Hello ARM community.
Point releases all around. The most exciting part of this update is the update to SystemD.
Some highlights:
- Most of our kernels got updated
- Firefox updated to 100.0.2
- And Thunderbird updated to 91.9.1
- SystemD updated to 251
- And Mesa updated to 22.0.4
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Mon May 23 21:18:48 CEST 2022)
- arm-testing community aarch64: 323 new and 299 removed package(s)
- arm-testing core aarch64: 31 new and 31 removed package(s)
- arm-testing extra aarch64: 422 new and 416 removed package(s)
- arm-testing kde-unstable aarch64: 258 new and 258 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-05-16 2022-05-23
clockworkpi-a06-post-install 20220117-1 20220518-1
code 1.67.0-1 1.67.2-1
element-desktop 1.10.12-2 1.10.12-3
element-web 1.10.12-2 1.10.12-3
gnome-settings-daemon-hybris 41.0-1 41.0-2
libglibutil 1.0.62-1 1.0.64-1
oc2-post-install 20220216-1 20220518-1
oc4-post-install 20210530-1 20220518-1
on2-post-install 20220306-1 20220518-1
phoc 0.13.1+28+g6eec533-1 0.13.1+47+g4d9e3b0-1
phosh0.17.0+140+ge00bc029-10.17.0+162+g95913fa0-1
pinebook-post-install 20220502-1 20220518-1
pinebookpro-post-install 20220215-1 20220518-1
quartz64-post-install 20210907-1 20220518-1
radxa-zero-post-install 20220216-1 20220518-1
rock64-post-install 20210125-1 20220518-1
rockpi4-post-install 20210728-1 20220518-1
rockpro64-post-install 20220122-1 20220518-1
rpi4-post-install 20220326-1 20220522-1
signal-desktop 5.40.1-1 5.43.0-1
vim3-post-install 20220211-1 20220518-1
feedbackd-hybris - 0.0.0+git20220208-1
linux-lts-udl - 5.15.41-1
linux-lts-udl-headers - 5.15.41-1
:: Different sync package(s) in repository community aarch64
acsccid 1.1.8-1 1.1.8-2
alembic 1.8.3-2 1.8.3-3
ansible 5.7.1-1 5.8.0-1
ansible-core 2.12.5-1 2.13.0-1
ansible-lint 6.1.0-2 6.2.1-1
argocd 2.3.3-2 2.3.4-1
babel-core 7.17.10-1 7.17.12-1
bacon 2.1.0-1 2.2.0-1
bash-language-server 3.0.2-1 3.0.3-1
bctoolbox 5.1.10-1 5.1.31-1
buho 2.1.1-1 2.1.2-1
bzrtp 5.1.10-1 5.1.31-1
cacti 1.2.20-1 1.2.21-1
cage 0.1.4-5 0.1.4-8
cargo-deny 0.11.4-1 0.12.1-1
cargo-udeps 0.1.28-1 0.1.29-1
ccache 4.6-1 4.6.1-1
cgns 4.3.0-2 4.3.0-3
chezmoi 2.15.4-1 2.16.0-1
clementine1.4.0rc1+776+gcefe81d0c-2 1.4.0rc2-1
cmark-gfm 0.29.0.gfm.2-2 0.29.0.gfm.2-3
colordiff 1.0.19-1 1.0.20-1
communicator 2.1.1-1 2.1.2-1
cppcheck 2.7.5-1 2.8-1
crash 8.0.0-2 8.0.1-1
cri-o 1.23.2-2 1.24.0-1
crictl 1.23.0-2 1.24.1-1
critest 1.23.0-2 1.24.1-1
cython 0.29.28-1 0.29.30-1
cython2 0.29.28-1 0.29.30-1
dagger 0.2.9-1 0.2.11-1
dart 2.17.0-1 2.17.1-1
dart-sass 1.51.0-1 1.52.1-1
deja-dup 43.2-1 43.3-1
diffoscope 212-1 213-1
displaycal 3.8.9.3-1 3.9.4-1
docker-compose 2.5.0-1 2.5.1-1
drone 2.11.1-2 2.12.0-1
drone-oss 2.11.1-2 2.12.0-1
drumstick 2.6.0-1 2.6.1-1
dune 3.1.1-1 3.2.0-1
e-antic 1.2.0-1 1.2.1-1
evtest 1.34-2 1.35-1
fcitx5 5.0.15-1 5.0.16-1
gdal 3.4.0-6 3.4.3-1
gitea 1.16.7-1 1.16.8-1
gmp-ecm 7.0.4-4 7.0.5-1
gnome-appfolders-manager 0.4.4-1 0.4.5-1
gnome-code-assistance2:3.16.1+14+gaad6437-23:3.16.1+r14+gaad6437-1
gnome-latex 3.38.0+13+g703c2c9-1 3.40.0-1
gnome-passwordsafe 6.4-1 6.5-1
gopass 1.14.1-1 1.14.2-1
gopls 0.8.3-1 0.8.4-1
gunicorn 20.1.0-3 20.1.0-4
gupnp-tools 0.10.2-1 0.10.3-1
gwakeonlan 0.8.2-2 0.8.3-1
hdf5 1.12.1-1 1.12.2-1
hdf5-openmpi 1.12.1-1 1.12.2-1
helm 3.8.2-1 3.9.0-1
htmldoc 1.9.15-1.1 1.9.16-1
httpie 2.6.0-2 3.2.1-1
hugo 0.98.0-1 0.99.1-1
hyperfine 1.13.0-1 1.14.0-1
i2pd 2.41.0-1 2.42.0-1
index-fm 2.1.1-1 2.1.2-1
java-atk-wrapper-common 0.38.0-4 0.40.0-1
java-atk-wrapper-openjdk 0.38.0-4 0.40.0-1
java-atk-wrapper-openjdk11 0.38.0-4 0.40.0-1
java-atk-wrapper-openjdk17 0.38.0-4 0.40.0-1
java-atk-wrapper-openjdk8 0.38.0-4 0.40.0-1
jc 1.18.8-1 1.19.0-1
jenkins 2.347-1 2.348-1
jmol 14.32.55-1 14.32.57-1
jsmol 14.32.55-1 14.32.57-1
kstars 1:3.5.8-1 1:3.5.8-2
kubeone 1.4.0-1 1.4.3-1
kvantum 1.0.1-2 1.0.2-1
labplot 2.9.0-1 2.9.0-2
libdnet 1.12-13 1.16.1-1
libhx 4.2-1 4.5-1
libindi 1.9.5.1-1 1.9.6-1
libmatio 1.5.23-1 1.5.23-2
libofx 0.10.3-1 0.10.5-1
libofx-doc 0.10.3-1 0.10.5-1
libressl 3.5.2-1 3.5.3-1
libretls 3.4.2-1 3.5.2-1
libtraceevent 1:1.5.3-1 1:1.6.0-1
libtraceevent-docs 1:1.5.3-1 1:1.6.0-1
libtracefs 1.3.1-1 1.4.0-1
libtracefs-docs 1.3.1-1 1.4.0-1
log4cxx 0.12.1-1 0.13.0-1
lua-dkjson 2.5-5 2.6-1
lua51-dkjson 2.5-5 2.6-1
lua52-dkjson 2.5-5 2.6-1
lua53-dkjson 2.5-5 2.6-1
luajit2.1.0.beta3.r404.g3ee3c9cf-12.1.0.beta3.r407.g4ef96cff-1
lynis 3.0.7-1 3.0.8-1
marked 4.0.0-1 4.0.1-1
mathjax 3.2.0-1 3.2.1-1
matrix-synapse 1.57.0-1 1.59.1-1
maturin 0.12.15-1 0.12.17-1
maui-clip 2.1.1-2 2.1.2-1
maui-nota 2.1.1-1 2.1.2-1
maui-pix 2.1.1-1 2.1.2-1
maui-shelf 2.1.1-1 2.1.2-1
maui-station 2.1.1-1 2.1.2-1
mauikit 2.1.1-1 2.1.2-1
mauikit-accounts 2.1.1-1 2.1.2-1
mauikit-filebrowsing 2.1.1-1 2.1.2-1
mauikit-imagetools 2.1.1-1 2.1.2-1
mauikit-texteditor 2.1.1-1 2.1.2-1
mdcat 0.26.1-1 0.27.1-1
med 4.1.0-7 4.1.0-8
mediastreamer 5.1.30-1 5.1.31-1
meilisearch 0.27.0-1 0.27.1-1
memray 1.0.3-4 1.1.0-2
miniserve 0.19.4-1 0.19.5-1
mmctl 6.6.1-1 6.7.0-1
monit 5.31.0-1.1 5.32.0-1
mruby 3.0.0-2 3.1.0-1
nerdctl 0.19.0-2 0.20.0-1
netcdf 4.8.1-2 4.8.1-3
netcdf-openmpi 4.8.1-2 4.8.1-3
