ASUS TUF GAMING FX504GM-E4353 temps with nvidia prime
My laptop ASUS TUF GAMING FX504GM-E4353 heats while using sudo set-nvidia.sh, if sudo set-intel.sh - works fine like in Windows 10. how to fix this issue? help please
Outputs:
[n7ce77@7nice77-pc ~]$ mhwd -li
> Installed PCI configs:
         network-r8168            2016.04.20                true            PCI
          video-nvidia            2018.08.09               false            PCI
[n7ce77@7nice77-pc ~]$ mhwd-kernel -li
Currently running: 4.19.59-1-MANJARO (linux419)
   * linux419
[n7ce77@7nice77-pc ~]$ pacman -Qs | grep -Ei "-headers|-nvidia|xrandr|dkms"
    Access control list utilities, libraries and headers
local/acpi_call-dkms 1.1.0-230
local/dkms 2.7.1-1
local/lib32-libxrandr 1.5.2-1
local/lib32-nvidia-utils 1:430.26-1
    The CUPS Printing System - client libraries and headers
local/libxrandr 1.5.2-1
local/linux-api-headers 5.1-1
    Kernel headers sanitized for use in userspace
local/linux419-headers 4.19.59-1
local/linux419-nvidia 1:430.26-9 (linux419-extramodules)
local/mhwd-nvidia 1:430.26-1
local/mhwd-nvidia-340xx 340.107-1
local/mhwd-nvidia-390xx 390.116-1
local/xorg-xrandr 1.5.0-2 (xorg-apps xorg)
    combined X.Org X11 Protocol headers
[n7ce77@7nice77-pc ~]$ ls -laR /etc/X11 ; cat /etc/X11/xorg.conf.d/*.conf
/etc/X11:
total 32
drwxr-xr-x  5 root root 4096 мар 12 12:16 .
drwxr-xr-x 95 root root 4096 июл 19 23:35 ..
drwxr-xr-x  2 root root 4096 июл 19 23:35 mhwd.d
drwxr-xr-x  3 root root 4096 мар 12 12:16 xinit
drwxr-xr-x  2 root root 4096 июл 19 23:35 xorg.conf.d
/etc/X11/mhwd.d:
total 16
drwxr-xr-x 2 root root 4096 июл 19 23:35 .
drwxr-xr-x 5 root root 4096 мар 12 12:16 ..
-rw-r--r-- 1 root root 1617 июл 19 23:35 99-nvidia.conf
/etc/X11/xinit:
total 28
drwxr-xr-x 3 root root 4096 мар 12 12:16 .
-rw-r--r-- 1 root root  739 мар  4 22:31 xinitrc
drwxr-xr-x 2 root root 4096 июл 19 02:31 xinitrc.d
-rw-r--r-- 1 root root   45 мар  4 22:31 xserverrc
/etc/X11/xinit/xinitrc.d:
total 20
drwxr-xr-x 2 root root 4096 июл 19 02:31 .
drwxr-xr-x 3 root root 4096 мар 12 12:16 ..
-rwxr-xr-x 1 root root  318 ноя 10  2018 40-libcanberra-gtk-module.sh
-rwxr-xr-x 1 root root  203 июл 18 00:21 50-systemd-user.sh
/etc/X11/xorg.conf.d:
total 20
-rw-r--r-- 1 root root  266 июл 19 02:05 00-keyboard.conf
-rw-r--r-- 1 root root  481 июл 19 23:35 99-nvidia.conf
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
        Identifier "system-keyboard"
        MatchIsKeyboard "on"
        Option "XkbLayout" "us"
        Option "XkbModel" "pc105"
EndSection
#/etc/switch/nvidia/99-nvidia.conf
#adjust BusID to match your nvidia GPU
#uncomment and edit the DPI option as needed
#to fix scaling issues.
