Hello ARM community.
A rather small update, nothing fancy.
VSCode was updated
Some highlights:
- A couple of our kernels got updated
- Plasma got a new point release with 5.22.2
- A new point release for Mesa, brings it to 21.1.3
- VSCode got updated to 1.57
- And Firefox also got a new 89.0.2 release
- Lots of Mobile specific packages got updated
- Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss
package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip
and firewalld
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Sat Jun 26 20:09:40 CEST 2021)
- arm-testing community aarch64: 182 new and 183 removed package(s)
- arm-testing core aarch64: 11 new and 11 removed package(s)
- arm-testing extra aarch64: 202 new and 202 removed package(s)
- arm-testing kde-unstable aarch64: 165 new and 162 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-06-22 2021-06-26
chatty 0.3.1+38+gef0cb56-1 0.3.1+59+g76e2813-1
code 1.56.2-1 1.57.1-1
electron 13.1.3-1 13.1.4-1
manjaro-arm-installer 1.4.3-1 1.4.4-1
matcha-gtk-theme 20210602-1 20210624-1
pico-wizard-git r125.bf62c5c-1 r137.19f80c4-1
pico-wizard-plamo-scripts r125.bf62c5c-1 r137.19f80c4-1
raspberrypi-userland-aarch64-git r813.3fd8527-1 r816.97bc818-1
rpi-imager 1.6.2-1 1.6.2-2
wayfire-git0.4.0.r244.g9e971208-1 -
wcm-gitv0.4.0.r14.g1595d35-1 -
wf-config-git 0.4.0.r6.ge3b78da-1 -
wf-shell-git 0.4.0.r10.g12435d0-1 -
:: Different sync package(s) in repository community aarch64
acorn 1:8.4.0-1 1:8.4.1-1
android-tools 31.0.0-3 31.0.0-4
ansible-core 2.11.1-1 2.11.2-1
apache-orc 1.6.7-3 1.6.7-4
apm 2.6.3-1 2.6.4-1
arcus 4.9.1-1 4.9.1-2
argocd 2.0.3-1 2.0.4-1
arrow 3.0.0-3 3.0.0-4
bctoolbox 4.5.20-1 4.5.22-1
broot 1.6.0-1 1.6.1-1
bzrtp 4.5.20-1 4.5.22-1
calc 2.13.0.1-1 2.13.0.1-2
calibre 5.21.0-1 5.22.1-1
cinnamon 5.0.2-1 5.0.3-1
clementine1.4.0rc1+495+g10bf5dc17-31.4.0rc1+495+g10bf5dc17-4
cockatrice 2.8.0-3 2.8.0-4
cockpit 246-1 247-1
cockpit-machines 245-1 246-1
cockpit-pcp 246-1 247-1
crypto++ 8.5.0-1 8.5.0-2
curaengine 4.9.1-1 4.9.1-2
dovecot 2.3.14-2 2.3.15-2
dovecot-fts-elastic 1.0.0-4 1.0.0-5
dovecot-fts-xapian 1.4.9b-1 1.4.9b-2
dpkg 1.20.7.1-1 1.20.9-1
eclib 20210503-3 20210625-1
etherwall 3.0.2-4 3.0.2-5
fcitx5-pinyin-zhwiki 1:0.2.3.20210605-1 1:0.2.3.20210625-1
feeluown 3.7.8-1 3.7.9-1
feeluown-netease 0.7-1 0.7.1-1
fuse-overlayfs 1.5.0-1 1.6-1
fwupd 1.6.0-3 1.6.1-2
gnuradio-osmosdr 0.2.3-2 0.2.3-3
go-tools 4:0.1.3-1 4:0.1.4-1
