Hello ARM community.
Preparing for our next release, so here’s a bunch of updates.
Some highlights:
- Most of our kernels got updated
- Firefox updated to 98.0.1 with a fix for aarch64
- KDE Frameworks update to 5.92
- And the OpenSSL package is now at 1.1.1.n
- Budgie Desktop updated to 10.6
- And a couple more QT5 packages got updated to 5.15.3
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Fri Mar 18 20:20:57 CET 2022)
- arm-testing community aarch64: 203 new and 201 removed package(s)
- arm-testing core aarch64: 34 new and 32 removed package(s)
- arm-testing extra aarch64: 284 new and 378 removed package(s)
- arm-testing kde-unstable aarch64: 364 new and 364 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-03-13 2022-03-18
code 1.65.0-1 1.65.2-1
element-desktop 1.10.6-1 1.10.7-1
element-web 1.10.6-1 1.10.7-1
iio-sensor-proxy 3.3-0 -
libglibutil 1.0.61-1 1.0.62-1
linux-rpi4-udl 5.15.24-1 5.15.28-1
linux-rpi4-udl-headers 5.15.24-1 5.15.28-1
nvm 0.39.1-1 0.38.0-2
rpi-eeprom 20220228-1 20220310-1
signal-desktop 5.34.0-1 5.35.0-1
:: Different sync package(s) in repository community aarch64
ansible 5.4.0-3 5.5.0-1
antlr4-runtime 4.9.3-3 4.9.3-4
aws-cli 1.22.61-1 1.22.74-1
bctoolbox 5.1.3-1 5.1.10-1
bitwarden-cli 1.21.1-1 1.22.0-1
borgmatic 1.5.23-1 1.5.24-1
bower 1.8.13-1 1.8.14-1
budgie-desktop 10.5.3-2 10.6-1
budgie-desktop-view 1.1.1-1 1.2-1
budgie-screensaver 4.0-2 5.0-1
bzrtp 5.1.3-1 5.1.10-1
cargo-crev 0.23.0-2 0.23.1-1
cargo-pgx 0.3.3-1 0.4.0-1
ccache 4.5.1-1 4.6-1
celluloid 0.22-1 0.23-1
cereal 1.3.1-2 1.3.2-1
cgal 4.14.3-3 5.4-1
cgns 4.2.0-1 4.2.0-2
clash 1.8.0-1 1.9.0-1
clojure 1.10.3.1075-1 1.10.3.1087-1
cockpit 264.1-1 265-1
cockpit-machines 263-1 264-1
cockpit-pcp 264.1-1 265-1
cockpit-podman 43-1 44-1
converseen 0.9.9.4-1 0.9.9.5-1
cri-o 1.23.1-1 1.23.2-1
dark-reader 4.9.46-1 4.9.47-1
dart 2.14.4-1 2.16.1-1
datovka 4.19.0-1 4.20.0-1
deepin-qt5platform-plugins 5.0.46-2 5.0.46-3
devede 4.16.0-3 4.17.0-1
doctl 1.70.0-1 1.71.1-1
dscanner 0.12.0-1 0.12.1-1
duplicity 0.8.21-2 0.8.22-1
element 0.42.0-2 0.46.4-1
erlang 24.2.1-1 24.3-1
erlang-nox 24.2.1-1 24.3-1
erlang-unixodbc 24.2.1-1 24.3-1
firefox-dark-reader 4.9.46-1 4.9.47-1
firefox-extension-mailvelope 4.5.0-1 4.5.1-1
freeciv 2.6.6-1 3.0.0-1
git-cliff 0.6.0-2 0.6.1-1
github-cli 2.5.2-1 2.6.0-1
gnome-passwordsafe 6.1-2 6.2-1
gnome-tour 40.0-1 40.1-1
go 2:1.17.8-1 2:1.18-1
go-tools 4:0.1.9-1 4:0.1.10-1
gopls 0.8.0-1 0.8.1-1
gprename 20210415-1 20220206-1
gpsbabel 1.7.0-2 1.8.0-1
gsoap 2.8.119-1 2.8.120-1
haproxy 2.5.4-1 2.5.5-1
helm 3.8.0-1 3.8.1-1
hugo 0.93.2-1 0.94.2-1
i3status-rust 0.21.7-1 0.21.8-1
igraph 0.9.6-1 0.9.7-1
iio-sensor-proxy 3.1-1 3.3-1
imagescan 3.65.0-4 3.65.0-5
imv 4.3.1-2 4.3.1-3
innernet 1.5.3-1 1.5.4-1
irker 2.21-1 2.22-1
jenkins 2.338-1 2.339-1
jmol 14.32.33-1 14.32.38-1
josm 18360-3 18387-1
jsmol 14.32.33-1 14.32.38-1
jupyter-nbclassic 0.3.6-1 0.3.7-1
jupyter-nbconvert 6.4.3-1 6.4.4-1
jupyter-nbformat 5.1.3-3 5.2.0-1
jupyter-notebook 6.4.8-1 6.4.10-2
jupyter-server 1.13.5-1 1.15.6-1
jupyter-widgetsnbextension 1:3.5.2-1 1:3.6.0-1
jupyterlab 3.3.1-1 3.3.2-2
kicad 6.0.2-1.1 6.0.3-1
kicad-library-3d 6.0.2-1.1 6.0.3-1
kicad-library 6.0.2-1.1 6.0.3-1
kiwix-desktop 2.1.0-2 2.2.1-1
kmymoney 5.1.2-3 5.1.2-5
knot 3.1.5-1 3.1.6-1
kstars 1:3.5.7-2 1:3.5.8-1
lazygit 0.33-1 0.34-1
lfs 2.4.0-1 2.5.0-1
libjcat 0.1.9-1 0.1.10-1
liblo 1:0.31-1 1:0.31-2
libnsbmp 0.1.6-3 0.1.6-6
libnsgif 0.2.1-5 0.2.1-6
libofx 0.9.15-1 0.10.3-1
libofx-doc 0.9.15-1 0.10.3-1
libressl 3.4.2-1 3.4.3-1
libtraceevent 1:1.5.1-1 1:1.5.2-1
libtraceevent-docs 1:1.5.1-1 1:1.5.2-1
libtracefs 1.3.0-1 1.3.1-1
libtracefs-docs 1.3.0-1 1.3.1-1
lxcfs 4.0.12-1 5.0.0-1
maturin 0.12.10-1 0.12.11-1
mediastreamer 5.1.3-1 5.1.10-1
meilisearch 0.25.2-1 0.26.0-1
miniflux 2.0.35-1 2.0.36-1
minio 2022.02.26-1 2022.03.14-1
minio-client 2022.02.26-1 2022.03.13-1
miniserve 0.19.2-1 0.19.3-1
new-session-manager 1.5.3-1 1.5.3-2
nextcloud-app-calendar 1:3.1.0-1 1:3.2.1-1
nextcloud-app-deck 1:1.6.0-1 1:1.6.1-1
nextcloud-app-news 17.0.1-1 18.0.0-1
nextcloud-client 2:3.4.3-1 2:3.4.3-2
nextcloud-client-cloudproviders 2:3.4.3-1 2:3.4.3-2
nix 2.6.1-2 2.7.0-1
nix-docs 2.6.1-2 2.7.0-1
nodejs-lts-gallium 16.13.2-1 16.14.1-1
npm-check-updates 12.5.2-1 12.5.3-1
nsd 4.3.9-1 4.4.0-1
nuitka 0.7-1 0.7.5-1
ocaml-csexp 1.5.1-3 1.5.1-4
openscad 2021.01-3 2021.01-4
ortp 5.1.3-1 5.1.10-1
osbuild 52-2 52-4
otter-browser 1.0.02-2 1.0.03-1
perl-test-simple 1.302189-1 1.302190-1
perl-test2-suite 0.000144-1 0.000145-1
piping-server 0.12.0-1 0.12.1-1
podman 4.0.1-1 4.0.1-2
podman-docker 4.0.1-1 4.0.1-2
prettier 2.5.1-1 2.6.0-1
pugixml 1.11.4-1 1.12.1-1
py3status 3.41-1 3.42-1
pyenv 2.2.4-1 2.2.5-1
pyright 1.1.229-1 1.1.230-1
python-ansible-compat 1.0.0-2 2.0.0-1
python-boto3 1.21.6-1 1.21.19-1
python-botocore 1.24.6-1 1.24.19-1
python-canonicaljson 1.5.0-3 1.6.0-1
python-click-log 0.3.2-9 0.4.0-1
python-collada 0.7.1-3 0.7.2-1
python-cycler 0.10.0-10 0.11.0-1
python-debtcollector 2.4.0-1 2.5.0-1
python-dulwich 0.20.33-1 0.20.34-1
python-ipykernel 6.9.1-1 6.9.2-2
python-ipywidgets 7.6.5-4 7.7.0-2
python-jupyter_core 4.9.1-3 4.9.2-1
python-jupyterlab_server 2.10.3-1 2.11.2-1
python-owslib 0.24.1-3 0.25.0-1
