Hello ARM community.
Not much in this update, so should be straight forward.
Some highlights:
- Most of our kernels got updated
- Cinnamon updated to 5.4.4
- Pipewire updated to 0.3.56
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Fri Jul 22 20:56:58 CEST 2022)
- arm-testing community aarch64: 381 new and 317 removed package(s)
- arm-testing core aarch64: 50 new and 50 removed package(s)
- arm-testing extra aarch64: 96 new and 96 removed package(s)
- arm-testing kde-unstable aarch64: 129 new and 129 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-07-15 2022-07-22
chatty 0.6.7-2 0.6.7+3+g8fdb00e8-1
code 1.69.0-1 1.69.2-1
libgbinder 1.1.24-1 1.1.25-1
libprolog 1.2.1.r0.g0d33632-1 1.2.2-1
libqofono-qt5 0.103-2 0.113-1
libtrace-ohm1.1.8+git4.r0.g02376f9-1 1.1.8+git4-2
linux-rpi4-udl 5.15.52-1 5.15.56-1
linux-rpi4-udl-headers 5.15.52-1 5.15.56-1
mate-tweak 22.04.8-2 22.04.8-5
nemo-qml-plugin-models 0.2.2-1 0.2.4-1
phoc0.21.0beta1+12+g56efa97-10.21.0beta1+15+gbfa954a-1
phosh0.20.0beta2+16+g4f3074c8-20.20.0beta2+18+g8bfc3fde-1
pinebookpro-post-install 20220713-1 20220720-1
qt5-contacts-sqlite-extensions-git 0.3.14.r0.gcff793e-1 -
qt5-mlite-git 0.3.7.r0.g7f21359-1 -
rock64-post-install 20220713-1 20220720-1
rockpro64-post-install 20220713-1 20220720-1
signal-desktop 5.49.0-1 5.50.1-1
buteo-sync-plugin-carddav - 0.1.7-1
buteo-sync-plugins-social - 0.4.17-1
buteo-syncfw - 0.10.16-1
contactsd - 1.4.10-1
geoclue1 - 0.12.99.8-1
google-opensans-fonts - 0.1-1
libcommhistory - 1.11.13-1
libconnman-qt - 1.2.46-1
libdres-ohm - 1.1.18-1
libiodata - 0.19.11+git2-1
libiphb - 1.2.7-1
libmce-qt - 1.4.2-1
libmlocale - 0.7.6-2
libngf - 0.28-1
libngf-qt - 0.8.2-1
libprofile-qt - 0.35.5-1
libqofonoext - 1.0.28-1
libresource - 0.25.1-1
libresourceqt - 1.31.0-1
libsocialcache - 0.1.7-1
libusb-moded-qt - 1.10-1
maliit-nemo-keyboard - 0.100-1
mce - 1.111.0-1
mce-headers - 1.30.0-1
mkcal - 0.6.9-1
nemo-keepalive - 1.8.7-1
nemo-qml-plugin-accounts - 0.0.7-1
nemo-qml-plugin-connectivity - 0.2.11-1
nemo-qml-plugin-contacts - 0.3.23-2
nemo-qml-plugin-devicelock - 0.3.7-1
nemo-qml-plugin-email - 0.6.22-1
nemo-qml-plugin-systemsettings - 0.8.0-4
nemo-qml-plugin-time - 0.1.4-1
nemo-theme-glacier - 0.2.1-1
ohm - 1.3.1-1
ohm-plugin-ruleengine - 1.1.14-5
ohm-plugins-misc - 1.9.1-1
policy-settings-common - 0.12.2-1
postprocessd - 0.2.1-1
profiled - 1.0.13-1
profiled-settings-nemo - 0.2-1
qmf-qt5 - 4.0.4+git135-1
qt-mobility-haptics-ffmemless - 0.2.8-1
qt5-pim - 5.6.0+git15-1
qt5-quickcontrols-nemo - 5.7.2-1
qt5-sensors-sensorfw - 5.15.4-1
qtcontacts-sqlite - 0.3.18-1
sensorfw - 0.12.6-1
swi-prolog7 - 7.6.4-1
timed - 3.6.13-1
tzdata-timed - 2021a+git1-1
usb-moded - 0.86.0+mer58-1
:: Different sync package(s) in repository community aarch64
abseil-cpp 20211102.0-2 20220623.0-1
acorn 1:8.7.1-1 1:8.8.0-1
agordejo 0.4.0-1 0.4.1-1
aml 0.2.1-2 0.2.2-1
ansible-core 2.13.1-1 2.13.2-1
apko 0.4.0-1 0.5.0-1
apptainer 1.0.1-2 1.0.3-1
asunder 2.9.7-3 2.9.7-5
baresip 2.5.0-1 2.5.1-1
benchmark 1.6.1-2 1.6.2-1
bitwarden-cli 2022.6.2-1 2022.6.2-2
blueman 2.2.5-1 2.3.1-1
brook 20210701-2 20220401-1
budgie-desktop 10.6.1-1 10.6.2-1
