Hello ARM community.
Rather small update this time. Enjoy!
Some highlights:
- A couple of kernels got updated
- Pacman got a new point release with 6.0.1
- A new release to Box64 brings it to 0.1.4
- SnapD updated to 2.52
- Also GreetD got a new update to 0.8.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Tue Sep 7 20:01:08 CEST 2021)
- arm-testing community aarch64: 199 new and 142 removed package(s)
- arm-testing core aarch64: 10 new and 10 removed package(s)
- arm-testing extra aarch64: 40 new and 37 removed package(s)
- arm-testing kde-unstable aarch64: 217 new and 217 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-09-01 2021-09-07
alsa-ucm-pinephone 0.4.0-1 0.5.1-1
bitwarden 1.28.2-3 1.28.2-4
box64 0.1.2-1 0.1.4-1
calls 41beta+29+g2df221c-1 41rc-1
chatty0.4.0beta2+7+g12d1e69-1 0.4.0beta3-1
eg25-manager 0.4.0-3 0.4.0-4
greetd 0.7.0-1 0.8.0-1
libmm-pp-glib1.18rc1+6+gfa19b2b9-11.18rc1+6+gfa19b2b9-2
mmsd-tng 1.1.1-1 1.1.1-2
modemmanager-pp1.18rc1+6+gfa19b2b9-11.18rc1+6+gfa19b2b9-2
phoc 0.8.0+12+gbe21b6d-1 0.8.0+25+g228d123-1
pinephone-manjaro-tweaks 20210903-1 20210903-2
postmarketos-tweaks-app 0.7.3+2+g11eb7c3-1 0.7.3+2+g11eb7c3-2
postmarketos-tweaks-app-phosh 0.7.3+2+g11eb7c3-1 0.7.3+2+g11eb7c3-2
quartz64-post-install 20210618-1 20210907-1
snapd 2.51.7-1 2.52-1
:: Different sync package(s) in repository community aarch64
abuse 0.9.0-1 -
ansible 4.4.0-1 4.5.0-1
argocd 2.1.0-1 2.1.2-1
autoconf-archive 1:2019.01.06-4 1:2021.02.19-1
babel-cli 7.14.8-1 7.15.4-1
babel-core 7.15.0-1 7.15.4-1
bctoolbox 5.0.15-1 5.0.18-1
blender 17:2.93.4-1 17:2.93.4-2
buckygen 1.1-1 1.1-2
bzrtp 5.0.15-1 5.0.18-1
caddy 2.4.4-1 2.4.5-1
capnproto 0.8.0-1 0.9.0-1
cargo-depgraph 1.2.2-2 1.2.2-3
cargo-edit 0.7.0-1 0.7.0-2
chezmoi 2.2.0-1 2.3.0-1
clojure 1.10.3.943-1 1.10.3.943-2
cmt 1.17-2 1.18-1
communicator 2.0.0-1 2.0.0-2
coolreader 3.2.57-1 3.2.59-1
cri-o 1.21.2-1 1.22.0-1
crun 0.21-1 1.0-1
deja-dup 42.7-1 42.8-1
diffoscope 182-1 183-1
distrobuilder 1.3-1 1.3-2
erlang 24.0.4-1 24.0.4-2
erlang-unixodbc 24.0.4-1 24.0.4-2
featherpad 0.18.0-2 1.0.0-1
giac 1.7.0.25-1 1.7.0.29-1
gnome-initial-setup 40.2-1 40.4-1
gnuradio-iqbal 0.38.1-4 0.38.2-1
gnuradio-osmosdr 0.2.3-3 0.2.3-4
goxel 0.10.7-2 0.10.8-2
gpg-tui 0.7.4-1 0.8.0-1
gqrx 2.14.4-1 2.14.4-2
gramps 2:5.1.3-3 2:5.1.4-1
home-assistant 2021.9.0-1 2021.9.3-1
httpie 2.4.0-1 2.5.0-1
hydrogen 1.0.2-1 1.1.0-1
iptux 0.8.1-1 0.8.2-1
jmol 14.31.52-1 14.31.53-1
jsmol 14.31.52-1 14.31.53-1
kbfs 5.7.1-2 5.7.1-3
keybase 5.7.1-2 5.7.1-3
keybase-gui 5.7.1-2 5.7.1-3
lfs 0.7.6-1 1.0.0-1
libad9361 0.2-4 0.2-5