python-proxy.py 2.4.0-2 2.4.1-1
python-py7zr 0.18.0-1 0.18.1-1
python-pyglet 1.5.21-3 1.5.22-1
python-pynitrokey 0.4.19-2 0.4.20-1
python-pyppmd 0.17.4-1 0.18.0-1
python-pytesseract 0.3.9-1 0.3.10-1
python-pytest 7.0.1-1 7.1.1-1
python-pytest-mpl 0.14.0-1 0.14.0-4
python-pytest-responsemock 1.1.0-1 1.1.1-1
python-s3transfer 0.5.1-1 0.5.2-1
python-spsdk 1.6.1-1 1.6.2-1
python-txtorcon 21.1.0-3 22.0.0-1
python-tzdata 2021.5-3 2022.1-1
rapid-photo-downloader 0.9.31-1 0.9.33-1
rednotebook 2.22-2 2.24-1
remmina 1:1.4.24-1 1:1.4.25-1
rkcommon 1.8.0-3 1.9.0-1
rkward 0.7.2-1 0.7.2-2
rust-analyzer 20220307-1 20220314-1
rustypaste 0.6.4-1 0.6.5-2
scite 5.1.6-1 5.2.1-1
sdcc 4.1.0-1 4.2.0-1
serverless 3.7.4-1 3.7.5-1
shellharden 4.1.3-1 4.2.0-1
simutrans 123.0-1 123.0.1-1
singularity-container 3.8.6-1 -
snd 22.1-1 22.2-1
sops 3.7.1-4 3.7.2-1
stellarsolver 2.1-2 2.2-1
stunnel 5.62-1 5.63-1
stylelint 14.5.3-1 14.6.0-1
task 2.6.1-1 2.6.2-1
telegram-desktop 3.6.0-1 3.6.1-1
thunderbird-dark-reader 4.9.46-1 4.9.47-1
tigervnc 1.12.0-2 1.12.0-3
tinygo 0.21.0-1 0.22.0-1
tinyssh 20220305-1 20220311-1
tpm2-tss 3.2.0-1 -
unpaper 6.1-8 6.1-9
urlwatch 2.24-2 2.25-1
v2ray-domain-list-community 20220310015105-1 20220313173740-1
vc-intrinsics 0.1.0-1 0.1.0-2
verilator 4.218-1 4.220-1
watchexec 1.18.7-1 1.18.8-1
weechat 3.4-1 3.4.1-1
xpad 5.5.0-1 5.6.0-1
xreader 3.2.2-1 3.3.0-1
yadm 3.1.1-2 3.2.0-1
yarn 1.22.17-1 1.22.18-1
zellij 0.26.0-1 0.26.1-1
apptainer - 1.0.1-1
nerdctl - 0.17.1-2
python-ipyparallel - 8.2.0-2
python-mpris2 - 1.0.2-1
rustypaste-cli - 0.1.5-1
:: Different overlay package(s) in repository core aarch64
linux 5.16.14-1 5.16.15-2
linux-clockworkpi-a06 5.16.14-1 5.16.15-1
linux-clockworkpi-a06-headers 5.16.14-1 5.16.15-1
linux-headers 5.16.14-1 5.16.15-2
linux-lts 5.15.28-1 5.15.29-1
linux-lts-headers 5.15.28-1 5.15.29-1
linux-pinephone 5.16.15-1 5.17.0rc8-1
linux-pinephone-headers 5.16.15-1 5.17.0rc8-1
linux-pinephonepro 5.16.15-1 5.17.0rc8-1
linux-pinephonepro-headers 5.16.15-1 5.17.0rc8-1
linux-quartz64 5.17.0-0.3 5.17.0-0.4
linux-quartz64-headers 5.17.0-0.3 5.17.0-0.4
linux-rc 5.17.rc7-3 5.17.rc8-3
linux-rc-headers 5.17.rc7-3 5.17.rc8-3
linux-rpi4 5.15.26-1 5.15.28-1
linux-rpi4-headers 5.15.26-1 5.15.28-1
linux-rpi4-mainline 5.16.12-1 5.16.14-1
linux-rpi4-mainline-headers 5.16.12-1 5.16.14-1
linux-rpi4-rc 5.17.rc6-1 5.17.rc8-1
linux-rpi4-rc-headers 5.17.rc6-1 5.17.rc8-1
raspberrypi-bootloader 20220301-1 20220315-1
raspberrypi-bootloader-x 20220301-1 20220315-1
uboot-pinephone 2022.04rc3-2 2022.04rc4-1
uboot-pinephonepro 4:2022.04rc3-2 4:2022.04rc4-2
uboot-quartz64-b - 2022.01.rc4-1
:: Different sync package(s) in repository core aarch64
lemon 3.38.0-1 3.38.1-1
libusb 1.0.25-2 1.0.25-3
mkinitcpio 31-2 31-2.1
openssl 1.1.1.m-1 1.1.1.n-1
sqlite 3.38.0-1 3.38.1-1
sqlite-analyzer 3.38.0-1 3.38.1-1
sqlite-doc 3.38.0-1 3.38.1-1
sqlite-tcl 3.38.0-1 3.38.1-1
tpm2-tss - 3.2.0-1
:: Different overlay package(s) in repository extra aarch64
calamares 3.2.51-1 3.2.53-1
firefox 97.0.2-1 -
firefox-i18n-ach 97.0.2-1 -
firefox-i18n-af 97.0.2-1 -
firefox-i18n-an 97.0.2-1 -
firefox-i18n-ar 97.0.2-1 -
firefox-i18n-ast 97.0.2-1 -
firefox-i18n-az 97.0.2-1 -
firefox-i18n-be 97.0.2-1 -
firefox-i18n-bg 97.0.2-1 -
firefox-i18n-bn 97.0.2-1 -
firefox-i18n-br 97.0.2-1 -
firefox-i18n-bs 97.0.2-1 -
firefox-i18n-ca 97.0.2-1 -
firefox-i18n-ca-valencia 97.0.2-1 -
firefox-i18n-cak 97.0.2-1 -
firefox-i18n-cs 97.0.2-1 -
firefox-i18n-cy 97.0.2-1 -
firefox-i18n-da 97.0.2-1 -
firefox-i18n-de 97.0.2-1 -
firefox-i18n-dsb 97.0.2-1 -
firefox-i18n-el 97.0.2-1 -
firefox-i18n-en-ca 97.0.2-1 -
firefox-i18n-en-gb 97.0.2-1 -
firefox-i18n-en-us 97.0.2-1 -
firefox-i18n-eo 97.0.2-1 -
firefox-i18n-es-ar 97.0.2-1 -
firefox-i18n-es-cl 97.0.2-1 -
firefox-i18n-es-es 97.0.2-1 -
firefox-i18n-es-mx 97.0.2-1 -
firefox-i18n-et 97.0.2-1 -
firefox-i18n-eu 97.0.2-1 -
firefox-i18n-fa 97.0.2-1 -
firefox-i18n-ff 97.0.2-1 -
firefox-i18n-fi 97.0.2-1 -
firefox-i18n-fr 97.0.2-1 -
firefox-i18n-fy-nl 97.0.2-1 -
firefox-i18n-ga-ie 97.0.2-1 -
firefox-i18n-gd 97.0.2-1 -
firefox-i18n-gl 97.0.2-1 -
firefox-i18n-gn 97.0.2-1 -
firefox-i18n-gu-in 97.0.2-1 -
firefox-i18n-he 97.0.2-1 -
firefox-i18n-hi-in 97.0.2-1 -
firefox-i18n-hr 97.0.2-1 -
firefox-i18n-hsb 97.0.2-1 -
firefox-i18n-hu 97.0.2-1 -
firefox-i18n-hy-am 97.0.2-1 -
firefox-i18n-ia 97.0.2-1 -
firefox-i18n-id 97.0.2-1 -
firefox-i18n-is 97.0.2-1 -
firefox-i18n-it 97.0.2-1 -
firefox-i18n-ja 97.0.2-1 -
firefox-i18n-ka 97.0.2-1 -
firefox-i18n-kab 97.0.2-1 -
firefox-i18n-kk 97.0.2-1 -
firefox-i18n-km 97.0.2-1 -
firefox-i18n-kn 97.0.2-1 -
firefox-i18n-ko 97.0.2-1 -
firefox-i18n-lij 97.0.2-1 -
firefox-i18n-lt 97.0.2-1 -
firefox-i18n-lv 97.0.2-1 -
firefox-i18n-mk 97.0.2-1 -
firefox-i18n-mr 97.0.2-1 -
firefox-i18n-ms 97.0.2-1 -
firefox-i18n-my 97.0.2-1 -
firefox-i18n-nb-no 97.0.2-1 -
firefox-i18n-ne-np 97.0.2-1 -
firefox-i18n-nl 97.0.2-1 -
firefox-i18n-nn-no 97.0.2-1 -
firefox-i18n-oc 97.0.2-1 -
firefox-i18n-pa-in 97.0.2-1 -
firefox-i18n-pl 97.0.2-1 -
firefox-i18n-pt-br 97.0.2-1 -
firefox-i18n-pt-pt 97.0.2-1 -
firefox-i18n-rm 97.0.2-1 -
firefox-i18n-ro 97.0.2-1 -
firefox-i18n-ru 97.0.2-1 -
firefox-i18n-si 97.0.2-1 -
firefox-i18n-sk 97.0.2-1 -
firefox-i18n-sl 97.0.2-1 -