Section "Module"
    Load "modesetting"
EndSection
Section "Device"
    Identifier "nvidia"
    Driver  "nvidia"
    BusID   "PCI:1:0:0"
    #Option  "DPI" "96 x 96"    #adjust this value as needed to fix scaling
    Option  "AllowEmptyInitialConfiguration"
EndSection
Section "Extensions"
    Option  "Composite" "Enable"
EndSection
[n7ce77@7nice77-pc ~]$ cat /etc/modprobe.d/*.conf ; cat /etc/modules-load.d/*.conf
#necessary blacklist and
#nvidia_drm modeset for nvidia/prime
blacklist nouveau
blacklist nvidiafb
blacklist rivafb
options nvidia_drm modeset=1
blacklist r8169
##loads necessary modules for nvidia gpu
nvidia
nvidia-drm
# List of modules to load at boot
[n7ce77@7nice77-pc ~]$ inxi -Fxxxz
  Host: 7nice77-pc Kernel: 4.19.59-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 9.1.0 Desktop: Xfce 4.13.5git-58bf69 tk: Gtk 3.24.10 info: xfce4-panel
  wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: TUF GAMING FX504GM_FX80GM v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: FX504GM v: 1.0 serial: <filter>
  UEFI: American Megatrends v: FX504GM.306 date: 11/30/2018
  ID-1: BAT1 charge: 47.2 Wh condition: 47.2/48.1 Wh (98%) volts: 4.0/11.7
  model: ASUS A32-K55 type: Li-ion serial: <filter> status: Full
  Topology: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
  arch: Kaby Lake rev: A L2 cache: 8192 KiB
  bogomips: 36872
  Speed: 1755 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 1701 2: 1701
  3: 1701 4: 1700 5: 1700 6: 1701 7: 1701 8: 1703
  Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: ASUSTeK
  driver: nvidia v: 430.26 bus ID: 01:00.0 chip ID: 10de:1c20
  Display: x11 server: X.Org 1.20.5 driver: modesetting,nvidia
  resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 1060/PCIe/SSE2 v: 4.6.0 NVIDIA 430.26
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 00:1f.3 chip ID: 8086:a348
  Sound Server: ALSA v: k4.19.59-1-MANJARO
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
  v: kernel port: 6000 bus ID: 00:14.3 chip ID: 8086:a370
  vendor: ASUSTeK driver: r8168 v: 8.047.02-NAPI port: 3000 bus ID: 03:00.0
  chip ID: 10ec:8168
  Local Storage: total: 1.14 TiB used: 9.10 GiB (0.8%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3256GJ
  size: 238.47 GiB speed: 15.8 Gb/s lanes: 2 serial: <filter> rev: E8FK11.C
  scheme: GPT
  ID-2: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
  speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0J scheme: GPT
  ID-1: / size: 25.83 GiB used: 7.98 GiB (30.9%) fs: ext4
  dev: /dev/nvme0n1p6
  ID-2: /home size: 90.72 GiB used: 1.12 GiB (1.2%) fs: ext4
  dev: /dev/nvme0n1p7
  System Temperatures: cpu: 61.0 C mobo: 27.8 C gpu: nvidia temp: 59 C
  Fan Speeds (RPM): cpu: 0
  Processes: 244 Uptime: 2m Memory: 7.65 GiB used: 1.04 GiB (13.6%)
  Init: systemd v: 242 Compilers: gcc: 9.1.0 Shell: bash v: 5.0.7
  running in: xfce4-terminal inxi: 3.0.34
i edited the title, probably better if you look at it as "i have higher than normal temperatures when using nvidia prime" because thats really what it is. optimus-switch is a tool that sets an nvidia prime mode or intel only mode.
@help.2019e also, the outputs i was referring to were these (from nvidia mode)
@dglt Did.