libiio 0.21-4 0.23-1
lua-sec 2:1.0.1-1 2:1.0.2-1
lua51-sec 2:1.0.1-1 2:1.0.2-1
lua52-sec 2:1.0.1-1 2:1.0.2-1
lua53-sec 2:1.0.1-1 2:1.0.2-1
lxd 4.17-1 4.18-1
matrix-synapse 1.40.0-1 1.41.1-1
mediastreamer 5.0.15-1 5.0.18-1
merkaartor 0.18.4-8 0.19.0-1
minder 1.12.4-1 1.13.1-1
minikube 1.22.0-1 1.23.0-1
minio 2021.07.22-1 2021.09.03-1
miniserve 0.16.0-1 0.17.0-1
moserial 3.0.16-1 3.0.20-1
nauty 27r2-1 27r3-1
nextcloud-app-deck 1:1.5.0-1 1:1.5.1-1
nextcloud-app-spreed 1:12.1.0-1 1:12.1.1-1
nlohmann-json 3.10.1-1 3.10.2-1
npm-check-updates 11.8.3-1 11.8.4-1
nuitka 0.6.16.3-1 0.6.16.4-2
opencolorio 2.0.1-3 2.1.0-1
openimageio 2.2.17.0-1 2.2.18.0-1
ortp 5.0.15-1 5.0.18-1
osinfo-db 20210531-1 20210903-1
pageedit 1.6.0-2 1.7.0-1
photoflare 1.6.8-1 1.6.9-1
plocate 1.1.10-1 1.1.11-1
pyenv 2.0.5-1 2.0.6-1
pyright 1.1.165-1 1.1.166-1
python-cfn-lint 0.53.0-1 0.53.1-1
python-django-haystack 3.0-3 3.0-4
python-dogpile.cache 1.1.3-1 1.1.4-1
python-enrich 1.2.6-1 1.2.6-2
python-fabulous 0.3.0-2 0.4.0-1
python-gmpy2 2.1.0b6-1 2.1.0rc1-1
python-google-auth 1.32.1-1 1.33.0-1
python-httpx 0.18.2-1 0.19.0-1
python-moto 2.2.4-1 2.2.6-1
python-novaclient 17.5.0-1 17.6.0-1
python-pg8000 1.21.0-1 1.21.1-1
python-pikepdf 2.16.1-1 3.0.0-1
python-podcastparser 0.6.6-2 0.6.7-1
python-pycapnp 1.1.0-1 1.1.0-2
python-pyroute2 0.5.19-2 0.5.19-3
python-pytest-subtests 0.5.0-1 0.5.0-2
python-pytest-xdist 2.3.0-1 2.3.0-2
python-pywayland 0.4.5-1 0.4.6-1
python-qrcode 6.1-6 7.3-5
python-scramp 1.4.0-1 1.4.1-1
python-setuptools-scm 6.1.0-1 6.3.1-1
python-sphinx-autoapi 1.8.3-1 1.8.4-1
python-symengine 0.7.2-1 0.7.2-2
qgis 3.20.1-3 3.20.2-1
rssguard 3.9.2-1 4.0.0-1
rssguard-nowebengine 3.9.2-1 4.0.0-1
rust-analyzer 20210830-1 20210906-1
s3cmd 2.1.0-4 2.1.0-5
salt 3003.1-2 3003.3-1
scite 5.1.0-1 5.1.1-1
sigil 1.6.0-1 1.7.0-1
snd 21.5-1 21.7-1
soapyosmo 0.2.5-11 0.2.5-12
soapyplutosdr 0.2.1-2 0.2.1-3
step-cli 0.16.1-1 0.17.2-1
supercollider 3.12.0-1 3.12.1-1
symengine 0.7.0-2 0.8.1-1
telegram-desktop 3.0.0-1 3.0.1-1
terraform 1.0.5-1 1.0.6-1
texmaker 5.1.1-1 5.1.2-1
trash-cli 0.21.6.30-1 0.21.7.24-1
tty-solitaire 1.3.0-1 1.3.1-1
ukui-greeter 3.0.1-1 3.0.2-1
urh 2.9.2-2 2.9.2-3
v2ray-geoip 202108260024-1 202109020025-1
vcsh 2.0.1-1 2.0.2-1
workrave 1.10.45-1 1.10.48-1
xapp 2.2.2-1 2.2.3-1
xdotool 3.20210804.2-1 3.20210903.1-1
zint 2.9.1-2 2.10.0-1
zint-qt 2.9.1-2 2.10.0-1
esh - 0.3.1-1
etc-update - 2.3.99-2
git-cliff - 0.2.6-1
glulxe-term - 1:0.5.4-1
hunspell-ru - 20210731-1
libglkterm - 1.0.4-2
lightdm-slick-greeter - 1.5.4-1
lua-bit32 - 5.3.5.1_0.10-1
lua-cassowary - 2.3.1-2