network-manager-sstp 1.2.6-4 1.3.0-1
nextcloud-client 2:3.5.0-1 2:3.5.1-2
nextcloud-client-cloudproviders 2:3.5.0-1 2:3.5.1-2
nim 1.4.8-1 1.6.6-1
nimble 1:0.13.1-1 -
nix 2.8.0-1 2.8.1-1
nix-docs 2.8.0-1 2.8.1-1
nodejs 18.1.0-1 18.2.0-1
nodejs-lts-fermium 14.19.2-1 14.19.3-1
nomad 1.2.6-3 1.3.1-1
npm-check-updates 12.5.11-1 13.0.1-1
nuitka 0.7.7-1 0.8-1
octave 7.1.0-3 7.1.0-4
oil 0.10.0-1 0.10.1-1
operator-sdk 1.20.0-1 1.20.1-1
ortp 5.1.10-1 5.1.31-1
osinfo-db 20220214-1 20220516-1
pdal 2.4.0-1 2.4.1-1
pdfjs 2.13.216-1 2.14.305-1
photoflare 1.6.9-1 1.6.10-1
php-snuffleupagus 0.8.0-1 0.8.2-1
plantri 5.2-1 5.3-1
pmbootstrap 1.43.0-2 1.43.1-1
popeye 0.9.8-2 0.10.0-1
pyright 1.1.247-1 1.1.248-1
pysolfc 2.14.1-1 2.16.0-1
pysolfc-cardsets 2.0-6 2.1-1
python-ansible-compat 2.0.3-1 2.0.4-1
python-autobahn 22.3.2-1 22.4.2-1
python-awesomeversion 22.4.2-1 22.5.1-1
python-cmarkgfm 0.7.0-1 0.8.0-1
python-darkdetect 0.5.1-2 0.6.0-1
python-dropbox 11.30.0-1 11.31.0-1
python-dulwich 0.20.35-1 0.20.40-1
python-filelock 3.4.2-1 3.5.0-1
python-fints 3.0.1-2 3.1.0-1
python-flake8-black 0.3.2-1 0.3.3-1
python-gdal 3.4.0-6 3.4.3-1
python-gnupg 0.4.8-2 0.4.9-1
python-google-api-core 2.7.2-1 2.8.0-1
python-google-api-python-client 2.46.0-1 2.48.0-1
python-h5py 3.6.0-3 3.6.0-4
python-h5py-openmpi 3.6.0-3 3.6.0-4
python-hatchling 0.21.1-2 0.25.0-2
python-httpcore 0.14.7-1 0.15.0-1
python-identify 2.5.0-1 2.5.1-1
python-ipywidgets 7.7.0-3 7.7.0-4
python-jupyterlab_server 2.13.0-1 2.14.0-1
python-jwcrypto 1.3.0-1 1.3.1-1
python-license-expression 21.6.14-5 30.0.0-1
python-mongoengine 0.24.0-1 0.24.1-1
python-oslo-utils 4.10.2-1 4.11.0-1
python-paramiko 2.9.2-1 2.11.0-1
python-pg8000 1.27.1-1 1.29.1-1
python-pint 0.19.1-1 0.19.2-1
python-praw 7.5.0-1 7.6.0-1
python-proxy.py 2.4.1-1 2.4.2-1
python-pynitrokey 0.4.21-1 0.4.22-1
python-pytables 3.7.0-2 3.7.0-3
python-pytest-asyncio 0.17.2-1 0.18.0-1
python-pytest-httpx 0.17.2-1 0.17.3-1
python-pytools 2022.1.2-1 2022.1.3-1
python-pywlroots 0.15.13-1 0.15.14-1
python-rpy2 3.5.1-1 3.5.2-1
python-scikit-learn 1.1.0-1 1.1.1-1
python-scipy 1.8.0-1 1.8.1-1
python-spsdk 1.6.3-2 1.6.3-3
python-sqlalchemy 1.4.35-1 1.4.36-1
python-svglib 1.2.1-1 1.3.0-1
python-terminado 0.13.3-1 0.15.0-1
python-traitlets 5.1.1-1 5.2.1.post0-1
python-ujson 5.2.0-1 5.3.0-1
python-utils 3.1.0-1 3.2.3-1
python-wsgi-intercept 1.9.3-1 1.10.0-1
qcad 3.27.5.0-2 3.27.6.0-1
qgis 3.24.1-2 3.24.3-1
qmmp 2.0.4-1 2.1.0-1
qpwgraph 0.2.6-2 0.3.0-1
remind 3.4.0-1 4.0.0-1
remmina 1:1.4.25-1 1:1.4.26-1
reuse 0.14.0-1 1.0.0-1
ruby-json 2.6.1-1 2.6.2-1
ruby-loofah 2.14.0-1 2.18.0-1
ruby-psych 4.0.3-2 4.0.4-2
ruby-rack-protection 2.1.0-2 2.2.0-1
ruby-rouge 3.26.0-2 3.28.0-1
rust-analyzer 20220509-1 20220517-1
rustypaste 0.7.0-1 0.7.1-1
scite 5.2.1-1 5.2.3-1
sentry-cli 1.72.1-1 2.0.4-1
serverless 3.17.0-1 3.18.1-1
shfmt 3.4.3-1 3.5.0-1
shotwell 2:0.30.15-1 2:0.30.16-1
sonic-pi 3.3.1-1 3.3.1-2
sqlfluff 0.13.1-1 0.13.2-1
staticcheck 2022.1.1-2 2022.1.2-1
stellarsolver 2.2-1 2.3-1
strawberry 1.0.4-2 1.0.4-3
stylelint 14.8.2-1 14.8.3-1
sway 1:1.7-2 1:1.7-9
sz 2.1.12-3 2.1.12-4
terraform 1.1.9-1 1.2.0-1
tiled 1.8.4-1 1.8.5-1
tor 0.4.7.7-1 0.4.7.7-2
translate-toolkit 3.6.1-1 3.6.2-1
ttc-iosevka 15.3.0-1 15.3.1-1
ttc-iosevka-aile 15.3.0-1 15.3.1-1
ttc-iosevka-curly 15.3.0-1 15.3.1-1
ttc-iosevka-curly-slab 15.3.0-1 15.3.1-1
ttc-iosevka-etoile 15.3.0-1 15.3.1-1
ttc-iosevka-slab 15.3.0-1 15.3.1-1
ttc-iosevka-ss01 15.3.0-1 15.3.1-1
ttc-iosevka-ss02 15.3.0-1 15.3.1-1
ttc-iosevka-ss03 15.3.0-1 15.3.1-1
ttc-iosevka-ss04 15.3.0-1 15.3.1-1
ttc-iosevka-ss05 15.3.0-1 15.3.1-1
ttc-iosevka-ss06 15.3.0-1 15.3.1-1
ttc-iosevka-ss07 15.3.0-1 15.3.1-1
ttc-iosevka-ss08 15.3.0-1 15.3.1-1
ttc-iosevka-ss09 15.3.0-1 15.3.1-1
ttc-iosevka-ss10 15.3.0-1 15.3.1-1
ttc-iosevka-ss11 15.3.0-1 15.3.1-1
ttc-iosevka-ss12 15.3.0-1 15.3.1-1
ttc-iosevka-ss13 15.3.0-1 15.3.1-1
ttc-iosevka-ss14 15.3.0-1 15.3.1-1
ttc-iosevka-ss15 15.3.0-1 15.3.1-1
ttc-iosevka-ss16 15.3.0-1 15.3.1-1
ttc-iosevka-ss17 15.3.0-1 15.3.1-1
ttc-iosevka-ss18 15.3.0-1 15.3.1-1
typescript-language-server 0.10.0-1 0.10.1-1
ukui-window-switch 3.0.1-3 3.0.1-4
umockdev 0.17.10-1 0.17.12-1
uutils-coreutils 0.0.13-2 0.0.14-1
v2ray-domain-list-community 20220512180118-1 20220519111546-1
v2ray-geoip 202205120051-1 202205190058-1
vigra1.11.1.r67+g093d57d1-11.11.1.r67+g093d57d1-2
vst3sdk 3.7.4_build_25-1 3.7.5_build_44-1
vtk 9.1.0-14 9.1.0-15
vvave 2.1.1-1 2.1.2-1
waf 2.0.23-1 2.0.24-1
wakatime 1:1.42.2-1 1:1.45.3-1
wallabag 2.4.3-1 2.5.0-1
wasmtime 0.36.0-1 0.37.0-1
wlroots 0.15.1-3 0.15.1-5
xarchiver 0.5.4.17-1 0.5.4.18-1
xarchiver-gtk2 0.5.4.17-1 0.5.4.18-1
xdebug 3.1.2-2 3.1.4-1
xh 0.16.0-1 0.16.1-1
xpad 5.7.0-2 5.8.0-1
xplr 0.17.6-1 0.18.0-1
yarn 1.22.18-1 1.22.19-1
yoshimi 2.1.2.2-1 2.2.0-1
yt-dlp 2022.04.08-1 2022.05.18-1
zk 0.10.0-1 0.10.1-1
zynaddsubfx 3.0.6-2.1 3.0.6-3
bearssl - 0.6-5
cl-alexandria - 1.4.r17.g2f39fbf-1
cl-asdf-flv - 2.1-2
cl-clx - 0.7.5.r67.g392421d-1
cl-fiveam - 1.4.2.r12.ge11dee7-2
cl-lift - 1.7.1.r47.ge08e84e-2
cl-rt -1990.12.19.r19.ga6a7503-2
cl-trivial-backtrace - 1.1.0.r20.g6eb65bd-1
gmni - 1.0-1
gss - 1.0.3-1
libspecbleach - 0.1.6-1