Outputs #2:
[n7ce77@7nice77-pc ~]$ sudo sensors-detect
[sudo] password for n7ce77:
# sensors-detect revision $Revision$
# System: ASUSTeK COMPUTER INC. TUF GAMING FX504GM_FX80GM [1.0] (laptop)
# Board: ASUSTeK COMPUTER INC. FX504GM
# Kernel: 4.19.59-1-MANJARO x86_64
# Processor: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz (6/158/10)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no):
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595...                       No
VIA VT82C686 Integrated Sensors...                          No
VIA VT8231 Integrated Sensors...                            No
AMD K8 thermal sensors...                                   No
AMD Family 10h thermal sensors...                           No
AMD Family 11h thermal sensors...                           No
AMD Family 12h and 14h thermal sensors...                   No
AMD Family 15h thermal sensors...                           No
AMD Family 16h thermal sensors...                           No
AMD Family 17h thermal sensors...                           No
AMD Family 15h power sensors...                             No
AMD Family 16h power sensors...                             No
Intel digital thermal sensor...                             Success!
    (driver `coretemp')
Intel AMB FB-DIMM thermal sensor...                         No
Intel 5500/5520/X58 thermal sensor...                       No
VIA C7 thermal sensor...                                    No
VIA Nano thermal sensor...                                  No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no):
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor/ITE'...               Yes
Found unknown chip with ID 0x8987
Probing for Super-I/O at 0x4e/0x4f
Trying family `National Semiconductor/ITE'...               No
Trying family `SMSC'...                                     No
Trying family `VIA/Winbond/Nuvoton/Fintek'...               No
Trying family `ITE'...                                      No
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no):
Probing for `National Semiconductor LM78' at 0x290...       No
Probing for `National Semiconductor LM79' at 0x290...       No
Probing for `Winbond W83781D' at 0x290...                   No
Probing for `Winbond W83782D' at 0x290...                   No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no):
Using driver `i2c-i801' for device 0000:00:1f.4: Cannon Lake-H (PCH)
Module i2c-dev loaded successfully.
Next adapter: SMBus I801 adapter at efa0 (i2c-0)
Do you want to scan it? (YES/no/selectively):
Client found at address 0x50
Probing for `Analog Devices ADM1033'...                     No
Probing for `Analog Devices ADM1034'...                     No
Probing for `SPD EEPROM'...                                 Yes
    (confidence 8, not a hardware monitoring chip)
Probing for `EDID EEPROM'...                                No
Next adapter: Synopsys DesignWare I2C adapter (i2c-1)
Adapter doesn't support all probing functions.
Some addresses won't be probed.
Next adapter: i915 gmbus dpb (i2c-2)
Do you want to scan it? (yes/NO/selectively):
Next adapter: i915 gmbus dpc (i2c-3)
Next adapter: i915 gmbus misc (i2c-4)
Next adapter: i915 gmbus dpd (i2c-5)
Next adapter: NVIDIA i2c adapter 1 at 1:00.0 (i2c-6)
Next adapter: NVIDIA i2c adapter 2 at 1:00.0 (i2c-7)
Next adapter: NVIDIA i2c adapter 6 at 1:00.0 (i2c-8)
Next adapter: DPDDC-A (i2c-9)
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `coretemp':
  * Chip `Intel digital thermal sensor' (confidence: 9)
Do you want to overwrite /etc/conf.d/lm_sensors? (YES/no):
Unloading i2c-dev... OK
Unloading cpuid... OK
[n7ce77@7nice77-pc ~]$ sensors
iwlwifi-virtual-0
Adapter: Virtual device
temp1:        +54.0°C
asus-isa-0000
Adapter: ISA adapter
cpu_fan:        0 RPM
acpitz-acpi-0
Adapter: ACPI interface
temp1:        +51.0°C  (crit = +99.0°C)
temp2:        +27.8°C  (crit = +119.0°C)
coretemp-isa-0000
Package id 0:  +53.0°C  (high = +100.0°C, crit = +100.0°C)
Core 0:        +53.0°C  (high = +100.0°C, crit = +100.0°C)
Core 1:        +50.0°C  (high = +100.0°C, crit = +100.0°C)
