6
[ 6.762307] hid-generic 0018:093A:3017.0001: input,hidraw0: I2C HID v1.00 Mouse [ASCP1201:00 093A:3017] on i2c-ASCP1201:00
[ 7.733348] i2c_hid_acpi i2c-ITE5570:00: device did not ack reset within 1000 ms
[ 7.886802] input: ITE5570:00 0B05:5570 Wireless Radio Control as /devices/platform/AMDI0010:01/i2c-1/i2c-ITE5570:00/0018:0B05:5570.0002/input/input7
[ 7.886976] input: ITE5570:00 0B05:5570 as /devices/platform/AMDI0010:01/i2c-1/i2c-ITE5570:00/0018:0B05:5570.0002/input/input8
[ 7.887060] hid-generic 0018:0B05:5570.0002: input,hidraw1: I2C HID v1.00 Device [ITE5570:00 0B05:5570] on i2c-ITE5570:00
[ 7.894044] cryptd: max_cpu_qlen set to 1000
[ 7.896955] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 7.896965] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 7.898413] asus_wmi: ASUS WMI generic driver loaded
[ 7.899442] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 7.900967] amd-tee driver initialization successful
[ 7.902835] AES CTR mode by8 optimization enabled
[ 7.906505] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 7.906619] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 7.906722] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 7.915393] usbcore: registered new interface driver btusb
[ 7.942148] input: ASCP1201:00 093A:3017 Mouse as /devices/platform/AMDI0010:00/i2c-0/i2c-ASCP1201:00/0018:093A:3017.0001/input/input9
[ 7.942270] input: ASCP1201:00 093A:3017 Touchpad as /devices/platform/AMDI0010:00/i2c-0/i2c-ASCP1201:00/0018:093A:3017.0001/input/input10
[ 7.942345] hid-multitouch 0018:093A:3017.0001: input,hidraw0: I2C HID v1.00 Mouse [ASCP1201:00 093A:3017] on i2c-ASCP1201:00
[ 7.969777] No matching power limits found for this system
[ 7.971661] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.971893] usb 1-1: Found UVC 1.10 device USB2.0 FHD UVC WebCam (3277:0060)
[ 7.976046] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.976267] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 7.981293] mousedev: PS/2 mouse device common for all mice
[ 7.981364] usb 1-1: Found UVC 1.50 device USB2.0 FHD UVC WebCam (3277:0060)
[ 7.981542] snd_hda_intel 0000:63:00.1: enabling device (0000 -> 0002)
[ 7.981579] snd_hda_intel 0000:63:00.1: Handle vga_switcheroo audio client
[ 7.981690] snd_hda_intel 0000:63:00.6: enabling device (0000 -> 0002)
[ 7.983580] usbcore: registered new interface driver uvcvideo
[ 7.986283] tee tee0: Direct firmware load for /amdtee/f29bb3d9-bd66-5441-afb88acc2b2b60d6.bin failed with error -2
[ 7.986294] failed to load firmware /amdtee/f29bb3d9-bd66-5441-afb88acc2b2b60d6.bin
[ 7.986297] failed to copy TA binary
[ 7.986298] Failed to open TEE session err:0x0, rc:-12
[ 7.986302] amd-pmf AMDI0103:00: Failed to open TA session (-12)
[ 7.986328] amd-pmf AMDI0103:00: registered PMF device successfully
[ 7.989280] asus_wmi: Initialization: 0x1
[ 7.989376] asus_wmi: SFUN value: 0x21
[ 7.989380] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 7.993794] snd_hda_intel 0000:63:00.1: bound 0000:63:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 7.994281] asus-nb-wmi asus-nb-wmi: Using throttle_thermal_policy for platform_profile support
[ 7.996391] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:63:00.1/sound/card2/input11
[ 7.996548] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:63:00.1/sound/card2/input12
[ 7.996589] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:63:00.1/sound/card2/input13
[ 7.999192] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input14
[ 8.000371] asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
[ 8.000482] snd_acp_pci 0000:63:00.5: enabling device (0000 -> 0002)
[ 8.000714] asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
[ 8.001186] asus_wmi: fan_curve_get_factory_default (0x00110032) failed: -19
[ 8.001588] asus_wmi: using asus-wmi for asus::kbd_backlight
[ 8.006464] ACPI: battery: new hook: ASUS Battery Extension
[ 8.032803] Bluetooth: hci0: HW/SW Version: 0x008a008a, Build Time: 20241106163512
[ 8.064653] snd_hda_codec_realtek hdaudioC3D0: ALC294: picked fixup (pin match)
[ 8.065163] snd_hda_codec_realtek hdaudioC3D0: autoconfig for ALC294: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 8.065169] snd_hda_codec_realtek hdaudioC3D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 8.065171] snd_hda_codec_realtek hdaudioC3D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 8.065173] snd_hda_codec_realtek hdaudioC3D0: mono: mono_out=0x0
[ 8.065175] snd_hda_codec_realtek hdaudioC3D0: inputs:
[ 8.065176] snd_hda_codec_realtek hdaudioC3D0: Internal Mic=0x12
[ 8.065179] snd_hda_codec_realtek hdaudioC3D0: Headset Mic=0x19
[ 8.121099] kvm_amd: TSC scaling supported
[ 8.121104] kvm_amd: Nested Virtualization enabled
[ 8.121104] kvm_amd: Nested Paging enabled
[ 8.121105] kvm_amd: LBR virtualization supported
[ 8.121111] kvm_amd: Virtual VMLOAD VMSAVE supported
[ 8.121111] kvm_amd: Virtual GIF supported
[ 8.121112] kvm_amd: Virtual NMI enabled
[ 8.139572] mt7921e 0000:62:00.0: enabling device (0000 -> 0002)
[ 8.144342] mt7921e 0000:62:00.0: ASIC revision: 79220010
[ 8.183681] amd_atl: AMD Address Translation Library initialized
[ 8.186941] intel_rapl_common: Found RAPL domain package
[ 8.186946] intel_rapl_common: Found RAPL domain core
[ 8.220147] mt7921e 0000:62:00.0: HW/SW Version: 0x8a108a10, Build Time: 20241106163228a
[ 8.221584] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.221591] Bluetooth: BNEP filters: protocol multicast
[ 8.221600] Bluetooth: BNEP socket layer initialized
[ 8.364695] NET: Registered PF_QIPCRTR protocol family
[ 8.596666] mt7921e 0000:62:00.0: WM Firmware Version: ____000000, Build Time: 20241106163310
[ 8.680985] input: HD-Audio Generic Headset Mic as /devices/pci0000:00/0000:00:08.1/0000:63:00.6/sound/card3/input15
[ 8.681036] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:63:00.6/sound/card3/input16
[ 8.716375] Initializing XFRM netlink socket
[ 8.843998] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 9.017301] docker0: port 1(vethdcf9df3) entered blocking state
[ 9.017316] docker0: port 1(vethdcf9df3) entered disabled state
[ 9.017323] vethdcf9df3: entered allmulticast mode
[ 9.017359] vethdcf9df3: entered promiscuous mode
[ 9.022722] eth0: renamed from vethef1d67d
[ 9.023770] docker0: port 1(vethdcf9df3) entered blocking state
[ 9.023777] docker0: port 1(vethdcf9df3) entered forwarding state
[ 9.708289] mt7921e 0000:62:00.0 wlp98s0: renamed from wlan0
[ 10.542291] Bluetooth: hci0: Device setup in 2565206 usecs
[ 10.542303] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[ 10.606963] Bluetooth: hci0: AOSP extensions version v1.00
