Running GNOME Shell 42.5
When I move the cursor with the touchpad after 1-2 minutes of inctivity it doesn’t move inmediately, but instead is stuck for some seconds and then jumps to a new position as a glitch.
Also, windows randomly freeze for some seconds too on moving and resizing, I don’t know if it may be related.
This doesn’t happen with XFCE desktop so I guess might be some gnome configuration. I’ll happily provide all the info you need.
Hello @Sanjaer
Sounds like GPU acceleration problem… just note that GNOME is a 3D-Desktop, that means that low GPUs will have problems here if not powerful enough.
You could mitigate that problem by disabling the effects for example.
Hi @megavolt
Thanks for your answer. I am running an NVIDIA GeForce RTX 3050Ti so I don’t think it is a resources problem. Could it be a problem with the drivers?
I am running official 515.76
Can you show your system information?
inxi -Fazy
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8c1d3e66-2b6e-4887-85bd-1f91fffff7c9 rw quiet splash apparmor=1
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: HP product: OMEN by HP Laptop 16-c0xxx v: N/A
Mobo: HP model: 8901 v: 89.55 serial: <superuser required> UEFI: AMI
v: F.11 date: 09/01/2021
ID-1: BAT0 charge: 59.7 Wh (85.0%) condition: 70.2/70.2 Wh (100.0%)
volts: 12.9 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: charging cycles: 29
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22 process: TSMC n7
(7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1529 high: 2361 min/max: 1200/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1303 4: 1213 5: 2252 6: 1380 7: 1378 8: 1257 9: 1806 10: 1330 11: 1927
12: 1197 13: 1881 14: 2361 15: 1197 16: 1197 bogomips: 102253
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: Hewlett-Packard
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a0
class-ID: 0300
Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: DP-1 bus-ID: 06:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 38.0 C
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 0408:5425 class-ID: fe01 serial: <filter>
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: amdgpu,nvidia dri: radeonsi
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: eDP-1-0 model: ChiMei InnoLux 0x1609 built: 2020
res: 1920x1080 hz: 144 dpi: 137 gamma: 1.2 size: 355x199mm (13.98x7.83")
diag: 407mm (16") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
vendor: Hewlett-Packard driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_pci v: N/A modules: rtw89pci pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
chip-ID: 10ec:8852 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
Local Storage: total: 953.87 GiB used: 283.87 GiB (29.8%)
model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
rev: HPS0NEXF temp: 32.9 C scheme: GPT
ID-1: / raw-size: 481.45 GiB size: 472.82 GiB (98.21%) used: 283.84 GiB
(60.0%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 29.5 MiB
(30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 6.84 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:6
System Temperatures: cpu: 47.6 C mobo: N/A
GPU: device: nvidia screen: :1.0 temp: 38 C device: amdgpu temp: 38.0 C
Processes: 437 Uptime: 1m wakeups: 1 Memory: 30.7 GiB used: 3.27 GiB (10.7%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 Packages: 1549 pm: pacman pkgs: 1526 libs: 360
tools: gnome-software,pamac,yay pm: flatpak pkgs: 0 pm: snap pkgs: 23
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.22
Not really… you run the amd gpu which is connected to your laptop screen. And if you are using mainly the nvidia gpu, then only GLX is outsourced to nvidia.
Sanjaer:
class-ID: 0300
Since this is missing:
I cannot tell which GLX (amd or nvidia) is running.
pamac install mesa-utils
What tells:
glxinfo | grep "OpenGL renderer"
prime-run glxinfo | grep "OpenGL renderer"
Ok so I have installed mesa-utils, now instead of that error message it says this:
OpenGL: renderer: NVIDIA GeForce RTX 3050 Ti Laptop GPU/PCIe/SSE2 v: 4.6.0
NVIDIA 520.56.06 direct render: Yes
The output of those commands is the following:
OpenGL renderer string: NVIDIA GeForce RTX 3050 Ti Laptop GPU/PCIe/SSE2
@Sanjaer ok great. Just to be sure… does it also happen when you run Gnome with the amdgpu? I know in the past there were problems on hybrid gpus with amd+nvidia and the nvidia readme also says that there are problems. Could be possible that a new issue has been introduced with that update.
How can I switch between gpus? I found this , I’ll try the suggested workaround now and I’ll inform you
(Although those logs doesn’t appear)
On Manjaro you can just install:
sudo mhwd --install video-hybrid-amd-nvidia-prime
and you have normal hybrid installation. AMD will be main and with prime-run
you can outsource GLX to nvidia.