Core 2:        +50.0°C  (high = +100.0°C, crit = +100.0°C)
Core 3:        +51.0°C  (high = +100.0°C, crit = +100.0°C)
pch_cannonlake-virtual-0
temp1:        +63.0°C
[n7ce77@7nice77-pc ~]$ nvidia-smi
Fri Jul 19 23:49:37 2019
| NVIDIA-SMI 430.26       Driver Version: 430.26       CUDA Version: 10.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 1060    Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   58C    P0    25W /  N/A |    140MiB /  3019MiB |      0%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0       664      G   /usr/lib/Xorg                                135MiB |
|    0       969      G   xfwm4                                          2MiB |
[n7ce77@7nice77-pc ~]$ journalctl -k | grep -Ei 'osi|windows|nvidia|thermal|temp|range|failed|error'
июл 19 23:35:18 7nice77-pc kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=5eb30e5b-281e-4dc0-8bcd-173cd41d7904 rw acpi_osi=Linux nouveau.modeset=0
июл 19 23:35:18 7nice77-pc kernel: MTRR fixed ranges enabled:
июл 19 23:35:18 7nice77-pc kernel: MTRR variable ranges enabled:
июл 19 23:35:18 7nice77-pc kernel: Zone ranges:
июл 19 23:35:18 7nice77-pc kernel: Early memory node ranges
июл 19 23:35:18 7nice77-pc kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=5eb30e5b-281e-4dc0-8bcd-173cd41d7904 rw acpi_osi=Linux nouveau.modeset=0
июл 19 23:35:18 7nice77-pc kernel: CPU0: Thermal monitoring enabled (TM1)
июл 19 23:35:18 7nice77-pc kernel: ACPI: Added _OSI(Module Device)
июл 19 23:35:18 7nice77-pc kernel: ACPI: Added _OSI(Processor Device)
июл 19 23:35:18 7nice77-pc kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
июл 19 23:35:18 7nice77-pc kernel: ACPI: Added _OSI(Processor Aggregator Device)
июл 19 23:35:18 7nice77-pc kernel: ACPI: Added _OSI(Linux-Dell-Video)
июл 19 23:35:18 7nice77-pc kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
июл 19 23:35:18 7nice77-pc kernel: ACPI: Added _OSI(Linux)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.GPLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-220)
июл 19 23:35:18 7nice77-pc kernel: ACPI Error: Skip parsing opcode Method (20180810/psloop-540)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.GUPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.TUPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS05._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS07._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS08._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS11._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS12._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS13._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS13._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.USR1._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.USR1._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.USR2._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.USR2._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS07._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS08._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS09._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCI0.XHC.RHUB.SS10._PLD], AE_ALREADY_EXISTS (20180810/dswload2-315)
июл 19 23:35:18 7nice77-pc kernel: ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
июл 19 23:35:18 7nice77-pc kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
июл 19 23:35:18 7nice77-pc kernel: dpc 0000:00:1d.0:pcie008: DPC error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
июл 19 23:35:18 7nice77-pc kernel: dpc 0000:00:1d.6:pcie008: DPC error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
июл 19 23:35:18 7nice77-pc kernel: thermal LNXTHERM:00: registered as thermal_zone0
июл 19 23:35:18 7nice77-pc kernel: ACPI: Thermal Zone [THRM] (50 C)
июл 19 23:35:18 7nice77-pc kernel: thermal LNXTHERM:01: registered as thermal_zone1
июл 19 23:35:18 7nice77-pc kernel: ACPI: Thermal Zone [TZ00] (28 C)
июл 19 23:35:18 7nice77-pc kernel: RAS: Correctable Errors collector initialized.
июл 19 23:35:18 7nice77-pc kernel: hidraw: raw HID events driver (C) Jiri Kosina
июл 19 23:35:18 7nice77-pc kernel: nvidia: loading out-of-tree module taints kernel.