[ 10.606974] Bluetooth: hci0: AOSP quality report is supported
[ 10.607508] Bluetooth: MGMT ver 1.23
[ 10.615643] NET: Registered PF_ALG protocol family
[ 12.436694] usbcore: registered new interface driver snd-usb-audio
[ 12.831764] wlp98s0: authenticate with 5c:a6:e6:40:28:43 (local address=14:ac:60:bc:29:af)
[ 13.317913] wlp98s0: send auth to 5c:a6:e6:40:28:43 (try 1/3)
[ 13.324146] wlp98s0: authenticated
[ 13.326345] wlp98s0: associate with 5c:a6:e6:40:28:43 (try 1/3)
[ 13.445949] wlp98s0: associate with 5c:a6:e6:40:28:43 (try 2/3)
[ 13.553249] wlp98s0: RX AssocResp from 5c:a6:e6:40:28:43 (capab=0x1411 status=0 aid=3)
[ 13.583822] wlp98s0: associated
[ 13.824692] wlp98s0: Limiting TX power to 26 (26 - 0) dBm as advertised by 5c:a6:e6:40:28:43
[ 13.968483] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 19.607601] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 23.344249] rfkill: input handler disabled
[ 24.175587] input: LogiOps Virtual Input as /devices/virtual/input/input17
[ 25.083224] input: MX Keys Keyboard as /devices/virtual/misc/uhid/0005:046D:B35B.0003/input/input18
[ 25.128873] input: MX Keys Mouse as /devices/virtual/misc/uhid/0005:046D:B35B.0003/input/input19
[ 25.129059] hid-generic 0005:046D:B35B.0003: input,hidraw2: BLUETOOTH HID v0.13 Keyboard [MX Keys] on 14:ac:60:bc:29:b0
[ 25.245312] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 28.309440] Bluetooth: RFCOMM TTY layer initialized
[ 28.309455] Bluetooth: RFCOMM socket layer initialized
[ 28.309457] Bluetooth: RFCOMM ver 1.11
[ 30.872749] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 31.221174] rfkill: input handler enabled
[ 32.127121] rfkill: input handler disabled
[ 32.245867] nvme nvme0: using unchecked data buffer
[ 32.250050] block nvme0n1: No UUID available providing old NGUID
[ 36.513074] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 40.342839] input: MX Master 3 Keyboard as /devices/virtual/misc/uhid/0005:046D:B023.0004/input/input21
[ 40.343423] input: MX Master 3 Mouse as /devices/virtual/misc/uhid/0005:046D:B023.0004/input/input22
[ 40.343830] hid-generic 0005:046D:B023.0004: input,hidraw3: BLUETOOTH HID v0.15 Keyboard [MX Master 3] on 14:ac:60:bc:29:b0
[ 40.351842] usbcore: registered new interface driver usbhid
[ 40.351844] usbhid: USB HID core driver
[ 40.840643] input: Logitech Wireless Mouse MX Master 3 as /devices/virtual/misc/uhid/0005:046D:B023.0004/input/input24
[ 40.841377] logitech-hidpp-device 0005:046D:B023.0004: input,hidraw3: BLUETOOTH HID v0.15 Keyboard [Logitech Wireless Mouse MX Master 3] on 14:ac:60:bc:29:b0
[ 40.858531] logitech-hidpp-device 0005:046D:B023.0004: HID++ 4.5 device connected.
[ 42.137853] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 48.499709] systemd-journald[514]: Time jumped backwards, rotating.
[ 52.885139] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 58.543170] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 64.152066] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 69.788858] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 75.431103] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 81.045129] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 86.164174] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 91.808826] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 96.927444] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 102.069284] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 107.670006] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 112.803918] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 117.925796] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 123.039921] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 128.152723] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 133.272310] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 138.408034] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 143.514935] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 148.642056] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 153.756328] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 158.871938] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 164.027354] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 169.628443] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 174.744208] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 179.870322] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 184.987136] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 190.133306] ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-16)
[ 196.156880] amdgpu 0000:63:00.0: amdgpu: Dumping IP State
[ 196.160729] amdgpu 0000:63:00.0: amdgpu: Dumping IP State Completed
[ 196.160799] amdgpu 0000:63:00.0: amdgpu: ring vcn_unified_0 timeout, signaled seq=20, emitted seq=22
[ 196.160802] amdgpu 0000:63:00.0: amdgpu: Process information: process RDD Process pid 3706 thread firefox:cs0 pid 4370
[ 196.160805] amdgpu 0000:63:00.0: amdgpu: GPU reset begin!
[ 196.742501] amdgpu 0000:63:00.0: amdgpu: MODE2 reset
[ 196.768748] amdgpu 0000:63:00.0: amdgpu: GPU reset succeeded, trying to resume
[ 196.769433] [drm] PCIE GART of 512M enabled (table at 0x0000008001300000).
[ 196.769490] amdgpu 0000:63:00.0: amdgpu: SMU is resuming...
[ 196.775375] amdgpu 0000:63:00.0: amdgpu: SMU is resumed successfully!
[ 196.785148] [drm] DMUB hardware initialized: version=0x09001B00
[ 197.582051] amdgpu 0000:63:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 197.582058] amdgpu 0000:63:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 197.582060] amdgpu 0000:63:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 197.582061] amdgpu 0000:63:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[ 197.582061] amdgpu 0000:63:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[ 197.582062] amdgpu 0000:63:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[ 197.582063] amdgpu 0000:63:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[ 197.582063] amdgpu 0000:63:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[ 197.582064] amdgpu 0000:63:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[ 197.582065] amdgpu 0000:63:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[ 197.582066] amdgpu 0000:63:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[ 197.582067] amdgpu 0000:63:00.0: amdgpu: ring jpeg_dec_0 uses VM inv eng 1 on hub 8
[ 197.582067] amdgpu 0000:63:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 13 on hub 0
[ 197.582068] amdgpu 0000:63:00.0: amdgpu: ring vpe uses VM inv eng 4 on hub 8
[ 197.586288] amdgpu 0000:63:00.0: amdgpu: GPU reset(1) succeeded!