firefox-i18n-son 97.0.2-1 -
firefox-i18n-sq 97.0.2-1 -
firefox-i18n-sr 97.0.2-1 -
firefox-i18n-sv-se 97.0.2-1 -
firefox-i18n-ta 97.0.2-1 -
firefox-i18n-te 97.0.2-1 -
firefox-i18n-th 97.0.2-1 -
firefox-i18n-tl 97.0.2-1 -
firefox-i18n-tr 97.0.2-1 -
firefox-i18n-trs 97.0.2-1 -
firefox-i18n-uk 97.0.2-1 -
firefox-i18n-ur 97.0.2-1 -
firefox-i18n-uz 97.0.2-1 -
firefox-i18n-vi 97.0.2-1 -
firefox-i18n-xh 97.0.2-1 -
firefox-i18n-zh-cn 97.0.2-1 -
firefox-i18n-zh-tw 97.0.2-1 -
manjaro-chrootbuild r255.gdf92080-1 r265.gd6558f7-1
pyside2-es2 5.15.2.1-1 5.15.3-1
qt5-es2-base 5.15.3+kde+r132-1 5.15.3+kde+r134-1
qt5-es2-xcb-private-headers 5.15.3+kde+r132-1 5.15.3+kde+r134-1
:: Different sync package(s) in repository extra aarch64
archboot-arm 2022.03-5 2022.03-20
attica 5.91.0-1 5.92.0-1
baloo 5.91.0-1 5.92.0-1
bind 9.18.0-1 9.18.1-1
bluez 5.63-2 5.64-1
bluez-cups 5.63-2 5.64-1
bluez-hid2hci 5.63-2 5.64-1
bluez-libs 5.63-2 5.64-1
bluez-plugins 5.63-2 5.64-1
bluez-qt 5.91.0-1 5.92.0-1
bluez-utils 5.63-2 5.64-1
breeze-icons 5.91.0-1 5.92.0-1
cfitsio 1:4.0.0-1 1:4.1.0-1
chromium 99.0.4844.51-1 99.0.4844.74-1
composer 2.2.7-1 2.2.9-1
directx-headers 1.4.9-1 1.600.10-1
discount 2.2.7-1 2.2.7-2
evince 41.3-1 41.4-1
extra-cmake-modules 5.91.0-1 5.92.0-1
firefox 98.0-1 98.0.1-1.1
firefox-i18n-ach 98.0-1 98.0.1-1
firefox-i18n-af 98.0-1 98.0.1-1
firefox-i18n-an 98.0-1 98.0.1-1
firefox-i18n-ar 98.0-1 98.0.1-1
firefox-i18n-ast 98.0-1 98.0.1-1
firefox-i18n-az 98.0-1 98.0.1-1
firefox-i18n-be 98.0-1 98.0.1-1
firefox-i18n-bg 98.0-1 98.0.1-1
firefox-i18n-bn 98.0-1 98.0.1-1
firefox-i18n-br 98.0-1 98.0.1-1
firefox-i18n-bs 98.0-1 98.0.1-1
firefox-i18n-ca 98.0-1 98.0.1-1
firefox-i18n-ca-valencia 98.0-1 98.0.1-1
firefox-i18n-cak 98.0-1 98.0.1-1
firefox-i18n-cs 98.0-1 98.0.1-1
firefox-i18n-cy 98.0-1 98.0.1-1
firefox-i18n-da 98.0-1 98.0.1-1
firefox-i18n-de 98.0-1 98.0.1-1
firefox-i18n-dsb 98.0-1 98.0.1-1
firefox-i18n-el 98.0-1 98.0.1-1
firefox-i18n-en-ca 98.0-1 98.0.1-1
firefox-i18n-en-gb 98.0-1 98.0.1-1
firefox-i18n-en-us 98.0-1 98.0.1-1
firefox-i18n-eo 98.0-1 98.0.1-1
firefox-i18n-es-ar 98.0-1 98.0.1-1
firefox-i18n-es-cl 98.0-1 98.0.1-1
firefox-i18n-es-es 98.0-1 98.0.1-1
firefox-i18n-es-mx 98.0-1 98.0.1-1
firefox-i18n-et 98.0-1 98.0.1-1
firefox-i18n-eu 98.0-1 98.0.1-1
firefox-i18n-fa 98.0-1 98.0.1-1
firefox-i18n-ff 98.0-1 98.0.1-1
firefox-i18n-fi 98.0-1 98.0.1-1
firefox-i18n-fr 98.0-1 98.0.1-1
firefox-i18n-fy-nl 98.0-1 98.0.1-1
firefox-i18n-ga-ie 98.0-1 98.0.1-1
firefox-i18n-gd 98.0-1 98.0.1-1
firefox-i18n-gl 98.0-1 98.0.1-1
firefox-i18n-gn 98.0-1 98.0.1-1
firefox-i18n-gu-in 98.0-1 98.0.1-1
firefox-i18n-he 98.0-1 98.0.1-1
firefox-i18n-hi-in 98.0-1 98.0.1-1
firefox-i18n-hr 98.0-1 98.0.1-1
firefox-i18n-hsb 98.0-1 98.0.1-1
firefox-i18n-hu 98.0-1 98.0.1-1
firefox-i18n-hy-am 98.0-1 98.0.1-1
firefox-i18n-ia 98.0-1 98.0.1-1
firefox-i18n-id 98.0-1 98.0.1-1
firefox-i18n-is 98.0-1 98.0.1-1
firefox-i18n-it 98.0-1 98.0.1-1
firefox-i18n-ja 98.0-1 98.0.1-1
firefox-i18n-ka 98.0-1 98.0.1-1
firefox-i18n-kab 98.0-1 98.0.1-1
firefox-i18n-kk 98.0-1 98.0.1-1
firefox-i18n-km 98.0-1 98.0.1-1
firefox-i18n-kn 98.0-1 98.0.1-1
firefox-i18n-ko 98.0-1 98.0.1-1
firefox-i18n-lij 98.0-1 98.0.1-1
firefox-i18n-lt 98.0-1 98.0.1-1
firefox-i18n-lv 98.0-1 98.0.1-1
firefox-i18n-mk 98.0-1 98.0.1-1
firefox-i18n-mr 98.0-1 98.0.1-1
firefox-i18n-ms 98.0-1 98.0.1-1
firefox-i18n-my 98.0-1 98.0.1-1
firefox-i18n-nb-no 98.0-1 98.0.1-1
firefox-i18n-ne-np 98.0-1 98.0.1-1
firefox-i18n-nl 98.0-1 98.0.1-1
firefox-i18n-nn-no 98.0-1 98.0.1-1
firefox-i18n-oc 98.0-1 98.0.1-1
firefox-i18n-pa-in 98.0-1 98.0.1-1
firefox-i18n-pl 98.0-1 98.0.1-1
firefox-i18n-pt-br 98.0-1 98.0.1-1
firefox-i18n-pt-pt 98.0-1 98.0.1-1
firefox-i18n-rm 98.0-1 98.0.1-1
firefox-i18n-ro 98.0-1 98.0.1-1
firefox-i18n-ru 98.0-1 98.0.1-1
firefox-i18n-si 98.0-1 98.0.1-1
firefox-i18n-sk 98.0-1 98.0.1-1
firefox-i18n-sl 98.0-1 98.0.1-1
firefox-i18n-son 98.0-1 98.0.1-1
firefox-i18n-sq 98.0-1 98.0.1-1
firefox-i18n-sr 98.0-1 98.0.1-1
firefox-i18n-sv-se 98.0-1 98.0.1-1
firefox-i18n-ta 98.0-1 98.0.1-1
firefox-i18n-te 98.0-1 98.0.1-1
firefox-i18n-th 98.0-1 98.0.1-1
firefox-i18n-tl 98.0-1 98.0.1-1
firefox-i18n-tr 98.0-1 98.0.1-1
firefox-i18n-trs 98.0-1 98.0.1-1
firefox-i18n-uk 98.0-1 98.0.1-1
firefox-i18n-ur 98.0-1 98.0.1-1
firefox-i18n-uz 98.0-1 98.0.1-1
firefox-i18n-vi 98.0-1 98.0.1-1
firefox-i18n-xh 98.0-1 98.0.1-1
firefox-i18n-zh-cn 98.0-1 98.0.1-1
firefox-i18n-zh-tw 98.0-1 98.0.1-1
flatpak 1:1.12.6-1 1:1.12.7-1
frameworkintegration 5.91.0-1 5.92.0-1
gnuplot 5.4.3-2 5.4.3-4
graphviz 2.50.0-2 3.0.0-1
gst-editing-services 1.20.0-3 1.20.1-1
gst-libav 1.20.0-3 1.20.1-1
gst-plugin-gtk 1.20.0-3 1.20.1-1
gst-plugin-opencv 1.20.0-3 1.20.1-1
gst-plugin-qmlgl 1.20.0-3 1.20.1-1
gst-plugin-va 1.20.0-3 1.20.1-1
gst-plugin-wpe 1.20.0-3 1.20.1-1
gst-plugins-bad 1.20.0-3 1.20.1-1
gst-plugins-bad-libs 1.20.0-3 1.20.1-1
gst-plugins-base 1.20.0-3 1.20.1-1
gst-plugins-base-libs 1.20.0-3 1.20.1-1
gst-plugins-good 1.20.0-3 1.20.1-1
gst-plugins-ugly 1.20.0-3 1.20.1-1
gst-python 1.20.0-3 1.20.1-1
gst-rtsp-server 1.20.0-3 1.20.1-1
gstreamer 1.20.0-3 1.20.1-1
gstreamer-docs 1.20.0-3 1.20.1-1
gstreamer-vaapi 1.20.0-3 1.20.1-1
hplip 1:3.22.2-1 1:3.22.2-2