caddy 2.5.1-1 2.5.2-1
cage 0.1.4-8 0.1.4-9
calibre 5.44.0-1 6.1.0-1
cargo-edit 0.9.1-1 0.10.2-1
carla 2.4.3-1 2.5.0-1
catfish 4.16.3-2 4.16.4-1
chafa 1.10.3-1 1.12.0-1
chezmoi 2.18.1-1 2.19.0-1
cinnamon 5.4.2-1 5.4.4-1
cinnamon-control-center 5.4.3-1 5.4.4-1
cinnamon-desktop 5.4.0-1 5.4.2-1
cinnamon-screensaver 5.4.0-1 5.4.1-1
cinnamon-settings-daemon 5.4.1-1 5.4.2-1
cjs 5.4.0-1 5.4.1-1
cmus 2.9.1-2 2.10.0-2
codec2 1:1.0.4-1 1:1.0.5-1
copyq 6.2.0-1 6.2.0-2
croc 9.5.6-1 9.6.0-1
crun 1.4.5-1 1.5-1
crystal 1.5.0-1 1.5.0-2
curtail 1.3.0-1 1.3.1-1
dagger 0.2.23-1 0.2.25-1
dht 0.27-1 0.27-2
diffoscope 218-2 219-1
displaycal 3.9.6-1 3.9.6-2
distrobuilder 2.1-1 2.1-2
drupal 9.2.9-2 9.4.2-1
element 0.46.5-1 0.46.6-1
evilginx 2.4.0-1 2.4.0-2
fabric 2.7.0-1 2.7.1-1
fcitx5-pinyin-zhwiki 1:0.2.4.20220529-1 1:0.2.4.20220722-1
fdkaac 1.0.2-2 1.0.3-1
fetchmail 6.4.30-1 6.4.31-1
filezilla 3.60.1-2 3.60.1-3
firefox-decentraleyes 2.0.17-1 2.0.17-2
fluajho 1.7.2-1 1.7.3-1
fluidd 1.18.2-1 1.19.0-1
gitea 1.16.8-1 1.16.9-1
go 2:1.18.3-1 2:1.18.4-1
go-tools 4:0.1.11-1 4:0.1.11-2
goaccess 1.6.1-1 1.6.2-1
gopls 0.9.0-1 0.9.1-1
grpc 1.47.0-1 1.48.0-1
grpc-cli 1.47.0-1 1.48.0-1
gtest 1.12.0-2 1.12.1-1
gtk-layer-shell 0.7.0-2 0.7.0-3
hdf5-openmpi 1.12.2-2 1.12.2-3
hepmc2 2.06.11-1 2.06.11-2
home-assistant 1:2022.6.7-1 1:2022.7.4-2
icewm 2.9.7-1 2.9.8-1
icmake 9.03.01-1 9.03.01-2
inn 2.6.4-5 2.7.0-1
interception-dual-function-keys 1.5.0-1 1.5.0-2
interception-tools 0.6.8-3 0.6.8-4
jenkins 2.359-1 2.360-1
jrnl 2.8.4-1 3.0-1
jupyterlab 3.4.3-1 3.4.4-1
kanshi 1.2.0-3 1.2.0-4
kvantum-theme-materia 20220607-1 20220714-1
laborejo 2.0.3-1 2.1.0-1
languagetool 5.7-1 5.8-1
lazygit 0.34-2 0.35-1
libafterimage 1.20-5 1.20-6
libcalfbox-lss 1.0.0-2 1.1.0-1
libclastfm 0.5-6 0.5-7
libfilezilla 1:0.37.2-1 1:0.38.1-1
libicns 0.8.1-8 0.8.1-9
libimagequant 2.17.0-3 4.0.0-1
libluv 1.43.0_0-1 1.44.2_0-1
libmusicbrainz5 5.1.0-4 5.1.0-5
libtg_owt 0.git14.10d5f4b-1 0.git14.10d5f4b-2
libtraceevent 1:1.6.1-1 1:1.6.2-1
libtraceevent-docs 1:1.6.1-1 1:1.6.2-1
libtracefs 1.4.1-1 1.4.2-1
libtracefs-docs 1.4.1-1 1.4.2-1
libvirt 1:8.5.0-2 1:8.5.0-3
libvirt-storage-gluster 1:8.5.0-2 1:8.5.0-3
libvirt-storage-iscsi-direct 1:8.5.0-2 1:8.5.0-3
liquidsfz 0.2.3-1 0.3.0-1
lua-language-server 3.4.2-1 3.5.0-1
lua-luv 1.43.0_0-1 1.44.2_0-1
lua51-luv 1.43.0_0-1 1.44.2_0-1
lua52-luv 1.43.0_0-1 1.44.2_0-1
lua53-luv 1.43.0_0-1 1.44.2_0-1
luajit2.1.0.beta3.r422.g4c2441c1-12.1.0.beta3.r431.g5677985d-1
mako 1.7.1-1 1.7.1-2
marked 4.0.3-1 4.0.4-1
materia-kde 20220607-1 20220714-1
matrix-synapse 1.62.0-1 1.63.0-1
maude 3.1-1 3.2.1-1
mcfly 0.6.0-1 0.6.1-1
mediathekview 13.8.1-3 13.9.1-1
menyoki 1.6.0-1 1.6.1-1
mimir 2.1.0-4 2.2.0-1
mktorrent 1.1-4 1.1-5
mmctl 7.0.1-1 7.1.2-1
muffin 5.4.1-1 5.4.3-1
nemo 5.4.0-1 5.4.1-1
nemo-audio-tab 5.4.0-1 5.4.1-1
nemo-emblems 5.4.0-1 5.4.1-1
nemo-fileroller 5.4.0-1 5.4.1-1
nemo-image-converter 5.4.0-1 5.4.1-1
nemo-pastebin 5.4.0-1 5.4.1-1
nemo-preview 5.4.0-1 5.4.1-1
nemo-python 5.4.0-1 5.4.1-1
nemo-seahorse 5.4.0-1 5.4.1-1
nemo-share 5.4.0-1 5.4.1-1
nemo-terminal 5.4.0-1 5.4.1-1
nerdctl 0.21.0-1 0.22.0-1
