Hello ARM community.
A rather small update, as we prepare for the next stable update and release.
Some highlights:
- Most of our kernels got updated
- KDE Frameworks updated to 5.95
- Boost updated to 1.79. Did we miss any rebuilds?
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Thu Jun 16 21:22:17 CEST 2022)
- arm-testing community aarch64: 210 new and 206 removed package(s)
- arm-testing core aarch64: 17 new and 17 removed package(s)
- arm-testing extra aarch64: 200 new and 197 removed package(s)
- arm-testing kde-unstable aarch64: 361 new and 361 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-06-12 2022-06-16
anbox 0_git20211020-1 0_git20211020-2
breath-wallpapers 21.2.0-2 21.3.0-3
element-desktop 1.10.14-1 1.10.15-1
element-web 1.10.14-1 1.10.15-1
kodi-rpi-git20.x.60481.ba4bb5e5af-220.x.60540.5244790365-1
kodi-rpi-git-dev20.x.60481.ba4bb5e5af-220.x.60540.5244790365-1
kodi-rpi-git-eventclients20.x.60481.ba4bb5e5af-220.x.60540.5244790365-1
kodi-rpi-git-tools-texturepacker20.x.60481.ba4bb5e5af-220.x.60540.5244790365-1
libgbinder 1.1.19-1 1.1.20-1
libglibutil 1.0.64-1 1.0.65-1
phosh-antispam 2.0-1 2.1-1
plasma5-themes-breath 21.2.0-2 21.3.0-3
plasma5-themes-breath-extra 21.2.0-2 21.3.0-3
plasma5-themes-breath-migration 21.2.0-2 21.3.0-3
sddm-breath-theme 21.2.0-2 21.3.0-3
snapd 2.56-1 -
snapd-glib 1.60-1 -
wcm 0.7.0-3 0.7.0-4
gnome-shell-mobile -42.1+r143+g67603c924-1
mutter-mobile -42.1+r111+gb7555238f-1
:: Different sync package(s) in repository community aarch64
aqbanking 6.4.1-1 6.5.0-1
arcus 4.13.1-2 4.13.1-3
arpack 3.8.0-2 3.8.0-3
astroid 0.16-2 0.16-4
blender 17:3.2.0-1 17:3.2.0-3
cargo-generate 0.14.0-1 0.15.0-1
cargo-nextest 0.9.18-1 0.9.20-1
cclive 0.9.3-26 0.9.3-27
ceph 15.2.14-5 15.2.14-6
ceph-libs 15.2.14-5 15.2.14-6
ceph-mgr 15.2.14-5 15.2.14-6
clementine 1.4.0rc2-1 1.4.0rc2-2
cockatrice 2.8.0-8 2.8.0-9
cockpit 270-1 271-1
cockpit-machines 269-1 270.2-1
cockpit-pcp 270-1 271-1
cockpit-podman 48-1 49.1-1
containerd 1.6.5-1 1.6.6-1
cpp-hocon 0.3.0-9 0.3.0-10
cryfs 0.11.2-2 0.11.2-3
cryptominisat5 5.8.0-9 5.8.0-10
curaengine 4.13.1-2 4.13.1-3
dagger 0.2.18-1 0.2.19-1
difftastic 0.29.0-1 0.29.1-1
direnv 2.31.0-2 2.32.0-1
dmtcp 2.5.2-1 2.6.1rc1-1
dnf 4.12.0-1 4.13.0-1
drone-runner-docker 1.8.1-2 1.8.2-1
eclib 20210625-3 20210625-4
etherwall 3.0.3-3 3.0.3-4
facter 3.14.23-1 3.14.23-2
fcitx5-chinese-addons 5.0.13-1 5.0.13-2
fdm 2.0-3 2.1-1
freecad 0.19.4-2 0.19.4-5
gearmand 1.1.19.1-1 1.1.19.1-2
glob2 0.9.4.4-43 0.9.4.4-44
globalprotect-openconnect 1.4.4-1 1.4.8-1
glom 1.32.0-8 1.32.0-9
gnuradio 3.10.2.0-5 3.10.2.0-6
gnuradio-companion 3.10.2.0-5 3.10.2.0-6
gnuradio-osmosdr 0.2.3-10 0.2.3-11
go-tools 4:0.1.10-2 4:0.1.11-1
gource 0.53-1 0.53-2
gpick 0.2.6-4 0.2.6-5
gping 1.3.1-1 1.3.2-1
grpc 1.46.3-1 1.46.3-2
grpc-cli 1.46.3-1 1.46.3-2
guake 3.8.5-1 3.9.0-1
guitarix 0.44.1-1 0.44.1-2
hamlib 3.3-13 4.4-1
hdf5-openmpi 1.12.2-1 1.12.2-2
heaptrack 1.3.0-1 1.3.0-2
hugin 2021.0.0-2 2021.0.0-3
hugo 0.99.1-1 0.100.2-1
hyperion 1.03.2-28 1.03.2-29
i2pd 2.42.1-1 2.42.1-2
ibus-table 1.16.7-1 1.16.8-1
imagescan 3.65.0-5 3.65.0-6
innoextract 1.9-5 1.9-6
jenkins 2.354-1 2.355-1
jmol 14.32.59-1 14.32.60-1
josm 18427-1 18463-1
jsmol 14.32.59-1 14.32.60-1
leatherman 1.12.7-1 1.12.7-2
ledger 3.2.1-9 3.2.1-10
libavif 0.10.1-1 0.10.1-2
libdeflate 1.8-4 1.11-1
libime 1.0.12-1 1.0.12-2
liblas1.8.1.r127+ge6a1aaed-11.8.1.r127+ge6a1aaed-2
libopenshot 0.2.7-11 0.2.7-12
libperconaserverclient 8.0.28_19-1 8.0.28_19-2
libuhd 4.2.0.0-1 4.2.0.0-2
libwhereami 0.5.0-11 0.5.0-12
lua-language-server 3.2.5-1 3.3.0-1
lucene++ 3.0.8-3 3.0.8-4
luminancehdr 2.6.1-7 2.6.1-8
manuskript 0.13.1-1 0.14.0-1
mapnik 3.1.0-10 3.1.0-11
mediastreamer 5.1.31-1 5.1.43-1
mosh 1.3.2-17 1.3.2-18
multipath-tools 0.8.9-1 0.9.0-1
ncmpcpp 0.9.2-6 0.9.2-7
netdata 1.34.1-2 1.35.1-1
nextcloud 23.0.3-1 24.0.1-1
nextcloud-app-bookmarks 1:10.3.1-2 1:10.4.0-1
nextcloud-app-calendar 1:3.3.0-1 1:3.3.2-1
nextcloud-app-contacts 4.1.0-1 4.1.1-1
nextcloud-app-deck 1:1.6.2-1 1:1.7.0-2
nextcloud-app-mail 1.11.0-2 1.13.4-1
nextcloud-app-news 18.0.1-1 18.1.0-1
nextcloud-app-notes 4.3.1-1 4.3.1-2
nextcloud-app-notify_push 0.4.0-2 0.4.0-4
nextcloud-app-tasks 0.14.4-1 0.14.4-2
nodejs-source-map 0.7.3-2 0.7.4-1
nodejs-yaml 2.1.0-1 2.1.1-1
npm-check-updates 13.1.2-1 13.1.4-1
nsjail 3.1-2 3.1-3
nushell 0.63.1-1 0.64.0-1
openimageio 2.3.16.0-1 2.3.16.0-2
