Hello ARM community.
It’s been a couple of weeks since the last update, but this one is a big one.
Big update of OpenSSL resulted in thousands of packages being rebuilt and updated
Some highlights:
- Most of our kernels got updated
- OpenSSL updated to 3.0.7! Did we miss any rebuilds?
- Firefox updated to 107.0
- Thunderbird updated to 102.5.0
- Plasma updated to 5.26.3
- KDE Frameworks updated to 5.100
- SystemD updated to 252.1
- QT6 updated to 6.4.1
- Box64 updated to 0.2.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver
. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1
as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Sun Nov 20 19:09:38 CET 2022)
- arm-testing community aarch64: 1445 new and 1406 removed package(s)
- arm-testing core aarch64: 105 new and 104 removed package(s)
- arm-testing extra aarch64: 789 new and 786 removed package(s)
- arm-testing kde-unstable aarch64: 348 new and 348 removed package(s)
See the full package list here
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