nextcloud 24.0.2-1 24.0.3-1
nextcloud-app-contacts 4.1.1-1 4.2.0-1
nginx-mod-headers-more 0.33-13 0.34-1
nginx-mod-njs 0.7.5-1 0.7.6-1
node-gyp 9.0.0-1 9.1.0-1
nomad 1.3.1-1 1.3.2-1
nomad-driver-podman 0.3.0-2 0.4.0-1
npm-check-updates 14.0.0-1 14.0.2-1
nvchecker 2.9-1 2.9-2
openfire 4.7.1-1 4.7.2-1
openrct2 0.4.0-1 0.4.1-1
osbuild 59-1 60-1
perl-finance-quote 1.51-3 1.52-1
perl-json 4.06-1 4.07-1
perl-json-parse 0.61-1 0.62-1
perl-ppi 1.274-2 1.275-1
perl-software-license 0.104001-2 0.104002-1
perl-www-mechanize 2.08-1 2.10-1
perl-yaml-pp 0.032-1 0.034-1
php-grpc 1.47.0-1 1.48.0-1
php-mongodb 1.13.0-2 1.14.0-1
php7-grpc 1.47.0-1 1.48.0-1
php7-mongodb 1.13.0-2 1.14.0-1
pkgdiff 1.7.2-3 1.7.2-4
plantuml 1.2022.4-2 1.2022.6-1
polymake 4.6-6 4.7-1
pop-icon-theme2.1.0.r2446.baf29712c7-12.1.0.r2450.b6b5d437ec-1
pueue 2.0.4-1 2.1.0-1
pybind11 2.9.2-1 2.10.0-1
pyright 1.1.260-1 1.1.262-1
python-aaf2 1.5.0-1 1.6.0-1
python-aiobotocore 2.2.0-1 2.3.4-1
python-ansible-compat 2.1.0-1 2.2.0-1
python-aws-sam-translator 1.46.0-1 1.47.0-1
python-bleach 5.0.0-1 5.0.1-1
python-celery 5.2.1-1 5.2.7-1
python-cfn-lint 0.61.2-1 0.61.3-1
python-cinderclient 8.3.0-1 9.0.0-1
python-cloudflare 2.9.10-1 2.9.11-1
python-cmd2 2.3.3-1 2.4.0-1
python-daiquiri 3.0.1-3 3.1.0-1
python-darkdetect 0.6.0-1 0.7.1-1
python-designateclient 4.5.1-1 5.0.0-1
python-distlib 0.3.4-1 0.3.5-1
python-dogpile.cache 1.1.6-1 1.1.7-1
python-dropbox 11.32.0-1 11.33.0-1
python-dulwich 0.20.44-1 0.20.45-1
python-elementpath 2.5.1-1 2.5.2-1
python-email-validator 1.1.3-3 1.2.0-1
python-eventlet 0.33.0-2 0.33.1-1
python-fastapi 0.78.0-1 0.79.0-1
python-fastjsonschema 2.15.3-1 2.16.1-1
python-flask-htmlmin 2.1.0-2 2.2.0-1
python-flask-migrate 3.0.0-3 3.1.0-1
python-flask-paranoid 0.2-8 0.3.0-1
python-flask-security-too 4.1.3-1 4.1.4-1
python-flask-socketio 5.1.1-1 5.2.0-1
python-flask-wtf 1.0.0-1 1.0.1-1
python-frozendict 1:2.3.2-1 1:2.3.3-1
python-funcparserlib 1.0.0a0-1 1.0.0-1
python-geoip2 4.4.0-1 4.5.0-1
python-googleapis-common-protos 1.56.2-1 1.56.3-1
python-grpcio 1.47.0-1 1.48.0-1
python-heatclient 2.5.1-1 3.0.0-1
python-identify 2.5.1-1 2.5.2-1
python-inflect 5.6.1-1 5.6.2-1
python-jaraco.classes 3.2.1-3 3.2.2-1
python-jaraco.functools 3.5.0-2 3.5.1-1
python-jaraco.text 3.8.0-2 3.8.1-1
python-jupymake 0.9-13 0.9-14
python-keystoneclient 4.5.0-1 5.0.0-1
python-libcharon 4.13.0-1 5.0.0-1
python-listparser 0.18-5 0.19-1
python-markdown 3.3.7-1 3.4.1-1
python-mygpoclient 1.8-9 1.9-1
python-neutronclient 7.8.0-1 8.0.0-1
python-nodeenv 1.6.0-3 1.7.0-1
python-nose2 0.11.0-1 0.12.0-1
python-odfpy 1.4.2-1 1.4.2-2
python-orjson 3.7.7-1 3.7.8-1
python-oslo-db 11.3.0-1 12.0.0-1
python-oslo-serialization 4.3.0-1 5.0.0-1
python-owslib 0.25.0-1 0.26.0-1
python-pallets-sphinx-themes 2.0.1-4 2.0.2-1
python-perf 2.3.0-1 2.3.1-1
python-pip-shims 0.7.0-1 0.7.1-1
python-podcastparser 0.6.7-3 0.6.8-1
python-pydrive2 1.10.1-1 1.13.0-1
python-pyface 7.3.0-4 7.4.2-1
python-pyjwt 2.2.0-3 2.4.0-1
python-pylink-square 0.13.0-1 0.14.0-1
python-pytest-aiohttp 0.3.0-8 1.0.4-1
python-pytest-metadata 2.0.1-1 2.0.2-1
python-pytest-subtesthack 0.1.2-3 0.2.0-1