openscad 2021.01-4 2021.01-5
openshadinglanguage 1.11.17.0-2 1.11.17.0-3
openvdb 9.0.0-9.1 9.1.0-1
pamixer 1.5-3 1.6-2
pdfmixtool 1.0.2-2 1.1-1
percona-server 8.0.28_19-1 8.0.28_19-2
percona-server-clients 8.0.28_19-1 8.0.28_19-2
perl-chart 2.401.1-1 2.402.1-1
perl-file-remove 1.60-2 1.61-1
perl-module-manifest 1.08-5 1.09-1
perl-package-stash-xs 0.29-6 0.30-1
perl-specio 0.47-2 0.48-1
perl-tidy 20220217-1 20220613-1
perl-x11-protocol-other 30-8 31-1
perl-xml-libxslt 2.000000-2 2.001000-1
php-grpc 1.46.3-1 1.46.3-2
php7-grpc 1.46.3-1 1.46.3-2
pnetcdf-openmpi 1.12.3-1 1.12.3-2
poedit 1:3.0.1-2 1:3.0.1-3
povray 2:3.7.0.10-2 2:3.7.0.10-3
powerdns 4.6.2-1 4.6.2-2
powerdns-recursor 4.7.0-1 4.7.0-2
prettier 2.6.2-1 2.7.0-1
prjtrellis 1.2.1-1 1.2.1-2
promscale 0.10.0-2 -
promscale_extension 0.3.2-2 -
proxyboi 0.5.0-1 0.5.0-2
pulseview 0.4.2-6 0.4.2-7
pyright 1.1.253-1 1.1.254-1
python-astroid 2.11.5-1 2.11.6-1
python-bcrypt 3.2.0-5 3.2.1-1
python-cbor2 5.4.3-1 5.4.3-2
python-django-environ 0.8.1-3 0.9.0-1
python-googleapis-common-protos 1.53.0-3 1.56.2-1
python-grpcio 1.46.3-1 1.46.3-2
python-internetarchive 3.0.0-1 3.0.1-1
python-ipykernel 6.13.1-1 6.15.0-1
python-jaraco.envs 2.2.0-1 2.3.0-1
python-more-itertools 8.12.0-2 8.13.0-1
python-mpi4py 3.1.3-1 3.1.3-2
python-phonenumbers 8.12.49-1 8.12.50-1
python-pipenv 2022.5.2-1 2022.6.7-1
python-proxy.py 2.4.2-1 2.4.3-1
python-psycopg 3.0.14-1 3.0.15-1
python-pybtex-docutils 1.0.1-3 1.0.2-1
python-pykeepass 4.0.1-3 4.0.2-1
python-pyroute2 0.6.11-1 0.6.12-1
python-pytools 2022.1.3-1 2022.1.4-1
python-stack-data 0.2.0-1 0.3.0-1
python-tpm2-pytss 1.1.0-1 1.2.0-2
python-versioningit 1.1.1-2 2.0.0-1
qbittorrent 4.4.3.1-2 4.4.3.1-3
qbittorrent-nox 4.4.3.1-2 4.4.3.1-3
qgis 3.24.3-1 3.24.3-2
qmmp 2.1.0-1 2.1.1-1
qpwgraph 0.3.1-1 0.3.2-1
redis 7.0.1-1 7.0.2-1
ruby-rails-html-sanitizer 1.4.2-2 1.4.3-1
ruby-zeitwerk 2.5.4-1 2.6.0-1
rust-analyzer 20220606-1 20220613-1
scaleway-cli 2.5.1-2 2.5.2-1
schroot 1.6.10-30 1.6.10-31
snapper 0.10.2-1 0.10.2-2
soapyosmo 0.2.5-13 0.2.5-14
stp 2.3.3-4 2.3.3-5
strawberry 1.0.5-1 1.0.5-2
sundials 6.2.0-1 6.2.0-2
supercollider 3.12.2-1 3.12.2-2
supertux 0.6.3-1 0.6.3-2
swift-im 4.0.2-8 4.0.2-10
swiften 4.0.2-8 4.0.2-10
sympol 0.1.9-11 0.1.9-12
timescaledb 2.6.1-3 2.7.0-1
trojan 1.16.0-5 1.16.0-6
typescript-language-server 0.11.0-1 0.11.1-1
umockdev 0.17.12-1 0.17.13-1
v2ray 4.45.0-1 4.45.2-1
v2ray-domain-list-community 20220611055103-1 20220612032845-1
vc-intrinsics 0.4.1-1 0.4.2-1
vigra1.11.1.r67+g093d57d1-21.11.1.r67+g093d57d1-3
vtk 9.1.0-15 9.1.0-18
wakatime 1:1.45.3-1 1:1.48.1-1
wasm-pack 0.10.2-2 0.10.3-1
wf-recorder 0.2.1-4 0.3.0-1
wt 4.7.1-1 4.7.1-2
xtrabackup 8.0.27_19-3 8.0.27_19-4
yosys 0.12-4 0.12-6
zerotier-one 1.8.10-1 1.10.0-1
znc 1.8.2-9 1.8.2-10
fluidd - 1.18.2-1
grcov - 0.8.10-2
libigl - 2.4.0-3
rustscan - 2.1.0-2
superslicer - 1:2.4.58.2-1
timescaledb-old-upgrade - 2.7.0-1
:: Different overlay package(s) in repository core aarch64
linux 5.18.3-2 5.18.5-1
linux-clockworkpi-a06 5.18.3-1 5.18.5-1
linux-clockworkpi-a06-headers 5.18.3-1 5.18.5-1
linux-headers 5.18.3-2 5.18.5-1
linux-lts 5.15.46-1 5.15.48-1
linux-lts-headers 5.15.46-1 5.15.48-1
linux-quartz64 5.19.0-0.3 5.19.0-0.4
linux-quartz64-headers 5.19.0-0.3 5.19.0-0.4
linux-rc 5.18.rc7-7 5.19.rc2-3
linux-rc-headers 5.18.rc7-7 5.19.rc2-3
linux-rpi4-rc 5.19.rc1-1 5.19.rc2-1
linux-rpi4-rc-headers 5.19.rc1-1 5.19.rc2-1
uboot-orangepi3-lts 2022.04-2 2022.04-4
:: Different sync package(s) in repository core aarch64
file 5.41-1 5.42-1
kbd 2.5.0-1 2.5.0-2
pciutils 3.8.0-1 3.8.0-2
sudo 1.9.11.p1-1 1.9.11.p2-1
:: Different overlay package(s) in repository extra aarch64
calamares 3.2.59-1 3.2.59-2
qt5-es2-base 5.15.4+kde+r152-1 5.15.4+kde+r168-1
qt5-es2-xcb-private-headers 5.15.4+kde+r152-1 5.15.4+kde+r168-1
snapd - 2.56.2-1
snapd-glib - 1.60-1
:: Different sync package(s) in repository extra aarch64
aisleriot 3.22.20-1 3.22.23-1
akonadi 22.04.2-1 22.04.2-2
alsa-card-profiles 1:0.3.52-1 1:0.3.52-2
assimp 5.2.3-1 5.2.4-1
attica 5.94.0-1 5.95.0-1
avogadrolibs 1.96.0-1 1.96.0-2
avogadrolibs-qt5 1.96.0-1 1.96.0-2
baloo 5.94.0-1 5.95.0-1
bluez-qt 5.94.0-1 5.95.0-1
boost 1.78.0-3 1.79.0-1
boost-libs 1.78.0-3 1.79.0-1
breeze-icons 5.94.0-1 5.95.0-1
breezy 3.2.1-2 3.2.2-2
digikam 7.6.0-4 7.6.0-5
erofs-utils 1.4-2 1.5-2
extra-cmake-modules 5.94.0-1 5.95.0-1