mitmproxy2swagger - 0.5.3-1
p2pool - 2.0-1
python-editables - 0.3-2
python-ipython-genutils - 0.2.0-1
python-json-stream - 1.3.0-1
python-loguru - 0.6.0-2
python-straight.plugin - 1.5.0-3
roswell - 21.10.14.111-2
ruby-minitest-power_assert - 0.3.1-1
spotify-launcher - 0.2.0-1
topcom - 0.17.8-1
:: Different overlay package(s) in repository core aarch64
linux 5.17.8-1 5.17.9-2
linux-clockworkpi-a06 5.17.8-1 5.17.9-1
linux-clockworkpi-a06-headers 5.17.8-1 5.17.9-1
linux-headers 5.17.8-1 5.17.9-2
linux-lts 5.15.40-1 5.15.41-1
linux-lts-headers 5.15.40-1 5.15.41-1
linux-pinephone 5.17.8-1 5.18.0-0
linux-pinephone-headers 5.17.8-1 5.18.0-0
linux-pinephonepro 5.17.8-1 5.18.0-0.1
linux-pinephonepro-headers 5.17.8-1 5.18.0-0.1
linux-rc 5.18.rc7-1 5.18.rc7-4
linux-rc-headers 5.18.rc7-1 5.18.rc7-4
linux-rpi4 5.15.40-1 5.15.41-1
linux-rpi4-headers 5.15.40-1 5.15.41-1
linux-rpi4-mainline 5.17.8-1 5.18.0-1
linux-rpi4-mainline-headers 5.17.8-1 5.18.0-1
raspberrypi-bootloader 20220510-1 20220519-1
raspberrypi-bootloader-x 20220510-1 20220519-1
uboot-pinebookpro 2022.04-1 2022.04-2
uboot-odroid-m1 - 2022.01.rc4-2
:: Different sync package(s) in repository core aarch64
device-mapper 2.03.15-1 2.03.16-1
gmp 6.2.1-1 6.2.1-2
iptables 1:1.8.7-1 1:1.8.8-1
iptables-nft 1:1.8.7-1 1:1.8.8-1
libbpf 0.7.0-1 -
libldap 2.6.1-1 2.6.2-1
lvm2 2.03.15-1 2.03.16-1
openldap 2.6.1-1 2.6.2-1
systemd 250.5-1 251-1
systemd-libs 250.5-1 251-1
systemd-resolvconf 250.5-1 251-1
systemd-sysvcompat 250.5-1 251-1
:: Different overlay package(s) in repository extra aarch64
mesa-git22.2.0_devel.153936.e9e8c649cd1-122.2.0_devel.154311.aa32b96c51f-1
qt5-es2-base 5.15.4+kde+r139-1 5.15.4+kde+r144-1
qt5-es2-declarative 5.15.4+kde+r17-1 5.15.4+kde+r19-1
qt5-es2-xcb-private-headers 5.15.4+kde+r139-1 5.15.4+kde+r144-1
:: Different sync package(s) in repository extra aarch64
appstream 0.15.3-1 0.15.4-1
appstream-qt 0.15.3-1 0.15.4-1
archboot-arm 2022.05-64 2022.05-89
avogadrolibs 1.95.1-7 1.95.1-8
avogadrolibs-qt5 1.95.1-7 1.95.1-8
bind 9.18.2-1 9.18.3-1
clucene 2.3.3.4-11 2.3.3.4-12
compface 1.5.2-9 1.5.2-10
cppunit 1.15.1-2 1.15.1-3
cups-pk-helper 0.2.6-4 0.2.6-5
dbus-broker 30-2 31-1
docbook-mathml 1.1CR1-6 1.1CR1-7
docbook-sgml 4.5-7 4.5-8
docbook-sgml31 3.1-4 3.1-5
docbook5-xml 5.1-2 5.1-3
easy-rsa 3.0.8-2 3.1.0-1
f2fs-tools 1.14.0-3 1.15.0-1
firefox 100.0-1 100.0.2-1
firefox-i18n-ach 100.0-1 100.0.2-1
firefox-i18n-af 100.0-1 100.0.2-1
firefox-i18n-an 100.0-1 100.0.2-1
firefox-i18n-ar 100.0-1 100.0.2-1
firefox-i18n-ast 100.0-1 100.0.2-1
firefox-i18n-az 100.0-1 100.0.2-1
firefox-i18n-be 100.0-1 100.0.2-1
firefox-i18n-bg 100.0-1 100.0.2-1
firefox-i18n-bn 100.0-1 100.0.2-1
firefox-i18n-br 100.0-1 100.0.2-1
firefox-i18n-bs 100.0-1 100.0.2-1
firefox-i18n-ca 100.0-1 100.0.2-1
firefox-i18n-ca-valencia 100.0-1 100.0.2-1
firefox-i18n-cak 100.0-1 100.0.2-1
firefox-i18n-cs 100.0-1 100.0.2-1
firefox-i18n-cy 100.0-1 100.0.2-1
firefox-i18n-da 100.0-1 100.0.2-1
firefox-i18n-de 100.0-1 100.0.2-1
firefox-i18n-dsb 100.0-1 100.0.2-1
firefox-i18n-el 100.0-1 100.0.2-1
firefox-i18n-en-ca 100.0-1 100.0.2-1
firefox-i18n-en-gb 100.0-1 100.0.2-1
firefox-i18n-en-us 100.0-1 100.0.2-1
firefox-i18n-eo 100.0-1 100.0.2-1
firefox-i18n-es-ar 100.0-1 100.0.2-1
firefox-i18n-es-cl 100.0-1 100.0.2-1
firefox-i18n-es-es 100.0-1 100.0.2-1
firefox-i18n-es-mx 100.0-1 100.0.2-1
firefox-i18n-et 100.0-1 100.0.2-1
firefox-i18n-eu 100.0-1 100.0.2-1
firefox-i18n-fa 100.0-1 100.0.2-1
firefox-i18n-ff 100.0-1 100.0.2-1
firefox-i18n-fi 100.0-1 100.0.2-1
firefox-i18n-fr 100.0-1 100.0.2-1
firefox-i18n-fy-nl 100.0-1 100.0.2-1
firefox-i18n-ga-ie 100.0-1 100.0.2-1
firefox-i18n-gd 100.0-1 100.0.2-1
firefox-i18n-gl 100.0-1 100.0.2-1
firefox-i18n-gn 100.0-1 100.0.2-1
firefox-i18n-gu-in 100.0-1 100.0.2-1
firefox-i18n-he 100.0-1 100.0.2-1
firefox-i18n-hi-in 100.0-1 100.0.2-1
firefox-i18n-hr 100.0-1 100.0.2-1
firefox-i18n-hsb 100.0-1 100.0.2-1
firefox-i18n-hu 100.0-1 100.0.2-1
firefox-i18n-hy-am 100.0-1 100.0.2-1
firefox-i18n-ia 100.0-1 100.0.2-1
firefox-i18n-id 100.0-1 100.0.2-1
firefox-i18n-is 100.0-1 100.0.2-1
firefox-i18n-it 100.0-1 100.0.2-1
firefox-i18n-ja 100.0-1 100.0.2-1
firefox-i18n-ka 100.0-1 100.0.2-1
firefox-i18n-kab 100.0-1 100.0.2-1
firefox-i18n-kk 100.0-1 100.0.2-1
firefox-i18n-km 100.0-1 100.0.2-1
firefox-i18n-kn 100.0-1 100.0.2-1
firefox-i18n-ko 100.0-1 100.0.2-1
firefox-i18n-lij 100.0-1 100.0.2-1
firefox-i18n-lt 100.0-1 100.0.2-1
firefox-i18n-lv 100.0-1 100.0.2-1
firefox-i18n-mk 100.0-1 100.0.2-1
firefox-i18n-mr 100.0-1 100.0.2-1
firefox-i18n-ms 100.0-1 100.0.2-1
firefox-i18n-my 100.0-1 100.0.2-1
firefox-i18n-nb-no 100.0-1 100.0.2-1
firefox-i18n-ne-np 100.0-1 100.0.2-1
firefox-i18n-nl 100.0-1 100.0.2-1
firefox-i18n-nn-no 100.0-1 100.0.2-1
firefox-i18n-oc 100.0-1 100.0.2-1
firefox-i18n-pa-in 100.0-1 100.0.2-1
firefox-i18n-pl 100.0-1 100.0.2-1
firefox-i18n-pt-br 100.0-1 100.0.2-1
firefox-i18n-pt-pt 100.0-1 100.0.2-1
firefox-i18n-rm 100.0-1 100.0.2-1
firefox-i18n-ro 100.0-1 100.0.2-1
firefox-i18n-ru 100.0-1 100.0.2-1
firefox-i18n-sco 100.0-1 100.0.2-1
firefox-i18n-si 100.0-1 100.0.2-1
firefox-i18n-sk 100.0-1 100.0.2-1