[ 197.587622] ------------[ cut here ]------------
[ 197.587623] WARNING: CPU: 14 PID: 3306 at drivers/gpu/drm/amd/amdgpu/../display/dc/dml2/dml2_translation_helper.c:992 map_dc_state_into_dml_display_cfg+0xc57/0xed0 [amdgpu]
[ 197.587878] Modules linked in: hid_logitech_hidpp usbhid snd_seq_dummy rfcomm snd_hrtimer snd_seq uinput uhid ccm typec_displayport cmac algif_hash algif_skcipher af_alg nf_conntrack_netlink xt_nat iptable_raw xt_tcpudp veth xt_conntrack xt_MASQUERADE bridge stp llc ip6table_nat ip6table_filter ip6_tables xt_set ip_set iptable_nat xt_addrtype iptable_filter xfrm_user xfrm_algo qrtr overlay snd_acp_legacy_mach snd_acp_mach snd_soc_nau8821 snd_acp3x_rn bnep snd_acp70 snd_acp_i2s snd_acp_pdm snd_soc_dmic snd_acp_pcm snd_sof_amd_acp70 snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci intel_rapl_msr snd_sof_xtensa_dsp amd_atl intel_rapl_common snd_sof snd_sof_utils snd_pci_ps snd_soc_acpi_amd_match snd_amd_sdw_acpi mt7921e soundwire_amd mt7921_common soundwire_generic_allocation soundwire_bus mt792x_lib snd_soc_sdca kvm_amd mt76_connac_lib snd_soc_core mt76 snd_compress ac97_bus kvm snd_hda_codec_realtek snd_pcm_dmaengine snd_hda_codec_generic mac80211 snd_ctl_led
[ 197.587905] irqbypass snd_hda_scodec_component snd_rpl_pci_acp6x snd_acp_pci polyval_clmulni snd_hda_codec_hdmi snd_acp_legacy_common polyval_generic asus_nb_wmi mousedev libarc4 snd_hda_intel ghash_clmulni_intel snd_intel_dspcfg snd_pci_acp6x snd_intel_sdw_acpi sha512_ssse3 uvcvideo snd_usb_audio asus_armoury btusb sha256_ssse3 snd_pci_acp5x cfg80211 videobuf2_vmalloc snd_hda_codec btrtl sha1_ssse3 sp5100_tco snd_usbmidi_lib snd_rn_pci_acp3x uvc amd_pmf btintel aesni_intel firmware_attributes_class snd_ump videobuf2_memops snd_acp_config amdtee btbcm crypto_simd snd_hda_core asus_wmi ucsi_acpi i2c_piix4 snd_rawmidi videobuf2_v4l2 vfat amd_sfh snd_soc_acpi hid_multitouch btmtk cryptd joydev typec_ucsi sparse_keymap fat hid_generic bluetooth videobuf2_common snd_seq_device rapl rfkill amdxdna wmi_bmof pcspkr typec thunderbolt ccp roles i2c_smbus k10temp snd_pci_acp3x snd_hwdep i2c_hid_acpi platform_profile amd_pmc tee i2c_hid mac_hid nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_masq nft_ct
[ 197.587932] nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 v4l2loopback(OE) snd_aloop snd_pcm nf_tables snd_timer snd soundcore videodev mc sg crypto_user loop dm_mod nfnetlink zram 842_decompress 842_compress lz4hc_compress lz4_compress ip_tables x_tables amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec serio_raw gpu_sched atkbd drm_suballoc_helper libps2 drm_panel_backlight_quirks drm_buddy vivaldi_fmap nvme drm_display_helper nvme_core i8042 cec video nvme_auth serio wmi
[ 197.587951] CPU: 14 UID: 0 PID: 3306 Comm: kworker/u97:5 Tainted: G OE 6.14.4-1-MANJARO #1 bff2b83f48a42fd4027b46cc5f07d71aa3ee8e78
[ 197.587954] Tainted: [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 197.587955] Hardware name: ASUSTeK COMPUTER INC. ASUS Vivobook S 15 M5506WA_M5506WA/M5506WA, BIOS M5506WA.313 03/19/2025
[ 197.587956] Workqueue: events_unbound commit_work
[ 197.587962] RIP: 0010:map_dc_state_into_dml_display_cfg+0xc57/0xed0 [amdgpu]
[ 197.588131] Code: 8b 7c 24 48 83 44 24 6c 01 48 83 44 24 58 08 8b 44 24 6c 39 47 38 0f 8f a3 fa ff ff 4c 89 f0 4d 89 fe 49 89 c7 e9 a7 f9 ff ff <0f> 0b e9 81 fd ff ff 89 44 24 2c 89 44 24 50 e9 1c fb ff ff 83 f8
[ 197.588133] RSP: 0018:ffffb01be45b3780 EFLAGS: 00010246
[ 197.588134] RAX: ffff8d10648c60f8 RBX: ffffb01be41b29b0 RCX: 0000000000000000
[ 197.588135] RDX: 0000000000000006 RSI: ffffffffc0a9a9b0 RDI: ffff8d10648c7248
[ 197.588136] RBP: ffffb01be45b3830 R08: ffffb01be41b29b0 R09: ffff8d0f767c0000
[ 197.588136] R10: ffffb01be45b3780 R11: 0000000000000000 R12: ffff8d0f3f189800
[ 197.588137] R13: ffffb01be41a9000 R14: ffffb01be41b29b0 R15: ffff8d10648c0000
[ 197.588138] FS: 0000000000000000(0000) GS:ffff8d15fe500000(0000) knlGS:0000000000000000
[ 197.588139] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 197.588139] CR2: 00007f011d1ed040 CR3: 000000017c622000 CR4: 0000000000f50ef0
[ 197.588140] PKRU: 55555554
[ 197.588141] Call Trace:
[ 197.588145] <TASK>
[ 197.588150] dml_mode_support_wrapper+0x11b/0x990 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.588302] call_dml_mode_support_and_programming+0x67/0x700 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.588436] dml2_validate+0x182/0x690 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.588570] ? dc_state_add_plane+0x17d/0x260 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.588727] dcn35_validate_bandwidth+0x35/0x80 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.588952] update_planes_and_stream_state+0x263/0x4e0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.589130] update_planes_and_stream_v2+0x240/0x590 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.589288] dc_update_planes_and_stream+0x5a/0xf0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.589436] amdgpu_dm_atomic_commit_tail+0x1595/0x3be0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.589630] ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.589751] ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x15d/0x390
[ 197.589755] ? dma_fence_default_wait+0x8b/0x250
[ 197.589757] ? __wait_for_common+0x177/0x1c0
[ 197.589760] ? __pfx_schedule_timeout+0x10/0x10
[ 197.589762] ? dma_fence_wait_timeout+0x108/0x130
[ 197.589765] commit_tail+0x91/0x130
[ 197.589767] process_one_work+0x17b/0x330
[ 197.589770] worker_thread+0x2ce/0x3f0
[ 197.589771] ? __pfx_worker_thread+0x10/0x10
[ 197.589772] kthread+0xec/0x230
[ 197.589774] ? __pfx_kthread+0x10/0x10
[ 197.589775] ret_from_fork+0x31/0x50
[ 197.589777] ? __pfx_kthread+0x10/0x10
[ 197.589778] ret_from_fork_asm+0x1a/0x30
[ 197.589781] </TASK>
