I switched to a new computer and now my WiFi adapter is not connecting to a WiFi network, but it still detects them.
I don’t have any other means of connecting to the internet on that computer except for another distro on the disk (Debian), which I assume has the correct WiFi adapter drivers.
Edit: I’d like to add that I am connecting to WiFi on a laptop as of right now, which has Arch Linux installed.
I tried to install the drivers from the AUR (whilst chrooting into the Manjaro install from Debian), but I get this error: System has not been booted with systemd as init system (PID 1). Can't operate. Failed to connect to bus: Host is down
I’m using the 4.19.167-MANJARO kernel, and the adapter chipset is RTL8812AU. Any help would be greatly appreciated, thanks!
If you have Arch installed and a working Wifi connection through it - then it should be easy to find out which driver it uses and then use the same in Manjaro.
But I think that’s not the case - on your currently not working machine there is Debian and Manjaro, correct?
Does Debian have a working Wifi connection?
some tools to get that info on any system: lsmod lsusb lspci inxi (probably not installed by default in Arch or Debian) dmesg
and the system logs
… don’t just post the info.
Compare for yourself for possible different driver versions on the Debian install
(where it seems to be working?)
vs. the Manjaro install.
The WiFi adapter is showing up on both Debian and Manjaro: Bus 001 Device 003: ID 0bda:8812 Realtek Semiconductor Corp. RTL8812AU 802.11a/b/g/n/ac 2T2R DB WLAN Adapter
And what do you mean by loaded, are rfkill and cfg80211 modules that I can load with modprobe?
rfkill list also gives the following output:
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
Additionally, I feel like I should clarify the problem in more detail; even though the WiFi networks show up, on Manjaro it keeps repeatedly asking for authentication, even when I enter the correct passphrase.
Ticking “all users can use this connection” in the General tab didn’t seem to do anything.
I actually searched all sorts of forums for a solution, but none of them seemed to have worked for me, hence why I’m making my own separate thread here.
Both Debian and Manjaro have the 4.19 kernel, but I’ll try booting into a different kernel anyway. I’ll edit this post with results.
Edit: No luck, the WiFi device doesn’t even show up on nmcli dev in a different kernel (5.10).
hmm, same kernel, same driver, same configuration - Debian works, Manjaro doesn’t
Since I don’t have that device I can just keep guessing without being able to give verified information.
Correct, but not exactly the same kernel. Although they both have the 4.19 kernel, they’re different versions; Manjaro has the 4.19.167 kernel, Debian has 4.19.0.
Plugging the WiFi adapter into a different port fixed my issue; I had it plugged into a USB 2.0 port, I plugged it into a USB 3.2 port and it started working!