июл 19 23:35:18 7nice77-pc kernel: nvidia: module license 'NVIDIA' taints kernel.
июл 19 23:35:18 7nice77-pc kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
июл 19 23:35:18 7nice77-pc kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 240
июл 19 23:35:18 7nice77-pc kernel: nvidia 0000:01:00.0: enabling device (0006 -> 0007)
июл 19 23:35:18 7nice77-pc kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
июл 19 23:35:18 7nice77-pc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  430.26  Tue Jun  4 17:40:52 CDT 2019
июл 19 23:35:18 7nice77-pc kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  430.26  Tue Jun  4 17:45:09 CDT 2019
июл 19 23:35:18 7nice77-pc kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
июл 19 23:35:18 7nice77-pc kernel: proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
июл 19 23:35:18 7nice77-pc kernel: proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
июл 19 23:35:19 7nice77-pc kernel: iTCO_wdt: probe of iTCO_wdt failed with error -16
июл 19 23:35:19 7nice77-pc kernel: thermal thermal_zone6: failed to read out thermal zone (-61)
июл 19 23:35:19 7nice77-pc kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[n7ce77@7nice77-pc ~]$ lsmod | grep -Ei 'wmi|therm|asus|laptop|acer'
x86_pkg_temp_thermal    16384  0
asus_nb_wmi            28672  0
asus_wmi               32768  1 asus_nb_wmi
sparse_keymap          16384  1 asus_wmi
wmi_bmof               16384  0
processor_thermal_device    16384  0
mxm_wmi                16384  0
int340x_thermal_zone    16384  1 processor_thermal_device
rfkill                 28672  8 asus_wmi,bluetooth,cfg80211
intel_soc_dts_iosf     16384  1 processor_thermal_device
intel_pch_thermal      16384  0
wmi                    28672  3 asus_wmi,wmi_bmof,mxm_wmi
int3400_thermal        16384  0
asus_wireless          16384  0
acpi_thermal_rel       16384  1 int3400_thermal
i8042                  32768  1 asus_nb_wmi
this here is part of a scan of the FX505 on manjaro from July 7, 2019 which is very similar to yours and shows 56c+
im looking at others as well.
FX504: (ubuntu)
https://linux-hardware.org/index.php?probe=9d9bbf8d79&log=sensors
https://linux-hardware.org/index.php?probe=e7c8363251&log=sensors
https://linux-hardware.org/index.php?probe=6b3d1e91d2&log=sensors
those temps seem very similar to yours.
you have to remember, when your using windows everything is using the intel gpu and the nvidia only kicks on when it's required. if you were to set nvidia as the primary gpu in windows, it would remain powered on constantly and produce heat as it does here on linux.
on linux, with intel mode the nvidia gpu is completely powered down, and with nvidia prime mode both gpu's are powered on as they would be in windows if you were to set the nvidia as primary instead of the intel.
@linesma , where you hiding? i just remembered you have one of these laptops :grin:
@dglt I am right here, I was typing a response when you tagged me.
Without knowing what the temperature of your room is, or if you have the laptop flat on a table, your temps are looking normal. The nVidia 1060 tends to run on the warm side in laptops. The problem is the cooling solution used by Asus. Unfortunately, this solution is common in many laptops made today. Here is a picture.
The CPU is on the right and the GPU is on the left. As you can see, both the GPU and the CPU share a heat pipe, and the GPU has an additional heat pipe. While there are 2 heat pipes on the GPU, it still has the heat from the CPU to deal with as well, and the Intel i7-8XXX series of chip run quite warm, even at idle. So this means your GPU will run warmer than say a GPU in a desktop would.
I have a nVidia 1050 in my FX-504G, and it can get quite warm depending on how warm the room is, and if I use a "Laptop Cooler" or not. Here are some examples.