lua-cliargs - 3.0-6
lua-cosmo - 16.06.04-5
lua-linenoise - 0.9-6
lua-luaepnf - 0.3-7
lua-luarepl - 0.9-6
lua-luautf8 - 0.1.3-2
lua-stdlib - 41.2.2-8
lua-vstruct - 2.1.1-4
lua51-bit32 - 5.3.5.1_0.10-1
lua51-cassowary - 2.3.1-2
lua51-cliargs - 3.0-6
lua51-cosmo - 16.06.04-5
lua51-linenoise - 0.9-6
lua51-luaepnf - 0.3-7
lua51-luarepl - 0.9-6
lua51-luautf8 - 0.1.3-2
lua51-stdlib - 41.2.2-8
lua51-vstruct - 2.1.1-4
lua52-bit32 - 5.3.5.1_0.10-1
lua52-cassowary - 2.3.1-2
lua52-cliargs - 3.0-6
lua52-cosmo - 16.06.04-5
lua52-linenoise - 0.9-6
lua52-luaepnf - 0.3-7
lua52-luarepl - 0.9-6
lua52-luautf8 - 0.1.3-2
lua52-stdlib - 41.2.2-8
lua52-vstruct - 2.1.1-4
lua53-bit32 - 5.3.5.1_0.10-1
lua53-cassowary - 2.3.1-2
lua53-cliargs - 3.0-6
lua53-cosmo - 16.06.04-5
lua53-linenoise - 0.9-6
lua53-luaepnf - 0.3-7
lua53-luarepl - 0.9-6
lua53-luautf8 - 0.1.3-2
lua53-stdlib - 41.2.2-8
lua53-vstruct - 2.1.1-4
magic-wormhole - 0.12.0-5
python-charset-normalizer - 2.0.4-1
python-database-knotinfo - 2021.9.1-1
python-hkdf - 0.0.3-7
python-j2cli - 0.3.12b-4
python-magic-wormhole-mailbox-server - 0.4.1-3
python-magic-wormhole-transit-relay - 0.2.1-2
python-spake2 - 0.8-8
python-txtorcon - 21.1.0-1
sile - 0.11.1-3
yadm - 3.1.1-2
:: Different overlay package(s) in repository core aarch64
linux 5.14.1-1 5.14.1-2
linux-headers 5.14.1-1 5.14.1-2
linux-pinephone 5.13.14-1 5.14.1-1
linux-pinephone-headers 5.13.14-1 5.14.1-1
pacman 6.0.0-5 6.0.1-5
pacman-debug 6.0.0-5 6.0.1-5
:: Different sync package(s) in repository core aarch64
archlinux-keyring 20210820-1 20210902-1
gzip 1.10-3 1.11-1
libseccomp 2.5.1-2 2.5.2-1
wireless-regdb 2021.04.21-1 2021.08.28-1
:: Different overlay package(s) in repository extra aarch64
calamares-arm-oem 20210715-1 20210903-1
mesa-git21.3.0_devel.144213.eacf50c27b7-121.3.0_devel.144490.43c4f5eb63e-1
libqmi - 1.30.0-1.1
:: Different sync package(s) in repository extra aarch64
babl 0.1.88-1 0.1.88-2
dav1d 0.9.1-1 0.9.2-1
dav1d-doc 0.9.1-1 0.9.2-1
dkms 2.8.5-1 2.8.6-1
dleyna-connector-dbus 0.4.0-1 0.4.1-1
dleyna-core 0.7.0-1 0.7.0-2
dleyna-renderer 0.7.0-2 0.7.0+6+g5b26696-1
dleyna-server 0.7.0-2 0.7.0+7+gba10c13-1
dracut 055-1 055-2
f2fs-tools 1.14.0-2 1.14.0-3
gegl 0.4.30-6 0.4.32-1
gimp 2.10.24-6 2.10.26-1
gtksourceview4 4.8.1-1 4.8.2-1
ibus 1.5.25-2 1.5.25-3
imagemagick 7.1.0.5-1 7.1.0.6-1
imagemagick-doc 7.1.0.5-1 7.1.0.6-1
imath 3.1.2-1 3.1.3-1
kdenetwork-filesharing 21.08.1-1 21.08.1-2
ladspa 1.15-2 1.16-1
libguess 1.2-3 1.2-4
libibus 1.5.25-2 1.5.25-3
liblouis 3.18.0-1 3.19.0-1
libpipewire02 0.2.7-1 0.2.7-2
libsamplerate 0.2.1-1 0.2.2-1