[ 197.589782] ---[ end trace 0000000000000000 ]---
[ 197.589815] ------------[ cut here ]------------
[ 197.589816] WARNING: CPU: 14 PID: 3306 at drivers/gpu/drm/amd/amdgpu/../display/dc/dml2/dml2_dc_resource_mgmt.c:664 dml2_map_dc_pipes+0x52d/0x1c00 [amdgpu]
[ 197.589988] Modules linked in: hid_logitech_hidpp usbhid snd_seq_dummy rfcomm snd_hrtimer snd_seq uinput uhid ccm typec_displayport cmac algif_hash algif_skcipher af_alg nf_conntrack_netlink xt_nat iptable_raw xt_tcpudp veth xt_conntrack xt_MASQUERADE bridge stp llc ip6table_nat ip6table_filter ip6_tables xt_set ip_set iptable_nat xt_addrtype iptable_filter xfrm_user xfrm_algo qrtr overlay snd_acp_legacy_mach snd_acp_mach snd_soc_nau8821 snd_acp3x_rn bnep snd_acp70 snd_acp_i2s snd_acp_pdm snd_soc_dmic snd_acp_pcm snd_sof_amd_acp70 snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci intel_rapl_msr snd_sof_xtensa_dsp amd_atl intel_rapl_common snd_sof snd_sof_utils snd_pci_ps snd_soc_acpi_amd_match snd_amd_sdw_acpi mt7921e soundwire_amd mt7921_common soundwire_generic_allocation soundwire_bus mt792x_lib snd_soc_sdca kvm_amd mt76_connac_lib snd_soc_core mt76 snd_compress ac97_bus kvm snd_hda_codec_realtek snd_pcm_dmaengine snd_hda_codec_generic mac80211 snd_ctl_led
[ 197.590005] irqbypass snd_hda_scodec_component snd_rpl_pci_acp6x snd_acp_pci polyval_clmulni snd_hda_codec_hdmi snd_acp_legacy_common polyval_generic asus_nb_wmi mousedev libarc4 snd_hda_intel ghash_clmulni_intel snd_intel_dspcfg snd_pci_acp6x snd_intel_sdw_acpi sha512_ssse3 uvcvideo snd_usb_audio asus_armoury btusb sha256_ssse3 snd_pci_acp5x cfg80211 videobuf2_vmalloc snd_hda_codec btrtl sha1_ssse3 sp5100_tco snd_usbmidi_lib snd_rn_pci_acp3x uvc amd_pmf btintel aesni_intel firmware_attributes_class snd_ump videobuf2_memops snd_acp_config amdtee btbcm crypto_simd snd_hda_core asus_wmi ucsi_acpi i2c_piix4 snd_rawmidi videobuf2_v4l2 vfat amd_sfh snd_soc_acpi hid_multitouch btmtk cryptd joydev typec_ucsi sparse_keymap fat hid_generic bluetooth videobuf2_common snd_seq_device rapl rfkill amdxdna wmi_bmof pcspkr typec thunderbolt ccp roles i2c_smbus k10temp snd_pci_acp3x snd_hwdep i2c_hid_acpi platform_profile amd_pmc tee i2c_hid mac_hid nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_masq nft_ct
[ 197.590023] nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 v4l2loopback(OE) snd_aloop snd_pcm nf_tables snd_timer snd soundcore videodev mc sg crypto_user loop dm_mod nfnetlink zram 842_decompress 842_compress lz4hc_compress lz4_compress ip_tables x_tables amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec serio_raw gpu_sched atkbd drm_suballoc_helper libps2 drm_panel_backlight_quirks drm_buddy vivaldi_fmap nvme drm_display_helper nvme_core i8042 cec video nvme_auth serio wmi
[ 197.590034] CPU: 14 UID: 0 PID: 3306 Comm: kworker/u97:5 Tainted: G W OE 6.14.4-1-MANJARO #1 bff2b83f48a42fd4027b46cc5f07d71aa3ee8e78
[ 197.590036] Tainted: [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 197.590037] Hardware name: ASUSTeK COMPUTER INC. ASUS Vivobook S 15 M5506WA_M5506WA/M5506WA, BIOS M5506WA.313 03/19/2025
[ 197.590037] Workqueue: events_unbound commit_work
[ 197.590039] RIP: 0010:dml2_map_dc_pipes+0x52d/0x1c00 [amdgpu]
[ 197.590211] Code: 44 24 78 3b 84 24 ac 00 00 00 0f 84 89 03 00 00 41 83 c5 01 48 81 c3 b8 0f 00 00 45 39 ec 75 a2 48 8b 5c 24 68 44 8b 44 24 18 <0f> 0b 48 c7 44 24 18 00 00 00 00 45 31 ed 4c 89 7c 24 68 c7 84 24
[ 197.590212] RSP: 0018:ffffb01be45b36a0 EFLAGS: 00010246
[ 197.590213] RAX: 0000000000000000 RBX: ffff8d10648c02a8 RCX: ffff8d10648c0060
[ 197.590214] RDX: 0000000000000000 RSI: 0000000000010000 RDI: 0000000000000001
[ 197.590215] RBP: ffffb01be45b38f0 R08: 0000000000000001 R09: ffffb01be45b374c
[ 197.590215] R10: ffff8d0f7d880000 R11: 0000000000000001 R12: 0000000000000004
[ 197.590216] R13: 0000000000000004 R14: ffffb01be41a9000 R15: ffff8d10648c0000
[ 197.590216] FS: 0000000000000000(0000) GS:ffff8d15fe500000(0000) knlGS:0000000000000000
[ 197.590217] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 197.590218] CR2: 00007f011d1ed040 CR3: 000000017c622000 CR4: 0000000000f50ef0
[ 197.590218] PKRU: 55555554
[ 197.590219] Call Trace:
[ 197.590220] <TASK>
[ 197.590222] dml2_validate+0x5ee/0x690 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.590373] dcn35_validate_bandwidth+0x35/0x80 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.590557] update_planes_and_stream_state+0x263/0x4e0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.590712] update_planes_and_stream_v2+0x240/0x590 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.590876] dc_update_planes_and_stream+0x5a/0xf0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.591028] amdgpu_dm_atomic_commit_tail+0x1595/0x3be0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.591217] ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.591337] ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x15d/0x390
[ 197.591339] ? dma_fence_default_wait+0x8b/0x250
[ 197.591341] ? __wait_for_common+0x177/0x1c0
[ 197.591342] ? __pfx_schedule_timeout+0x10/0x10
[ 197.591344] ? dma_fence_wait_timeout+0x108/0x130
[ 197.591346] commit_tail+0x91/0x130
[ 197.591348] process_one_work+0x17b/0x330
[ 197.591349] worker_thread+0x2ce/0x3f0
[ 197.591350] ? __pfx_worker_thread+0x10/0x10
[ 197.591351] kthread+0xec/0x230
[ 197.591352] ? __pfx_kthread+0x10/0x10
[ 197.591353] ret_from_fork+0x31/0x50
[ 197.591355] ? __pfx_kthread+0x10/0x10
[ 197.591356] ret_from_fork_asm+0x1a/0x30
[ 197.591358] </TASK>
[ 197.591358] ---[ end trace 0000000000000000 ]---
[ 197.591369] ------------[ cut here ]------------
[ 197.591370] WARNING: CPU: 14 PID: 3306 at drivers/gpu/drm/amd/amdgpu/../display/dc/dml2/dml2_dc_resource_mgmt.c:1141 dml2_map_dc_pipes+0xfb6/0x1c00 [amdgpu]
