Touchpad of my laptop stopped working after latest set of updates. It is one of those Numpad cum touchpad in Asus Zenbook. The Numpad functionality never worked, but the touchpad was working fine until the update. I tried with a Manjaro livecd and it detects the touchpad fine.
One weird observation is that the touchpad is not detected after cold booting, but it is detected after rebooting. So I am forced to boot it and then again reboot it to work with the Laptop.
The Touchpad section of the System Settings just show “No Touchpad found”
sudo dmesg | grep touch
gives nothing
sudo libinput list-devices
does not show any touchpad
inxi -Fazy
shows
Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=01e6c1d9-5825-4b3c-b03d-96752433aa3e ro nouveau.modset=0 quiet
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ZenBook UX434DA_UM433DA v: 1.0
serial: <filter>
Mobo: ASUSTeK model: UX434DA v: 1.0 serial: <filter>
UEFI: American Megatrends v: UX434DA_UM433DA.302 date: 09/05/2019
ID-1: BAT0 charge: 41.9 Wh (100.0%) condition: 41.9/50.0 Wh (83.8%)
volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 82
Info: Quad Core model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108109 cache: L2: 2 MiB
bogomips: 36748
Speed: 1297 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz):
1: 1297 2: 1243 3: 1225 4: 1226 5: 1225 6: 1227 7: 1224 8: 1223
disabled, RSB filling
Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-2: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-2:3 chip-ID: 13d3:56cb class-ID: 0e02 serial: <filter>
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.40.0
5.10.60-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-4:2 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 52.39 GiB (11.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GDJTNG-8310A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: 80001C00 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 50 GiB size: 48.97 GiB (97.93%) used: 22.3 GiB (45.5%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 410.44 GiB size: 403 GiB (98.19%)
used: 30.08 GiB (7.5%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 59.6 C mobo: N/A gpu: amdgpu temp: 59.0 C
Fan Speeds (RPM): cpu: 2400
Processes: 260 Uptime: 25m wakeups: 3767 Memory: 13.67 GiB
used: 2.94 GiB (21.5%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1419 pacman: 1412 lib: 399 flatpak: 0 snap: 7
Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