imlib2 1.8.0-1 1.8.1-1
kactivities 5.91.0-1 5.92.0-1
kactivities-stats 5.91.0-1 5.92.0-1
kapidox 5.91.0-1 5.92.0-1
karchive 5.91.0-1 5.92.0-1
kauth 5.91.0-1 5.92.0-1
kbookmarks 5.91.0-1 5.92.0-1
kcalendarcore 5.91.0-1 5.92.0-1
kcmutils 5.91.0-1 5.92.0-1
kcodecs 5.91.0-1 5.92.0-1
kcompletion 5.91.0-1 5.92.0-1
kconfig 5.91.0-1 5.92.0-1
kconfigwidgets 5.91.0-1 5.92.0-1
kcontacts 1:5.91.0-1 1:5.92.0-1
kcoreaddons 5.91.0-1 5.92.0-1
kcrash 5.91.0-1 5.92.0-1
kdav 1:5.91.0-1 1:5.92.0-1
kdbusaddons 5.91.0-1 5.92.0-1
kdeclarative 5.91.0-1 5.92.0-1
kded 5.91.0-1 5.92.0-1
kdelibs4support 5.91.0-1 5.92.0-1
kdesignerplugin 5.91.0-1 5.92.0-1
kdesu 5.91.0-1 5.92.0-1
kdewebkit 5.91.0-1 5.92.0-1
kdnssd 5.91.0-1 5.92.0-1
kdoctools 5.91.0-1 5.92.0-1
kemoticons 5.91.0-1 5.92.0-1
kfilemetadata 5.91.0-2 5.92.0-1
kglobalaccel 5.91.0-1 5.92.0-1
kguiaddons 5.91.0-1 5.92.0-1
kholidays 1:5.91.0-1 1:5.92.0-1
khtml 5.91.0-1 5.92.0-1
ki18n 5.91.0-1 5.92.0-1
kiconthemes 5.91.0-1 5.92.0-1
kidletime 5.91.0-1 5.92.0-1
kimageformats 5.91.0-1 5.92.0-1
kinit 5.91.0-1 5.92.0-1
kio 5.91.0-1 5.92.0-1
kirigami2 5.91.0-1 5.92.0-1
kitemmodels 5.91.0-1 5.92.0-1
kitemviews 5.91.0-1 5.92.0-1
kjobwidgets 5.91.0-1 5.92.0-1
kjs 5.91.0-1 5.92.0-1
kjsembed 5.91.0-1 5.92.0-1
kmediaplayer 5.91.0-1 5.92.0-1
knewstuff 5.91.0-1 5.92.0-1
knotifications 5.91.0-1 5.92.0-1
knotifyconfig 5.91.0-1 5.92.0-1
kpackage 5.91.0-1 5.92.0-1
kparts 5.91.0-1 5.92.0-1
kpeople 5.91.0-1 5.92.0-1
kplotting 5.91.0-1 5.92.0-1
kpty 5.91.0-1 5.92.0-1
kquickcharts 5.91.0-1 5.92.0-1
kross 5.91.0-1 5.92.0-1
krunner 5.91.0-1 5.92.0-1
kservice 5.91.0-1 5.92.0-1
ktexteditor 5.91.0-1 5.92.0-1
ktextwidgets 5.91.0-1 5.92.0-1
kunitconversion 5.91.0-1 5.92.0-1
kwallet 5.91.0-1 5.92.0-1
kwayland 5.91.0-1 5.92.0-1
kwidgetsaddons 5.91.0-1 5.92.0-1
kwindowsystem 5.91.0-1 5.92.0-1
kxmlgui 5.91.0-1 5.92.0-1
kxmlrpcclient 5.91.0-1 5.92.0-1
libaccounts-glib 1.25-6 1.25-7
libopenmpt 0.6.1-1 0.6.2-1
libqalculate 4.0.0-1 4.1.0-1
librsvg 2:2.52.7-1 2:2.54.0-1
libvdpau 1.4-2 1.5-1
live-media 2021.08.24-1 2022.02.07-1
mencoder 38322-3 38359-1
meson 0.61.2-1 0.61.3-1
modemmanager-qt 5.91.0-1 5.92.0-1
mpd 0.23.5-6 0.23.6-1
mplayer 38322-3 38359-1
networkmanager-qt 5.91.0-1 5.92.0-1
openvpn 2.5.5-1 2.5.6-1
oxygen-icons 1:5.91.0-1 1:5.92.0-1
oxygen-icons-svg 1:5.91.0-1 1:5.92.0-1
php 8.1.3-1 8.1.4-1
php-apache 8.1.3-1 8.1.4-1
php-cgi 8.1.3-1 8.1.4-1
php-dblib 8.1.3-1 8.1.4-1
php-embed 8.1.3-1 8.1.4-1
php-enchant 8.1.3-1 8.1.4-1
php-fpm 8.1.3-1 8.1.4-1
php-gd 8.1.3-1 8.1.4-1
php-imap 8.1.3-1 8.1.4-1
php-intl 8.1.3-1 8.1.4-1
php-odbc 8.1.3-1 8.1.4-1
php-pgsql 8.1.3-1 8.1.4-1
php-phpdbg 8.1.3-1 8.1.4-1
php-pspell 8.1.3-1 8.1.4-1
php-snmp 8.1.3-1 8.1.4-1
php-sodium 8.1.3-1 8.1.4-1
php-sqlite 8.1.3-1 8.1.4-1
php-tidy 8.1.3-1 8.1.4-1
php-xsl 8.1.3-1 8.1.4-1
plasma-framework 5.91.0-1 5.92.0-1
prison 5.91.0-1 5.92.0-1
prometheus-blackbox-exporter 0.19.0-1 0.20.0-1
purpose 5.91.0-1 5.92.0-1
pyside2 5.15.2.1-1 5.15.3-1
python-pyparsing 3.0.1-1 3.0.2-1
python-shiboken2 5.15.2.1-2 5.15.3-1
qalculate-gtk 4.0.0-1 4.1.0-1
qqc2-desktop-style 5.91.0-1 5.92.0-1
qt5-base 5.15.3+kde+r133-1 5.15.3+kde+r136-1
qt5-doc 5.15.2-2 5.15.3-1
qt5-examples 5.15.2-2 5.15.3-1
qt5-location 5.15.3+kde+r0-1 5.15.3+kde+r1-1
qt5-mqtt 5.15.2-2 5.15.2-3
qt5-xcb-private-headers 5.15.3+kde+r133-1 5.15.3+kde+r136-1
rubygems 3.3.5-1 3.3.8-1
samba 4.15.5-1 4.15.6-1
smbclient 4.15.5-1 4.15.6-1
solid 5.91.0-1 5.92.0-1
sonnet 5.91.0-1 5.92.0-1
squashfs-tools 4.5-2.1 4.5.1-1
suitesparse 5.10.1-2 5.11.0-1
syndication 5.91.0-1 5.92.0-1
syntax-highlighting 5.91.0-1 5.92.0-1
syslog-ng 3.35.1-4 3.36.1-1
threadweaver 5.91.0-1 5.92.0-1
varnish 7.0.2-2 7.1.0-1
vlc 3.0.16-8 3.0.17.3-1
vulkan-headers 1:1.3.207-1 1:1.3.208-1
vulkan-html-docs 1:1.3.207-1 1:1.3.208-1
xdg-desktop-portal 1.12.1-1 1.14.0-1
zabbix-agent 5.4.10-1 6.0.1-1
zabbix-agent2 5.4.10-1 6.0.1-1
zabbix-frontend-php 5.4.10-1 6.0.1-1
zabbix-proxy 5.4.10-1 6.0.1-1
zabbix-server 5.4.10-1 6.0.1-1
gnuplot-demos - 5.4.3-4
librsvg-docs - 2:2.54.0-1
qalculate-qt - 4.1.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.12.2.r12709.g5de212f70-121.12.2.r12711.g4d8fdf914-1
akonadi-calendar21.12.2.1.r2042.ge431b28-121.12.2.1.r2049.gd987efe-1
akonadi-calendar-tools21.12.2.1.r937.g5507907-121.12.2.1.r939.g6b5ba40-1
akonadi-contacts21.12.2.r3152.g9ee86e05-121.12.2.r3156.ge41554f9-1
akonadi-import-wizard21.12.2.1.r1795.gbd11794-121.12.2.1.r1797.g64b72aa-1
akonadi-mime21.12.2.1.r1704.g838f664-121.12.2.1.r1706.g34d9bea-1
akonadi-notes21.12.2.1.r1061.g8a314ac-121.12.2.1.r1063.g2b3eef1-1
akonadi-search21.12.2.1.r1192.gf278fdc-121.12.2.1.r1210.gb2d9c7e-1
akonadiconsole21.12.2.1.r1575.gbd231d5-121.12.2.1.r1577.g91aa1e3-1
akregator21.12.2.r6348.g69ed929b-121.12.2.r6350.g8b386cc3-1
ark21.12.2.1.r4710.g56fd3e93-121.12.2.1.r4715.g389511b1-1
artikulate21.12.2.1.r1405.gcaba6ce-121.12.2.1.r1406.g6421d7a-1
attica5.91.0.r859.gb8fe1bc-15.92.0.r860.gdde032d-1
audiotube 22.02.r13.g347613a-1 22.02.r14.g1a93e0d-1
baloo5.91.0.r3041.g607428c7-15.92.0.r3042.g41ea9394-1
baloo-widgets21.12.2.r734.gbc5c273-121.12.2.r735.ga1ef854-1
bigscreen-image-settings r12.af8ccb1-1 r15.a8bd93e-1
blinken21.12.2.1.r655.ga154234-121.12.2.1.r656.g3396042-1