python-pytest-sugar 0.9.4-5 0.9.5-1
python-pytools 2022.1.5-1 2022.1.7-1
python-simplebayes 1.5.7-9 1.5.8-1
python-sphinx-autodoc-typehints 1.12.0-1 1.13.1-1
python-sphinx-issues 1.2.0-7 3.0.1-1
python-swiftclient 4.0.0-1 4.0.1-1
python-tempora 5.0.1-2 5.0.2-1
python-traits 6.2.0-3 6.3.2-1
python-traitsui 7.2.1-3 7.4.0-1
python-uritemplate 3.0.1-6 4.1.1-1
python-websocket-client 1.3.3-1 1.3.3-2
qgis 3.24.3-2 3.26.0-1
radicale 3.1.7-1 3.1.8-1
reaper 6.63-1 6.64-1
redis 7.0.3-1 7.0.4-1
release-cli 0.11.0-2 0.13.0-1
repo 2.27-1 2.28-1
revive 1.1.4-2 1.2.1-1
rime-pinyin-zhwiki 1:0.2.4.20220529-1 1:0.2.4.20220722-1
rofimoji 5.4.0-1 5.5.0-1
roundcubemail 1.5.2-2 1.5.3-1
rubberband 2.0.2-1 3.0.0-2
ruby 3.0.4-1 3.0.4-2
ruby-bundler 2.3.15-1 2.3.18-1
ruby-docs 3.0.4-1 3.0.4-2
ruby-i18n 1.10.0-1 1.12.0-1
ruby-tzinfo 2.0.4-1 2.0.5-1
rust-analyzer 20220711-1 20220718-1
rxvt-unicode 9.26-3 9.30-1
rxvt-unicode-terminfo 9.26-3 9.30-1
scdoc 1.11.2-3 1.11.2-4
scite 5.2.3-1 5.2.4-1
seatd 0.7.0-1 0.7.0-2
sequoia-sop 0.27.0-1 0.27.1-1
sile 0.13.2-2 0.13.3-1
sl 5.05-2 5.05-3
slurp 1.3.2-2 1.3.2-3
spdlog 1.10.0-1 1.10.0-2
spice-gtk 0.41-1 0.41-2
spice-vdagent 0.22.1-1 0.22.1-2
sqlfluff 1.1.0-1 1.2.1-1
sstp-client 1:1.0.16-1 1:1.0.17-1
strawberry 1.0.5-2 1.0.6-1
stunnel 5.64-1 5.65-1
stylua 0.14.0-1 0.14.1-1
supertux 0.6.3-2 0.6.3-3
swappy 1.4.0-1 1.4.0-2
swayidle 1.7.1-2 1.7.1-3
swaylock 1.6-1 1.6-2
systembus-notify 1.1-1 1.1-2
telegram-desktop 4.0.2-2 4.0.2-4
tembro 0.5.0-1 0.5.1-1
tepl 6.1.2-1 1:6.0.2-1
tldr 3.1.0-1 3.1.0-2
trace-cmd 3.1.1-1 3.1.2-1
translate-shell 0.9.6.12-2 0.9.6.12-3
trivy 0.29.2-1 0.30.2-1
ts-node 10.8.2-1 10.9.1-1
tt-rss 2:r11220.b59bde7b4-1 2:r11325.8f19423c2-1
ttf-ionicons 6.0.2-1 6.0.2-2
ttf-sarasa-gothic 0.36.6-1 0.36.7-1
tuna 1:0.17-1 1:0.18-1
urlscan 0.9.9-1 0.9.9-2
v2ray-domain-list-community 20220714074155-1 20220721123730-1
v2ray-geoip 202207140057-1 202207210057-1
visidata 2.8-2 2.9-1
wasmtime 0.37.0-1 0.39.1-1
webp-pixbuf-loader 0.0.5-1 0.0.6-1
wf-recorder 0.3.0-1 0.3.0-2
wl-clipboard 1:2.1.0-1 1:2.1.0-2
wlroots 0.15.1-5 0.15.1-6
wxsqlite3 4.7.8-2 4.8.2-1
x42-plugins 20220605-1 20220714-1
xapp 2.2.12-1 2.2.13-1
xbindkeys 1.8.7-2 1.8.7-3
xed 3.2.4-1 3.2.5-1
xlockmore 5.69-1 5.70-1
xsecurelock 1.7.0-1 1.7.0-2
yt-dlp 2022.06.29-1 2022.07.18-1
zk 0.11.0-1 0.11.1-1
zola 0.15.3-1 0.16.0-2
zsh-completions 0.33.0-1 0.34.0-1
cargo-tauri - 1.0.4-1
corectrl - 1.2.4-2
gtksourceview3 -1:3.24.11+r28+g73e57b57-1
kdesrc-build - 22.07-1
kubo - 0.14.0-1
libptytty - 2.0-4
ncnn - 20220721-1
python-absl - 1.1.0-2
python-requests-wsgi-adapter - 0.4.1-1
python-sphinx-bootstrap-theme - 0.8.1-3
python-sphinx-lv2-theme - 1.2.0-1
ruby-bundledgems - 3.0.4-2
ruby-stdlib - 3.0.4-2
waifu2x-ncnn-vulkan - 20220419-2
:: Different overlay package(s) in repository core aarch64
linux 5.18.12-1 5.18.13-1
linux-clockworkpi-a06 5.18.12-1 5.18.13-1
linux-clockworkpi-a06-headers 5.18.12-1 5.18.13-1
linux-headers 5.18.12-1 5.18.13-1
linux-khadas 5.18.5-1 5.18.12-1
linux-khadas-headers 5.18.5-1 5.18.12-1
linux-lts 5.15.55-1 5.15.56-1
linux-lts-headers 5.15.55-1 5.15.56-1
linux-odroid 5.18.5-1 5.18.12-1