libwebsockets 4.2.1-1 4.2.2-1
libxfce4ui 4.16.0-1 4.16.1-1
llvm10 10.0.1-6 10.0.1-7
llvm10-libs 10.0.1-6 10.0.1-7
mpg123 1.28.2-1 1.29.0-1
pahole 1.21-1 1.22-1
plasma-wayland-protocols 1.3.0-1 1.4.0-1
pyside6 6.1.2-1 6.1.3-1
rinutils 0.8.0-1 0.10.0-1
shiboken6 6.1.2-2 6.1.3-1
zimg 3.0.2-1 3.0.3-1
libxcvt - 0.1.0-1
xf86-video-nouveau - 1.0.17-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.08.1.r12562.gee9ec222c-121.08.1.r12566.gbc0c31ce4-1
akonadi-calendar21.08.1.r1977.gc11c303-121.08.1.r1981.g7946f6f-1
akonadi-calendar-tools21.08.1.r894.g10323b9-121.08.1.r897.gea6537f-1
akonadi-contacts21.08.1.r3054.g93c19af4-121.08.1.r3057.g67bafee1-1
akonadi-import-wizard21.08.1.r1734.gdd5e516-121.08.1.r1737.ge58bc96-1
akonadi-mime21.08.1.r1639.gddb8661-121.08.1.r1642.g1599e44-1
akonadi-notes21.08.1.r1022.g0e92d47-121.08.1.r1025.g2552b56-1
akonadi-search21.08.1.r1120.g2413dce-121.08.1.r1124.gf9d184b-1
akonadiconsole21.08.1.r1520.g120a964-121.08.1.r1523.g94efa5d-1
akregator21.08.1.r6218.g58f0bd02-121.08.1.r6221.g596b76f9-1
artikulate21.08.1.r1388.g89c15b6-121.08.1.r1389.g8c87655-1
attica5.85.0.r831.g8473ba1-15.85.0.r833.g921f663-1
baloo5.85.0.r3005.g9fb7f7fe-15.85.0.r3007.g76b61d36-1
baloo-widgets21.08.1.r701.gaa2f910-121.08.1.r703.g37f30d9-1
bluez-qt5.85.0.r675.g3e767d4-15.85.0.r678.gc19c35f-1
breeze5.22.5.r2240.ge63d64ae-15.22.5.r2241.ge64c9aca-1
breeze-gtk5.22.5.r421.g58344d6-15.22.5.r422.g4db54ea-1
breeze-icons5.85.0.r1781.ga1ec7a6d-15.85.0.r1786.g97c6865d-1
buho 2.0.0.r2.g745e3b4-1 2.0.0.r4.g213f277-1
calendarsupport21.08.1.r24.g7fda64d-121.08.1.r27.gae7ce0e-1
cervisia21.08.1.r1641.g8e8a98e-121.08.1.r1642.g5f8e3d1-1
discover5.22.5.r8290.g7674dae2-15.22.5.r8297.g1931ef22-1
eventviews21.08.1.r25.g601af0f-121.08.1.r28.g5cb693f-1
frameworkintegration5.85.0.r595.g53915cc-15.85.0.r597.gecedf87-1
grantlee-editor21.08.1.r766.gbaa3e34-121.08.1.r769.gc82ec4c-1
grantleetheme21.08.1.r342.g5cc6f08-121.08.1.r344.g22b988b-1
gwenview21.08.1.r6658.g0a1e1932-121.08.1.r6659.g46b06fbb-1
incidenceeditor21.08.1.r763.gd404e90-121.08.1.r766.gc640bc6-1
itinerary21.08.1.r1443.g6799fe9-121.08.1.r1448.ga779d04-1
juk21.08.1.r3111.g811cd6c0-121.08.1.r3113.ga5b8c609-1
kactivities5.85.0.r1360.g8ceb7b0-15.85.0.r1362.gedc455b-1
kactivities-stats5.85.0.r369.g8efa0c2-15.85.0.r371.g9e99d0c-1
kactivitymanagerd5.22.5.r1367.g73e9cb5-15.22.5.r1368.g861e5cc-1
kaddressbook21.08.1.r6034.gdaa868d9-121.08.1.r6037.g315bfb74-1
kalarm21.08.1.r6455.g0cfb501d-121.08.1.r6461.g2efe1770-1
kalarmcal21.08.1.r1140.g16e912e-121.08.1.r1143.g3642558-1
kapidox5.85.0.r550.g41ab74c-15.85.0.r552.g9d1f94c-1