These temps were taken with the laptop flat on a desk.
  1. Room Temp 35°C - GPU Temp 54°C on desktop, fan not running
  2. Room Temp 35°C - GPU Temp 70°C running Tomb Raider (2013) on medium details, fan running at 75%.
  3. Room Temp 28°C - GPU Temp 42°C on desktop, fan not running.
  4. Room Temp 28°C - GPU Temp 60°C running Tomb Raider (2013) on medium details, fan barely running.
I then put a laptop cooler under the laptop and ran the same tests.
  1. Room Temp 35°C - GPU Temp 45°C on desktop, fan not running
  2. Room Temp 35°C - GPU Temp 65°C running Tomb Raider (2013) on medium details, fan running at 50%.
  3. Room Temp 28°C - GPU Temp 35°C on desktop, fan not running.
  4. Room Temp 28°C - GPU Temp 43°C running Tomb Raider (2013) on medium details, fan barely running.
My suggestion is to get yourself a laptop cooler that will raise the vents on the bottom of the laptop off of the table. This will increase airflow and both the GPU and CPU will run cooler. Even one as simple as this one will make a difference.
s-l300
my kids msi laptop, i5/gtx1050 can get really warm and when the fans are on "Cooler boost" sound like a leaf blower :laughing:
i guess i got lucky with my dell, these are my thermals and i keep it at a constant 3.2ghz and fans are pretty damn quiet while gaming
sensors & nvidia-smi
~ >>> sensors
iwlwifi-virtual-0
temp1:        +48.0°C
dell_smm-virtual-0
Processor Fan: 1935 RPM
Processor Fan: 2122 RPM
CPU:            +41.0°C
GPU:            +42.0°C
SODIMM:         +46.0°C
acpitz-acpi-0
temp1:        +27.8°C  (crit = +119.0°C)
temp2:        +29.8°C  (crit = +119.0°C)
coretemp-isa-0000
Package id 0:  +45.0°C  (high = +100.0°C, crit = +100.0°C)
Core 0:        +43.0°C  (high = +100.0°C, crit = +100.0°C)
Core 1:        +43.0°C  (high = +100.0°C, crit = +100.0°C)
Core 2:        +45.0°C  (high = +100.0°C, crit = +100.0°C)
Core 3:        +43.0°C  (high = +100.0°C, crit = +100.0°C)
pch_skylake-virtual-0
temp1:        +54.0°C
~ >>> nvidia-smi
Fri Jul 19 12:43:21 2019
|   0  GeForce GTX 960M    Off  | 00000000:02:00.0 Off |                  N/A |
| N/A   42C    P0    N/A /  N/A |    363MiB /  4046MiB |      0%      Default |
|    0       639      G   /usr/lib/Xorg                                156MiB |
|    0       944      G   compton                                       10MiB |
|    0      1204      G   ...uest-channel-token=10701992267152885873   151MiB |
|    0      2015      G   ...uest-channel-token=14249071836591213001    41MiB |
if you want to save more power and reduce heat you can look into setting a slight undervolt on the cpu and that should help quite a bit, a -120mv undervolt should do it and not hurt performance. since both your gpu and cpu are tied together thermally, making the cpu run cooler will also help with gpu temps.
there's arch wiki's that explain how to do it using intel-undervolt
@dglt Yes those are some cool temps, what is the temperature of the room you are in? That also has an effect on the temperatures. I will have to look into the undervolting thing myself. Why? Just because.
@help.2019e On July 10, 2019, Asus has released a new bios. It supposedly will improve system stability and help with the temps. You can install it using the EZ-Flash utility in the bios. You can get the file here:
MAKE SURE THE LAPTOP IS PLUGGED INTO THE MAINS
  1. Save and extract the file to a USB drive. Make sure it is FAT32.
  2. Plug the drive into your laptop.
  3. Hold the esc key when you power on.
  4. Choose "enter setup"
  5. Hit F7 to enter advanced mode.
  6. Navigate to EZ-Flash Utility.
  7. Choose the bios file from the USB disk, and let it update.
  8. When you reboot, you will get an error about secure boot. The bios update turns it back on by default. Enter back into the bios and turn it back off.