feh 3.8-2.1 3.9-1
ffmpeg 2:5.0-7 2:5.0.1-2
ffmpeg4.4 4.4.1-5 4.4.2-2
fftw 3.3.10-2 3.3.10-3
frameworkintegration 5.94.0-1 5.95.0-1
galera 26.4.11-2 26.4.11-3
ghex 42.2-1 42.3-1
ghex-docs 42.2-1 42.3-1
gimp 2.10.30-3 2.10.32-1
glslang 11.9.0-1 11.10.0-1
gnome-calendar 42.1-1 42.2-1
gperftools 2.9.1-2 2.10-1
gst-plugin-pipewire 1:0.3.52-1 1:0.3.52-2
gtksourceview5 5.4.1-1 5.4.2-1
gtksourceview5-docs 5.4.1-1 5.4.2-1
hefur 1.0-6 1.0-7
imath 3.1.5-1 3.1.5-2
inkscape 1.2-3 1.2-4
kactivities 5.94.0-1 5.95.0-1
kactivities-stats 5.94.0-1 5.95.0-1
kapidox 5.94.0-1 5.95.0-1
karchive 5.94.0-1 5.95.0-1
kauth 5.94.0-1 5.95.0-1
kbookmarks 5.94.0-1 5.95.0-1
kcalendarcore 5.94.0-1 5.95.0-1
kcmutils 5.94.0-1 5.95.0-1
kcodecs 5.94.0-1 5.95.0-1
kcompletion 5.94.0-1 5.95.0-1
kconfig 5.94.0-1 5.95.0-1
kconfigwidgets 5.94.0-1 5.95.0-1
kcontacts 1:5.94.0-1 1:5.95.0-1
kcoreaddons 5.94.0-1 5.95.0-1
kcrash 5.94.0-1 5.95.0-1
kdav 1:5.94.0-1 1:5.95.0-1
kdbusaddons 5.94.0-1 5.95.0-1
kdeclarative 5.94.0-1 5.95.0-1
kded 5.94.0-1 5.95.0-1
kdelibs4support 5.94.0-1 5.95.0-1
kdenlive 22.04.2-1 22.04.2-2
kdesignerplugin 5.94.0-1 5.95.0-1
kdesu 5.94.0-1 5.95.0-1
kdewebkit 5.94.0-1 5.95.0-1
kdnssd 5.94.0-1 5.95.0-1
kdoctools 5.94.0-1 5.95.0-1
kemoticons 5.94.0-1 5.95.0-1
kfilemetadata 5.94.0-1 5.95.0-1
kglobalaccel 5.94.0-1 5.95.0-1
kguiaddons 5.94.0-1 5.95.0-1
kholidays 1:5.94.0-1 1:5.95.0-1
khtml 5.94.0-1 5.95.0-1
ki18n 5.94.0-1 5.95.0-1
kiconthemes 5.94.0-1 5.95.0-1
kidletime 5.94.0-1 5.95.0-1
kig 22.04.2-1 22.04.2-2
kimageformats 5.94.0-1 5.95.0-1
kinit 5.94.0-1 5.95.0-1
kio 5.94.0-1 5.95.0-1
kirigami2 5.94.0-1 5.95.0-1
kismet 2022_02_R1-2 2022_02_R1-3
kitemmodels 5.94.0-1 5.95.0-1
kitemviews 5.94.0-1 5.95.0-1
kjobwidgets 5.94.0-1 5.95.0-1
kjs 5.94.0-1 5.95.0-1
kjsembed 5.94.0-1 5.95.0-1
kmediaplayer 5.94.0-1 5.95.0-1
knewstuff 5.94.0-2 5.95.0-1
knotifications 5.94.0-1 5.95.0-1
knotifyconfig 5.94.0-1 5.95.0-1
kopeninghours 22.04.2-1 22.04.2-2
kosmindoormap 22.04.2-1 22.04.2-2
kpackage 5.94.0-1 5.95.0-1
kparts 5.94.0-1 5.95.0-1
kpeople 5.94.0-1 5.95.0-1
kplotting 5.94.0-1 5.95.0-1
kpty 5.94.0-1 5.95.0-1
kquickcharts 5.94.0-1 5.95.0-1
kross 5.94.0-1 5.95.0-1
krunner 5.94.0-1 5.95.0-1
kservice 5.94.0-1 5.95.0-1
ktexteditor 5.94.0-1 5.95.0-1
ktextwidgets 5.94.0-1 5.95.0-1
kunitconversion 5.94.0-1 5.95.0-1
kwallet 5.94.0-1 5.95.0-1
kwayland 5.94.0-2 5.95.0-1
kwidgetsaddons 5.94.0-1 5.95.0-1
kwindowsystem 5.94.0-1 5.95.0-1
kxmlgui 5.94.0-1 5.95.0-1
kxmlrpcclient 5.94.0-1 5.95.0-1
libakonadi 22.04.2-1 22.04.2-2
libappimage 1.0.4.5-1 1.0.4.5-2
libass 0.15.2-2 0.16.0-1
libcmis 0.5.2-9 0.5.2-10
libinput 1.20.1-1 1.21.0-1
libixion 0.17.0-1 0.17.0-2
libkolabxml 1.1.6-17 1.1.6-18
libnma 1.8.38-1 1.8.40-1
libnma-common 1.8.38-1 1.8.40-1
libnma-gtk4 1.8.38-1 1.8.40-1
libopenmpt 0.6.3-1 0.6.4-1
liborcus 0.17.2-1 0.17.2-2
libphonenumber 1:8.12.49-1 1:8.12.50-2
libplacebo 4.192.1-2 4.192.1-3
libpst 0.6.76-6 0.6.76-7
libpst-docs 0.6.76-6 0.6.76-7
libreoffice-fresh 7.3.4-1 7.3.4-2
libreoffice-fresh-sdk 7.3.4-1 7.3.4-2
libreoffice-still 7.2.7-2 7.2.7-3
libreoffice-still-sdk 7.2.7-2 7.2.7-3
libtorrent-rasterbar 1:2.0.6-1 1:2.0.6-2
libutempter 1.2.1-2 1.2.1-3
maeparser 1.2.4-5 1.2.4-6
marble 22.04.2-1 22.04.2-2
marble-common 22.04.2-1 22.04.2-2
marble-maps 22.04.2-1 22.04.2-2
marble-qt 22.04.2-1 22.04.2-2
modemmanager-qt 5.94.0-1 5.95.0-1
networkmanager-qt 5.94.0-1 5.95.0-1
opencl-headers 2:2022.01.04-1 2:2022.05.18-1
opencv 4.6.0-2 4.6.0-3
opencv-samples 4.6.0-2 4.6.0-3
oxygen-icons 1:5.94.0-1 1:5.95.0-1
oxygen-icons-svg 1:5.94.0-1 1:5.95.0-1
php7 7.4.29-2 7.4.29-4
php7-apache 7.4.29-2 7.4.29-4
php7-cgi 7.4.29-2 7.4.29-4
php7-dblib 7.4.29-2 7.4.29-4
php7-embed 7.4.29-2 7.4.29-4
php7-enchant 7.4.29-2 7.4.29-4
php7-fpm 7.4.29-2 7.4.29-4
php7-gd 7.4.29-2 7.4.29-4
php7-imap 7.4.29-2 7.4.29-4
php7-intl 7.4.29-2 7.4.29-4
php7-odbc 7.4.29-2 7.4.29-4
php7-pgsql 7.4.29-2 7.4.29-4
php7-phpdbg 7.4.29-2 7.4.29-4
php7-pspell 7.4.29-2 7.4.29-4
php7-snmp 7.4.29-2 7.4.29-4
php7-sodium 7.4.29-2 7.4.29-4
php7-sqlite 7.4.29-2 7.4.29-4
php7-tidy 7.4.29-2 7.4.29-4
php7-xsl 7.4.29-2 7.4.29-4
pipewire-alsa 1:0.3.52-1 1:0.3.52-2
pipewire-docs 1:0.3.52-1 1:0.3.52-2
pipewire-jack 1:0.3.52-1 1:0.3.52-2
pipewire-pulse 1:0.3.52-1 1:0.3.52-2
pipewire-v4l2 1:0.3.52-1 1:0.3.52-2
pipewire-x11-bell 1:0.3.52-1 1:0.3.52-2
pipewire-zeroconf 1:0.3.52-1 1:0.3.52-2