karchive5.85.0.r504.g4573a2c-15.85.0.r506.g8385306-1
kasts 21.08.r0.gc0fff75-1 21.08.r1.g8a57c1e-1
kate21.08.1.r18341.gc429a24f4-121.08.1.r18342.g834e06e7d-1
kauth5.85.0.r446.g9473e2d-15.85.0.r448.g1016ded-1
kbookmarks5.85.0.r419.g459cfb9-15.85.0.r421.gfb2c00a-1
kcalc21.08.1.r1521.g1a65c13-121.08.1.r1522.g1524f0a-1
kcalendarcore5.85.0.r1231.g58561b7d8-15.85.0.r1237.g9e903c0e6-1
kcalutils21.08.1.r868.g5a6bb5f6b-121.08.1.r871.g7ffcc18f3-1
kclock 21.08.r2.g51f3f5c-1 21.08.r3.g3d800cf-1
kcmutils5.85.0.r542.gdf129f8-15.85.0.r544.g3285782-1
kcodecs5.85.0.r383.g4bfa1d6-15.85.0.r385.g1a1e609-1
kcolorchooser21.08.1.r230.gb7268d9-121.08.1.r231.gac2e3ae-1
kcompletion5.85.0.r454.g6956438-15.85.0.r456.g887dac0-1
kconfig5.85.0.r860.g7ad396a-15.85.0.r862.g3691e4f-1
kconfigwidgets5.85.0.r616.g321de25-15.85.0.r620.g1c535d8-1
kcontacts1:5.85.0.r3251.geb873f27-11:5.85.0.r3253.g100bbb25-1
kcoreaddons5.85.0.r1278.g2cdb5127-15.85.0.r1289.gbe0d7ca2-1
kcrash5.85.0.r406.gc9f0ae9-15.85.0.r408.gf006b6f-1
kdav1:5.85.0.r1297.g70adea3-11:5.85.0.r1299.g60fa2f6-1
kdbusaddons5.85.0.r375.gd30aaf7-15.85.0.r379.g901a435-1
kde-cli-tools5.22.5.r1861.gbb9b116-15.22.5.r1862.g927db99-1
kdebugsettings21.08.1.r847.g3135e76-121.08.1.r848.gabcfb20-1
kdeclarative5.85.0.r918.g70500e1-15.85.0.r920.g47782d5-1
kdeconnect21.08.1.r3312.g9d78e17e-121.08.1.r3313.gbff51724-1
kded5.85.0.r415.g1d31ebc-15.85.0.r417.g7374a57-1
kdelibs4support5.85.0.r1034.gcbb5134a-15.85.0.r1036.g457d0509-1
kdepim-addons21.08.1.r4326.g83381843-121.08.1.r4329.g3f51d3ca-1
kdepim-runtime21.08.1.r15259.gb9b53f2d1-121.08.1.r15269.g199c250b6-1
kdesignerplugin5.85.0.r333.ga429b2e-15.85.0.r335.g36087aa-1
kdesu5.85.0.r473.g55e7b78-15.85.0.r475.gc8a8e38-1
kdewebkit5.85.0.r280.g3050935-15.85.0.r282.gb686bcf-1
kdf21.08.1.r798.gb35a14a-121.08.1.r801.gc53ce1a-1
kdnssd5.85.0.r322.g93b28af-15.85.0.r325.g2f11bd7-1
kdoctools5.85.0.r626.g88a63e3-15.85.0.r628.g28667e1-1
kemoticons5.85.0.r383.g4e614f9-15.85.0.r385.gae064b7-1
kfilemetadata5.85.0.r806.g92c7ced-15.85.0.r808.g92f2295-1
kglobalaccel5.85.0.r462.g4baa4cb-15.85.0.r467.gadea064-1
kguiaddons5.85.0.r387.gc2cf397-15.85.0.r390.g3325717-1
kholidays1:5.85.0.r956.gbc5d97e-11:5.85.0.r958.g37b9c86-1
khotkeys5.22.5.r2091.g925d5d9-15.22.5.r2092.gfe5c2a8-1
khtml5.85.0.r555.gb10f364-15.85.0.r557.ge915e4c-1
ki18n5.85.0.r477.gfe5d6d7-15.85.0.r479.gb144562-1
kiconthemes5.85.0.r541.g3ef834c-15.85.0.r543.g1b50a3c-1
kidentitymanagement21.08.1.r3818.g6392a75e-121.08.1.r3821.g4a32d4d5-1
kidletime5.85.0.r314.gd028a87-15.85.0.r317.g00e79dc-1
kimageformats5.85.0.r357.g1d2b51d-15.85.0.r359.g45cd128-1
