Artix linux-lts not detecting Ethernet, only Wifi
#21
Well that is the same card as me
And you should be using the board I linked for you for help it works for me and help is pretty fast.
#22
Success… see the arrows to the right on the upper task bar which indicate the ethernet is working
Also it was a busy day today installing Artix on this:
It’s a 128 gb msata drive… 65$ from amazon… i did it the long way around of course. First i tried copying my partitions from the 128gb pen drive i was using and when i couldn’t chroot into it with mhwd-chroot-shell i went ahead and installed manjaro openrc xfce and then migrated that to Artix again just for the practice… makes perfect I’m told…
#23
So now i have it installed on a proper ssd
And that reminds me to make open-dyslexic my terminal font as well… I’m not technically dyslexic but it’s easier to read from a distance with my bad eyes and all…
#24
Well ok then… that’s not a forum though and having to read through every single post, even to scroll past them all is a huge inconvenience… you complained about that thread being 300 posts… how many is that one on the blog?
@artoo We really need a real forum… even something temporary until you have the time to put one together that you like
PLEASE!!!
#25
Why would you want to scroll the whole board just sign in ask a question get a answer either on the board and your email address simple really
#26
for the same reason you have added a banner to manjaro forums telling people how to search the forums for their problem before asking a question
#27
If that is aimed at me the link I gave is a blog you can post on, why would any sane person scroll for answers from 2 years ago. nothing is relevant till 7 days ago when Artix was born come on just trying to hang on in there. They really have a lot of work to do. Work with them not against them + artoo has done a upgraded migration read me, but its not on here this is manjaro, they have totally migrated from the arch core in the last day or two. I installed cinnamon using artix ISO same eth0 driver as you have it worked out of the box, if you are trying to mix manjaro repro you will end up with a borked system in the long run. so i don’t see the point the same as posting Artix technical here how will they know you have a problem Manjaro users are good but Artix is its own animal, so all you are doing is delaying bugs by not reporting them to the correct place
#28
give the artix people some time, they are doing a great job in shortest time
#29
Obviously. I can’t prevent anyone from creating some unofficial forum. However, I would dislike it because we already got several places for help. One being the systemd-free.org.
Have some patience, a forum is atm not top priority. I found it more important people have already a system available to move, so they are left with an already working distro to move to.
If you want to report a bug, use the github issue tracker, which is always the better place to report technical issues than a forum.
An updated migration guide can be found here:
We got artixlinux.org domain, so things are moving forward.
closed #30