plasma-framework 5.94.0-1 5.95.0-2
prison 5.94.0-1 5.95.0-1
prometheus 2.36.0-1 2.36.1-1
protobuf 3.20.1-2 21.1-1
protobuf-c 1.4.0-3 1.4.0-4
purpose 5.94.0-1 5.95.0-1
python-opencv 4.6.0-2 4.6.0-3
python-protobuf 3.20.1-2 21.1-1
python-setuptools 1:60.10.0-1 1:61.3.1-1
qqc2-desktop-style 5.94.0-1 5.95.0-1
rubygems 3.3.8-1 3.3.15-1
samba 4.16.1-4 4.16.2-1
shaderc 2022.1-3 2022.1-4
smbclient 4.16.1-4 4.16.2-1
solid 5.94.0-1 5.95.0-1
sonnet 5.94.0-1 5.95.0-1
source-highlight 3.1.9-7 3.1.9-8
syndication 5.94.0-1 5.95.0-1
syntax-highlighting 5.94.0-1 5.95.0-1
threadweaver 5.94.0-1 5.95.0-1
usbguard 1.1.1-2 1.1.1-3
vlc 3.0.17.4-4 3.0.17.4-5
vulkan-headers 1:1.3.213-1 1:1.3.217-1
vulkan-html-docs 1:1.3.211-1 1:1.3.217-1
vulkan-icd-loader 1.3.213-1 1.3.217-1
vulkan-tools 1.3.213-1 1.3.217-1
xfce4-wavelan-plugin 0.6.2-1 0.6.3-1
xkeyboard-config 2.36-1 2.36-2
zimg 3.0.3-2 3.0.4-1
python-fastbencode - 0.0.7-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.04.2.r12766.g9b2b51157-122.04.2.r12768.g757023978-1
akonadi-calendar22.04.2.r2124.gb9fdbb0-122.04.2.r2128.g13425fd-1
akonadi-calendar-tools22.04.2.r952.geacbf30-122.04.2.r953.g7b2d882-1
akonadi-contacts22.04.2.r3187.g292eebb1-122.04.2.r3192.g0c241dd0-1
akonadi-import-wizard22.04.2.r1832.gb91b7a9-122.04.2.r1833.g9a6d052-1
akonadi-mime22.04.2.r1726.gb105bee-122.04.2.r1737.gda65f9f-1
akonadi-notes22.04.2.r1075.gfbbd2dd-122.04.2.r1076.gf431a80-1
akonadi-search22.04.2.r1236.gb2714ea-122.04.2.r1238.g2ce4fa0-1
akonadiconsole22.04.2.r1592.gc805f1c-122.04.2.r1593.g5c3c2c6-1
akregator22.04.2.r6431.gf78fdc6a-122.04.2.r6435.g9c5aca0f-1
alligator 22.04.r22.gafffa26-1 22.04.r25.gf4b49b0-1
amazfish 2.0.8.r0.g3ffc996-1 2.0.8.r5.gd083090-1
angelfish 22.04.r30.g27f4ad5-1 22.04.r34.ge7f9bc6-1
ark22.04.2.r4775.g71ad43ee-122.04.2.r4781.g0eea2195-1
attica5.94.0.r866.g7be6ede-15.95.0.r873.g3e2a430-1
audiotube 22.04.r49.gd498d6a-1 22.04.r52.gef1582c-1
baloo5.94.0.r3054.gbcc58b5a-15.95.0.r3056.g77640514-1
baloo-widgets22.04.2.r758.g72fa5d6-122.04.2.r759.g3479921-1
blinken22.04.2.r670.g641a45b-122.04.2.r671.g5a81524-1
bluedevil1:5.24.5.r2406.g0cd64f35-11:5.24.5.r2409.g1cd23983-1
bluez-qt5.94.0.r711.g0615523-15.95.0.r712.g8a55d40-1
bomber22.04.2.r564.gd9de16c-122.04.2.r565.g8cf733f-1
breeze5.24.5.r2409.gc00fd4f4-15.24.5.r2414.g95e7d82f-1
breeze-gtk5.24.5.r484.g2b25cda-15.24.5.r485.gf5c1363-1
breeze-icons5.94.0.r1900.gfe012918-15.95.0.r1904.g57ae311b-1
calendarsupport22.04.1.r709.gc6c9b3f-122.04.2.r710.gc00699c-1
calindori 22.04.r22.g7f3c5de-1 22.04.r29.g3a28f37-1
cervisia22.04.2.r1669.g93f2f24-122.04.2.r1670.gcfffa58-1
discover5.24.5.r8698.gb9b40f2b-15.24.5.r8703.g058159e1-1
dolphin22.04.2.r7007.ga7f35a01c-122.04.2.r7017.g5ebf2065d-1
dolphin-plugins22.04.2.r661.gb08107a-122.04.2.r663.g1b416e7-1
drkonqi5.24.5.r789.g662f567f-15.24.5.r794.gb83a59ef-1
elisa22.04.2.r2980.ge09c5ac0-122.04.2.r2981.g1c55dcef-1
elisa-qtmm22.04.2.r2980.ge09c5ac0-122.04.2.r2981.g1c55dcef-1
eventviews22.04.1.r848.g5c7dd31-122.04.2.r850.g561d2c5-1
extra-cmake-modules5.94.0.r3488.g1ea9e424-15.95.0.r3501.gaa022e06-1
ffmpegthumbs22.04.2.r220.g06b17f9-122.04.2.r222.g3410855-1
filelight22.04.2.r1131.g390deee-122.04.2.r1137.g5d25ca0-1
frameworkintegration5.94.0.r638.g65e03e1-15.95.0.r640.g02f7b32-1
granatier22.04.2.r977.g67a6e3f-122.04.2.r979.gd9376be-1
grantlee-editor22.04.2.r823.g0bb5f15-122.04.2.r824.g468ddaa-1
grantleetheme22.04.2.r401.gb4f46cb-122.04.2.r402.gcc63045-1
gwenview22.04.2.r6858.g7276743f-122.04.2.r6862.g3e9e5275-1
incidenceeditor22.04.2.r902.g5f92a15-122.04.2.r903.g4b971fd-1
index-fm 2.1.2.r25.gba89ced-1 2.1.2.r28.g349212f-1
itinerary22.04.2.r1891.g225ae0e-122.04.2.r1905.gdfdc41e-1
juk22.04.2.r3154.g84e9cd76-122.04.2.r3156.g60597b74-1
k3b1:22.04.2.r6789.g0ede72063-11:22.04.2.r6794.g155f4173c-1
kaccounts-integration22.04.2.r1258.g95165c3-122.04.2.r1260.g722c934-1
kaccounts-providers22.04.2.r398.g1ecceb7-122.04.2.r399.g2025b96-1
kactivities5.94.0.r1396.gcf0bdeb6-15.95.0.r1397.gd9ffc203-1
kactivities-stats5.94.0.r408.g1dfdef1-15.95.0.r409.g82fb004-1
kactivitymanagerd5.24.5.r1401.gc6a8ee5-15.24.5.r1404.g4800f70-1
kaddressbook22.04.2.r6202.g155ff339-122.04.2.r6206.gc15b1318-1
kajongg22.04.2.r4344.g8e98986f-122.04.2.r4345.g075109cd-1
kalarm22.04.2.r7929.geaba0e02-122.04.2.r7931.g2c303202-1
kalk 22.04.r13.g1ef6c26-1 22.04.r15.g96d63b0-1
kalzium22.04.2.r4358.gc512b24a-122.04.2.r4362.g57bfa9b3-1