linux-odroid-headers 5.18.5-1 5.18.12-1
linux-rc 5.19.rc6-2 5.19.rc7-1
linux-rc-headers 5.19.rc6-2 5.19.rc7-1
linux-rpi4 5.15.52-1 5.15.56-1
linux-rpi4-headers 5.15.52-1 5.15.56-1
linux-rpi4-mainline 5.18.9-2 5.18.12-2
linux-rpi4-mainline-headers 5.18.9-2 5.18.12-2
linux-rpi4-rc 5.19.rc6-1 5.19.rc7-2
linux-rpi4-rc-headers 5.19.rc6-1 5.19.rc7-2
manjaro-system 20220619-1 20220719-1
raspberrypi-bootloader 20220704-1 20220718-1
raspberrypi-bootloader-x 20220704-1 20220718-1
uboot-odroid-m1 2022.01.rc4-3 2022.01.rc4-4
uboot-pinebookpro 2022.04-3 2022.04-4
uboot-pinenote 2022.01.rc4-2 2022.01.rc4-3
uboot-quartz64-a 2022.01.rc4-1 2022.01.rc4-2
uboot-quartz64-b 2022.01.rc4-2 2022.01.rc4-3
uboot-rock64 2022.04-1 2022.04-2
uboot-rockpro64 2022.04-1 2022.04-2
uboot-soquartz-cm4 2022.01.rc4-2 2022.01.rc4-3
:: Different sync package(s) in repository core aarch64
amd-ucode 20220610.7b71b75-1 20220708.be7798e-1
hdparm 9.63-2 9.64-1
lemon 3.39.0-2 3.39.1-1
libbpf 0.8.0-1 0.8.1-1
libidn2 2.3.2-1 2.3.3-1
libldap 2.6.2-2 2.6.3-1
linux-firmware 20220610.7b71b75-1 20220708.be7798e-1
linux-firmware-bnx2x 20220610.7b71b75-1 20220708.be7798e-1
linux-firmware-liquidio 20220610.7b71b75-1 20220708.be7798e-1
linux-firmware-marvell 20220610.7b71b75-1 20220708.be7798e-1
linux-firmware-mellanox 20220610.7b71b75-1 20220708.be7798e-1
linux-firmware-nfp 20220610.7b71b75-1 20220708.be7798e-1
linux-firmware-qcom 20220610.7b71b75-1 20220708.be7798e-1
linux-firmware-qlogic 20220610.7b71b75-1 20220708.be7798e-1
linux-firmware-whence 20220610.7b71b75-1 20220708.be7798e-1
nilfs-utils 2.2.8-2 2.2.9-1
openldap 2.6.2-2 2.6.3-1
sqlite 3.39.0-2 3.39.1-1
sqlite-analyzer 3.39.0-2 3.39.1-1
sqlite-doc 3.39.0-2 3.39.1-1
sqlite-tcl 3.39.0-2 3.39.1-1
:: Different overlay package(s) in repository extra aarch64
mesa-git22.2.0_devel.156464.b8397991c888-122.2.0_devel.156755.81d85be9a5cf-1
:: Different sync package(s) in repository extra aarch64
alsa-card-profiles 1:0.3.55-2 1:0.3.56-1
atkmm 2.28.2-2 2.28.3-1
atkmm-2.36 2.36.1-2 2.36.2-1
atkmm-2.36-docs 2.36.1-2 2.36.2-1
atkmm-docs 2.28.2-2 2.28.3-1
chromium 103.0.5060.114-1 103.0.5060.134-1
composer 2.3.9-1 2.3.10-1
gcab 1.4-1 1.4-2
gcr 3.41.0-2 3.41.1-1
gmime3 3.2.7-1 3.2.12-1
gnome-menus 3.36.0-1 3.36.0-2
gnome-tweaks42beta+r14+g2d9d76c-142beta+r14+g2d9d76c-2
gnuplot 5.4.3-6 5.4.4-1
gnuplot-demos 5.4.3-6 5.4.4-1
graphviz 4.0.0-1 5.0.0-1
gst-plugin-pipewire 1:0.3.55-2 1:0.3.56-1
gtksourceview33.24.11+28+g73e57b57-1 -
ibus-typing-booster 2.15.25-1 2.17.1-1
imake 1.0.8-3 1.0.8-4
inkscape 1.2-5 1.2.1-1
jasper 3.0.4-1 3.0.6-1
jasper-doc 3.0.4-1 3.0.6-1
jdk-openjdk 18.0.1.1.u2-1 18.0.2.u9-1
jdk11-openjdk 11.0.15.u10-2 11.0.16.u8-2
jdk17-openjdk 17.0.3.u7-2 17.0.4.u8-2
jre-openjdk 18.0.1.1.u2-1 18.0.2.u9-1
jre-openjdk-headless 18.0.1.1.u2-1 18.0.2.u9-1
jre11-openjdk 11.0.15.u10-2 11.0.16.u8-2
jre11-openjdk-headless 11.0.15.u10-2 11.0.16.u8-2
jre17-openjdk 17.0.3.u7-2 17.0.4.u8-2
jre17-openjdk-headless 17.0.3.u7-2 17.0.4.u8-2
kitinerary 22.04.3-1 22.04.3-2
libbs2b 3.1.0-7 3.1.0-8
libcryptui3.12.2+55+ged3b12af-11:3.12.2+r69+g9c70a43b-1
libmikmod 3.3.11.1-4 3.3.11.1-6
libnotify 0.8.0-1 0.8.1-1