bluedevil1:5.24.2.r2379.g9ef54dd8-11:5.24.3.r2381.g608de9bd-1
bluez-qt5.91.0.r704.gbf87dfb-15.92.0.r706.g97a0033-1
bomber21.12.2.1.r551.g65b6e3c-121.12.2.1.r552.g07efc86-1
bovo21.12.2.1.r766.g85d82ba-121.12.2.1.r767.gc8336f5-1
breeze5.24.2.r2363.g30cc831a-15.24.3.r2366.gaf1ddf45-1
breeze-grub5.24.2.r11.g63136a9-15.24.3.r11.g63136a9-1
breeze-gtk5.24.2.r449.gdcd699b-15.24.3.r451.g1c4d3d1-1
breeze-icons5.91.0.r1886.gb28db6ce-15.92.0.r1887.g77af4671-1
calendarsupport21.12.2.r668.g3609fd6-121.12.2.r671.g3287867-1
cervisia21.12.2.1.r1653.gcd37a8c-121.12.2.1.r1654.gf931187-1
discover5.24.2.r8587.g0004808f-15.24.3.r8596.gd3fa32a3-1
disman5.24.0.r1814.gdfb62eb-15.24.3.r1814.gdfb62eb-1
dolphin-plugins21.12.2.r644.g2498bd6-121.12.2.r645.g58ff080-1
dragon21.12.2.1.r1026.gf807873-121.12.2.1.r1027.g0d71796-1
drkonqi5.24.2.r732.gcb263a5f-15.24.3.r741.gdc8579af-1
elisa21.12.2.1.r2904.g3b5f0c49-121.12.2.1.r2908.g74c04d51-1
elisa-qtmm21.12.2.1.r2904.g3b5f0c49-121.12.2.1.r2908.g74c04d51-1
eventviews21.12.2.r794.g41867f9-121.12.2.r796.g90d9ff3-1
extra-cmake-modules5.91.0.r3451.gc958fdb-15.91.0.r3455.g7cb3191-1
ffmpegthumbs21.12.2.1.r206.g547540f-121.12.2.1.r209.gd27049f-1
filelight21.12.2.r1053.g2fa33eb-121.12.2.r1059.g01acfad-1
frameworkintegration5.91.0.r623.g3c53fdb-15.92.0.r624.g6117719-1
granatier21.12.2.1.r962.g57a5fff-121.12.2.1.r963.g4eb9587-1
grantlee-editor21.12.2.1.r808.gf600534-121.12.2.1.r810.g78d8afc-1
grantleetheme21.12.2.r384.g471f10d-121.12.2.r385.g2eed32d-1
gwenview21.12.2.1.r6815.g0c7b7bf0-121.12.2.1.r6816.g38f1da76-1
incidenceeditor21.12.2.1.r849.g6a5622c-121.12.2.1.r851.g3e127a9-1
itinerary21.12.2.1.r1739.g2aeb051-121.12.2.1.r1747.g31543e9-1
juk21.12.2.1.r3131.g954a10ad-121.12.2.1.r3135.gda0d8d71-1
k3b1:21.12.2.1.r6715.g1ec8b7408-11:21.12.2.1.r6716.gfcb2336b4-1
kaccounts-integration21.12.2.r1243.ga5143e6-121.12.2.r1244.g5012daa-1
kaccounts-providers21.12.2.1.r391.g69b99b6-121.12.2.1.r392.g9370311-1
kactivities5.91.0.r1389.g8423e5c-15.92.0.r1390.geec00c0-1
kactivities-stats5.91.0.r398.g85ce556-15.92.0.r399.gd4ab11f-1
kactivitymanagerd5.24.2.r1385.gb5c80ae-15.24.3.r1385.gb5c80ae-1
kaddressbook21.12.2.1.r6120.g67bd1460-121.12.2.1.r6123.g0b5823a7-1
kajongg21.12.2.1.r4330.gda449d25-121.12.2.1.r4331.g29d00a4f-1
kalarm21.12.2.1.r7812.g4c52a3cf-121.12.2.1.r7829.g306878b7-1
kalgebra21.12.2.1.r2057.ge5831df-121.12.2.1.r2058.g656a53f-1
kalzium21.12.2.1.r4306.gf9a20c14-121.12.2.1.r4307.ged1603d8-1
kamera21.12.1.r704.gae8874f-121.12.1.r705.gdd5795b-1
kamoso21.12.2.1.r1450.g5f5198d-121.12.2.1.r1451.gbf55b3f-1
kanagram21.12.2.r1301.gb114bed-121.12.2.r1302.gb277148-1
kapidox5.91.0.r563.gce8da5f-15.92.0.r566.gd385445-1
kapman21.12.2.1.r637.gf86deaf-121.12.2.1.r638.g716d254-1
kapptemplate21.12.2.1.r979.g0482df6-121.12.2.1.r980.g1b19092-1
karchive5.91.0.r533.g81bc87f-15.92.0.r534.g17647fa-1
kate21.12.2.1.r18786.g59dfdce10-121.12.2.1.r18794.g916c617e4-1
katomic21.12.2.1.r947.g5a14f5d-121.12.2.1.r948.gdfb9ace-1
kauth5.91.0.r491.g4b07130-15.92.0.r492.g863d87c-1
kbackup21.12.2.1.r422.g055d022-121.12.2.1.r423.g8cf381e-1
kblackbox21.12.2.1.r755.g53a43b2-121.12.2.1.r756.ga3cb067-1
kblocks21.12.2.1.r697.g10a91f0-121.12.2.1.r698.g06637b4-1
kbookmarks5.91.0.r452.g4c66155-15.92.0.r453.g81bf8e2-1
kbounce21.12.2.1.r837.ga0684c6-121.12.2.1.r838.ga102c9f-1
kbreakout21.12.2.1.r898.ge97d0bd-121.12.2.1.r899.ge97c83d-1
kbruch21.12.2.1.r852.g17c9057-121.12.2.1.r853.gee0afff-1
kcachegrind21.12.2.1.r1171.gd366342-121.12.2.1.r1172.gb144e21-1
kcachegrind-common21.12.2.1.r1171.gd366342-121.12.2.1.r1172.gb144e21-1
kcalc21.12.2.1.r1596.gf460e9d-121.12.2.1.r1599.g456ab08-1
kcalendarcore5.91.0.r1304.g6713e0166-15.92.0.r1306.gdbd6a1d40-1
kcalutils21.12.2.1.r939.gdaac3a582-121.12.2.1.r941.g89d2174cf-1
kcharselect21.12.2.r505.g4127335-121.12.2.r506.gbf7e16d-1
kcmutils5.91.0.r605.g6599d44-15.92.0.r607.gc9c58de-1
kcodecs5.91.0.r413.g5434fa0-15.92.0.r414.gc003a22-1
kcolorchooser21.12.2.1.r252.gfcce901-121.12.2.1.r253.gc922e9b-1
kcompletion5.91.0.r487.g987a530-15.92.0.r488.gffa9c89-1
kconfig5.91.0.r941.g7ff8bf3f-15.92.0.r943.g7206ba3f-1
kconfigwidgets5.91.0.r695.g4b642df-15.92.0.r696.g00804e2-1
kcontacts1:5.91.0.r3312.g6361ac03-11:5.92.0.r3314.g41114f48-1
kcoreaddons5.91.0.r1441.g3ea63c08-15.92.0.r1443.gec41ef16-1
kcrash5.91.0.r435.gea0f128-15.92.0.r437.g9d13d87-1
kdav1:5.91.0.r1335.g8e9e87d-11:5.92.0.r1336.gbd981a7-1
kdbusaddons5.91.0.r408.ge3056b0-15.92.0.r409.g201c1fc-1
kde-cli-tools5.24.2.r1914.g97781af-15.24.3.r1915.g8d6ef8c-1
kde-dev-scripts21.12.2.1.r4144.gc500048-121.12.2.1.r4145.g06765a6-1
kde-dev-utils21.12.2.1.r572.g77d2de4-121.12.2.1.r573.g2aa9a74-1
kde-gtk-config5.24.2.r924.g4ee021a-15.24.3.r924.g4ee021a-1
kdebugsettings21.12.2.1.r894.gf95f82d-121.12.2.1.r896.g53aae06-1
kdeclarative5.91.0.r984.g945f784-15.92.0.r985.g8570dfb-1
kdeconnect21.12.2.1.r3409.gef0efc36-121.12.2.1.r3412.g5a9361c2-1
kdecoration5.24.2.r287.gd30a034-15.24.3.r288.g4123ec8-1
kded5.91.0.r450.ge830915-15.92.0.r451.gf02a9af-1
kdelibs4support5.91.0.r1073.g1fc3d46d-15.92.0.r1075.gab1bca20-1
kdenetwork-filesharing21.12.2.1.r901.g528fe25-121.12.2.1.r903.g81f68e1-1
kdenlive21.12.1.r15780.g34da6a7bf-121.12.1.r15819.g7dee407ab-1
kdepim-addons21.12.2.r4577.g1bbdc265-121.12.2.r4584.ga6f6f335-1