kamera22.04.2.r720.gf4ed624-122.04.2.r722.g0fc71b5-1
kamoso22.04.2.r1465.g9a98cf2-122.04.2.r1467.g8d426f2-1
kanagram22.04.2.r1313.gddb7b30-122.04.2.r1314.gf126bc4-1
kapidox5.94.0.r571.g9d0fffa-15.95.0.r572.g9baade5-1
kapman22.04.2.r654.g89f00ad-122.04.2.r656.g2d68338-1
kapptemplate22.04.2.r994.gd63178c-122.04.2.r995.g5544793-1
karchive5.94.0.r545.g09b9002-15.95.0.r546.g02873f6-1
kasts 22.04.r49.g7254d08-1 22.04.r56.g5fd96b6-1
kate22.04.2.r19102.g78126c435-122.04.2.r19107.g76b6067f3-1
katomic22.04.2.r960.g4e950df-122.04.2.r962.g42b067f-1
kauth5.94.0.r499.ge7d71ac-15.95.0.r500.g45e4859-1
kbackup22.04.2.r441.ga3fe030-122.04.2.r444.gd21d341-1
kblocks22.04.2.r716.g1e4294b-122.04.2.r717.g803621c-1
kbookmarks5.94.0.r461.g6a19b06-15.95.0.r462.g48e9e0c-1
kbounce22.04.2.r848.g3cbb1f2-122.04.2.r850.g68827aa-1
kbreakout22.04.2.r919.g15eb32e-122.04.2.r925.gd560231-1
kbruch22.04.2.r867.g0aa5d3c-122.04.2.r870.g1cae120-1
kcachegrind22.04.2.r1184.g2a25c3e-122.04.2.r1187.gfff2c26-1
kcachegrind-common22.04.2.r1184.g2a25c3e-122.04.2.r1187.gfff2c26-1
kcalc22.04.2.r1613.g324280d-122.04.2.r1615.g029c5b8-1
kcalendarcore5.94.0.r1325.gb4366b936-15.95.0.r1327.ge511aa0e8-1
kcalutils22.04.2.r966.g868c4edf0-122.04.2.r967.g2f2f818f0-1
kcharselect22.04.2.r531.gf5b0724-122.04.2.r532.g7788372-1
kclock 22.04.r22.gf3d3929-1 22.04.r28.g25741ac-1
kcmutils5.94.0.r641.g9cb74ec-15.95.0.r643.g1a295da-1
kcodecs5.94.0.r422.g80d6a55-15.95.0.r423.g9c370d3-1
kcolorchooser22.04.2.r272.g774e0b7-122.04.2.r273.gdb56e9b-1
kcompletion5.94.0.r494.gd0b541b-15.95.0.r495.geac2729-1
kconfig5.94.0.r958.g4e51b692-15.95.0.r960.ga83e1f50-1
kconfigwidgets5.94.0.r742.gafadfea-15.95.0.r744.g8ed2ec9-1
kcontacts1:5.94.0.r3334.g08d12955-11:5.95.0.r3335.gc5e94167-1
kcoreaddons5.94.0.r1503.g21e10c10-15.95.0.r1506.gc6f97178-1
kcrash5.94.0.r447.gb01f547-15.95.0.r448.g450d939-1
kdav1:5.94.0.r1343.g643e335-11:5.95.0.r1344.g007a2b6-1
kdbusaddons5.94.0.r416.g1e67d39-15.95.0.r417.g991b736-1
kde-cli-tools5.24.5.r1940.gdc0c68a-15.24.5.r1941.g81bc9a7-1
kde-dev-utils22.04.2.r589.ga98af95-122.04.2.r590.ge8897f8-1
kde-gtk-config5.24.5.r933.gc6ee331-15.24.5.r935.g1c13481-1
kdeclarative5.94.0.r1004.g48fc37d-15.95.0.r1008.g6206df6-1
kdeconnect22.04.2.r3463.gf4b1f842-122.04.2.r3466.gfc1efc3e-1
kded5.94.0.r461.g656e8fc-15.95.0.r462.g6179827-1
kdegraphics-thumbnailers22.04.2.r270.g49c71ed-122.04.2.r272.g3f44b67-1
kdelibs4support5.94.0.r1089.g7834c9f4-15.95.0.r1092.g56ac36d6-1
kdenetwork-filesharing22.04.2.r948.gf5b9946-122.04.2.r956.g70826c9-1
kdenlive22.04.2.r16231.g8d9869d25-122.04.2.r16261.g89f2e438e-1
kdepim-addons22.04.2.r4672.ge3d9c7822-122.04.2.r4678.g6bb95fb05-1
kdepim-runtime22.04.2.r15546.g9e6daf04f-122.04.2.r15550.g49bac12ea-1
kdeplasma-addons5.24.5.r8857.g6f47e15fd-15.24.5.r8890.gf568260f9-1
kdesignerplugin5.94.0.r354.gb096102-15.95.0.r355.gd7683e7-1
kdesu5.94.0.r507.g1ea4137-15.95.0.r508.ge288ba9-1
kdewebkit5.94.0.r302.gc988bec-15.95.0.r303.g966b456-1
kdf22.04.2.r857.gd210dbe-122.04.2.r858.g8b9c16c-1
kdialog22.04.2.r1226.gbd2024735-122.04.2.r1228.g1032b256c-1
kdiamond22.04.2.r725.gebc5929-122.04.2.r727.g518dd56-1
kdisplay5.24.5.r1487.g5b8ef1b-15.24.5.r1513.g21100f4-1
kdnssd5.94.0.r350.gddacb9c-15.95.0.r351.g10435ce-1
kdoctools5.94.0.r661.g260675e-15.95.0.r662.gc73e13e-1
keditbookmarks22.04.2.r2765.ge15b5e87e-122.04.2.r2766.gf43976f3a-1
kemoticons5.94.0.r416.gd9d73b7-15.95.0.r418.g6a34588-1
keysmith 22.04.r14.g40ba9f6-1 22.04.r16.g315eceb-1
kfilemetadata5.94.0.r862.gf5bfc2f-15.95.0.r863.g62b72c7-1
kfind22.04.2.r2697.g8c0c4d5cb-122.04.2.r2698.g3aec9b6e5-1
kfourinline22.04.2.r1027.g7155641-122.04.2.r1028.gca8a682-1
kgamma55.24.5.r477.g85a4bf9-15.24.5.r479.g2e745b2-1
kget22.04.2.r3201.gd47ea836-122.04.2.r3203.g7ceb76b4-1
kglobalaccel5.94.0.r524.g1a8e8cb-15.95.0.r525.g6d1e2d1-1
kgoldrunner22.04.2.r1280.g6a6c08a-122.04.2.r1282.g5c17758-1
kguiaddons5.94.0.r472.gcf020f9-15.95.0.r473.g37bab8b-1
khangman22.04.2.r1612.g64cb6a6-122.04.2.r1615.g026608f-1
khelpcenter22.04.2.r2744.g98d313b0-122.04.2.r2746.g2a98c394-1
kholidays1:5.94.0.r1037.g6d647f4-11:5.95.0.r1039.g16ae9fe-1
khotkeys5.24.5.r2137.gf1891e9-15.24.5.r2142.ga4c9785-1
khtml5.94.0.r586.gd37fa51-15.95.0.r588.gf78ee37-1
ki18n5.94.0.r556.g3708d6a-15.95.0.r557.g7303138-1
kiconthemes5.94.0.r602.geb2035a-15.95.0.r603.g7b3288f-1
kidentitymanagement22.04.2.r3889.ga02996b3-122.04.2.r3890.gbccaf0ed-1