  9. Reboot and enjoy!
Hope this helps!
Another option that would help temperatures is to replace the factory thermal paste on the GPU and CPU with something better. I plan on changing mine to Kryonaught once the laptop is out of warranty. Unless I can con the local service center to do it for me. :stuck_out_tongue_winking_eye: When I changed the Thermal Paste on my old laptop, I saw a drop in temps by about 5 degrees or more depending on the task.
UPDATE I just updated my bios to the latest, and it does seem to help a little bit. From just using the machine, no testing, the temps do seem a little better.
thx! wondering my laptop won't break from bios update?
@help.2019e It can be scary doing a bios update, but compared to 10 years ago, it is a snap. I especially like Asus' EZ-Flash 3 program. I have yet to have a bios update go wrong.
Besides the cooling solution being a little on the weak side, Asus and other manufacturers, use cheap thermal compound. As I said above, once the lappy is out of warranty, the second thing I am doing is changing out the thermal paste. The first thing is formatting my spare NVME SSD that has Windows 10 on it. I have it in a box in case I need to get warranty support. I can throw it in if needed.
you've been out of the US for too long. :grin:
73F , before i had my AC running, on a 90F day would be higher obviously.
i just did my dell and my twins msi laptops a few weeks ago and i have the numbers before/after written down somewhere :man_shrugging: . anyhow temps of all 3 were much better. after reading about a hundred different thermal paste reviews (which btw, are incredibly inconsistent) i was stuck between grizzly kryonaught and noctua nt-h2 . i ended up going with the noctua.
aren't you the local service center? :laughing:
@dglt @linesma also i found video-hybrid-intel-nvidia-bumblebee in Hardware Configuration. Can this help make like in Windows?
I do NOT suggest using Bumblebee. There has not been development on it for almost 6 years. Also, the Bumblebee setup does NOT support Vulkan. While yes, it can make it more like Windows, but it will be a lot of trouble making it work properly. Today, I personally do NOT recommend Bumblebee at all. 5 years ago, I thought it was awesome. Not any more.
Also, Bumblebee will NOT help you with temperature. In my opinion, if your system is working right now, stay with what you got.
I tend to switch between Noctua and Grizzly's Kryonaught. It depends on what is available. Right now, on my gaming rig, I am using Noctua thermal paste. I am also in the process of replacing all of my case fans with Noctua. Their 6 year warranty is the best in the business.
Damn, that is COLD. My house normally sits at 80-90F. Outside the temps are normally in the 100's. Because of that, cooling is a big deal for me. Yes, the heat in Thailand sucks, but after living here for 6 years, 70F feels f*($in' cold. :upside_down_face:
Sorry for asking about what the temperature of your room was. It is important and many "reviewers" do not mention it. One cannot cool a CPU/ GPU below the temperature of the room.
EDIT
@help.2019e After the bios update, my GPU is running much cooler. The room is 27C and the GPU is 35C. These are the temps I am getting after watching 1080p videos for an hour.
no worries, it's only the temperature of the room im in, it's not like you asked for my gps coordinates.
it's 90F outside right now, we get our 100 degree days but not nearly as many as you do. i imagine the humidity there is also not so pleasant. :hot_face:
@help.2019e :point_up: . i am of the very same opinion. the thermals would be the same as nvidia prime any time you run something with optirun/primusrun the nvidia gpu gets turned on (if it works).
if you only use your nvidia gpu occasionally you can stick to intel only mode and the nvidia gpu will remain powered down until you need it, saving a decent amount of power and there will be no heat generated from the nvidia gpu when it's off.
Ok. Thx @dglt @linesma!