firefox-i18n-sl 100.0-1 100.0.2-1
firefox-i18n-son 100.0-1 100.0.2-1
firefox-i18n-sq 100.0-1 100.0.2-1
firefox-i18n-sr 100.0-1 100.0.2-1
firefox-i18n-sv-se 100.0-1 100.0.2-1
firefox-i18n-szl 100.0-1 100.0.2-1
firefox-i18n-ta 100.0-1 100.0.2-1
firefox-i18n-te 100.0-1 100.0.2-1
firefox-i18n-th 100.0-1 100.0.2-1
firefox-i18n-tl 100.0-1 100.0.2-1
firefox-i18n-tr 100.0-1 100.0.2-1
firefox-i18n-trs 100.0-1 100.0.2-1
firefox-i18n-uk 100.0-1 100.0.2-1
firefox-i18n-ur 100.0-1 100.0.2-1
firefox-i18n-uz 100.0-1 100.0.2-1
firefox-i18n-vi 100.0-1 100.0.2-1
firefox-i18n-xh 100.0-1 100.0.2-1
firefox-i18n-zh-cn 100.0-1 100.0.2-1
firefox-i18n-zh-tw 100.0-1 100.0.2-1
foomatic-db-engine 4:20200206-1 4:20220521-1
gnome-keyring 1:40.0-1 1:42.0-1
graphite 1:1.3.14-1 1:1.3.14-2
gtk31:3.24.33+r28+g01edbfb976-1 1:3.24.34-1
gtk3-demos1:3.24.33+r28+g01edbfb976-1 1:3.24.34-1
gtk3-docs1:3.24.33+r28+g01edbfb976-1 1:3.24.34-1
gvim 8.2.4827-1 8.2.4981-1
harfbuzz 4.2.1-1 4.3.0-1
harfbuzz-icu 4.2.1-1 4.3.0-1
hunspell 1.7.0-3 1.7.0-4
hyphen 2.8.8-3 2.8.8-4
hyphen-de 20060120-5 20060120-6
hyphen-en 2.8.8-3 2.8.8-4
ijs 0.35-3 0.35-4
imagemagick 7.1.0.34-1 7.1.0.35-1
imagemagick-doc 7.1.0.34-1 7.1.0.35-1
inkscape 1.1.2-3 1.2-2
jemalloc 1:5.2.1-6 1:5.3.0-1
js91 91.8.0-1 91.9.1-1
kcolorpicker 0.1.6-1 0.2.0-1
kimageannotator 0.5.3-2 0.6.0-1
krita 5.0.6-1 5.0.6-2
libabw 0.1.3-2 0.1.3-3
libasyncns 0.8+3+g68cd5af-3 1:0.8+r3+g68cd5af-1
libepubgen 0.1.1-2 0.1.1-3
libfreehand 0.1.2-3 0.1.2-4
libice 1.0.10-3 1.0.10-4
libjpeg-turbo 2.1.3-1 2.1.3-2
liblangtag 0.6.3-2 0.6.3-3
libmythes 1:1.2.4-4 1:1.2.4-5
libnetfilter_cthelper 1.0.0-4 1.0.1-1
libnetfilter_cttimeout 1.0.0-6 1.0.1-1
libpagemaker 0.0.4-2 0.0.4-3
libpaper 1.1.28-1 1.1.28-2
libpciaccess 0.16-2 0.16-3
libphonenumber 1:8.12.47-1 1:8.12.48-1
librevenge 0.0.4-3 0.0.4-4
libsm 1.2.3-2 1.2.3-3
libstaroffice 0.0.7-1 0.0.7-2
libva-mesa-driver 22.0.3-1 22.0.4-1
libwebsockets 4.3.1-1 4.3.2-2
libwpg 0.3.3-2 0.3.3-3
libxau 1.0.9-3 1.0.9-4
libxcomposite 0.4.5-3 0.4.5-4
libxdamage 1.1.5-3 1.1.5-4
libxdmcp 1.1.3-3 1.1.3-4
libxext 1.3.4-3 1.3.4-4
libxinerama 1.1.4-3 1.1.4-4
libxkbcommon 1.4.0-1 1.4.1-1
libxkbcommon-doc 1.4.0-1 1.4.1-1
libxkbcommon-x11 1.4.0-1 1.4.1-1
libxkbfile 1.1.0-2 1.1.0-3
libxmu 1.1.3-2 1.1.3-3
libxp 1.0.3-4 1.0.3-5
libxpm 3.5.13-2 3.5.13-3
libxrandr 1.5.2-3 1.5.2-4
libxrender 0.9.10-4 0.9.10-5
libxshmfence 1.3-2 1.3-3
libxss 1.2.3-3 1.2.3-4
libxtst 1.2.3-4 1.2.3-5
libxv 1.0.11-4 1.0.11-5
libxxf86vm 1.1.4-4 1.1.4-5
live-media 2022.02.07-1 2022.04.26-1
llvm 13.0.1-3 13.0.1-4
llvm-libs 13.0.1-3 13.0.1-4
llvm-ocaml 13.0.1-3 13.0.1-4
malcontent 0.10.3-2 0.10.4-1
man2html 3.0.1-7 3.0.1-8
mesa 22.0.3-1 22.0.4-1
mesa-vdpau 22.0.3-1 22.0.4-1
mtdev 1.1.6-1 1.1.6-2
mutt 2.2.4-1 2.2.5-1
mythes-de 20180514-2 20180514-3
mythes-en 20060306-5 20060306-6
numactl 2.0.14-2 2.0.14-3
okteta 1:0.26.7-1 1:0.26.8-1
opencl-mesa 22.0.3-1 22.0.4-1
opengl-man-pages 20190725-2 20190725-3
openjade 1.3.2-6 1.3.2-7
orca 42.0-1 42.1-1
pixman 0.40.0-1 0.40.0-2
plasma-wayland-session 5.24.5-2 5.24.5-3
plasma-workspace 5.24.5-2 5.24.5-3
python-dbusmock 0.27.3-1 0.27.5-1
python-pyparsing 3.0.8-1 3.0.9-1
python-setuptools 1:60.5.0-1 1:60.6.0-1
qemu-audio-alsa 7.0.0-9 7.0.0-10
qemu-audio-dbus 7.0.0-9 7.0.0-10
qemu-audio-jack 7.0.0-9 7.0.0-10
qemu-audio-oss 7.0.0-9 7.0.0-10
qemu-audio-pa 7.0.0-9 7.0.0-10
qemu-audio-sdl 7.0.0-9 7.0.0-10
qemu-audio-spice 7.0.0-9 7.0.0-10
qemu-base 7.0.0-9 7.0.0-10
qemu-block-curl 7.0.0-9 7.0.0-10
qemu-block-dmg 7.0.0-9 7.0.0-10
qemu-block-gluster 7.0.0-9 7.0.0-10
qemu-block-iscsi 7.0.0-9 7.0.0-10
qemu-block-nfs 7.0.0-9 7.0.0-10
qemu-block-ssh 7.0.0-9 7.0.0-10
qemu-chardev-baum 7.0.0-9 7.0.0-10
qemu-chardev-spice 7.0.0-9 7.0.0-10
qemu-common 7.0.0-9 7.0.0-10
qemu-desktop 7.0.0-9 7.0.0-10
qemu-docs 7.0.0-9 7.0.0-10
qemu-emulators-full 7.0.0-9 7.0.0-10
qemu-full 7.0.0-9 7.0.0-10
qemu-guest-agent 7.0.0-9 7.0.0-10
qemu-hw-display-qxl 7.0.0-9 7.0.0-10
qemu-hw-display-virtio-gpu 7.0.0-9 7.0.0-10
qemu-hw-display-virtio-gpu-gl 7.0.0-9 7.0.0-10
qemu-hw-display-virtio-gpu-pci 7.0.0-9 7.0.0-10
qemu-hw-display-virtio-gpu-pci-gl 7.0.0-9 7.0.0-10
qemu-hw-display-virtio-vga 7.0.0-9 7.0.0-10
qemu-hw-display-virtio-vga-gl 7.0.0-9 7.0.0-10
qemu-hw-s390x-virtio-gpu-ccw 7.0.0-9 7.0.0-10
qemu-hw-usb-host 7.0.0-9 7.0.0-10
qemu-hw-usb-redirect 7.0.0-9 7.0.0-10
qemu-hw-usb-smartcard 7.0.0-9 7.0.0-10
qemu-img 7.0.0-9 7.0.0-10
qemu-pr-helper 7.0.0-9 7.0.0-10
qemu-system-aarch64 7.0.0-9 7.0.0-10
qemu-system-alpha 7.0.0-9 7.0.0-10
qemu-system-arm 7.0.0-9 7.0.0-10
qemu-system-avr 7.0.0-9 7.0.0-10
qemu-system-cris 7.0.0-9 7.0.0-10
qemu-system-hppa 7.0.0-9 7.0.0-10
qemu-system-m68k 7.0.0-9 7.0.0-10
qemu-system-microblaze 7.0.0-9 7.0.0-10
qemu-system-mips 7.0.0-9 7.0.0-10
qemu-system-nios2 7.0.0-9 7.0.0-10
qemu-system-or1k 7.0.0-9 7.0.0-10
qemu-system-ppc 7.0.0-9 7.0.0-10
qemu-system-riscv 7.0.0-9 7.0.0-10
qemu-system-rx 7.0.0-9 7.0.0-10
qemu-system-s390x 7.0.0-9 7.0.0-10
qemu-system-sh4 7.0.0-9 7.0.0-10
qemu-system-sparc 7.0.0-9 7.0.0-10
qemu-system-tricore 7.0.0-9 7.0.0-10
qemu-system-x86 7.0.0-9 7.0.0-10
qemu-system-xtensa 7.0.0-9 7.0.0-10
qemu-tests 7.0.0-9 7.0.0-10