libphonenumber 1:8.12.50-2 1:8.12.52-1
libwebp 1.2.2-1.1 1.2.3-1
libzip 1.8.0-1 1.9.2-1
meld 3.20.4-2 3.21.2-1
mkvtoolnix-cli 68.0.0-1 69.0.0-1
mkvtoolnix-gui 68.0.0-1 69.0.0-1
mpg123 1.29.3-2 1.30.1-1
openjdk-src 18.0.1.1.u2-1 18.0.2.u9-1
openjdk11-src 11.0.15.u10-2 11.0.16.u8-2
openjdk17-src 17.0.3.u7-2 17.0.4.u8-2
perl-crypt-openssl-rsa 0.32-2 0.33-1
perl-crypt-ssleay 0.73_04-16 0.73_06-1
perl-date-manip 6.87-1 6.88-1
pipewire-alsa 1:0.3.55-2 1:0.3.56-1
pipewire-docs 1:0.3.55-2 1:0.3.56-1
pipewire-jack 1:0.3.55-2 1:0.3.56-1
pipewire-pulse 1:0.3.55-2 1:0.3.56-1
pipewire-v4l2 1:0.3.55-2 1:0.3.56-1
pipewire-x11-bell 1:0.3.55-2 1:0.3.56-1
pipewire-zeroconf 1:0.3.55-2 1:0.3.56-1
prison 5.96.0-1 5.96.0-2
prometheus 2.36.2-1 2.37.0-1
protobuf-c 1.4.0-4 1.4.1-1
python-evdev 1.5.0-1 1.6.0-1
python-gobject 3.42.1-1 3.42.2-1
python-lxml 4.9.0-1 4.9.1-1
python-lxml-docs 4.9.0-1 4.9.1-1
qbs 1.22.1-1 1.23.0-1
qt5-base 5.15.5+kde+r170-1 5.15.5+kde+r172-1
qt5-svg 5.15.5+kde+r10-1 5.15.5+kde+r11-1
qt5-xcb-private-headers 5.15.5+kde+r170-1 5.15.5+kde+r172-1
qtcreator 7.0.2-4 8.0.0-1
qtcreator-devel 7.0.2-4 8.0.0-1
rtkit 0.13-1 0.13-2
rust 1:1.62.0-1 1:1.62.1-1
rust-src 1:1.62.0-1 1:1.62.1-1
samba 4.16.2-1 4.16.3-1
sbc 1.5-2 2.0-1
seahorse-nautilus3.11.92+66+g02c81f1-11:3.11.92+r88+g86214b8-1
sip 6.6.2-2 6.6.2-3
smbclient 4.16.2-1 4.16.3-1
tomcat-native 1.2.34-1 1.2.35-1
tomcat10 10.0.22-1 10.0.23-1
tomcat9 9.0.64-1 9.0.65-1
vulkan-headers 1:1.3.217-1 1:1.3.221-1
vulkan-html-docs 1:1.3.217-1 1:1.3.221-1
vulkan-icd-loader 1.3.217-1 1.3.221-1
woff2 1.0.2-3 1.0.2-4
wxwidgets-common 3.2.0-2 3.2.0-4
wxwidgets-gtk3 3.2.0-2 3.2.0-4
wxwidgets-qt5 3.2.0-2 3.2.0-4
xdg-desktop-portal 1.14.4-1 1.14.5-1
zabbix-agent 6.0.5-1 6.2.0-1
zabbix-agent2 6.0.5-1 6.2.0-1
zabbix-frontend-php 6.0.5-1 6.2.0-1
zabbix-proxy 6.0.5-1 6.2.0-1
zabbix-server 6.0.5-1 6.2.0-1
zita-alsa-pcmi 0.4.0-1 0.5.1-1
gcr-docs - 3.41.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi-calendar22.04.3.r2140.ge74a923-122.04.3.r2142.gd82e700-1
akonadi-contacts22.04.3.r3227.g41e4ae03-122.04.3.r3229.ge11e12c3-1
akonadi-search22.04.3.r1249.ga07a980-122.04.3.r1250.g996f4a5-1
alligator 22.06.r19.g4677847-1 22.06.r22.ge37b88b-1
analitza22.04.3.r2352.gb312e7db-122.04.3.r2355.g4637e049-1
angelfish 22.06.r9.g486ec6d-1 22.06.r21.g4ab1280-1
ark22.04.3.r4817.g3861d22e-122.04.3.r4820.g239f99d3-1
audiocd-kio22.04.3.r1088.g89d626d-122.04.3.r1094.g8f766a9-1
audiotube 22.06.r12.g1aabf2e-1 22.06.r17.g56ffb52-1
baloo-widgets22.04.3.r762.g66425c4-122.04.3.r763.gf93b9a3-1
bomber22.04.3.r569.g56cdf3c-122.04.3.r570.gbe88435-1
breeze5.25.3.r2430.g224f6c37-15.25.3.r2432.gc0f7505c-1
breeze-icons5.96.0.r1908.ge6ae2ea7-15.96.0.r1909.gacc75ff7-1
calendarsupport22.04.2.r715.g08e6017-122.04.2.r716.g955489f-1
calindori 22.06.r7.g53c09da-1 22.06.r8.g8553328-1
discover5.25.3.r8730.g45170af1-15.25.3.r8742.gcd2b9b05-1
dolphin22.04.3.r7045.g513fe3bb4-122.04.3.r7050.gd0c3e373a-1
drkonqi5.25.3.r801.g00b3f48e-15.25.3.r809.g80efd753-1
extra-cmake-modules5.96.0.r3505.g7d9d14e7-15.96.0.r3506.gce726d38-1
filelight22.04.3.r1154.g97fbbd4-122.04.3.r1155.g7d2f734-1