[ 197.591543] Modules linked in: hid_logitech_hidpp usbhid snd_seq_dummy rfcomm snd_hrtimer snd_seq uinput uhid ccm typec_displayport cmac algif_hash algif_skcipher af_alg nf_conntrack_netlink xt_nat iptable_raw xt_tcpudp veth xt_conntrack xt_MASQUERADE bridge stp llc ip6table_nat ip6table_filter ip6_tables xt_set ip_set iptable_nat xt_addrtype iptable_filter xfrm_user xfrm_algo qrtr overlay snd_acp_legacy_mach snd_acp_mach snd_soc_nau8821 snd_acp3x_rn bnep snd_acp70 snd_acp_i2s snd_acp_pdm snd_soc_dmic snd_acp_pcm snd_sof_amd_acp70 snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci intel_rapl_msr snd_sof_xtensa_dsp amd_atl intel_rapl_common snd_sof snd_sof_utils snd_pci_ps snd_soc_acpi_amd_match snd_amd_sdw_acpi mt7921e soundwire_amd mt7921_common soundwire_generic_allocation soundwire_bus mt792x_lib snd_soc_sdca kvm_amd mt76_connac_lib snd_soc_core mt76 snd_compress ac97_bus kvm snd_hda_codec_realtek snd_pcm_dmaengine snd_hda_codec_generic mac80211 snd_ctl_led
[ 197.591560] irqbypass snd_hda_scodec_component snd_rpl_pci_acp6x snd_acp_pci polyval_clmulni snd_hda_codec_hdmi snd_acp_legacy_common polyval_generic asus_nb_wmi mousedev libarc4 snd_hda_intel ghash_clmulni_intel snd_intel_dspcfg snd_pci_acp6x snd_intel_sdw_acpi sha512_ssse3 uvcvideo snd_usb_audio asus_armoury btusb sha256_ssse3 snd_pci_acp5x cfg80211 videobuf2_vmalloc snd_hda_codec btrtl sha1_ssse3 sp5100_tco snd_usbmidi_lib snd_rn_pci_acp3x uvc amd_pmf btintel aesni_intel firmware_attributes_class snd_ump videobuf2_memops snd_acp_config amdtee btbcm crypto_simd snd_hda_core asus_wmi ucsi_acpi i2c_piix4 snd_rawmidi videobuf2_v4l2 vfat amd_sfh snd_soc_acpi hid_multitouch btmtk cryptd joydev typec_ucsi sparse_keymap fat hid_generic bluetooth videobuf2_common snd_seq_device rapl rfkill amdxdna wmi_bmof pcspkr typec thunderbolt ccp roles i2c_smbus k10temp snd_pci_acp3x snd_hwdep i2c_hid_acpi platform_profile amd_pmc tee i2c_hid mac_hid nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_masq nft_ct
[ 197.591577] nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 v4l2loopback(OE) snd_aloop snd_pcm nf_tables snd_timer snd soundcore videodev mc sg crypto_user loop dm_mod nfnetlink zram 842_decompress 842_compress lz4hc_compress lz4_compress ip_tables x_tables amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec serio_raw gpu_sched atkbd drm_suballoc_helper libps2 drm_panel_backlight_quirks drm_buddy vivaldi_fmap nvme drm_display_helper nvme_core i8042 cec video nvme_auth serio wmi
[ 197.591588] CPU: 14 UID: 0 PID: 3306 Comm: kworker/u97:5 Tainted: G W OE 6.14.4-1-MANJARO #1 bff2b83f48a42fd4027b46cc5f07d71aa3ee8e78
[ 197.591589] Tainted: [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 197.591590] Hardware name: ASUSTeK COMPUTER INC. ASUS Vivobook S 15 M5506WA_M5506WA/M5506WA, BIOS M5506WA.313 03/19/2025
[ 197.591590] Workqueue: events_unbound commit_work
[ 197.591592] RIP: 0010:dml2_map_dc_pipes+0xfb6/0x1c00 [amdgpu]
[ 197.591745] Code: 84 c0 0f 84 9e 04 00 00 8b 44 24 44 c7 44 24 48 02 00 00 00 c7 84 24 b0 01 00 00 02 00 00 00 8d 14 00 85 d2 0f 85 f1 f3 ff ff <0f> 0b e9 ea f3 ff ff 49 8b 97 08 49 00 00 31 c0 4c 8d 84 24 b0 00
[ 197.591745] RSP: 0018:ffffb01be45b36a0 EFLAGS: 00010246
[ 197.591746] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000001
[ 197.591747] RDX: 0000000000000000 RSI: ffffb01be41b35d0 RDI: ffff8d0ecde08000
[ 197.591747] RBP: ffffb01be45b38f0 R08: 0000000000000000 R09: ffffb01be45b3740
[ 197.591748] R10: ffff8d0f7d880000 R11: 0000000000000001 R12: 0000000000000000
[ 197.591748] R13: 0000000000000000 R14: ffffb01be41a9000 R15: ffff8d10648c0000
[ 197.591749] FS: 0000000000000000(0000) GS:ffff8d15fe500000(0000) knlGS:0000000000000000
[ 197.591750] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 197.591750] CR2: 00007f011d1ed040 CR3: 000000017c622000 CR4: 0000000000f50ef0
[ 197.591751] PKRU: 55555554
[ 197.591751] Call Trace:
[ 197.591752] <TASK>
[ 197.591754] dml2_validate+0x5ee/0x690 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.591906] dcn35_validate_bandwidth+0x35/0x80 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.592117] update_planes_and_stream_state+0x263/0x4e0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.592303] update_planes_and_stream_v2+0x240/0x590 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.592485] dc_update_planes_and_stream+0x5a/0xf0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.592659] amdgpu_dm_atomic_commit_tail+0x1595/0x3be0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.592878] ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.593053] ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x15d/0x390
[ 197.593055] ? dma_fence_default_wait+0x8b/0x250
[ 197.593056] ? __wait_for_common+0x177/0x1c0
[ 197.593058] ? __pfx_schedule_timeout+0x10/0x10
[ 197.593059] ? dma_fence_wait_timeout+0x108/0x130
[ 197.593061] commit_tail+0x91/0x130
[ 197.593063] process_one_work+0x17b/0x330
[ 197.593064] worker_thread+0x2ce/0x3f0
[ 197.593065] ? __pfx_worker_thread+0x10/0x10
[ 197.593066] kthread+0xec/0x230
[ 197.593067] ? __pfx_kthread+0x10/0x10
[ 197.593068] ret_from_fork+0x31/0x50
[ 197.593070] ? __pfx_kthread+0x10/0x10
[ 197.593071] ret_from_fork_asm+0x1a/0x30
[ 197.593073] </TASK>
[ 197.593073] ---[ end trace 0000000000000000 ]---
[ 197.593086] ------------[ cut here ]------------
[ 197.593086] WARNING: CPU: 14 PID: 3306 at drivers/gpu/drm/amd/amdgpu/../display/dc/dml2/dml_display_rq_dlg_calc.c:505 dml_rq_dlg_get_dlg_reg+0x1423/0x1470 [amdgpu]