qemu-tools 7.0.0-9 7.0.0-10
qemu-ui-curses 7.0.0-9 7.0.0-10
qemu-ui-dbus 7.0.0-9 7.0.0-10
qemu-ui-egl-headless 7.0.0-9 7.0.0-10
qemu-ui-gtk 7.0.0-9 7.0.0-10
qemu-ui-opengl 7.0.0-9 7.0.0-10
qemu-ui-sdl 7.0.0-9 7.0.0-10
qemu-ui-spice-app 7.0.0-9 7.0.0-10
qemu-ui-spice-core 7.0.0-9 7.0.0-10
qemu-user 7.0.0-9 7.0.0-10
qemu-vhost-user-gpu 7.0.0-9 7.0.0-10
qemu-virtiofsd 7.0.0-9 7.0.0-10
qt5-base 5.15.4+kde+r135-1 5.15.4+kde+r144-1
qt5-connectivity 5.15.4+kde+r4-1 5.15.4+kde+r5-1
qt5-declarative 5.15.4+kde+r17-1 5.15.4+kde+r19-1
qt5-imageformats 5.15.4+kde+r0-1 5.15.4+kde+r1-1
qt5-xcb-private-headers 5.15.4+kde+r135-1 5.15.4+kde+r144-1
rinutils 0.10.0-1 0.10.1-1
rust 1:1.60.0-1 1:1.61.0-1
rust-src 1:1.60.0-1 1:1.61.0-1
sdl2 2.0.22-1 2.0.22-2
seahorse 1:41.0-2 1:42.0-1
sgml-common 0.6.3-7 0.6.3-8
sip 6.6.1-3 6.6.2dev2205162316-1
sound-theme-freedesktop 0.8-4 0.8-5
spectacle 22.04.1-1 22.04.1-2
texi2html 5.0-6 5.0-7
thunderbird 91.9.0-1 91.9.1-1
thunderbird-i18n-af 91.9.0-1 91.9.1-1
thunderbird-i18n-ar 91.9.0-1 91.9.1-1
thunderbird-i18n-ast 91.9.0-1 91.9.1-1
thunderbird-i18n-be 91.9.0-1 91.9.1-1
thunderbird-i18n-bg 91.9.0-1 91.9.1-1
thunderbird-i18n-br 91.9.0-1 91.9.1-1
thunderbird-i18n-ca 91.9.0-1 91.9.1-1
thunderbird-i18n-cak 91.9.0-1 91.9.1-1
thunderbird-i18n-cs 91.9.0-1 91.9.1-1
thunderbird-i18n-cy 91.9.0-1 91.9.1-1
thunderbird-i18n-da 91.9.0-1 91.9.1-1
thunderbird-i18n-de 91.9.0-1 91.9.1-1
thunderbird-i18n-dsb 91.9.0-1 91.9.1-1
thunderbird-i18n-el 91.9.0-1 91.9.1-1
thunderbird-i18n-en-gb 91.9.0-1 91.9.1-1
thunderbird-i18n-en-us 91.9.0-1 91.9.1-1
thunderbird-i18n-es-ar 91.9.0-1 91.9.1-1
thunderbird-i18n-es-es 91.9.0-1 91.9.1-1
thunderbird-i18n-et 91.9.0-1 91.9.1-1
thunderbird-i18n-eu 91.9.0-1 91.9.1-1
thunderbird-i18n-fi 91.9.0-1 91.9.1-1
thunderbird-i18n-fr 91.9.0-1 91.9.1-1
thunderbird-i18n-fy-nl 91.9.0-1 91.9.1-1
thunderbird-i18n-ga-ie 91.9.0-1 91.9.1-1
thunderbird-i18n-gd 91.9.0-1 91.9.1-1
thunderbird-i18n-gl 91.9.0-1 91.9.1-1
thunderbird-i18n-he 91.9.0-1 91.9.1-1
thunderbird-i18n-hr 91.9.0-1 91.9.1-1
thunderbird-i18n-hsb 91.9.0-1 91.9.1-1
thunderbird-i18n-hu 91.9.0-1 91.9.1-1
thunderbird-i18n-hy-am 91.9.0-1 91.9.1-1
thunderbird-i18n-id 91.9.0-1 91.9.1-1
thunderbird-i18n-is 91.9.0-1 91.9.1-1
thunderbird-i18n-it 91.9.0-1 91.9.1-1
thunderbird-i18n-ja 91.9.0-1 91.9.1-1
thunderbird-i18n-ka 91.9.0-1 91.9.1-1
thunderbird-i18n-kab 91.9.0-1 91.9.1-1
thunderbird-i18n-kk 91.9.0-1 91.9.1-1
thunderbird-i18n-ko 91.9.0-1 91.9.1-1
thunderbird-i18n-lt 91.9.0-1 91.9.1-1
thunderbird-i18n-ms 91.9.0-1 91.9.1-1
thunderbird-i18n-nb-no 91.9.0-1 91.9.1-1
thunderbird-i18n-nl 91.9.0-1 91.9.1-1
thunderbird-i18n-nn-no 91.9.0-1 91.9.1-1
thunderbird-i18n-pa-in 91.9.0-1 91.9.1-1
thunderbird-i18n-pl 91.9.0-1 91.9.1-1
thunderbird-i18n-pt-br 91.9.0-1 91.9.1-1
thunderbird-i18n-pt-pt 91.9.0-1 91.9.1-1
thunderbird-i18n-rm 91.9.0-1 91.9.1-1
thunderbird-i18n-ro 91.9.0-1 91.9.1-1
thunderbird-i18n-ru 91.9.0-1 91.9.1-1
thunderbird-i18n-sk 91.9.0-1 91.9.1-1
thunderbird-i18n-sl 91.9.0-1 91.9.1-1
thunderbird-i18n-sq 91.9.0-1 91.9.1-1
thunderbird-i18n-sr 91.9.0-1 91.9.1-1
thunderbird-i18n-sv-se 91.9.0-1 91.9.1-1
thunderbird-i18n-th 91.9.0-1 91.9.1-1
thunderbird-i18n-tr 91.9.0-1 91.9.1-1
thunderbird-i18n-uk 91.9.0-1 91.9.1-1
thunderbird-i18n-uz 91.9.0-1 91.9.1-1
thunderbird-i18n-vi 91.9.0-1 91.9.1-1
thunderbird-i18n-zh-cn 91.9.0-1 91.9.1-1
thunderbird-i18n-zh-tw 91.9.0-1 91.9.1-1
vde2 2.3.2-21 2.3.3-1
vim-runtime 8.2.4827-1 8.2.4981-1
vulkan-broadcom 22.0.3-1 22.0.4-1
vulkan-mesa-layers 22.0.3-1 22.0.4-1
vulkan-panfrost 22.0.3-1 22.0.4-1
vulkan-radeon 22.0.3-1 22.0.4-1
vulkan-swrast 22.0.3-1 22.0.4-1
webkit2gtk 2.36.1-1 2.36.2-1
webkit2gtk-4.1 2.36.1-1 2.36.2-1
webkit2gtk-5.0 2.36.1-1 2.36.2-1
wpewebkit 2.36.1-1 2.36.2-1
xaw3d 1.6.3-2 1.6.3-3
xbitmaps 1.1.2-2 1.1.2-3
xcb-util 0.4.0-3 0.4.0-4
xcb-util-cursor 0.1.3-3 0.1.3-4
xcb-util-image 0.4.0-3 0.4.0-4
xcb-util-keysyms 0.4.0-3 0.4.0-4
xcb-util-renderutil 0.3.9-3 0.3.9-4
xcb-util-wm 0.4.1-3 0.4.1-4
xcompmgr 1.1.8-2 1.1.8-3
xcursor-themes 1.0.6-2 1.0.6-3
xdg-utils 1.1.3+19+g9816ebb-1 1.1.3+21+g1a58bc2-1
xfce4-terminal 1.0.3-1 1.0.4-1
xorg-bdftopcf 1.1-2 1.1-3
xorg-font-util 1.3.2-2 1.3.2-3
xorg-oclock 1.0.4-2 1.0.4-3
xorg-sessreg 1.1.2-2 1.1.2-3
xorg-smproxy 1.0.6-3 1.0.6-4
xorg-x11perf 1.6.1-2 1.6.1-3
xorg-xbacklight 1.2.3-2 1.2.3-3
xorg-xbiff 1.0.4-2 1.0.4-3
xorg-xclipboard 1.1.3-3 1.1.3-4
xorg-xcmsdb 1.0.5-3 1.0.5-4
xorg-xconsole 1.0.7-3 1.0.7-4
xorg-xcursorgen 1.0.7-2 1.0.7-3
xorg-xdriinfo 1.0.6-2 1.0.6-3
xorg-xfd 1.1.3-2 1.1.3-3
xorg-xgamma 1.0.6-3 1.0.6-4
xorg-xhost 1.0.8-2 1.0.8-3
xorg-xinput 1.6.3-2 1.6.3-3
xorg-xkbevd 1.1.4-3 1.1.4-4
xorg-xkbutils 1.0.4-4 1.0.4-5
xorg-xkill 1.0.5-2 1.0.5-3
xorg-xlogo 1.0.5-2 1.0.5-3
xorg-xlsatoms 1.1.3-2 1.1.3-3
xorg-xlsclients 1.1.4-2 1.1.4-3
xorg-xmag 1.0.6-3 1.0.6-4
xorg-xman 1.1.5-2 1.1.5-3
xorg-xmessage 1.0.5-2 1.0.5-3
xorg-xmodmap 1.0.10-2 1.0.10-3
xorg-xpr 1.0.5-2 1.0.5-3
xorg-xrefresh 1.0.6-2 1.0.6-3
xorg-xset 1.2.4-2 1.2.4-3
xorg-xsetroot 1.1.2-2 1.1.2-3
xorg-xvidtune 1.0.3-4 1.0.3-5
xorg-xvinfo 1.1.4-2 1.1.4-3
xorg-xwininfo 1.1.5-2 1.1.5-3
xorg-xwud 1.0.5-2 1.0.5-3
xterm 372-1 372-2