itinerary22.04.3.r1948.g2b8f969-122.04.3.r1961.gd2cf370-1
juk22.04.3.r3163.g9de34979-122.04.3.r3167.g03eb4fc3-1
k3b1:22.04.3.r6805.g37c595478-11:22.04.3.r6807.ga8f810d6a-1
kalarm22.04.3.r7956.gef920816-122.04.3.r7966.g387f37e3-1
kalgebra22.04.3.r2069.g71f9bdf-122.04.3.r2070.g0c74265-1
kalk 22.06.r8.g7626461-1 22.06.r9.g52b84ad-1
kalzium22.04.3.r4370.g254ff1d8-122.04.3.r4373.gfc36b715-1
kasts 22.06.r27.gce45074-1 22.06.r29.g91de33f-1
kate22.04.3.r19238.g2403075c3-122.04.3.r19251.g2a72944b0-1
kcalutils22.04.3.r973.ga853bbb6d-122.04.3.r978.g9a68537fa-1
kclock 22.06.r13.g882a72a-1 22.06.r14.g16989c8-1
kcmutils5.96.0.r648.g58af203-15.96.0.r651.g85097f0-1
kconfig5.96.0.r964.gd96f19bc-15.96.0.r965.g491f5464-1
kconfigwidgets5.96.0.r750.geb393b1-15.96.0.r752.g89d04a1-1
kcoreaddons5.96.0.r1530.g8e0f756e-15.96.0.r1532.gdf8a2f6b-1
kdebugsettings22.04.3.r942.gfc9b1f2-122.04.3.r949.g5890609-1
kdeconnect22.04.3.r3490.g280c0fb2-122.04.3.r3494.geefdf0c5-1
kded5.96.0.r467.gc7a921a-15.96.0.r468.gec9f232-1
kdenlive22.04.3.r16365.g9c3e77ecd-122.04.3.r16404.gfab80c851-1
kdepim-runtime22.04.3.r15559.g04a8d8375-122.04.3.r15560.ga9f36a1b6-1
kdeplasma-addons5.25.3.r8926.gb7c0de671-15.25.3.r8938.g4f6891294-1
keysmith 22.06.r7.gdc845ae-1 22.06.r9.gab97a00-1
kfilemetadata5.96.0.r866.gcb95bf6-15.96.0.r868.g138880a-1
kget22.04.3.r3215.g827824c6-122.04.3.r3216.g3682529a-1
kglobalaccel5.96.0.r536.gca47aad-15.96.0.r537.g5683e03-1
khangman22.04.3.r1618.gb49b93f-122.04.3.r1619.gca39294-1
khelpcenter22.04.3.r2757.g460a5dff-122.04.3.r2759.g1bfabb70-1
khotkeys5.25.3.r2149.g831ed9e-15.25.3.r2151.g292cd1d-1
kinfocenter5.25.3.r2116.gcc19207f-15.25.3.r2124.ge928b457-1
kio5.96.0.r5582.g90afd1559-15.96.0.r5595.gc6207ee11-1
kio-extras22.04.3.r7298.g52a56adc-122.04.3.r7302.g2b4ec3a8-1
kirigami-addons 1:0.3.r4.g4054d97-1 1:0.3.r6.gbd7741e-1
kirigami-gallery22.04.3.r254.g82bfb6a-122.04.3.r256.g09384d4-1
kirigami25.96.0.r3181.gc28dff79-15.96.0.r3184.g1b19825b-1
kitinerary22.04.3.r2298.g46ce330-122.04.3.r2328.gf19e8f4-1
kleopatra22.04.3.r6674.g3e82c3fd-122.04.3.r6697.ga71ac7b3-1
kmahjongg22.04.3.r1559.g96f1bbf-122.04.3.r1565.g6d8fc1b-1
kmines22.04.3.r1771.gd14a074-122.04.3.r1772.ga4000b6-1
knewstuff5.96.0.r1366.g39c74671-15.96.0.r1367.g6b941efe-1
koko 22.06.r6.gdd9222a-1 22.06.r9.gc8e4141-1
kompare22.04.3.r1145.gf7b472b-122.04.3.r1146.g3d27211-1
kongress 22.06.r5.gbaa77e7-1 22.06.r10.ge9b588f-1
konqueror22.04.3.r15130.g90807e9fa-122.04.3.r15131.g1d7ed315e-1
konsole22.04.3.r8550.ga49dfc0f-122.04.3.r8554.g05a4d489-1
konversation22.04.3.r9130.g08bfe884-122.04.3.r9131.g4d441ef8-1
kpackage5.96.0.r758.g2cc209e-15.96.0.r759.ge8b40d7-1
kpimtextedit22.04.3.r1604.g1bf4ec6-122.04.3.r1609.g9095e0b-1
kpipewire5.25.3.r134.gca8fbdb-15.25.3.r135.g3bc932e-1
krdc22.04.3.r1609.g194d0c5-122.04.3.r1610.g6b9f4c1-1
krecorder 22.06.r8.gb303c3b-1 22.06.r9.g182d96f-1
krfb22.04.3.r1507.g2cd15b6-122.04.3.r1511.g5173e7f-1
kscreen5.25.3.r1484.gbcc0353-15.25.3.r1491.g387fda6-1
kservice5.96.0.r1023.g5b12b2d-15.96.0.r1024.g7b06291-1
ksudoku22.04.3.r1122.g5057715-122.04.3.r1123.g61a004a-1
ktexteditor5.96.0.r3439.gfb610965-15.96.0.r3440.g623703c7-1