[ 197.593262] Modules linked in: hid_logitech_hidpp usbhid snd_seq_dummy rfcomm snd_hrtimer snd_seq uinput uhid ccm typec_displayport cmac algif_hash algif_skcipher af_alg nf_conntrack_netlink xt_nat iptable_raw xt_tcpudp veth xt_conntrack xt_MASQUERADE bridge stp llc ip6table_nat ip6table_filter ip6_tables xt_set ip_set iptable_nat xt_addrtype iptable_filter xfrm_user xfrm_algo qrtr overlay snd_acp_legacy_mach snd_acp_mach snd_soc_nau8821 snd_acp3x_rn bnep snd_acp70 snd_acp_i2s snd_acp_pdm snd_soc_dmic snd_acp_pcm snd_sof_amd_acp70 snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci intel_rapl_msr snd_sof_xtensa_dsp amd_atl intel_rapl_common snd_sof snd_sof_utils snd_pci_ps snd_soc_acpi_amd_match snd_amd_sdw_acpi mt7921e soundwire_amd mt7921_common soundwire_generic_allocation soundwire_bus mt792x_lib snd_soc_sdca kvm_amd mt76_connac_lib snd_soc_core mt76 snd_compress ac97_bus kvm snd_hda_codec_realtek snd_pcm_dmaengine snd_hda_codec_generic mac80211 snd_ctl_led
[ 197.593280] irqbypass snd_hda_scodec_component snd_rpl_pci_acp6x snd_acp_pci polyval_clmulni snd_hda_codec_hdmi snd_acp_legacy_common polyval_generic asus_nb_wmi mousedev libarc4 snd_hda_intel ghash_clmulni_intel snd_intel_dspcfg snd_pci_acp6x snd_intel_sdw_acpi sha512_ssse3 uvcvideo snd_usb_audio asus_armoury btusb sha256_ssse3 snd_pci_acp5x cfg80211 videobuf2_vmalloc snd_hda_codec btrtl sha1_ssse3 sp5100_tco snd_usbmidi_lib snd_rn_pci_acp3x uvc amd_pmf btintel aesni_intel firmware_attributes_class snd_ump videobuf2_memops snd_acp_config amdtee btbcm crypto_simd snd_hda_core asus_wmi ucsi_acpi i2c_piix4 snd_rawmidi videobuf2_v4l2 vfat amd_sfh snd_soc_acpi hid_multitouch btmtk cryptd joydev typec_ucsi sparse_keymap fat hid_generic bluetooth videobuf2_common snd_seq_device rapl rfkill amdxdna wmi_bmof pcspkr typec thunderbolt ccp roles i2c_smbus k10temp snd_pci_acp3x snd_hwdep i2c_hid_acpi platform_profile amd_pmc tee i2c_hid mac_hid nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_masq nft_ct
[ 197.593297] nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 v4l2loopback(OE) snd_aloop snd_pcm nf_tables snd_timer snd soundcore videodev mc sg crypto_user loop dm_mod nfnetlink zram 842_decompress 842_compress lz4hc_compress lz4_compress ip_tables x_tables amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec serio_raw gpu_sched atkbd drm_suballoc_helper libps2 drm_panel_backlight_quirks drm_buddy vivaldi_fmap nvme drm_display_helper nvme_core i8042 cec video nvme_auth serio wmi
[ 197.593307] CPU: 14 UID: 0 PID: 3306 Comm: kworker/u97:5 Tainted: G W OE 6.14.4-1-MANJARO #1 bff2b83f48a42fd4027b46cc5f07d71aa3ee8e78
[ 197.593309] Tainted: [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 197.593309] Hardware name: ASUSTeK COMPUTER INC. ASUS Vivobook S 15 M5506WA_M5506WA/M5506WA, BIOS M5506WA.313 03/19/2025
[ 197.593310] Workqueue: events_unbound commit_work
[ 197.593312] RIP: 0010:dml_rq_dlg_get_dlg_reg+0x1423/0x1470 [amdgpu]
[ 197.593458] Code: 0f 0b e9 34 ed ff ff 0f 0b e9 65 f9 ff ff 0f 0b e9 cd f9 ff ff 0f 0b e9 ea f9 ff ff 0f 0b e9 0a fa ff ff 0f 0b e9 26 fa ff ff <0f> 0b e9 2e f7 ff ff 0f 0b e9 44 f7 ff ff 0f 0b e9 5a f7 ff ff 0f
[ 197.593459] RSP: 0018:ffffb01be45b3720 EFLAGS: 00010203
[ 197.593459] RAX: 0000000000000000 RBX: ffffb01be41b843c RCX: 0000000000000000
[ 197.593460] RDX: 0000000000000008 RSI: 0000000000000000 RDI: 000000000000000d
[ 197.593460] RBP: ffffb01be45b3840 R08: 0000000000000048 R09: 0000000000000b40
[ 197.593461] R10: 0000000000000000 R11: ffff8d0ec1c60000 R12: ffffb01be41a96d0
[ 197.593461] R13: 0000000000000000 R14: ffffb01be41b84f4 R15: 0000000000000000
[ 197.593462] FS: 0000000000000000(0000) GS:ffff8d15fe500000(0000) knlGS:0000000000000000
[ 197.593463] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 197.593463] CR2: 00007f011d1ed040 CR3: 000000017c622000 CR4: 0000000000f50ef0
[ 197.593464] PKRU: 55555554
[ 197.593464] Call Trace:
[ 197.593465] <TASK>
[ 197.593466] ? dml2_calculate_rq_and_dlg_params+0x4af/0x5c0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.593610] dml2_calculate_rq_and_dlg_params+0x4af/0x5c0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.593752] dml2_validate+0x666/0x690 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.593910] dcn35_validate_bandwidth+0x35/0x80 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.594096] update_planes_and_stream_state+0x263/0x4e0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.594256] update_planes_and_stream_v2+0x240/0x590 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.594406] dc_update_planes_and_stream+0x5a/0xf0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.594560] amdgpu_dm_atomic_commit_tail+0x1595/0x3be0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.594748] ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.594880] ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x15d/0x390
[ 197.594882] ? dma_fence_default_wait+0x8b/0x250
[ 197.594883] ? __wait_for_common+0x177/0x1c0
[ 197.594885] ? __pfx_schedule_timeout+0x10/0x10
[ 197.594886] ? dma_fence_wait_timeout+0x108/0x130
[ 197.594888] commit_tail+0x91/0x130
[ 197.594890] process_one_work+0x17b/0x330
[ 197.594891] worker_thread+0x2ce/0x3f0
[ 197.594892] ? __pfx_worker_thread+0x10/0x10
[ 197.594893] kthread+0xec/0x230
[ 197.594894] ? __pfx_kthread+0x10/0x10
[ 197.594895] ret_from_fork+0x31/0x50
[ 197.594897] ? __pfx_kthread+0x10/0x10
[ 197.594898] ret_from_fork_asm+0x1a/0x30
[ 197.594900] </TASK>
[ 197.594900] ---[ end trace 0000000000000000 ]---
[ 197.594911] ------------[ cut here ]------------
[ 197.594911] WARNING: CPU: 14 PID: 3306 at drivers/gpu/drm/amd/amdgpu/../display/dc/dml2/dml_display_rq_dlg_calc.c:552 dml_rq_dlg_get_dlg_reg+0x1407/0x1470 [amdgpu]