kidletime5.94.0.r356.g9a34611-15.95.0.r357.g092bc38-1
kig22.04.2.r3188.g91e0bee1-122.04.2.r3190.g3a3aedbc-1
kigo22.04.2.r567.g0fb4a28-122.04.2.r568.g9f37f4e-1
killbots22.04.2.r788.gbdde38e-122.04.2.r793.g31dea29-1
kimageformats5.94.0.r404.g2aec1d3-15.95.0.r404.g2aec1d3-1
kimagemapeditor22.04.2.r493.ge1a2e5c-122.04.2.r495.g4254485-1
kimap22.04.2.r1194.gb218217-122.04.2.r1195.g80ae9b4-1
kinfocenter5.24.5.r2095.ga42bb35c-15.24.5.r2099.g65f3051c-1
kinit5.94.0.r437.gcb24988-15.95.0.r438.g3531c4b-1
kio5.94.0.r5502.gfbddc3c07-15.95.0.r5508.gbe09f7c18-1
kio-extras22.04.2.r7257.g41a6d351-122.04.2.r7264.g0ce6ea52-1
kio-gdrive22.04.2.r604.gcc3dac9-122.04.2.r613.ga698d46-1
kirigami25.94.0.r3146.g43751efe-15.95.0.r3153.g3cc181ae-1
kiriki22.04.2.r451.g67b9e37-122.04.2.r452.g7d12406-1
kitemmodels5.94.0.r607.gc02f2d8-15.95.0.r608.g00f2db8-1
kitemviews5.94.0.r371.g99465ed-15.95.0.r373.g8213c87-1
kiten22.04.2.r1185.g1e0da08-122.04.2.r1186.gd129628-1
kitinerary22.04.2.r2245.gc93acfe-122.04.2.r2248.g11ba3d2-1
kjobwidgets5.94.0.r415.ge8239db-15.95.0.r416.gb636904-1
kjs5.94.0.r362.gdb0d84f-15.95.0.r363.gfe9b0f5-1
kjsembed5.94.0.r326.gae85182-15.95.0.r327.g5c51bcf-1
kjumpingcube22.04.2.r824.gd091b62-122.04.2.r825.g89b816d-1
kldap22.04.2.r949.g58c9601-122.04.2.r952.ge0d6f23-1
kleopatra22.04.2.r6555.g8d50e6ad-122.04.2.r6566.gc538a8de-1
klettres22.04.2.r962.g3c4ed84-122.04.2.r965.g1c2e818-1
klickety22.04.2.r673.gd8d1a11-122.04.2.r675.g21fe0e8-1
klines22.04.2.r815.gd0e2223-122.04.2.r818.g1976282-1
kmag22.04.2.r736.g4a8ca00-122.04.2.r737.g2ea44ab-1
kmahjongg22.04.2.r1549.g687c34a-122.04.2.r1551.gf6c525e-1
kmail22.04.2.r26412.gdf82fa4fe-122.04.2.r26416.g1d3fb518a-1
kmail-account-wizard22.04.2.r886.g50bd247-122.04.2.r887.g826f9dd-1
kmailtransport22.04.2.r1744.g6e1b2a5-122.04.2.r1745.g6e08863-1
kmbox22.04.2.r598.g4fba26c-122.04.2.r599.g62b4fa7-1
kmediaplayer5.94.0.r317.g5843afa-15.95.0.r318.g560b0af-1
kmenuedit5.24.5.r1041.gdf1efd2-15.24.5.r1042.g3d3785e-1
kmime22.04.2.r1517.g6bf8b7b-122.04.2.r1518.ga183dcc-1
kmines22.04.2.r1765.g80458c8-122.04.2.r1766.g794f6e4-1
kmousetool22.04.2.r444.g9be51b9-122.04.2.r445.g9ef888a-1
kmouth22.04.2.r728.gdb7edab-122.04.2.r731.gb6eb782-1
kmplot22.04.2.r1495.g8c295cd-122.04.2.r1496.ge9322f1-1
knavalbattle22.04.2.r1430.gc88b30f-122.04.2.r1432.g7b07ac1-1
knetwalk22.04.2.r700.gca8f4f9-122.04.2.r701.g73f7fd6-1
knewstuff5.94.0.r1349.g4b2e1167-15.95.0.r1354.gf518415e-1
knights22.04.2.r1140.g298b00e-122.04.2.r1144.ge36f2e2-1
knotes22.04.2.r3667.ge1c43fc8-122.04.2.r3670.g9e3b836c-1
knotifications5.94.0.r739.g0cdaaae-15.95.0.r743.g2fb91eb-1
knotifyconfig5.94.0.r383.g5ea70c4-15.95.0.r384.gb1ad8bb-1
koko 22.04.r22.gf90b596-1 22.04.r27.g1ebdd1d-1
kolf22.04.2.r1501.g4c15e42-122.04.2.r1505.g49e3f4a-1
kollision22.04.2.r535.gcb67278-122.04.2.r536.g0d791c8-1
kolourpaint22.04.2.r2410.g897e92cb-122.04.2.r2413.ge0c9f0c4-1
kompare22.04.2.r1141.ga5986f0-122.04.2.r1142.gc31d802-1
kongress 22.04.r15.gb1d311a-1 22.04.r18.g9e54ca2-1
konqueror22.04.2.r15118.g709bc77f1-122.04.2.r15121.g111ebc5a1-1
konquest22.04.2.r930.gdaf22b6-122.04.2.r932.g2100fac-1
konsole22.04.2.r8467.gdff5c1fa-122.04.2.r8472.g75226860-1
kontact22.04.2.r5533.g1ccb9b7a-122.04.2.r5537.g0e5d4bb7-1
kontactinterface22.04.2.r691.g76e2942-122.04.2.r695.g55c27c1-1
kontrast22.04.2.r207.gac08e3d-122.04.2.r208.gdde15c4-1
konversation22.04.2.r9117.g06251138-122.04.2.r9120.ge7d3b8f8-1
kopete22.04.2.r16437.gd6e89297d-122.04.2.r16441.g73ae620b4-1
korganizer22.04.2.r11718.gd3205f8c3-122.04.2.r11723.g092799b0e-1
kosmindoormap22.04.2.r734.gc9b32b7-122.04.2.r735.g33a701c-1
kpackage5.94.0.r751.g8faa108-15.95.0.r752.g3fa2476-1
kparts5.94.0.r585.g23de3a2-15.95.0.r587.ga563fe5-1
kpat22.04.2.r2617.g36da91eb-122.04.2.r2619.g22b77e05-1
kpeople5.94.0.r1375.g48fd77a-15.95.0.r1376.g07e1a84-1
kpimtextedit22.04.2.r1596.g4170e58-122.04.2.r1597.g08daf8b-1
kpkpass22.04.2.r297.ge731000-122.04.2.r298.g76e2810-1
kplotting5.94.0.r323.g7174d74-15.95.0.r324.g0fa36e5-1
kpmcore22.04.2.r1285.geb50358-122.04.2.r1286.g26e069d-1
kpty5.94.0.r374.g593dc86-15.95.0.r375.g5d745ae-1
kpublictransport22.04.2.r2020.gb732d04e-122.04.2.r2022.g61f73bd9-1
kquickcharts5.94.0.r518.g467561f-15.95.0.r519.gc9638ad-1
krdc22.04.2.r1595.g239d395-122.04.2.r1599.g322ed80-1
krecorder 22.04.r20.gea2d0f5-1 22.04.r23.gb05163e-1
kreversi22.04.2.r1270.g3425b3c-122.04.2.r1272.gb7ccf09-1
krfb22.04.2.r1495.g1722292-122.04.2.r1497.g4433609-1