kdepim-runtime21.12.2.r15467.g1a5b38082-121.12.2.r15469.g611bec397-1
kdeplasma-addons5.24.2.r8668.g5a314fcda-15.24.3.r8670.gd264fff12-1
kdesdk-kioslaves21.12.2.1.r501.gaf87828-121.12.2.1.r502.g633726e-1
kdesdk-thumbnailers21.12.2.1.r87.gf6b26e6-121.12.2.1.r88.g1092504-1
kdesignerplugin5.91.0.r349.gbf21bdc-15.92.0.r350.g4e32de7-1
kdesu5.91.0.r501.gb5634c1-15.92.0.r502.gf543caa-1
kdewebkit5.91.0.r296.g96d6ac9-15.92.0.r297.gb19e3d7-1
kdf21.12.2.1.r837.g1f5e4e9-121.12.2.1.r838.geb47fa2-1
kdialog21.12.2.1.r1205.g5a6116821-121.12.2.1.r1206.g5e331761c-1
kdiamond21.12.2.1.r709.g218c9b1-121.12.2.1.r710.g61a0a34-1
kdisplay5.24.0.r1467.g3a9c6c8-15.24.3.r1467.g3a9c6c8-1
kdnssd5.91.0.r343.ge571261-15.92.0.r344.g93a5892-1
kdoctools5.91.0.r652.geec0413-15.92.0.r653.ga00d2d9-1
keditbookmarks21.12.2.1.r2759.gae988d9e5-121.12.2.1.r2761.g1fd08561c-1
kemoticons5.91.0.r405.ge3a4a26-15.92.0.r406.ge74dcd6-1
kfilemetadata5.91.0.r850.g3c9975d-15.92.0.r851.g4c1839f-1
kfind21.12.2.1.r2669.gcab1e00b1-121.12.2.1.r2670.g8c512173c-1
kfloppy21.12.2.r788.gfe3cafc-121.12.2.r789.g9795729-1
kfourinline21.12.2.1.r1011.gec5b749-121.12.2.1.r1012.g58a0e9b-1
kgamma55.24.2.r471.gfa4f2b8-15.24.3.r471.gfa4f2b8-1
kgeography21.12.2.1.r1138.g3321a91-121.12.2.1.r1139.g7f415a4-1
kget21.12.2.1.r3162.g5ee89611-121.12.2.1.r3163.g7b4ca8fa-1
kglobalaccel5.91.0.r504.g40c6e24-15.92.0.r505.gc4fff79-1
kgoldrunner21.12.2.1.r1266.g9bd4b9b-121.12.2.1.r1267.gbe9d052-1
kgpg21.12.2.1.r3173.gc3d9f24a-121.12.2.1.r3174.ge55cce4e-1
kguiaddons5.91.0.r447.g322dd7e-15.92.0.r448.ga02c852-1
khangman21.12.2.1.r1589.g863c5c9-121.12.2.1.r1590.gd685107-1
khelpcenter21.12.2.r2724.g8498c966-121.12.2.r2725.g627564c5-1
kholidays1:5.91.0.r997.gb01c3d0-11:5.92.0.r999.g29fdd3e-1
khotkeys5.24.2.r2113.ged47291-15.24.3.r2113.ged47291-1
khtml5.91.0.r576.g80b0423-15.92.0.r577.ga58f402-1
ki18n5.91.0.r545.g4c458aa-15.92.0.r546.ga234e7c-1
kiconthemes5.91.0.r592.g77f580e-15.92.0.r593.g74a6d4c-1
kidentitymanagement21.12.2.1.r3873.gaf0c8161-121.12.2.1.r3875.gdf829e46-1
kidletime5.91.0.r349.g8eafecc-15.92.0.r350.ge160ff5-1
kig21.12.2.1.r3163.gb6e3661e-121.12.2.1.r3178.g05a44120-1
kigo21.12.2.r551.g0dab000-121.12.2.r552.g899098f-1
killbots21.12.2.1.r766.g3291c8c-121.12.2.1.r767.gab1d772-1
kimageformats5.91.0.r386.ge69dff7-15.92.0.r386.ge69dff7-1
kimagemapeditor21.12.2.1.r480.g2daf890-121.12.2.1.r481.g0958da4-1
kimap21.12.2.1.r1176.g60bc94c-121.12.2.1.r1178.gacb00db-1
kinfocenter5.24.2.r2041.g8d95f11-15.24.3.r2046.g1fb7a9e-1
kinit5.91.0.r431.g98ed510-15.92.0.r432.ga3aa283-1
kio5.91.0.r5350.g85c519fed-15.92.0.r5358.g1f12ece78-1
kio-extras21.12.2.1.r7206.g2c05bf83-121.12.2.1.r7207.g22fafece-1
kio-gdrive21.12.2.1.r584.gc68a8f9-121.12.2.1.r585.g466cdbc-1
kirigami-gallery21.12.2.1.r231.g01920c6-121.12.2.1.r232.g70d039a-1
kirigami25.91.0.r3094.g147baecc-15.91.0.r3097.g3ccfae68-1
kiriki21.12.2.1.r441.ge122d48-121.12.2.1.r442.gb07b187-1
kitemmodels5.91.0.r597.ga5873c4-15.92.0.r598.g6395874-1
kitemviews5.91.0.r364.g1d06e1b-15.92.0.r365.gfc6dbc7-1
kiten21.12.2.1.r1176.gdf442e0-121.12.2.1.r1177.g264d272-1
kitinerary21.12.2.1.r2109.gaa4df9e-121.12.2.1.r2117.gd6ad887-1
kjobwidgets5.91.0.r406.g0dc18f6-15.92.0.r407.g97d433d-1
kjs5.91.0.r356.g1caa743-15.92.0.r357.gf7885ff-1
kjsembed5.91.0.r320.g0a266e6-15.92.0.r321.gc43332b-1
kjumpingcube21.12.2.1.r814.g8da9f19-121.12.2.1.r815.g2aeb8f8-1
kldap21.12.2.1.r937.g1a31985-121.12.2.1.r938.g23abaa6-1
kleopatra21.12.2.1.r6296.g0c18ce92-121.12.2.1.r6314.gb6f570f5-1
klettres21.12.2.1.r950.gd3b633e-121.12.2.1.r951.g3166350-1
klickety21.12.2.1.r663.g2618ec9-121.12.2.1.r664.g637824d-1
klines21.12.2.1.r796.g4501c0c-121.12.2.1.r797.g1ff0561-1
kmag21.12.2.1.r719.gacf3aff-121.12.2.1.r724.gc1b1a98-1
kmahjongg21.12.2.r1515.g81057c8-121.12.2.r1516.g52e1e39-1
kmail21.12.2.r26281.gfb30bfe9e-121.12.2.r26289.g07345bf14-1
kmail-account-wizard21.12.2.1.r865.gb5f8ed0-121.12.2.1.r868.geba0d08-1
kmailtransport21.12.2.1.r1714.gedf7681-121.12.2.1.r1716.g979c6cd-1
kmbox21.12.2.1.r582.g6c29561-121.12.2.1.r584.g2e5d5ba-1
kmediaplayer5.91.0.r312.gfc615ef-15.92.0.r313.g79c1c65-1
kmenuedit5.24.2.r1014.g4a3c599-15.24.3.r1014.g4a3c599-1
kmime21.12.2.1.r1498.g28ae11d-121.12.2.1.r1499.gbc05378-1
kmines21.12.2.r1756.gd3ed6f9-121.12.2.r1757.g3238863-1
kmix21.12.2.1.r2424.gb179383b-121.12.2.1.r2425.g4cc50d16-1
kmousetool21.12.2.1.r424.g43a4d5d-121.12.2.1.r425.ga475e60-1
kmouth21.12.2.1.r704.g0db0b84-121.12.2.1.r706.g66b2b33-1
kmplot21.12.2.1.r1476.g2228a4e-121.12.2.1.r1477.gc1bc857-1
knavalbattle21.12.2.1.r1416.gc97facf-121.12.2.1.r1417.g48f55ff-1
knetwalk21.12.2.1.r682.g6ace336-121.12.2.1.r683.gab4c2f8-1
knewstuff5.91.0.r1299.gea19fa6e-15.92.0.r1300.gce1cf018-1
knights21.12.2.1.r1095.g3bc2ea5-121.12.2.1.r1112.g4b1f0ea-1
knotes21.12.2.r3602.g1b584726-121.12.2.r3608.g07de53cd-1
knotifications5.91.0.r724.g9c30f20-15.92.0.r725.g403b5d7-1
knotifyconfig5.91.0.r376.g15a7f85-15.92.0.r377.g2379d3a-1
kolf21.12.2.1.r1475.g1212f53-121.12.2.1.r1476.g355cf4e-1
kollision21.12.2.1.r520.gc5ab370-121.12.2.1.r521.g120f0e1-1
kolourpaint21.12.2.1.r2382.gb264923a-121.12.2.1.r2383.g95aec03e-1
kompare21.12.2.1.r1123.g3f6f533-121.12.2.1.r1125.g45d5334-1
konqueror21.12.2.r15047.g454c120b2-121.12.2.r15050.g2020b6d48-1