[ 197.595071] Modules linked in: hid_logitech_hidpp usbhid snd_seq_dummy rfcomm snd_hrtimer snd_seq uinput uhid ccm typec_displayport cmac algif_hash algif_skcipher af_alg nf_conntrack_netlink xt_nat iptable_raw xt_tcpudp veth xt_conntrack xt_MASQUERADE bridge stp llc ip6table_nat ip6table_filter ip6_tables xt_set ip_set iptable_nat xt_addrtype iptable_filter xfrm_user xfrm_algo qrtr overlay snd_acp_legacy_mach snd_acp_mach snd_soc_nau8821 snd_acp3x_rn bnep snd_acp70 snd_acp_i2s snd_acp_pdm snd_soc_dmic snd_acp_pcm snd_sof_amd_acp70 snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci intel_rapl_msr snd_sof_xtensa_dsp amd_atl intel_rapl_common snd_sof snd_sof_utils snd_pci_ps snd_soc_acpi_amd_match snd_amd_sdw_acpi mt7921e soundwire_amd mt7921_common soundwire_generic_allocation soundwire_bus mt792x_lib snd_soc_sdca kvm_amd mt76_connac_lib snd_soc_core mt76 snd_compress ac97_bus kvm snd_hda_codec_realtek snd_pcm_dmaengine snd_hda_codec_generic mac80211 snd_ctl_led
[ 197.595088] irqbypass snd_hda_scodec_component snd_rpl_pci_acp6x snd_acp_pci polyval_clmulni snd_hda_codec_hdmi snd_acp_legacy_common polyval_generic asus_nb_wmi mousedev libarc4 snd_hda_intel ghash_clmulni_intel snd_intel_dspcfg snd_pci_acp6x snd_intel_sdw_acpi sha512_ssse3 uvcvideo snd_usb_audio asus_armoury btusb sha256_ssse3 snd_pci_acp5x cfg80211 videobuf2_vmalloc snd_hda_codec btrtl sha1_ssse3 sp5100_tco snd_usbmidi_lib snd_rn_pci_acp3x uvc amd_pmf btintel aesni_intel firmware_attributes_class snd_ump videobuf2_memops snd_acp_config amdtee btbcm crypto_simd snd_hda_core asus_wmi ucsi_acpi i2c_piix4 snd_rawmidi videobuf2_v4l2 vfat amd_sfh snd_soc_acpi hid_multitouch btmtk cryptd joydev typec_ucsi sparse_keymap fat hid_generic bluetooth videobuf2_common snd_seq_device rapl rfkill amdxdna wmi_bmof pcspkr typec thunderbolt ccp roles i2c_smbus k10temp snd_pci_acp3x snd_hwdep i2c_hid_acpi platform_profile amd_pmc tee i2c_hid mac_hid nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_masq nft_ct
[ 197.595105] nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 v4l2loopback(OE) snd_aloop snd_pcm nf_tables snd_timer snd soundcore videodev mc sg crypto_user loop dm_mod nfnetlink zram 842_decompress 842_compress lz4hc_compress lz4_compress ip_tables x_tables amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec serio_raw gpu_sched atkbd drm_suballoc_helper libps2 drm_panel_backlight_quirks drm_buddy vivaldi_fmap nvme drm_display_helper nvme_core i8042 cec video nvme_auth serio wmi
[ 197.595116] CPU: 14 UID: 0 PID: 3306 Comm: kworker/u97:5 Tainted: G W OE 6.14.4-1-MANJARO #1 bff2b83f48a42fd4027b46cc5f07d71aa3ee8e78
[ 197.595117] Tainted: [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 197.595118] Hardware name: ASUSTeK COMPUTER INC. ASUS Vivobook S 15 M5506WA_M5506WA/M5506WA, BIOS M5506WA.313 03/19/2025
[ 197.595118] Workqueue: events_unbound commit_work
[ 197.595120] RIP: 0010:dml_rq_dlg_get_dlg_reg+0x1407/0x1470 [amdgpu]
[ 197.595268] Code: 0f 0b e9 89 fa ff ff 0f 0b e9 a6 fa ff ff 0f 0b e9 55 ed ff ff 0f 0b e9 95 ed ff ff 0f 0b e9 34 ed ff ff 0f 0b e9 65 f9 ff ff <0f> 0b e9 cd f9 ff ff 0f 0b e9 ea f9 ff ff 0f 0b e9 0a fa ff ff 0f
[ 197.595269] RSP: 0018:ffffb01be45b3720 EFLAGS: 00010a06
[ 197.595270] RAX: 0000000000002000 RBX: ffffb01be41b843c RCX: 0000000000000000
[ 197.595270] RDX: 0000000000000008 RSI: 0000000000000000 RDI: 000000000000000d
[ 197.595271] RBP: ffffb01be45b3840 R08: 0000000000000048 R09: 0000000000000b40
[ 197.595271] R10: 0000000000000000 R11: ffff8d0ec1c60000 R12: 0000000080000000
[ 197.595272] R13: 0000000000000000 R14: ffffb01be41b84f4 R15: 0000000000000000
[ 197.595272] FS: 0000000000000000(0000) GS:ffff8d15fe500000(0000) knlGS:0000000000000000
[ 197.595273] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 197.595273] CR2: 00007f011d1ed040 CR3: 000000017c622000 CR4: 0000000000f50ef0
[ 197.595274] PKRU: 55555554
[ 197.595274] Call Trace:
[ 197.595275] <TASK>
[ 197.595276] ? dml2_calculate_rq_and_dlg_params+0x4af/0x5c0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.595423] dml2_calculate_rq_and_dlg_params+0x4af/0x5c0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.595566] dml2_validate+0x666/0x690 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.595710] dcn35_validate_bandwidth+0x35/0x80 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.595900] update_planes_and_stream_state+0x263/0x4e0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.596052] update_planes_and_stream_v2+0x240/0x590 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.596210] dc_update_planes_and_stream+0x5a/0xf0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.596353] amdgpu_dm_atomic_commit_tail+0x1595/0x3be0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.596538] ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.596657] ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x15d/0x390
[ 197.596659] ? dma_fence_default_wait+0x8b/0x250
[ 197.596661] ? __wait_for_common+0x177/0x1c0
[ 197.596662] ? __pfx_schedule_timeout+0x10/0x10
[ 197.596663] ? dma_fence_wait_timeout+0x108/0x130
[ 197.596665] commit_tail+0x91/0x130
[ 197.596667] process_one_work+0x17b/0x330
[ 197.596668] worker_thread+0x2ce/0x3f0
[ 197.596669] ? __pfx_worker_thread+0x10/0x10
[ 197.596670] kthread+0xec/0x230
[ 197.596671] ? __pfx_kthread+0x10/0x10
[ 197.596673] ret_from_fork+0x31/0x50
[ 197.596674] ? __pfx_kthread+0x10/0x10
[ 197.596675] ret_from_fork_asm+0x1a/0x30
[ 197.596677] </TASK>
[ 197.596677] ---[ end trace 0000000000000000 ]---
[ 197.596824] ------------[ cut here ]------------
[ 197.596824] WARNING: CPU: 14 PID: 3306 at drivers/gpu/drm/amd/amdgpu/../display/dc/core/dc.c:3953 commit_planes_for_stream+0x1417/0x1600 [amdgpu]