kross5.94.0.r358.ge186dad-15.95.0.r359.gd3baa4f-1
krunner5.94.0.r765.g8410293-15.95.0.r767.g9d2eafe-1
kscreen5.24.5.r1472.g7811d81-15.24.5.r1475.g3387ca5-1
kscreenlocker5.24.5.r952.ge851369-15.24.5.r955.g71c1cde-1
kservice5.94.0.r1014.g48b10de-15.95.0.r1016.g4ed15f6-1
kshisen22.04.2.r1243.g6ab1cb6-122.04.2.r1245.ge3dcbef-1
ksirk22.04.2.r1029.ga5a331e-122.04.2.r1030.gc2fff2b-1
ksmtp22.04.2.r448.gce2f022-122.04.2.r449.gf6086e4-1
ksnakeduel22.04.2.r846.g0dde9cf-122.04.2.r852.gd696ce9-1
kspaceduel22.04.2.r671.gb7accb7-122.04.2.r672.g13e709f-1
ksquares22.04.2.r558.g2abf6be-122.04.2.r559.g4b16b84-1
ksshaskpass5.24.5.r209.gd906c9e-15.24.5.r210.gcd5e9f9-1
ksudoku22.04.2.r1111.gb89b6d8-122.04.2.r1113.g1b81fe5-1
ksysguard5.24.5.r3530.gcfa80101-15.24.5.r3532.geaf09c18-1
ksystemlog22.04.2.r730.g09e735a-122.04.2.r734.gfe661b5-1
ksystemstats5.24.5.r227.g18a85e5-15.24.5.r229.g2b5c815-1
kteatime22.04.2.r758.g3f8f2a0-122.04.2.r759.g8ee5306-1
ktexteditor5.94.0.r3413.g895524a2-15.95.0.r3417.g11b76751-1
ktextwidgets5.94.0.r447.g2adcaa6-15.95.0.r448.g5cab5e6-1
ktimer22.04.2.r517.gcdcc455-122.04.2.r518.gedc32ed-1
ktnef22.04.2.r718.g42c3edb-122.04.2.r719.g4832e5d-1
ktorrent22.04.2.r2856.g88ed88d5-122.04.2.r2863.g6149f01c-1
ktouch22.04.2.r2182.g510b582-122.04.2.r2184.gbaa288f-1
ktrip 22.04.r10.g0787d0f-1 22.04.r13.gd40bc43-1
ktuberling22.04.2.r1042.g10bbd81-122.04.2.r1043.g2499bca-1
kturtle22.04.2.r1171.ga68e065-122.04.2.r1173.g7fd5c38-1
kubrick22.04.2.r407.g92980bc-122.04.2.r408.g4477e3b-1
kunitconversion5.94.0.r417.g8fcc890-15.95.0.r419.g8192623-1
kwallet5.94.0.r1150.g26b7551-15.95.0.r1152.g1f9ddb3-1
kwallet-pam5.24.5.r268.g445e1e4-15.24.5.r269.g4112e1f-1
kwave22.04.2.r3794.g1b4d6e6b-122.04.2.r3797.gca0072aa-1
kwayland5.94.0.r1163.g6f94454-15.95.0.r1164.ga6d238b-1
kweather 22.04.r25.g83a4e48-1 22.04.r32.g7f44c36-1
kweathercore 0.5.r28.g654cd01-1 0.5.r29.g48e07b1-1
kwidgetsaddons5.94.0.r943.g41da9dda-15.95.0.r946.g733fc84d-1
kwin5.24.5.r22576.gdc9c431fe-15.24.5.r22607.ga4b41c84e-1
kwindowsystem5.94.0.r683.gc3fa9ca-15.95.0.r684.ge66fb67-1
kwinft5.24.5.r20608.gc6af0068f-15.24.5.r20822.g972bc0a4c-1
kwordquiz22.04.2.r1183.g3c7c07d-122.04.2.r1185.g5483ce2-1
kwrite22.04.2.r19102.g78126c435-122.04.2.r19107.g76b6067f3-1
kwrited5.24.5.r507.g9f98101-15.24.5.r509.g9cfbcd4-1
kxmlgui5.94.0.r882.gb025ee95-15.95.0.r886.gf9772b11-1
kxmlrpcclient5.94.0.r481.g0d4d74420-15.95.0.r482.g9d96a79eb-1
libakonadi22.04.2.r12766.g9b2b51157-122.04.2.r12768.g757023978-1
libgravatar22.04.2.r424.g29c8756-122.04.2.r425.gf25146c-1
libkcddb22.04.2.r762.gca224c5-122.04.2.r764.ga779c9f-1
libkdegames22.04.2.r2233.gfef5ac21-122.04.2.r2241.gc1fdffea-1
libkdepim22.04.2.r908.g024c373-122.04.2.r909.g0d7d0ac-1
libkgapi22.04.2.r1363.g765620a-122.04.2.r1364.g6c803cd-1
libkipi22.04.2.r1279.g5b90094-122.04.2.r1280.g5b6d13f-1
libkleo22.04.2.r1173.gb8a0ab7-122.04.2.r1176.g941b805-1
libkmahjongg22.04.2.r481.g848e1a2-122.04.2.r484.g1aef9b5-1
libkomparediff222.04.2.r342.gf465f1a-122.04.2.r346.g5e898ac-1
libkscreen5.24.5.r1629.g18b8f22-15.24.5.r1630.g28b1f89-1
libksieve22.04.2.r1717.gbd666860-122.04.2.r1718.g990608f2-1
libksysguard5.24.5.r2401.g487511f-15.24.5.r2412.g2437fd7-1
libktorrent22.04.2.r548.g361f3ce-122.04.2.r551.g66cdae3-1
lokalize22.04.2.r1828.g20cd498c-122.04.2.r1832.gbef89622-1
lskat22.04.2.r853.g3bbd499-122.04.2.r854.g412d41f-1
mailcommon22.04.2.r1243.g63d153e-122.04.2.r1246.g15d8479-1
mailimporter22.04.2.r520.g659950e-122.04.2.r521.g5e0c82c-1
marble22.04.2.r13445.gc8d57df6e-122.04.2.r13449.gcb32bb359-1
marble-common22.04.2.r13445.gc8d57df6e-122.04.2.r13449.gcb32bb359-1
marble-qt22.04.2.r13445.gc8d57df6e-122.04.2.r13449.gcb32bb359-1
markdownpart22.04.2.r125.g7e27b35-122.04.2.r127.g9cd5d34-1
maui-nota 2.1.2.r5.g44f8193-1 2.1.2.r6.g0e29f74-1
maui-pix 2.1.2.r8.gc5ad85f-1 2.1.2.r10.g732d5f7-1
maui-shell 0.5.0.r31.g7cfc7c8-1 0.5.0.r32.ga77c031-1
mauikit-accounts 2.1.2.r2.g4338583-1 2.1.2.r3.ga54446a-1
mauikit-filebrowsing 2.1.2.r5.ge9136cf-1 2.1.2.r6.g5afb74f-1
mauikit-imagetools 2.1.2.r2.gb58ccc3-1 2.1.2.r3.g9de2c06-1
mauikit-texteditor 2.1.2.r3.g17e1da7-1 2.1.2.r4.g2270a27-1
mbox-importer22.04.2.r568.g198ae0a-122.04.2.r569.g3301724-1
messagelib22.04.2.r6576.g546a6f306-122.04.2.r6582.ge8989952d-1
milou5.24.5.r773.g19dc0f0-15.24.5.r776.g7cb6340-1
minuet22.04.2.r611.g9dd35fc-122.04.2.r614.g3e56823-1