kimap21.08.1.r1109.gf7cda63-121.08.1.r1112.g5f3509e-1
kinfocenter5.22.5.r1909.geffdc2a-15.22.5.r1920.g78d217b-1
kinit5.85.0.r410.g70e7178-15.85.0.r412.gf92a618-1
kio5.85.0.r4956.g8a788aa9-15.85.0.r4963.g2abb3fa9-1
kio-gdrive21.08.1.r567.g1d425ba-121.08.1.r568.g7607e00-1
kirigami-gallery21.08.1.r214.ge6bfbf4-121.08.1.r215.gb1b8234-1
kirigami25.85.0.r2878.g117bcf9e-15.85.0.r2884.g9cb846a6-1
kitemmodels5.85.0.r556.g192a2be-15.85.0.r558.ga0b0db1-1
kitemviews5.85.0.r338.g2eb5c08-15.85.0.r340.g4902bd2-1
kitinerary21.08.1.r1923.g0f46893-121.08.1.r1929.gf1972fa-1
kjobwidgets5.85.0.r376.g0e49b67-15.85.0.r378.gaaff19c-1
kjs5.85.0.r334.g18a1876-15.85.0.r336.g96b7c1b-1
kjsembed5.85.0.r303.g58c98d2-15.85.0.r305.gf506dc9-1
kldap21.08.1.r883.g0ed5bf0-121.08.1.r885.g599501c-1
kleopatra21.08.1.r5972.geaae2c47-121.08.1.r5989.g69f69c15-1
kmail21.08.1.r25938.g7bba991af-121.08.1.r25950.g7151a2c50-1
kmail-account-wizard21.08.1.r810.gf8d1938-121.08.1.r813.gf9f8c08-1
kmailtransport21.08.1.r1648.g5e06237-121.08.1.r1652.g139b466-1
kmbox21.08.1.r538.g9c2d473-121.08.1.r541.gf32ef3c-1
kmediaplayer5.85.0.r294.g62ae572-15.85.0.r296.gaeed11a-1
kmime21.08.1.r1456.g53b7462-121.08.1.r1458.g103179b-1
knewstuff5.85.0.r1199.g824e3d31-15.85.0.r1202.g36c87be2-1
knotes21.08.1.r3505.gc853dcaf-121.08.1.r3510.g5a306467-1
knotifications5.85.0.r675.gda2521e-15.85.0.r679.g1d73ea7-1
knotifyconfig5.85.0.r352.g6f824e7-15.85.0.r354.g3f81983-1
kompare21.08.1.r1106.g857f92a-121.08.1.r1108.g7c0c2ba-1
kongress 21.08.r0.gacca390-1 21.08.r1.gdab8bec-1
konsole21.08.1.r7933.g1374d853-121.08.1.r7935.gfed1a9d2-1
kontact21.08.1.r5379.geab83a86-121.08.1.r5382.gdeba0f99-1
kontactinterface21.08.1.r629.gc966691-121.08.1.r632.gaeb9dfb-1
konversation21.08.1.r8993.gd3623ee6-121.08.1.r8994.gcafec3c4-1
kopeninghours21.08.1.r270.ge9138d0-121.08.1.r271.gb3177a0-1
korganizer21.08.1.r11485.g02b520532-121.08.1.r11493.g417ce07bf-1
kosmindoormap21.08.1.r636.gb112375-121.08.1.r642.g71083d0-1
kpackage5.85.0.r696.g188e725-15.85.0.r698.g9db62a6-1
kparts5.85.0.r524.g804a2f0-15.85.0.r526.g5be87a5-1
kpeople5.85.0.r1343.g4d8a6f9-15.85.0.r1345.gf218f48-1
kpeoplesink r72.g54b653d-1 r73.g792e312-1
kpimtextedit21.08.1.r1407.gafafbc1-121.08.1.r1409.g490343b-1
kpkpass21.08.1.r236.g2e358f4-121.08.1.r238.g8b5da12-1
kplotting5.85.0.r293.g2c423a0-15.85.0.r295.g515f017-1
kpmcore21.08.1.r1197.g00e6b77-121.08.1.r1198.gd31f173-1
kpty5.85.0.r340.gfb28723-15.85.0.r342.gde58c1d-1
kpublictransport21.08.1.r1749.g96580c4a-121.08.1.r1799.g54da1a48-1
kquickcharts5.85.0.r473.gb945de6-15.85.0.r479.gdfe0e74-1