gpg-tui 0.5.0-1 0.6.0-1
grpc 1.38.0-3 1.38.1-1
grpc-cli 1.38.0-3 1.38.1-1
hcloud 1.23.0-1 1.24.0-1
hyperion 1.03.2-24 1.03.2-25
ipython 7.24.1-1 7.25.0-1
jedi-language-server 0.32.0-3 0.33.0-1
jenkins 2.298-1 2.299-1
jmol 14.31.41-1 14.31.42-1
jsmol 14.31.41-1 14.31.42-1
jupyter-server 1.8.0-1 1.9.0-1
kanshi 1.1.0-1 1.2.0-1
kcptun 20210103-2 20210624-1
klayout 0.27.1-1 0.27.2-1
libperconaserverclient 8.0.23_14-4 8.0.23_14-5
libsvm 3.24-3 3.25-1
limesuite 20.10.0-1 20.10.0-2
lollypop 1.4.19-1 1.4.20-1
marked 2.1.1-1 2.1.3-1
mediastreamer 4.5.20-1 4.5.22-1
mosh 1.3.2-14 1.3.2-15
mumble 1.3.4-6 1.3.4-7
murmur 1.3.4-6 1.3.4-7
mypy 0.902-1 0.910-1
netdata 1.31.0-1 1.31.0-2
nextcloud-client 3.2.2-1 3.2.3-1
nextcloud-client-cloudproviders 3.2.2-1 3.2.3-1
nodejs 16.3.0-1 16.4.0-1
nsjail 3.0-3 3.0-4
ntl 11.5.0-1 11.5.1-1
openfpgaloader 0.1-2 0.3.0-1
ortp 4.5.20-1 4.5.22-1
pari 2.13.1-2 2.13.2-1
percona-server 8.0.23_14-4 8.0.23_14-5
percona-server-clients 8.0.23_14-4 8.0.23_14-5
php-grpc 1.38.0-3 1.38.1-1
php7-grpc 1.38.0-3 1.38.1-1
pigeonhole 0.5.14-1 0.5.15-1
powerdns 4.4.1-4 4.4.1-5
procs 0.11.7-1 0.11.9-1
ptex 2.3.2-2 2.4.0-1
pynac 0.7.27-2 0.7.28-1
pyright 1.1.151-1 1.1.152-1
python-anyio 3.2.0-1 3.2.1-1
python-asteval 0.9.23-1 0.9.25-1
python-asyncpg 0.22.0-1 0.23.0-1
python-black 21.6b0-2 21.6b0-3
python-build 0.4.0-1 0.5.1-1
python-celery 5.0.5-2 5.1.1-1
python-coverage 5.5-1 5.5-2
python-docutils 0.17-1 0.17.1-1
python-edalize 0.2.3-1 0.2.5-1
python-faker 8.8.1-1 8.8.2-1
python-fastapi 0.65.1-1 0.65.2-1
python-grpcio 1.38.0-3 1.38.1-1
python-httptools 0.1.1-4 0.2.0-1
python-importlib-metadata 4.0.1-1 4.5.0-1
python-json5 0.9.5-3 0.9.6-1
python-jupyter_packaging 0.10.2-1 0.10.3-1
python-kajiki 0.8.2-4 0.8.3-1
python-moto 2.0.9-1 2.0.10-1
python-myst-parser 0.14.0-1 0.15.1-1
python-nmigen-boards r170.5c8c8ca-1 r186.9d24c51-1
python-nox 2020.12.31-1 2021.6.12-1
python-ovirt-engine-sdk 4.4.12-1 4.4.13-1
python-pikepdf 2.12.2-1 2.13.0-1
python-pipx 0.16.2.1-1 0.16.3-1
python-pygls 0.10.3-3 0.11.1-1
python-pyvhdlmodel 0.8.0-1 0.10.2-1
python-ruamel-yaml 0.17.9-1 0.17.10-1
python-setuptools-scm 5.0.2-1 6.0.1-1
python-tempora 4.0.2-1 4.1.1-1
python-trimesh 3.9.14-2 3.9.20-1
python-typing_inspect 0.6.0-4 0.7.1-1
python-userpath 1.5.0-1 1.6.0-1
python-uvloop 0.15.1-1 0.15.2-1
python2-coverage 5.5-1 5.5-2
python2-docutils 0.17-1 0.17.1-1
python2-setuptools-scm 5.0.2-1 -
qgis 3.20.0-1 3.20.0-2