[ 197.596984] Modules linked in: hid_logitech_hidpp usbhid snd_seq_dummy rfcomm snd_hrtimer snd_seq uinput uhid ccm typec_displayport cmac algif_hash algif_skcipher af_alg nf_conntrack_netlink xt_nat iptable_raw xt_tcpudp veth xt_conntrack xt_MASQUERADE bridge stp llc ip6table_nat ip6table_filter ip6_tables xt_set ip_set iptable_nat xt_addrtype iptable_filter xfrm_user xfrm_algo qrtr overlay snd_acp_legacy_mach snd_acp_mach snd_soc_nau8821 snd_acp3x_rn bnep snd_acp70 snd_acp_i2s snd_acp_pdm snd_soc_dmic snd_acp_pcm snd_sof_amd_acp70 snd_sof_amd_acp63 snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir snd_sof_amd_acp snd_sof_pci intel_rapl_msr snd_sof_xtensa_dsp amd_atl intel_rapl_common snd_sof snd_sof_utils snd_pci_ps snd_soc_acpi_amd_match snd_amd_sdw_acpi mt7921e soundwire_amd mt7921_common soundwire_generic_allocation soundwire_bus mt792x_lib snd_soc_sdca kvm_amd mt76_connac_lib snd_soc_core mt76 snd_compress ac97_bus kvm snd_hda_codec_realtek snd_pcm_dmaengine snd_hda_codec_generic mac80211 snd_ctl_led
[ 197.597001] irqbypass snd_hda_scodec_component snd_rpl_pci_acp6x snd_acp_pci polyval_clmulni snd_hda_codec_hdmi snd_acp_legacy_common polyval_generic asus_nb_wmi mousedev libarc4 snd_hda_intel ghash_clmulni_intel snd_intel_dspcfg snd_pci_acp6x snd_intel_sdw_acpi sha512_ssse3 uvcvideo snd_usb_audio asus_armoury btusb sha256_ssse3 snd_pci_acp5x cfg80211 videobuf2_vmalloc snd_hda_codec btrtl sha1_ssse3 sp5100_tco snd_usbmidi_lib snd_rn_pci_acp3x uvc amd_pmf btintel aesni_intel firmware_attributes_class snd_ump videobuf2_memops snd_acp_config amdtee btbcm crypto_simd snd_hda_core asus_wmi ucsi_acpi i2c_piix4 snd_rawmidi videobuf2_v4l2 vfat amd_sfh snd_soc_acpi hid_multitouch btmtk cryptd joydev typec_ucsi sparse_keymap fat hid_generic bluetooth videobuf2_common snd_seq_device rapl rfkill amdxdna wmi_bmof pcspkr typec thunderbolt ccp roles i2c_smbus k10temp snd_pci_acp3x snd_hwdep i2c_hid_acpi platform_profile amd_pmc tee i2c_hid mac_hid nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_masq nft_ct
[ 197.597018] nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 v4l2loopback(OE) snd_aloop snd_pcm nf_tables snd_timer snd soundcore videodev mc sg crypto_user loop dm_mod nfnetlink zram 842_decompress 842_compress lz4hc_compress lz4_compress ip_tables x_tables amdgpu amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec serio_raw gpu_sched atkbd drm_suballoc_helper libps2 drm_panel_backlight_quirks drm_buddy vivaldi_fmap nvme drm_display_helper nvme_core i8042 cec video nvme_auth serio wmi
[ 197.597029] CPU: 14 UID: 0 PID: 3306 Comm: kworker/u97:5 Tainted: G W OE 6.14.4-1-MANJARO #1 bff2b83f48a42fd4027b46cc5f07d71aa3ee8e78
[ 197.597030] Tainted: [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 197.597031] Hardware name: ASUSTeK COMPUTER INC. ASUS Vivobook S 15 M5506WA_M5506WA/M5506WA, BIOS M5506WA.313 03/19/2025
[ 197.597031] Workqueue: events_unbound commit_work
[ 197.597033] RIP: 0010:commit_planes_for_stream+0x1417/0x1600 [amdgpu]
[ 197.597175] Code: 48 8b b5 90 05 00 00 48 89 ef e8 64 f4 00 00 e9 33 ed ff ff 48 c7 c2 30 91 08 c1 31 f6 48 89 ef e8 ce e5 ff ff e9 75 fc ff ff <0f> 0b 48 8b 85 98 05 00 00 8b 80 a8 02 00 00 85 c0 0f 84 aa 01 00
[ 197.597175] RSP: 0018:ffffb01be45b3990 EFLAGS: 00010246
[ 197.597176] RAX: 0000000000000000 RBX: ffff8d10648c0000 RCX: 0000000000000006
[ 197.597177] RDX: ffff8d10648c6100 RSI: ffff8d0ecde08000 RDI: ffff8d10648c02a8
[ 197.597177] RBP: ffff8d0edcc00000 R08: ffffb01be45b394c R09: 0000000000000004
[ 197.597178] R10: 000000000003e078 R11: 0000000000000001 R12: 0000000000000001
[ 197.597178] R13: ffff8d10648c4188 R14: 0000000000000004 R15: 0000000000000002
[ 197.597179] FS: 0000000000000000(0000) GS:ffff8d15fe500000(0000) knlGS:0000000000000000
[ 197.597179] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 197.597180] CR2: 00007f011d1ed040 CR3: 000000017c622000 CR4: 0000000000f50ef0
[ 197.597181] PKRU: 55555554
[ 197.597181] Call Trace:
[ 197.597182] <TASK>
[ 197.597183] update_planes_and_stream_v2+0x2ad/0x590 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.597327] dc_update_planes_and_stream+0x5a/0xf0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.597468] amdgpu_dm_atomic_commit_tail+0x1595/0x3be0 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.597654] ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu a6e73617c56a4196aa7176db5fbbfb8df704e09c]
[ 197.597773] ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0x15d/0x390
[ 197.597775] ? dma_fence_default_wait+0x8b/0x250
[ 197.597776] ? __wait_for_common+0x177/0x1c0
[ 197.597778] ? __pfx_schedule_timeout+0x10/0x10
[ 197.597779] ? dma_fence_wait_timeout+0x108/0x130
[ 197.597781] commit_tail+0x91/0x130
[ 197.597783] process_one_work+0x17b/0x330
[ 197.597784] worker_thread+0x2ce/0x3f0
[ 197.597785] ? __pfx_worker_thread+0x10/0x10
[ 197.597785] kthread+0xec/0x230
[ 197.597787] ? __pfx_kthread+0x10/0x10
[ 197.597788] ret_from_fork+0x31/0x50
[ 197.597789] ? __pfx_kthread+0x10/0x10
[ 197.597790] ret_from_fork_asm+0x1a/0x30
[ 197.597792] </TASK>
[ 197.597793] ---[ end trace 0000000000000000 ]---
[ 197.599054] show_signal_msg: 154 callbacks suppressed
[ 197.599059] firefox:cs0[4370]: segfault at 0 ip 00006351bdca5fe7 sp 000075f1401fea50 error 6 in firefox[85fe7,6351bdc42000+96000] likely on CPU 10 (core 14, socket 0)
[ 197.599071] Code: 35 3e 41 03 00 49 8b 36 ff 15 fd 41 03 00 49 8b 36 bf 0a 00 00 00 ff 15 6f 42 03 00 48 89 1d 70 7c 03 00 31 c0 b9 23 00 00 00 <48> 89 08 e8 00 00 00 00 f3 0f 1e fa 50 48 8d 3d 83 73 f8 ff e8 b0
[ 207.932953] amdgpu 0000:63:00.0: [drm] *ERROR* [CRTC:83:crtc-1] flip_done timed out
[ 238.141654] amdgpu 0000:63:00.0: [drm] *ERROR* flip_done timed out
[ 238.141673] amdgpu 0000:63:00.0: [drm] *ERROR* [CRTC:83:crtc-1] commit wait timed out
[ 248.381473] amdgpu 0000:63:00.0: [drm] *ERROR* flip_done timed out
[ 248.381486] amdgpu 0000:63:00.0: [drm] *ERROR* [PLANE:52:plane-2] commit wait timed out
[ 248.382111] [drm:dc_state_remove_stream [amdgpu]] *ERROR* Pipe not found for stream 0000000080d77caa !
[ 248.382649] amdgpu 0000:63:00.0: [drm] dc_validate_with_context:resource validation failed, dc_status:-1