kreversi21.08.1.r1226.g394eab6-121.08.1.r1227.g7a8fb0c-1
kross5.85.0.r334.g5108482-15.85.0.r336.gf97bdaf-1
krunner5.85.0.r667.gae64d40-15.85.0.r669.g172da4e-1
kscreen5.22.5.r1345.g78c65e1-15.22.5.r1346.gf97d5f1-1
kservice5.85.0.r940.gb758304-15.85.0.r942.g8775462-1
ksirk21.08.1.r961.gfa60d1e-121.08.1.r963.g8b813b0-1
ksmtp21.08.1.r365.gf50bff4-121.08.1.r368.g0caf31f-1
ksudoku21.08.1.r1050.g721bdf1-121.08.1.r1051.g1a62981-1
ksystemstats5.22.5.r187.g8622236-15.22.5.r193.g207b896-1
ktexteditor5.85.0.r2937.g9662b146-15.85.0.r2941.g4955f8c8-1
ktextwidgets5.85.0.r411.gc996af7-15.85.0.r413.g676a32f-1
ktnef21.08.1.r662.g6a0defe-121.08.1.r665.g8ff8b40-1
ktorrent21.08.1.r2773.gddef52b4-121.08.1.r2776.g29857fee-1
ktrip 21.08.r0.gd9ea44f-1 21.08.r1.g62b9a40-1
kturtle21.08.1.r1118.gcfc622b-121.08.1.r1120.gce77c9b-1
kunitconversion5.85.0.r375.g2a57f9d-15.85.0.r377.ga73d698-1
kwallet5.85.0.r1085.g541d972-15.85.0.r1090.gf8fc9d9-1
kwayland5.85.0.r1108.ge2ae850-15.85.0.r1113.g4fbfad6-1
kwayland-integration5.22.5.r184.g71736b3-15.22.5.r185.g2f5d482-1
kwayland-server5.22.5.r1378.g12f273e-15.22.5.r1381.g30ced05-1
kweather 21.08.r4.ge3098ab-1 21.08.r5.g08af12e-1
kwidgetsaddons5.85.0.r865.gba2252ec-15.85.0.r873.g54d85c98-1
kwin5.22.5.r19922.g5da8df39a-15.22.5.r19954.g6d35d63ac-1
kwindowsystem5.85.0.r617.g59b849d-15.85.0.r627.g3563ed0-1
kwinft5.22.4.r19253.g433e5ca4b-15.22.4.r19271.g7130ecce4-1
kwordquiz21.08.1.r1141.g2e60dd3-121.08.1.r1146.g6ca5430-1
kwrite21.08.1.r18341.gc429a24f4-121.08.1.r18342.g834e06e7d-1
kxmlgui5.85.0.r803.gfc5844a8-15.85.0.r805.gbe808a4e-1
kxmlrpcclient5.85.0.r455.g2b6d42ae4-15.85.0.r457.ge48022fb4-1
libakonadi21.08.1.r12562.gee9ec222c-121.08.1.r12566.gbc0c31ce4-1
libgravatar21.08.1.r365.gf03ffbb-121.08.1.r369.gbb3111c-1
libkdepim21.08.1.r847.gc51e41b-121.08.1.r850.gf067cdb-1
libkleo21.08.1.r929.gb95f62e-121.08.1.r932.gcc4e224-1
libksane21.08.1.r556.gcef1e7c-121.08.1.r558.gf135f4a-1
libkscreen5.22.5.r1589.gf88cb0e-15.22.5.r1590.gd24df22-1
libksieve21.08.1.r1583.ge915c5be-121.08.1.r1586.gfaa0e310-1
libksysguard5.22.5.r2290.g7fad025-15.22.5.r2297.g9d91ea2-1
libquotient r2075.gc521332-1 r2080.g9ec9f5c-1
mailcommon21.08.1.r1103.gcc3e3fc-121.08.1.r1106.g71fe9ae-1
mailimporter21.08.1.r469.gc2fe16c-121.08.1.r472.ge2281ed-1
maui-clip 2.0.0.r4.gf00b830-1 2.0.0.r5.g343336b-1
maui-nota 2.0.0.r3.gc65f54d-1 2.0.0.r5.gedc2e3c-1
mauikit 2.0.1.r1.g99825889-1 2.0.1.r3.g5cf0a6f3-1
mauikit-filebrowsing 2.0.1.r0.g27eb236-1 2.0.1.r1.g301faba-1
mbox-importer21.08.1.r511.g8077b59-121.08.1.r514.g0430e77-1
messagelib21.08.1.r6150.g8c3174ec-121.08.1.r6157.gcca6d983-1