xtrans 1.4.0-2 1.4.0-3
zsh 5.8.1-2 5.9-1
zsh-doc 5.8.1-2 5.9-1
aha - 0.5.1-2
libbpf - 0.8.0-1
libmalcontent - 0.10.4-1
openpmix - 4.1.2-1
prrte - 2.0.2-1
wolfssl - 5.3.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.04.1.r12734.g29e357458-122.04.1.r12746.gccf678278-1
akonadi-calendar22.04.1.r2083.ge46a70e-122.04.1.r2112.g29a74cd-1
akonadi-contacts22.04.1.r3171.g4a0e5e5e-122.04.1.r3174.g444f2526-1
akonadi-mime22.04.1.r1719.gab395a5-122.04.1.r1722.gaf78ae4-1
akonadi-notes22.04.1.r1073.g6dd0081-122.04.1.r1074.gb37c716-1
akonadi-search22.04.1.r1222.gd123945-122.04.1.r1224.g0d93787-1
akregator22.04.1.r6408.ga4f84fa6-122.04.1.r6409.g431fa01c-1
angelfish 22.04.r19.gf52caba-1 22.04.r21.g763238e-1
ark22.04.1.r4736.g15bccd6a-122.04.1.r4751.gd55d1487-1
audiotube 22.04.r9.gc83d7f5-1 22.04.r11.ga7e9588-1
aura-browser r47.c924414-1 r52.5ec6b0c-1
baloo-widgets22.04.1.r744.g754c6d9-122.04.1.r745.gdbe51a3-1
bluedevil1:5.24.5.r2393.gdedbba3f-11:5.24.5.r2395.g76c9e11a-1
bovo22.04.1.r776.g6b3cebb-122.04.1.r777.gaae9a5d-1
breeze5.24.5.r2394.ga6188267-15.24.5.r2396.g1c137f7f-1
breeze-gtk5.24.5.r463.gf83845b-15.24.5.r481.gcb7c58f-1
breeze-icons5.94.0.r1896.gcaf9b8e0-15.94.0.r1897.g3851024f-1
buho 2.1.1.r9.g8cdcee3-1 2.1.2.r0.g8cdcee3-1
calendarsupport22.04.1.r702.gf7b182e-122.04.1.r705.g9a21730-1
calindori 22.04.r8.gf9e4438-1 22.04.r9.g057c1be-1
cervisia22.04.1.r1664.g12571f5-122.04.1.r1665.g210246c-1
discover5.24.5.r8671.ge8e13de4-15.24.5.r8676.gd266af5b-1
dolphin22.04.1.r6958.g0b27270be-122.04.1.r6966.g30b62a1c0-1
dolphin-plugins22.04.1.r654.gb8b6632-122.04.1.r655.gf18f19d-1
drkonqi5.24.5.r779.g48f2e760-15.24.5.r783.gca434b56-1
elisa22.04.1.r2964.g6463cde6-122.04.1.r2966.g9c8ab409-1
elisa-qtmm22.04.1.r2965.gf80d24b9-122.04.1.r2966.g9c8ab409-1
eventviews22.04.1.r838.g7f0fa86-122.04.1.r841.g3e69109-1
filelight22.04.1.r1110.g603a966-122.04.1.r1111.ge1c480f-1
frameworkintegration5.94.0.r633.ga37dcd9-15.94.0.r635.g3ba56a9-1
grantleetheme22.04.1.r394.g9fbdd58-122.04.1.r396.ge8f680e-1
gwenview22.04.1.r6849.g8cc4c78c-122.04.1.r6850.gb7e70692-1
incidenceeditor22.04.1.r891.g9db2ace-122.04.1.r893.g220e095-1
index-fm 2.1.1.r17.g410a56b-1 2.1.2.r1.gd64cd02-1
itinerary22.04.1.r1822.gdf0f16d-122.04.1.r1827.g63e1745-1
juk22.04.1.r3142.gdbae0029-122.04.1.r3143.g2eb2ef8b-1
k3b1:22.04.1.r6777.gdbc9964c9-11:22.04.1.r6779.g807072ba6-1
kaccounts-integration22.04.1.r1254.g6b916de-122.04.1.r1255.gd4060e6-1
kaccounts-providers22.04.1.r395.gae51a37-122.04.1.r396.gc13bb0b-1
kactivities5.94.0.r1394.gd965ec3f-15.94.0.r1395.g0fa51036-1
kactivities-stats5.94.0.r405.g5418265-15.94.0.r406.g1d76e80-1
kactivitymanagerd5.24.5.r1396.g7eec88a-15.24.5.r1398.g2d07e86-1
kajongg22.04.1.r4340.g031ec8c5-122.04.1.r4342.g1819d31e-1
kalarm22.04.1.r7911.g35c49688-122.04.1.r7912.g79afa89d-1
kalzium22.04.1.r4336.ga3a03dee-122.04.1.r4354.ge343c6b7-1
kamoso22.04.1.r1459.g2bac85a-122.04.1.r1460.g10567e8-1
kapman22.04.1.r649.g6d297f7-122.04.1.r650.ge5f2794-1
karchive5.94.0.r539.g606d862-15.94.0.r540.g54a7bcf-1
kasts 22.04.r10.gf0bab73-1 22.04.r17.ge34d979-1
kate22.04.1.r19023.g6db5a71ac-122.04.1.r19048.g4023b2dcf-1
kbackup22.04.1.r432.gc7f65c1-122.04.1.r434.g03c2fda-1
kblocks22.04.1.r711.g7228f93-122.04.1.r712.g2fe083b-1
kbookmarks5.94.0.r459.g749d823-15.94.0.r460.g7a369da-1
kbreakout22.04.1.r913.g15d19ab-122.04.1.r914.g20708c6-1
kcachegrind22.04.1.r1178.g26c0cec-122.04.1.r1179.g82a4b92-1
kcachegrind-common22.04.1.r1178.g26c0cec-122.04.1.r1179.g82a4b92-1
kcalendarcore5.94.0.r1315.g71ecc4421-15.94.0.r1317.ga2470cf4f-1
kcalutils22.04.1.r963.g0f2359231-122.04.1.r964.gc175659c5-1
kcharselect22.04.1.r523.g41f2f44-122.04.1.r524.g42ad574-1
kclock 22.04.r11.gd5cd85a-1 22.04.r12.ge91e1da-1
kcodecs5.94.0.r419.gaa3d702-15.94.0.r420.g0e426d4-1
kcolorchooser22.04.1.r266.gb9094eb-122.04.1.r267.g66680ff-1
kconfig5.94.0.r954.ge4d19066-15.94.0.r955.gaafd381f-1
kcoreaddons5.94.0.r1478.g9e26ee97-15.94.0.r1484.ga3d37d5c-1
kcron22.04.1.r841.g0e3d815-122.04.1.r842.g46f18a2-1
kdbusaddons5.94.0.r413.g3e3dbcb-15.94.0.r414.ga43ed3a-1
kde-cli-tools5.24.5.r1933.ge3fdf1e-15.24.5.r1935.g6e0ddcc-1
kde-dev-scripts22.04.1.r4145.g06765a6-122.04.1.r4146.g04f44a1-1
kde-gtk-config5.24.5.r930.g687ee79-15.24.5.r932.g691d1cc-1
kdebugsettings22.04.1.r920.gb063fbc-122.04.1.r921.g5fd8a2c-1
kdeclarative5.94.0.r994.g07b1e86-15.94.0.r1001.gb3c0544-1
kdeconnect22.04.1.r3442.gbee030fc-122.04.1.r3443.gd76207db-1
kdecoration5.24.5.r288.g4123ec8-15.24.5.r290.gde4e9d4-1
kdegraphics-mobipocket22.04.1.r270.g8a94719-122.04.1.r272.ge2624e9-1
kdegraphics-thumbnailers22.04.1.r264.g757fb9c-122.04.1.r266.g79fe9b1-1
kdenlive22.04.1.r16060.gd84fa82f7-122.04.1.r16090.g3b5ecdd89-1
kdepim-addons22.04.1.r4638.gd54d5510e-122.04.1.r4642.g696416964-1
kdepim-runtime22.04.1.r15516.ge3a69e539-122.04.1.r15522.g07e3b4cd9-1
kdeplasma-addons5.24.5.r8793.gc1f182862-15.24.5.r8829.gf6458a3e6-1
kdesdk-kioslaves22.04.1.r502.g633726e-122.04.1.r503.g5a8c59f-1
kdesdk-thumbnailers22.04.1.r89.g068d9d1-122.04.1.r91.g97befb5-1
kdewebkit5.94.0.r300.gc530140-15.94.0.r301.g7d36253-1
kdialog22.04.1.r1214.g84db6eb7d-122.04.1.r1220.gb6517d0dd-1
kdoctools5.94.0.r658.g64b5339-15.94.0.r659.gf4cbcba-1