rime-pinyin-zhwiki 1:0.2.3.20210605-1 1:0.2.3.20210625-1
ruby-bundler 2.2.20-1 2.2.21-1
ruby-irb 1.3.5-1 1.3.6-1
runc 1.0.0rc95-1 1.0.0-1
salt 3003-2 3003.1-1
sn0int 0.21.1-1 0.21.2-1
soapyairspy 0.1.2-2 0.2.0-1
soapyaudio 0.1.1-2 0.1.1-3
soapybladerf 0.4.1-3 0.4.1-4
soapyhackrf 0.3.3-2 0.3.3-3
soapynetsdr 0.2.0-1 0.2.0-2
soapyosmo 0.2.5-10 0.2.5-11
soapyplutosdr 0.2.1-1 0.2.1-2
soapyremote 0.5.1-1 0.5.2-1
soapyrtlsdr 0.3.0-2 0.3.2-1
soapysdr 0.7.2-3 0.8.0-1
soapyuhd 0.4.1-2 0.4.1-3
strawberry 0.9.3-2 0.9.3-3
suscan 0.1.0-3 0.1.0-4
tailscale 1.8.7-1 1.8.8-1
terraform 1.0.0-1 1.0.1-1
timescaledb 2.3.0-1 2.3.0-2
timew 1.4.3-1 1.4.3-2
tree-sitter 0.19.4-1 0.19.5-1
ttc-iosevka 7.0.4-1 7.1.1-1
ttc-iosevka-aile 7.0.4-1 7.1.1-1
ttc-iosevka-curly 7.0.4-1 7.1.1-1
ttc-iosevka-curly-slab 7.0.4-1 7.1.1-1
ttc-iosevka-etoile 7.0.4-1 7.1.1-1
ttc-iosevka-slab 7.0.4-1 7.1.1-1
ttc-iosevka-ss01 7.0.4-1 7.1.1-1
ttc-iosevka-ss02 7.0.4-1 7.1.1-1
ttc-iosevka-ss03 7.0.4-1 7.1.1-1
ttc-iosevka-ss04 7.0.4-1 7.1.1-1
ttc-iosevka-ss05 7.0.4-1 7.1.1-1
ttc-iosevka-ss06 7.0.4-1 7.1.1-1
ttc-iosevka-ss07 7.0.4-1 7.1.1-1
ttc-iosevka-ss08 7.0.4-1 7.1.1-1
ttc-iosevka-ss09 7.0.4-1 7.1.1-1
ttc-iosevka-ss10 7.0.4-1 7.1.1-1
ttc-iosevka-ss11 7.0.4-1 7.1.1-1
ttc-iosevka-ss12 7.0.4-1 7.1.1-1
ttc-iosevka-ss13 7.0.4-1 7.1.1-1
ttc-iosevka-ss14 7.0.4-1 7.1.1-1
ttc-iosevka-ss15 7.0.4-1 7.1.1-1
ttc-iosevka-ss16 7.0.4-1 7.1.1-1
ttc-iosevka-ss17 7.0.4-1 7.1.1-1
ttc-iosevka-ss18 7.0.4-1 7.1.1-1
uvicorn 0.13.4-1 0.14.0-1
v2ray 4.39.2-1 4.40.1-1
v2ray-domain-list-community 20210621183458-1 20210625061329-1
v2ray-geoip 202106170022-1 202106240309-1
web-ext 6.1.0-1 6.2.0-1
xplr 0.14.2-1 0.14.3-1
xprintidle 0.2.2-3 0.2.4-1
yosys 0.9-13 0.9-14
lfs - 0.7.1-1
python-jwcrypto - 0.9.1-1
python-pyhcl - 0.4.4-1
serverless - 2.48.0-1
:: Different overlay package(s) in repository core aarch64
linux 5.12.12-1 5.12.13-1
linux-headers 5.12.12-1 5.12.13-1
manjaro-keyring 20201216-1 20210622-1
raspberrypi-bootloader 20210608-1 20210623-1
raspberrypi-bootloader-x 20210608-1 20210623-1
:: Different sync package(s) in repository core aarch64
groff 1.22.4-5 1.22.4-6
libldap 2.4.58-3 2.4.59-1
libxcrypt 4.4.22-4 4.4.23-1
man-db 2.9.4-1 2.9.4-2
man-pages 5.11-1 5.12-1
openldap 2.4.58-3 2.4.59-1
:: Different overlay package(s) in repository extra aarch64
firefox 89.0.1-1 89.0.2-1
firefox-i18n-ach 89.0.1-1 89.0.2-1
firefox-i18n-af 89.0.1-1 89.0.2-1
firefox-i18n-an 89.0.1-1 89.0.2-1