ktorrent22.04.3.r2867.gcb0986aa-122.04.3.r2868.gce4aef3c-1
ktrip 22.06.r7.g6c20cf6-1 22.06.r8.g162e6ef-1
kwallet5.96.0.r1162.g6239a80-15.96.0.r1163.g47ed32b-1
kwayland5.96.0.r1170.ge5fda97-15.96.0.r1172.g5227e3f-1
kweather 22.06.r14.g4e09fef-1 22.06.r16.gc572d1b-1
kweathercore 0.6.r5.g51000a1-1 0.6.r6.gee49ab6-1
kwidgetsaddons5.96.0.r951.g4407542b-15.96.0.r952.g8bce29ac-1
kwin5.25.3.r22762.ge801819a2-15.25.3.r22827.gb6cf576ef-1
kwrite22.04.3.r19238.g2403075c3-122.04.3.r19251.g2a72944b0-1
kxmlgui5.96.0.r893.gde0790fe-15.96.0.r894.g59affd7d-1
libkdepim22.04.3.r913.g5e2ee45-122.04.3.r918.g9472b5b-1
libkleo22.04.3.r1206.g121ed86-122.04.3.r1221.g1be06ea-1
libkscreen5.25.3.r1632.g6c3140b-15.25.3.r1633.gf6c8db3-1
libksysguard5.25.3.r2419.gabe0012-15.25.3.r2420.g481a0eb-1
lokalize22.04.3.r1839.g33f0eb22-122.04.3.r1841.g167df143-1
maliit-keyboard 2.3.0.r0.gdcde37d3-1 2.3.1.r0.g9673c8e8-1
maui-pix 2.1.2.r17.g68f91a1-1 2.1.2.r18.g1ea25f0-1
mauikit2.1.2.r49.g82274116-12.1.2.r50.g8ad10f4d-1
mauiman r22.f42eb96-1 r23.6ccbef3-1
neochat22.06.r40.ga37fd071-122.06.r51.g94f32560-1
oxygen5.25.3.r4497.g489752e0-15.25.3.r4499.g84305086-1
parley22.04.3.r4531.g5d76d7d5-122.04.3.r4533.g767fa241-1
plank-player r29.f536191-1 r30.7520b22-1
plasma-bigscreen r485.g6520768-1 r489.gee83ea0-1
plasma-browser-integration5.25.3.r1338.g5b57c8be-15.25.3.r1339.g3ba5d473-1
plasma-desktop5.25.3.r9421.g890b3862b-15.25.3.r9454.g0fc8d0316-1
plasma-dialer 22.06.r15.g5714110-1 22.06.r16.gf6cf597-1
plasma-disks5.25.3.r285.gd2e6d02-15.25.3.r286.g3f58a5f-1
plasma-firewall5.25.3.r642.gbbdfe7b-15.25.3.r643.g0c9bbb3-1
plasma-framework5.96.0.r16364.gbea3b07c3-15.96.0.r16366.g50eaece7a-1
plasma-mobile5.25.3.r1910.gd2824deed-15.25.3.r1918.ga0ea1f743-1
plasma-phonebook 22.06.r4.gd3c3687-1 22.06.r5.g62a98d0-1
plasma-sdk5.25.3.r2377.g29f3ee38-15.25.3.r2378.g811d92d1-1
plasma-settings 22.06.r27.g587b098-1 22.06.r32.g0a02044-1
plasma-systemmonitor5.25.3.r591.g1ea5812-15.25.3.r597.g43f1a12-1
plasma-wayland-protocols1.4.0.r1054.g0469915-11.4.0.r1055.gbcb428f-1
plasma-wayland-session5.25.3.r12076.g4989651e0-15.25.3.r12094.g502430d76-1
plasma-workspace5.25.3.r12076.g4989651e0-15.25.3.r12094.g502430d76-1
plasma-workspace-wallpapers5.25.3.r360.g7705661-15.25.3.r361.g2c96c7a-1
plasmatube 22.06.r6.g858abe4-1 22.06.r7.g07b6f24-1
print-manager22.04.3.r1145.g5d29881-122.04.3.r1147.g66eda1f-1
purpose5.96.0.r983.ge4ae404-15.96.0.r984.g51e3a30-1
qmlkonsole 22.06.r8.ge54d9b8-1 22.06.r10.ga75f5ab-1
qqc2-desktop-style5.96.0.r639.gf804b45-15.96.0.r643.g299748e-1
sddm-kcm5.25.3.r670.g08ecf2b-15.25.3.r671.gea131ce-1
solid5.96.0.r782.g806fb38-15.96.0.r784.g8c9ad6a-1
spacebar 22.06.r15.g9274506-1 22.06.r18.g075044d-1
spectacle22.04.3.r1373.gba86116-122.04.3.r1374.gf32cc2f-1
systemsettings5.25.3.r2693.g682b604c-15.25.3.r2694.gd2a36f1d-1
tokodon 22.06.r13.g21aae2b-1 22.06.r17.gb30ed83-1
umbrello22.04.3.r8486.g4f81aaa82-122.04.3.r8487.g908b3425f-1
vakzination 22.06.r9.g872245a-1 22.06.r10.gdaac6be-1
xdg-desktop-portal-kde5.25.3.r509.g3b31623-15.25.3.r512.g57f17b2-1
yakuake22.04.3.r802.g10be48c-122.04.3.r803.g7bd2d68-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