kemoticons5.94.0.r412.g54baefa-15.94.0.r414.g18d91f3-1
keysmith 22.04.r5.gbacea75-1 22.04.r6.g87cf7ea-1
kgamma55.24.5.r473.ge593e27-15.24.5.r475.g1d5fa88-1
kget22.04.1.r3191.g1f1876c7-122.04.1.r3193.g11583934-1
kglobalaccel5.94.0.r514.g633fe86-15.94.0.r520.gdd89ba4-1
kguiaddons5.94.0.r464.gd7402db-15.94.0.r469.g60b3c93-1
khangman22.04.1.r1601.g0a9af72-122.04.1.r1602.g296c528-1
khelpcenter22.04.1.r2738.gb7276f90-122.04.1.r2739.ga97256bc-1
kholidays1:5.94.0.r1033.g37e6565-11:5.94.0.r1034.gf6f54ad-1
khotkeys5.24.5.r2129.g58171c2-15.24.5.r2132.g88c9931-1
ki18n5.94.0.r553.g62121fc-15.94.0.r554.g5fc3c06-1
kiconthemes5.94.0.r599.g389af6a-15.94.0.r600.g584acbd-1
kidentitymanagement22.04.1.r3887.g1c7d1b8b-122.04.1.r3888.g4d81a192-1
kimagemapeditor22.04.1.r488.ga654793-122.04.1.r489.g67a89e9-1
kimap22.04.1.r1189.g21ff886-122.04.1.r1190.g9de9e29-1
kinfocenter5.24.5.r2079.g2c7a3694-15.24.5.r2085.g4990dfbb-1
kinit5.94.0.r435.g3101b1d-15.94.0.r436.ge3dc918-1
kio5.94.0.r5459.gc11e99a49-15.94.0.r5476.g2da56ac98-1
kio-extras22.04.1.r7239.g3638f589-122.04.1.r7241.gdee13e46-1
kio-gdrive22.04.1.r598.gf970418-122.04.1.r599.gb0961ad-1
kirigami-addons 1:0.2.r28.g67f7e4e-1 1:0.2.r30.g762eea5-1
kirigami-gallery22.04.1.r239.ga0c5568-122.04.1.r240.g7efbc75-1
kirigami25.94.0.r3133.g88c572b4-15.94.0.r3135.g015a8395-1
kitinerary22.04.1.r2184.gc9cecdc-122.04.1.r2189.g7e7bac5-1
kldap22.04.1.r947.gb74c9fd-122.04.1.r948.g8e9db7d-1
kleopatra22.04.1.r6432.g3e64320a-122.04.1.r6491.ge27d777a-1
kmail22.04.1.r26366.ga398a78c1-122.04.1.r26367.gbb7a0f253-1
kmailtransport22.04.1.r1740.g8aad2c6-122.04.1.r1743.gdf00209-1
kmbox22.04.1.r595.g18c65a3-122.04.1.r596.g0c5614d-1
kmenuedit5.24.5.r1035.gd16a211-15.24.5.r1038.ga358a14-1
kmime22.04.1.r1512.gb2fc3cb-122.04.1.r1513.g8af52ee-1
kmix22.04.1.r2449.g969b5f23-122.04.1.r2450.gf456545b-1
kmouth22.04.1.r722.g8709521-122.04.1.r723.g7063d96-1
kmplot22.04.1.r1488.g828fdc5-122.04.1.r1490.gcd526d7-1
knavalbattle22.04.1.r1427.gf01b240-122.04.1.r1428.gbd84302-1
knetwalk22.04.1.r695.ge900c4a-122.04.1.r697.g953cb1c-1
knewstuff5.94.0.r1333.g667327a6-15.94.0.r1334.g9be22770-1
knights22.04.1.r1130.g2f0f72a-122.04.1.r1132.gdb2a440-1
knotifications5.94.0.r736.g7b9aea6-15.94.0.r737.g3096049-1
koko 22.04.r12.gab1e5bc-1 22.04.r14.g80656cb-1
kolf22.04.1.r1495.g2d75b5d-122.04.1.r1497.g5b943a8-1
kolourpaint22.04.1.r2403.gb2416163-122.04.1.r2404.g7b7d9202-1
konqueror22.04.1.r15106.g7efa0d97a-122.04.1.r15108.g6db4473f1-1
konsole22.04.1.r8358.gc88c123f-122.04.1.r8363.g694d1c68-1
kontactinterface22.04.1.r684.g1683244-122.04.1.r685.gb747b67-1
kontrast22.04.1.r201.gc4ca5e4-122.04.1.r202.g3659c12-1
konversation22.04.1.r9107.gbbdeca71-122.04.1.r9108.g724c5afb-1
kopete22.04.1.r16425.g6eddda540-122.04.1.r16427.g0bb0a4c0a-1
kpackage5.94.0.r749.g18a78cf-15.94.0.r750.gc1ad10e-1
kpeoplesink r79.g9d18ae6-1 r80.g8f64248-1
kpimtextedit22.04.1.r1591.g9fc3ac6-122.04.1.r1593.g029d299-1
kpublictransport22.04.1.r2009.g2b831f73-122.04.1.r2014.ga9eda848-1
krdc22.04.1.r1590.g8c38078-122.04.1.r1591.g3895f2e-1
krecorder 22.04.r12.g16bfbe3-1 22.04.r13.g519c603-1
krfb22.04.1.r1489.g6f1d60b-122.04.1.r1491.gea5d2f4-1
kruler22.04.1.r733.g15e0b0e-122.04.1.r734.g21ce109-1
krunner5.94.0.r753.g137c9d0-15.94.0.r757.g4c34284-1
kscreen5.24.5.r1450.g09908d8-15.24.5.r1465.g7f411e6-1
kscreenlocker5.24.5.r939.g4485c8c-15.24.5.r944.gfc70ea5-1
kservice5.94.0.r1007.g77e24c0-15.94.0.r1008.g21ce3b1-1
ksirk22.04.1.r1021.ge38aebe-122.04.1.r1022.g84ff88d-1
ksmtp22.04.1.r446.g56c9d3a-122.04.1.r447.gb4ba5a6-1
ksshaskpass5.24.5.r207.g5110d15-15.24.5.r209.gd906c9e-1
ksudoku22.04.1.r1107.gd4ee434-122.04.1.r1108.gcb9a00d-1
ksystemstats5.24.5.r224.g679c508-15.24.5.r227.g18a85e5-1
ktexteditor5.94.0.r3403.gdf44da08-15.94.0.r3407.g07cb64ff-1
ktnef22.04.1.r716.g4bb7ebb-122.04.1.r717.ga4bf6ff-1
ktorrent22.04.1.r2844.g2e0aa9e3-122.04.1.r2846.g589076bd-1
ktouch22.04.1.r2177.g52883f6-122.04.1.r2178.g3380ebe-1
ktrip 22.04.r5.g395c735-1 22.04.r6.g38cb6d2-1
ktuberling22.04.1.r1039.g39154ce-122.04.1.r1040.g780576d-1
kturtle22.04.1.r1163.ga445e43-122.04.1.r1165.gc10321f-1
kubrick22.04.1.r404.g318140e-122.04.1.r405.g9fa9580-1
kwallet-pam5.24.5.r266.gbc69453-15.24.5.r268.g445e1e4-1
kwave22.04.1.r3785.gdf5832a0-122.04.1.r3787.g65466126-1
kwayland5.94.0.r1159.g70eb1df-15.94.0.r1160.g48612d7-1
kwayland-integration5.24.5.r202.g402d7ba-15.24.5.r206.g28e7a11-1
kweather 22.04.r12.gafc5508-1 22.04.r16.g93a2cb0-1
kwidgetsaddons5.94.0.r939.gaf36ab53-15.94.0.r941.g10d15898-1
kwin5.24.5.r22463.g2178f26e7-15.24.5.r22511.gd91bdee3c-1
kwrite22.04.1.r19023.g6db5a71ac-122.04.1.r19048.g4023b2dcf-1
kwrited5.24.5.r504.g4050519-15.24.5.r506.g97a673a-1
kxmlgui5.94.0.r874.g9dd91dca-15.94.0.r875.gac72a514-1
layer-shell-qt5.24.5.r56.g345676a-15.24.5.r58.g563b61c-1
libakonadi22.04.1.r12734.g29e357458-122.04.1.r12746.gccf678278-1
libgravatar22.04.1.r422.g5713bc5-122.04.1.r423.g365af91-1
libkdegames22.04.1.r2232.g63969b23-122.04.1.r2233.gfef5ac21-1
libkdepim22.04.1.r906.g538cba3-122.04.1.r907.gae00923-1
libkexiv222.04.1.r821.gcee9d6e-122.04.1.r823.g6dce742-1
libkgapi22.04.1.r1359.g4c38fd1-122.04.1.r1361.gd09e86d-1
libkleo22.04.1.r1148.ga7653ca-122.04.1.r1149.gc3b895e-1