modemmanager-qt5.94.0.r554.g1427c53-15.95.0.r555.ge6dbd16-1
mycroft-skill-installer r92.f37d97f-1 r94.3f124f8-1
neochat22.04.r72.g72994d03-122.04.r81.g10922aeb-1
networkmanager-qt5.94.0.r1153.gb3af371-15.95.0.r1154.ga9a9bb1-1
okular22.04.2.r9754.g12a222c95-122.04.2.r9757.gfbdc3f0fa-1
oxygen5.24.5.r4482.g301b69e8-15.24.5.r4485.g49e860d3-1
oxygen-icons1:5.94.0.r5.gbff159d-11:5.95.0.r5.gbff159d-1
oxygen-icons-svg1:5.94.0.r5.gbff159d-11:5.95.0.r5.gbff159d-1
palapeli22.04.2.r1284.gf1a4bbd-122.04.2.r1286.g4aa0212-1
parley22.04.2.r4523.g0acdabee-122.04.2.r4526.g3ec94a32-1
partitionmanager22.04.2.r1629.g64c42a2-122.04.2.r1630.g1b55a1f-1
picmi22.04.2.r563.gabee479-122.04.2.r564.g4c78eed-1
pim-data-exporter22.04.2.r2757.gf9ca308b-122.04.2.r2761.g931b33b5-1
pim-sieve-editor22.04.2.r1628.g27329f5-122.04.2.r1629.gd8fac69-1
pimcommon22.04.1.r1243.g223bd77-122.04.2.r1244.g440bbb9-1
plank-player r26.fb747e3-1 r27.21e231b-1
plasma-bigscreen r469.gbecee04-1 r470.g38bf2e2-1
plasma-browser-integration5.24.5.r1327.gebbdb0f0-15.24.5.r1331.g1ee520f9-1
plasma-camera 1.0.r125.gd3e8648-1 1.0.r127.g85ec608-1
plasma-desktop5.24.5.r9319.gf251558c6-15.24.5.r9341.gf6755c2a9-1
plasma-dialer 22.04.r32.g69bbfa4-1 22.04.r37.g0b47426-1
plasma-disks5.24.5.r275.gb7ad094-15.24.5.r277.g544e1c7-1
plasma-firewall5.24.5.r625.g0b29f4c-15.24.5.r627.g1e71967-1
plasma-framework5.94.0.r16337.gd444c3452-15.95.0.r16343.g4cda8ccf2-1
plasma-mobile5.24.5.r1818.g23b4ad1f0-15.24.5.r1822.g25f36c402-1
plasma-mobile-nm5.24.5.r3256.g5af8b689-15.24.5.r3257.g193621bd-1
plasma-nano5.24.5.r186.g8422e10-15.24.5.r187.ga823e03-1
plasma-nm5.24.5.r3256.g5af8b689-15.24.5.r3257.g193621bd-1
plasma-phonebook 22.04.r20.g9294660-1 22.04.r24.g076ad6d-1
plasma-remotecontrollers r90.gaa77d1e-1 r92.gf9d7b6f-1
plasma-sdk5.24.5.r2361.g87b50a99-15.24.5.r2363.g792813e3-1
plasma-settings 22.04.r40.gff651c4-1 22.04.r45.gb3bc6a3-1
plasma-systemmonitor5.24.5.r571.g651908a-15.24.5.r577.g7471d88-1
plasma-thunderbolt5.24.5.r186.g75719e2-15.24.5.r188.gef12dd5-1
plasma-vault5.24.5.r382.gd5bb749-15.24.5.r383.g6ce0f40-1
plasma-wayland-session5.24.5.r11940.g0e699f49e-15.24.5.r11976.ga8a455e8f-1
plasma-workspace5.24.5.r11940.g0e699f49e-15.24.5.r11976.ga8a455e8f-1
plasma-workspace-wallpapers5.24.5.r347.g6f61fb5-15.24.5.r352.g664f9e8-1
plasmatube 22.04.r13.g8b9e1aa-1 22.04.r16.g6537b94-1
polkit-kde-agent5.24.5.r525.g56ad717-15.24.5.r528.gdc2264d-1
powerdevil5.24.5.r2547.g278f9d25-15.24.5.r2551.ge43367e3-1
print-manager22.04.2.r1134.g2c584b8-122.04.2.r1137.g0e2d46d-1
prison5.94.0.r386.g33118b8-15.95.0.r387.g541e19c-1
purpose5.94.0.r974.g08006d7-15.95.0.r976.gf4f4ef4-1
qcachegrind22.04.2.r1184.g2a25c3e-122.04.2.r1187.gfff2c26-1
qmlkonsole 22.04.r31.gba5ce5f-1 22.04.r39.g662c0fb-1
qqc2-breeze-style5.24.5.r247.g0a28fc4-15.24.5.r248.g2514ff8-1
qqc2-desktop-style5.94.0.r622.gae16062-15.95.0.r624.g17715aa-1
rocs22.04.2.r3081.gc6ae7d1f-122.04.2.r3085.g3261b2e9-1
sddm-kcm5.24.5.r657.g74e187b-15.24.5.r663.g0803d17-1
signon-kwallet-extension22.04.2.r79.g87b0c1e-122.04.2.r81.gd26709f-1
solid5.94.0.r769.g48bdc56-15.95.0.r772.g5c4585e-1
sonnet5.94.0.r696.g9b0f16a-15.95.0.r697.g263f3dd-1
spacebar 22.04.r23.g48fc06d-1 22.04.r28.g1a37539-1
spectacle22.04.2.r1354.ge1253ee-122.04.2.r1356.gdd8cf5c-1
step22.04.2.r1191.g63fe411-122.04.2.r1192.g9297122-1
svgpart22.04.2.r224.g406ed03-122.04.2.r226.g05ee109-1
sweeper22.04.2.r572.g3bc29ce-122.04.2.r573.g02092f6-1
syndication5.94.0.r872.ge2f42e9-15.95.0.r873.g1b51658-1
syntax-highlighting5.94.0.r1836.g3557b4fd-15.95.0.r1840.ga4cc793d-1
systemsettings5.24.5.r2667.g6a7c670b-15.24.5.r2669.g9a0ab367-1
telepathy-kde-accounts-kcm22.04.2.r1216.ga98e69c-122.04.2.r1217.gf18fe77-1
telepathy-kde-common-internals22.04.2.r2016.gc63b3dc-122.04.2.r2018.g46dc56c-1
telepathy-kde-text-ui22.04.2.r2043.ga0f4b60-122.04.2.r2045.gf5f9baf-1
threadweaver5.94.0.r540.g0a6e3c2-15.95.0.r541.g0ec4b7f-1
tokodon 22.04.r45.g16da6cf-1 22.04.r50.g25d4087-1
umbrello22.04.2.r8470.ge68f65b97-122.04.2.r8485.ge4d79cfe8-1
vakzination 22.04.r26.g31dc285-1 22.04.r29.gd443082-1
vvave 2.1.2.r16.g4db7199-1 2.1.2.r18.g42b3eba-1
wrapland5.24.5.r1750.gb2d64a3-15.24.5.r1755.g1c509e2b-1
xdg-desktop-portal-kde5.24.5.r495.g9865283-15.24.5.r498.g826878e-1
yakuake22.04.2.r796.gf0f382b-122.04.2.r797.gc92c662-1
zeroconf-ioslave22.04.2.r385.gd0d85c6-122.04.2.r388.g6e1c9fe-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