konquest21.12.2.1.r919.gcf5d4d6-121.12.2.1.r920.g8bdcd97-1
konsole21.12.2.r8310.g56abf298-121.12.2.r8312.g5039938a-1
kontact21.12.2.1.r5484.g74a68692-121.12.2.1.r5486.g6d513671-1
kontactinterface21.12.2.1.r667.g7788fea-121.12.2.1.r668.g123bab4-1
kontrast21.12.2.1.r193.gaa68da3-121.12.2.1.r194.gb7b8fb0-1
konversation21.12.2.1.r9085.gba43804d-121.12.2.1.r9086.gc5b06610-1
kopeninghours21.12.2.1.r320.g662d8ba-121.12.2.1.r321.g01bf1eb-1
korganizer21.12.2.r11636.g6ae165493-121.12.2.r11643.g6d285af8b-1
kosmindoormap21.12.2.1.r705.g1036cb6-121.12.2.1.r706.g0f55048-1
kpackage5.91.0.r737.ga8496a7-15.92.0.r738.g62d41e0-1
kparts5.91.0.r573.gf356161-15.92.0.r574.gd1745fa-1
kpat21.12.2.r2601.g6c17431-121.12.2.r2602.g6bb3925-1
kpeople5.91.0.r1367.g06652d3-15.92.0.r1368.g63c76ec-1
kpimtextedit21.12.2.1.r1562.g79034b4-121.12.2.1.r1567.gcb86598-1
kpkpass21.12.2.1.r274.g4254b2b-121.12.2.1.r275.g0105471-1
kplotting5.91.0.r316.g5b6a5c0-15.92.0.r317.g2cfe75b-1
kpmcore21.12.2.r1271.gbbcfd82-121.12.2.r1272.g76ede03-1
kpty5.91.0.r365.g3c99d9e-15.92.0.r366.g96d7c84-1
kpublictransport21.12.1.r1983.g31f6f149-121.12.1.r1984.g0fc8912e-1
kquickcharts5.91.0.r506.gbae4599-15.92.0.r511.g6214f29-1
krdc21.12.2.1.r1564.g1c27f40-121.12.2.1.r1565.g761502a-1
krecorder 22.02.r7.g56d761d-1 22.02.r8.gb61cea1-1
kreversi21.12.2.1.r1255.g40fa14f-121.12.2.1.r1256.ge7f911e-1
krfb21.12.2.1.r1471.gc14d37e-121.12.2.1.r1472.ge2f3910-1
kross5.91.0.r352.g1a166fa-15.92.0.r353.gae6b3f3-1
kruler21.12.2.1.r724.g8f0b880-121.12.2.1.r725.g3436835-1
krunner5.91.0.r734.g952ea77-15.92.0.r739.g1ef7a4a-1
kscreen5.24.2.r1434.g7ea4408-15.24.3.r1434.g7ea4408-1
kscreenlocker5.24.2.r910.g9d3a95f-15.24.3.r910.g9d3a95f-1
kservice5.91.0.r995.g3b9253e-15.92.0.r996.g79b66d0-1
kshisen21.12.2.1.r1226.g66e5be1-121.12.2.1.r1227.g275b8c9-1
ksirk21.12.2.1.r1012.g5853d5e-121.12.2.1.r1013.ge8328b3-1
ksmtp21.12.2.1.r424.g983e629-121.12.2.1.r425.g9b389ac-1
ksnakeduel21.12.2.1.r837.g277764a-121.12.2.1.r838.gb96d956-1
kspaceduel21.12.2.1.r660.g7a33e57-121.12.2.1.r661.g9884782-1
ksquares21.12.2.1.r550.gf00afc2-121.12.2.1.r551.g5dadded-1
ksshaskpass5.24.2.r206.g1412c4a-15.24.3.r206.g1412c4a-1
ksudoku21.12.2.1.r1093.g6fef85a-121.12.2.1.r1094.g5d35f1f-1
ksysguard5.24.2.r3524.g1367cb0d-15.24.3.r3524.g1367cb0d-1
ksystemlog21.12.2.1.r706.g8dbe8c1-121.12.2.1.r708.gc5c7a9d-1
ksystemstats5.24.2.r219.g6fd7f37-15.24.3.r219.g6fd7f37-1
kteatime21.12.2.1.r741.g545c291-121.12.2.1.r742.gab083a6-1
ktexteditor5.91.0.r3249.gcb70942c-15.92.0.r3273.gdd1edbd6-1
ktextwidgets5.91.0.r439.g5becc72-15.92.0.r440.g8805f06-1
ktimer21.12.2.1.r498.g18dfe6f-121.12.2.1.r499.g3ed4118-1
ktnef21.12.2.1.r705.g67a94d5-121.12.2.1.r707.g50eac67-1
ktorrent21.12.2.r2825.gb948a326-121.12.2.r2826.g50a06198-1
ktouch21.12.2.1.r2167.ge1b827b-121.12.2.1.r2168.gf37391d-1
ktrip 22.02.r0.g3ce0cf3-1 22.02.r1.g3459a37-1
ktuberling21.12.2.1.r1032.g4f96319-121.12.2.1.r1033.g336409f-1
kturtle21.12.2.1.r1154.g19471cb-121.12.2.1.r1155.g375405a-1
kubrick21.12.2.1.r394.g53f0d30-121.12.2.1.r395.gcd3a40c-1
kunitconversion5.91.0.r407.g28c6983-15.92.0.r408.gcb09b05-1
kwallet5.91.0.r1132.g0638c15-15.92.0.r1134.g016552b-1
kwallet-pam5.24.2.r264.g2da1635-15.24.3.r264.g2da1635-1
kwalletmanager21.12.2.1.r1254.g9f0aa78-121.12.2.1.r1255.gcf1dd80-1
kwave21.12.2.1.r3765.ge3edc9f9-121.12.2.1.r3766.g870e8fd3-1
kwayland5.91.0.r1147.gc15365f-15.92.0.r1148.ge2ce367-1
kwayland-integration5.24.2.r199.gb05afab-15.24.3.r199.gb05afab-1
kwayland-server5.24.2.r1456.gb90a3cb-15.24.3.r1458.g0a98dd7-1
kwidgetsaddons5.91.0.r918.g1c261220-15.92.0.r919.ga2a02ec2-1
kwin5.24.2.r20878.gfe56f36dd-15.24.3.r20937.g140c2fb20-1
kwindowsystem5.91.0.r669.g8800b5f-15.92.0.r670.gc8b03a4-1
kwinft5.24.0.r20420.g0dfab6193-15.24.3.r20449.gfe54aa914-1
kwordquiz21.12.2.r1171.g15c5973-121.12.2.r1172.g1c3a502-1
kwrite21.12.2.1.r18786.g59dfdce10-121.12.2.1.r18794.g916c617e4-1
kwrited5.24.2.r501.g2de2d30-15.24.3.r501.g2de2d30-1
kxmlgui5.91.0.r856.g2cc06e85-15.92.0.r857.gb3610c5a-1
kxmlrpcclient5.91.0.r475.g5e3d6a3a9-15.92.0.r476.gc2ca2c045-1
libakonadi21.12.2.r12709.g5de212f70-121.12.2.r12711.g4d8fdf914-1
libgravatar21.12.2.1.r408.g7e57db1-121.12.2.1.r410.g8aeb731-1
libkdepim21.12.2.1.r892.gd1773bd-121.12.2.1.r895.geb4089c-1
libkgapi21.12.2.1.r1348.g872bb70-121.12.2.1.r1349.g796c430-1
libkleo21.12.2.1.r1094.gd9119e2-121.12.2.1.r1098.gc4b2a06-1
libkomparediff221.12.2.1.r341.gc0ec97e-121.12.2.1.r342.gf465f1a-1
libksane21.12.2.1.r589.g5a2bd07-121.12.2.1.r592.g323cf80-1
libkscreen5.24.2.r1620.g33b8ed6-15.24.3.r1620.g33b8ed6-1
libksieve21.12.2.1.r1674.gfd019338-121.12.2.1.r1677.g5e894204-1
libksysguard5.24.2.r2380.g1eb9c86-15.24.3.r2382.g2ce71ca-1
libktorrent21.12.2.1.r546.gc3d2072-121.12.2.1.r547.gcc058bb-1
lokalize21.12.2.1.r1805.g7c6199c2-121.12.2.1.r1812.gb0544763-1
lskat21.12.2.1.r837.gf4d6ccb-121.12.2.1.r838.gef0d9be-1
mailcommon21.12.2.1.r1205.gb28d388-121.12.2.1.r1208.gfed0e1f-1
mailimporter21.12.2.1.r506.g3fab048-121.12.2.1.r508.gf005dbe-1
marble21.12.2.1.r13401.g28b9be6cf-121.12.2.1.r13402.gbf3a3ff11-1
marble-common21.12.2.1.r13401.g28b9be6cf-121.12.2.1.r13402.gbf3a3ff11-1
marble-qt21.12.2.1.r13401.g28b9be6cf-121.12.2.1.r13402.gbf3a3ff11-1
markdownpart21.12.2.1.r103.g66c35e1-121.12.2.1.r104.g2e9782a-1
maui-nota 2.1.1.r9.ge5ab0af-1 2.1.1.r10.gcc1c0a0-1