libksane22.04.1.r595.gd3e7150-122.04.1.r596.gccb6b71-1
libkscreen5.24.5.r1623.g167b699-15.24.5.r1628.g0b1186f-1
libksieve22.04.1.r1696.gf4402fb3-122.04.1.r1698.gf4917131-1
libksysguard5.24.5.r2395.g3456133-15.24.5.r2398.gfcf74a4-1
libktorrent22.04.1.r547.gcc058bb-122.04.1.r548.g361f3ce-1
lokalize22.04.1.r1818.ge534a6f0-122.04.1.r1820.gd9a26d09-1
lskat22.04.1.r847.g22bcb47-122.04.1.r849.g7c53954-1
mailcommon22.04.1.r1235.g93ee65d-122.04.1.r1239.ga66d5fa-1
marble22.04.1.r13432.g2361f898f-122.04.1.r13435.g2e0c96db7-1
marble-common22.04.1.r13432.g2361f898f-122.04.1.r13435.g2e0c96db7-1
marble-qt22.04.1.r13432.g2361f898f-122.04.1.r13435.g2e0c96db7-1
maui-clip 2.1.1.r9.g22418d5-1 2.1.2.r1.ge80cec5-1
maui-nota 2.1.1.r23.gc51d7c9-1 2.1.2.r0.gc51d7c9-1
maui-pix 2.1.0.r32.g357b7ba-1 2.1.2.r2.gc00bbd2-1
maui-shell 0.5.0.r24.g160acae-1 0.5.0.r25.g92b3352-1
mauikit2.1.1.r32.g535bd57e-1 2.1.2.r2.gf7899647-1
mauikit-accounts 2.1.1.r1.g0efebb4-1 2.1.2.r0.g0efebb4-1
mauikit-filebrowsing 2.1.1.r2.g9fe9bff-1 2.1.2.r0.g1f9bcce-1
mauikit-imagetools 2.1.1.r2.gf5e0766-1 2.1.2.r0.gfbf17b3-1
mauikit-texteditor 2.1.1.r2.gc77ec41-1 2.1.2.r0.gc77ec41-1
messagelib22.04.1.r6535.gf29c5b553-122.04.1.r6546.geffd6879d-1
milou5.24.5.r770.g0dbf227-15.24.5.r772.gaced252-1
neochat22.04.r30.gb994907b-122.04.r41.g853113df-1
okular22.04.1.r9725.ge8d5f24ad-122.04.1.r9727.g26bb7b6a0-1
oxygen5.24.5.r4466.ge1babdde-15.24.5.r4468.g5c9b252a-1
partitionmanager22.04.1.r1615.gc5609fe-122.04.1.r1616.ga0f9411-1
picmi22.04.1.r561.g09b785d-122.04.1.r562.g96841fa-1
pim-data-exporter22.04.1.r2664.g6a6ec3d4-122.04.1.r2705.g1fb5ace3-1
pimcommon22.04.1.r1221.g0ff8128-122.04.1.r1237.gb4551ec-1
plasma-browser-integration5.24.5.r1316.gf2086f25-15.24.5.r1319.ge9fa7be0-1
plasma-desktop5.24.5.r9259.gdad8082ee-15.24.5.r9279.g2429893f6-1
plasma-dialer 22.04.r15.g280861e-1 22.04.r20.g7ae77ca-1
plasma-disks5.24.5.r269.g70787f1-15.24.5.r272.g70d94bc-1
plasma-firewall5.24.5.r620.g3515962-15.24.5.r622.gb10887a-1
plasma-framework5.94.0.r16300.g12d5943b0-15.94.0.r16307.gf1f354ac7-1
plasma-integration5.24.5.r563.g32a2f51-15.24.5.r565.ge380201-1
plasma-mobile5.24.5.r1765.g4c83a3e42-15.24.5.r1787.g2c61bb172-1
plasma-mobile-nm5.24.5.r3239.gba895483-15.24.5.r3247.gac32bd98-1
plasma-nano5.24.5.r182.g12a8821-15.24.5.r184.ga671fb1-1
plasma-nm5.24.5.r3239.gba895483-15.24.5.r3247.gac32bd98-1
plasma-pa5.24.5.r1050.g47f8338-15.24.5.r1052.g14a5ceb-1
plasma-phonebook 22.04.r8.gc5c190b-1 22.04.r9.g30bccea-1
plasma-remotecontrollers r84.g4ada532-2 r88.g0835330-1
plasma-sdk5.24.5.r2346.ga421f566-15.24.5.r2350.g12d14c36-1
plasma-settings 22.04.r18.ga21db05-1 22.04.r25.g53b197e-1
plasma-systemmonitor5.24.5.r567.g0ca0b4f-15.24.5.r569.g401cd77-1
plasma-vault5.24.5.r379.g94d2ab3-15.24.5.r381.g5d8ad5f-1
plasma-wayland-session5.24.5.r11764.gad1a51c83-15.24.5.r11846.g7f308065a-1
plasma-workspace5.24.5.r11764.gad1a51c83-15.24.5.r11846.g7f308065a-1
plasma-workspace-wallpapers5.24.5.r336.g685fa57-15.24.5.r338.g81f1253-1
polkit-kde-agent5.24.5.r520.gd6360ed-15.24.5.r522.g1b42f89-1
powerdevil5.24.5.r2538.ga3225694-15.24.5.r2541.ge3f1a593-1
poxml22.04.1.r281.g183b2c7-122.04.1.r282.g2615361-1
print-manager22.04.1.r1125.g631b086-122.04.1.r1131.g8a71d7c-1
prison5.94.0.r375.g71384bf-15.94.0.r377.g03ab24c-1
qcachegrind22.04.1.r1178.g26c0cec-122.04.1.r1179.g82a4b92-1
qmlkonsole 22.04.r19.g355754d-1 22.04.r20.gdda723d-1
qqc2-desktop-style5.94.0.r598.gb5c335d-15.94.0.r605.ga681d40-1
sddm-kcm5.24.5.r647.g2ea254d-15.24.5.r649.gd12c6e3-1
spacebar 22.04.r6.g0fcbe67-1 22.04.r13.g9c0d676-1
spectacle22.04.1.r1345.gedbe920-122.04.1.r1348.gf3171f9-1
svgpart22.04.1.r215.gf36061c-122.04.1.r217.ge8e3631-1
syntax-highlighting5.94.0.r1830.g12e610d0-15.94.0.r1831.g7c54fd90-1
systemsettings5.24.5.r2656.ge373a9a9-15.24.5.r2661.g019da1ff-1
telepathy-kde-accounts-kcm22.04.1.r1211.ga82a68a-122.04.1.r1213.g4bd6686-1
telepathy-kde-approver22.04.1.r302.gf9aae9d-122.04.1.r303.g74abcb5-1
telepathy-kde-auth-handler22.04.1.r282.ga240a20-122.04.1.r283.gece2e65-1
telepathy-kde-call-ui22.04.1.r448.gf01f09a-122.04.1.r449.g4c30cd2-1
telepathy-kde-common-internals22.04.1.r2010.g48a8c04-122.04.1.r2011.gd910636-1
telepathy-kde-contact-list22.04.1.r1090.g58353ef-122.04.1.r1091.gbad1b7a-1
telepathy-kde-contact-runner22.04.1.r258.gd1d25e2-122.04.1.r259.gec20b79-1
telepathy-kde-desktop-applets22.04.1.r1000.g135606f-122.04.1.r1002.g426f6e2-1
telepathy-kde-filetransfer-handler22.04.1.r225.g3958b9e-122.04.1.r226.g89862cf-1
telepathy-kde-integration-module22.04.1.r399.gfed9154-122.04.1.r400.gd2643d8-1
telepathy-kde-send-file22.04.1.r234.gae2a4de-122.04.1.r235.ga2969bb-1
telepathy-kde-text-ui22.04.1.r2037.g6695846-122.04.1.r2038.g992033c-1
tokodon 22.04.r26.gce37bc5-1 22.04.r33.g7296fa0-1
umbrello22.04.1.r8461.g253f318d7-122.04.1.r8464.ga8037fbad-1
vakzination 22.04.r13.g7b4f3db-1 22.04.r16.ga4aa636-1
vvave 2.1.1.r22.geb01109-1 2.1.2.r3.g72fd3b1-1
xdg-desktop-portal-kde5.24.5.r477.gf15399f-15.24.5.r479.gf0193bb-1
yakuake22.04.1.r790.g554ca4b-122.04.1.r791.g75666cf-1
zeroconf-ioslave22.04.1.r378.gd6a38e6-122.04.1.r379.g3ac8dc0-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