modemmanager-qt5.85.0.r518.ga25335a-15.85.0.r521.g32e62f7-1
neochat r1836.g1d5b7dee-1 r1845.g8d59e2ba-1
networkmanager-qt5.85.0.r1117.g26b6bff-15.85.0.r1120.gd8e33e6-1
okular21.08.1.r9443.gb80d3614e-121.08.1.r9451.gbb34db29b-1
oxygen5.22.5.r4424.g758c7aed-15.22.5.r4426.g30a5d585-1
palapeli21.08.1.r1233.gc33f37d-121.08.1.r1235.g3294210-1
pim-data-exporter21.08.1.r2445.g4256f6e4-121.08.1.r2449.g9e1ac191-1
pim-sieve-editor21.08.1.r1508.g728ebed-121.08.1.r1511.ga77b0c7-1
pimcommon21.07.80.r1098.g7f8db38-121.07.80.r1101.g1151f4d-1
plasma-camera 1.0.r104.g2ee0aaf-1 1.0.r105.g96e682d-1
plasma-desktop5.22.5.r8592.g6d54c27d8-15.22.5.r8599.g032cbc795-1
plasma-dialer 21.08.r0.g93c5974-1 21.08.r2.gae2c182-1
plasma-firewall5.22.5.r504.gc9a8709-15.22.5.r505.g5982e0d-1
plasma-framework5.85.0.r15972.gc43928cb7-15.85.0.r15977.g8e979a45d-1
plasma-integration5.22.5.r528.g841b917-15.22.5.r532.g04ac5f9-1
plasma-mobile-nm5.22.3.r3078.g7d10d426-15.22.3.r3087.gb4fc87e2-1
plasma-nm5.22.5.r3078.g7d10d426-15.22.5.r3087.gb4fc87e2-1
plasma-pa5.22.5.r959.gd716b52-15.22.5.r962.g0703026-1
plasma-phone-components5.22.5.r1456.g464141c0-15.22.5.r1459.g1de0f3ec-1
plasma-phonebook 21.08.r0.g45fc014-1 21.08.r5.g277789e-1
plasma-sdk5.22.5.r2277.g956ce673-15.22.5.r2278.g28233174-1
plasma-settings 21.08.r0.g137a5da-1 21.08.r1.g5503a2b-1
plasma-vault5.22.5.r340.g2b093e8-15.22.5.r341.g3cb86f4-1
plasma-wayland-protocols1.3.0.r1034.g26d31d8-11.3.0.r1035.gefc0d76-1
plasma-wayland-session5.22.5.r10603.gf9ae5830e-15.22.5.r10617.g6379d1ec8-1
plasma-workspace5.22.5.r10603.gf9ae5830e-15.22.5.r10617.g6379d1ec8-1
powerdevil5.22.5.r2462.g9fa3e568-15.22.5.r2464.gc0f4317a-1
prison5.85.0.r328.gd82575e-15.85.0.r332.g4fd34cf-1
purpose5.85.0.r877.g6bfb832-15.85.0.r879.gb867c66-1
qmlkonsole 21.08.r4.g88fc6e6-1 21.08.r5.ge268c2f-1
qqc2-desktop-style5.85.0.r519.g4982473-15.85.0.r521.g46d068f-1
rocs21.08.1.r3027.ga686a428-121.08.1.r3029.gd827af34-1
solid5.85.0.r702.g9874be2-15.85.0.r706.gb9b32db-1
sonnet5.85.0.r630.g5bcee2a-15.85.0.r633.gd7fc220-1
spectacle21.08.1.r1158.gdda0c7e-121.08.1.r1164.gaa227e6-1
syndication5.85.0.r838.gb27c491-15.85.0.r840.ge3f49c4-1
syntax-highlighting5.85.0.r1685.g5780ab44-15.85.0.r1695.g94a836af-1
telepathy-kde-text-ui21.08.1.r2020.gf0e1be3-121.08.1.r2021.gb8a5fc7-1
threadweaver5.85.0.r509.gd92be43-15.85.0.r511.g30d66fc-1
vakzination r90.f158025-1 r93.ae8475e-1
vvave 2.0.0.r14.g2eb4073-1 2.0.0.r16.g7199c63-1
wrapland5.22.4.r1550.gdfa699d-15.22.4.r1583.gb1c532a-1
xdg-desktop-portal-kde5.22.5.r379.g711f13d-15.22.5.r382.g7cfe798-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