maui-shell r155.7caa364-1 r166.167c285-1
mauikit 2.1.1.r9.g193d07ea-12.1.1.r10.g4d820a1a-1
mbox-importer21.12.2.1.r554.g654113e-121.12.2.1.r556.g5b2d424-1
messagelib21.12.1.r6427.g220633182-121.12.1.r6436.g9cb5b9d36-1
milou5.24.2.r763.g6a2fd07-15.24.3.r763.g6a2fd07-1
minuet21.12.2.1.r597.ga7aac83-121.12.2.1.r598.g41ae771-1
modemmanager-qt5.91.0.r548.gb980ad1-15.92.0.r549.g2be3452-1
mycroft-gui r717.5b01471-1 r719.22652c3-1
neochat22.02.r33.g334c13b3-122.02.r34.ga747d44c-1
networkmanager-qt5.91.0.r1143.gc5a5b0c-15.92.0.r1144.g4f667f3-1
okular21.12.2.1.r9649.g1489c9aac-121.12.2.1.r9652.gad6426be5-1
oxygen5.24.2.r4451.gbf4888d5-15.24.3.r4451.gbf4888d5-1
oxygen-icons1:5.91.0.r5.gbff159d-11:5.92.0.r5.gbff159d-1
oxygen-icons-svg1:5.91.0.r5.gbff159d-11:5.92.0.r5.gbff159d-1
palapeli21.12.2.1.r1264.g2b0122e-121.12.2.1.r1265.g71d9f71-1
parley21.12.2.r4506.g0b491ca3-121.12.2.r4507.g5a9bb35d-1
partitionmanager21.12.2.r1601.g1184422-121.12.2.r1602.g4ce27ce-1
pico-wizard-bigscreen-configs r5.dc15f57-1 r7.a3393d7-1
pim-data-exporter21.12.2.r2580.gdd5c7431-121.12.2.r2582.g0623382f-1
pim-sieve-editor21.12.2.r1592.gddc7794-121.12.2.r1595.g902ff51-1
pimcommon21.12.2.r1199.g907e0d9-121.12.2.r1203.g9fd75aa-1
plasma-browser-integration5.24.2.r1304.g0e2541f7-15.24.3.r1306.ga3e8e7a6-1
plasma-desktop5.24.2.r9104.gee87d089d-15.24.3.r9126.g69f4af186-1
plasma-dialer 22.02.r14.ga3304c6-1 22.02.r16.gbc3453b-1
plasma-disks5.24.2.r258.g0a7005e-15.24.3.r259.g74a8f69-1
plasma-firewall5.24.2.r599.gf5fb94a-15.24.3.r599.gf5fb94a-1
plasma-framework5.91.0.r16205.g6817ff635-15.92.0.r16211.ge53cee90d-1
plasma-integration5.24.2.r551.gfffe10d-15.24.3.r552.g65cbbba-1
plasma-mobile5.24.2.r1655.gd18baac31-15.24.3.r1674.ga86c06cfd-1
plasma-mobile-nm5.24.2.r3213.g2ab582bd-15.24.3.r3216.g57abb2f6-1
plasma-nano5.24.2.r176.gf4a6251-15.24.3.r176.gf4a6251-1
plasma-nm5.24.2.r3213.g2ab582bd-15.24.3.r3216.g57abb2f6-1
plasma-pa5.24.2.r1032.ged58f86-15.24.3.r1033.g8d79911-1
plasma-sdk5.24.2.r2329.g01754224-15.24.3.r2331.g3ef06c64-1
plasma-settings 22.02.r18.gb77ff5e-1 22.02.r19.g86f6d4e-1
plasma-systemmonitor5.24.2.r551.gd602ce9-15.24.3.r553.g76a3d6f-1
plasma-thunderbolt5.24.2.r182.ga89df5b-15.24.3.r182.ga89df5b-1
plasma-vault5.24.2.r374.g05a2eb9-15.24.3.r375.gdbe85a8-1
plasma-wayland-protocols1.4.0.r1045.g64b9d6a-11.4.0.r1047.gb49a289-1
plasma-wayland-session5.24.2.r11505.ge1692be47-15.24.3.r11556.g39b429f13-1
plasma-workspace5.24.2.r11505.ge1692be47-15.24.3.r11556.g39b429f13-1
plasma-workspace-wallpapers5.24.2.r332.geb758d3-15.24.3.r333.g896dd9c-1
polkit-kde-agent5.24.2.r518.gff0264d-15.24.3.r518.gff0264d-1
powerdevil5.24.2.r2523.g4e46153d-15.24.3.r2524.g7586da3a-1
print-manager21.12.2.r1102.gd1313e9-121.12.2.r1104.gdb216c0-1
prison5.91.0.r363.g4067aaf-15.92.0.r364.g2279598-1
purpose5.91.0.r950.g83621530-15.91.0.r953.g6773fa71-1
qcachegrind21.12.2.1.r1171.gd366342-121.12.2.1.r1172.gb144e21-1
qqc2-breeze-style5.24.2.r242.g5a20abd-15.24.3.r242.g5a20abd-1
qqc2-desktop-style5.91.0.r586.gdc954f3-15.92.0.r588.ga42ef45-1
rocs21.12.2.1.r3058.g2f43adf4-121.12.2.1.r3059.ge428ad5f-1
sddm0.19.0.r137.gc257a40-10.19.0.r138.gd19813c-1
sddm-kcm5.24.2.r644.g11d2ff1-15.24.3.r644.g11d2ff1-1
signon-kwallet-extension21.12.2.1.r74.g36818d6-121.12.2.1.r75.g46af618-1
solid5.91.0.r759.gba974fe-15.92.0.r760.gd5335ad-1
sonnet5.91.0.r682.gbb5080b-15.92.0.r683.g70874c9-1
spacebar22.02.2.r9.g40ce326-122.02.2.r10.g6b18cae-1
spectacle21.12.2.1.r1307.gc569622-121.12.2.1.r1309.g2dbb2bd-1
step21.12.2.1.r1173.g13f0455-121.12.2.1.r1174.g78c2423-1
svgpart21.12.2.1.r207.g4914e93-121.12.2.1.r210.g5612f01-1
sweeper21.12.2.1.r557.gda012ec-121.12.2.1.r558.g528006f-1
syndication5.91.0.r866.g7943f44-15.92.0.r867.g0baa14c-1
syntax-highlighting5.91.0.r1815.g96e33865-15.92.0.r1816.g1a0c480f-1
systemsettings5.24.2.r2629.g0dc39b60-15.24.3.r2631.ga93554d4-1
telepathy-kde-accounts-kcm21.12.2.1.r1208.g268286f-121.12.2.1.r1210.g052843e-1
telepathy-kde-approver21.12.2.1.r298.g4bd63f8-121.12.2.1.r299.g58b535d-1
telepathy-kde-auth-handler21.12.2.1.r281.ge323060-121.12.2.1.r282.ga240a20-1
telepathy-kde-call-ui21.12.2.1.r447.gae91520-121.12.2.1.r448.gf01f09a-1
telepathy-kde-common-internals21.12.2.1.r2001.g8a3b02e-121.12.2.1.r2002.g3b11e85-1
telepathy-kde-contact-list21.12.2.1.r1089.gf7ca2d1-121.12.2.1.r1090.g58353ef-1
telepathy-kde-contact-runner21.12.2.1.r257.gaec3b37-121.12.2.1.r258.gd1d25e2-1
telepathy-kde-desktop-applets21.12.2.1.r999.g40781ed-121.12.2.1.r1000.g135606f-1
telepathy-kde-filetransfer-handler21.12.2.1.r224.gcc00cf7-121.12.2.1.r225.g3958b9e-1
telepathy-kde-integration-module21.12.2.1.r395.ga0f05f2-121.12.2.1.r396.g5b8dc56-1
telepathy-kde-send-file21.12.2.1.r233.g45bef4a-121.12.2.1.r234.gae2a4de-1
telepathy-kde-text-ui21.12.2.1.r2030.gdd9bc7b-121.12.2.1.r2031.gc381360-1
threadweaver5.91.0.r534.g181f215-15.92.0.r535.g46253ab-1
umbrello21.12.2.r8410.gf0ee00ce0-121.12.2.r8412.g81f6992f5-1
wrapland5.24.0.r1748.g5ba9db79-15.24.3.r1748.g5ba9db79-1
xdg-desktop-portal-kde5.24.2.r438.gd12c437-15.24.3.r443.g79f3b13-1
yakuake21.12.2.1.r769.g7a319db-121.12.2.1.r773.g56c0b6f-1
zeroconf-ioslave21.12.2.1.r368.g9711a05-121.12.2.1.r371.gae2fa67-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