firefox-i18n-ar 89.0.1-1 89.0.2-1
firefox-i18n-ast 89.0.1-1 89.0.2-1
firefox-i18n-az 89.0.1-1 89.0.2-1
firefox-i18n-be 89.0.1-1 89.0.2-1
firefox-i18n-bg 89.0.1-1 89.0.2-1
firefox-i18n-bn 89.0.1-1 89.0.2-1
firefox-i18n-br 89.0.1-1 89.0.2-1
firefox-i18n-bs 89.0.1-1 89.0.2-1
firefox-i18n-ca 89.0.1-1 89.0.2-1
firefox-i18n-cak 89.0.1-1 89.0.2-1
firefox-i18n-cs 89.0.1-1 89.0.2-1
firefox-i18n-cy 89.0.1-1 89.0.2-1
firefox-i18n-da 89.0.1-1 89.0.2-1
firefox-i18n-de 89.0.1-1 89.0.2-1
firefox-i18n-dsb 89.0.1-1 89.0.2-1
firefox-i18n-el 89.0.1-1 89.0.2-1
firefox-i18n-en-ca 89.0.1-1 89.0.2-1
firefox-i18n-en-gb 89.0.1-1 89.0.2-1
firefox-i18n-en-us 89.0.1-1 89.0.2-1
firefox-i18n-eo 89.0.1-1 89.0.2-1
firefox-i18n-es-ar 89.0.1-1 89.0.2-1
firefox-i18n-es-cl 89.0.1-1 89.0.2-1
firefox-i18n-es-es 89.0.1-1 89.0.2-1
firefox-i18n-es-mx 89.0.1-1 89.0.2-1
firefox-i18n-et 89.0.1-1 89.0.2-1
firefox-i18n-eu 89.0.1-1 89.0.2-1
firefox-i18n-fa 89.0.1-1 89.0.2-1
firefox-i18n-ff 89.0.1-1 89.0.2-1
firefox-i18n-fi 89.0.1-1 89.0.2-1
firefox-i18n-fr 89.0.1-1 89.0.2-1
firefox-i18n-fy-nl 89.0.1-1 89.0.2-1
firefox-i18n-ga-ie 89.0.1-1 89.0.2-1
firefox-i18n-gd 89.0.1-1 89.0.2-1
firefox-i18n-gl 89.0.1-1 89.0.2-1
firefox-i18n-gn 89.0.1-1 89.0.2-1
firefox-i18n-gu-in 89.0.1-1 89.0.2-1
firefox-i18n-he 89.0.1-1 89.0.2-1
firefox-i18n-hi-in 89.0.1-1 89.0.2-1
firefox-i18n-hr 89.0.1-1 89.0.2-1
firefox-i18n-hsb 89.0.1-1 89.0.2-1
firefox-i18n-hu 89.0.1-1 89.0.2-1
firefox-i18n-hy-am 89.0.1-1 89.0.2-1
firefox-i18n-ia 89.0.1-1 89.0.2-1
firefox-i18n-id 89.0.1-1 89.0.2-1
firefox-i18n-is 89.0.1-1 89.0.2-1
firefox-i18n-it 89.0.1-1 89.0.2-1
firefox-i18n-ja 89.0.1-1 89.0.2-1
firefox-i18n-ka 89.0.1-1 89.0.2-1
firefox-i18n-kab 89.0.1-1 89.0.2-1
firefox-i18n-kk 89.0.1-1 89.0.2-1
firefox-i18n-km 89.0.1-1 89.0.2-1
firefox-i18n-kn 89.0.1-1 89.0.2-1
firefox-i18n-ko 89.0.1-1 89.0.2-1
firefox-i18n-lij 89.0.1-1 89.0.2-1
firefox-i18n-lt 89.0.1-1 89.0.2-1
firefox-i18n-lv 89.0.1-1 89.0.2-1
firefox-i18n-mk 89.0.1-1 89.0.2-1
firefox-i18n-mr 89.0.1-1 89.0.2-1
firefox-i18n-ms 89.0.1-1 89.0.2-1
firefox-i18n-my 89.0.1-1 89.0.2-1
firefox-i18n-nb-no 89.0.1-1 89.0.2-1
firefox-i18n-ne-np 89.0.1-1 89.0.2-1
firefox-i18n-nl 89.0.1-1 89.0.2-1
firefox-i18n-nn-no 89.0.1-1 89.0.2-1
firefox-i18n-oc 89.0.1-1 89.0.2-1
firefox-i18n-pa-in 89.0.1-1 89.0.2-1
firefox-i18n-pl 89.0.1-1 89.0.2-1
firefox-i18n-pt-br 89.0.1-1 89.0.2-1
firefox-i18n-pt-pt 89.0.1-1 89.0.2-1
firefox-i18n-rm 89.0.1-1 89.0.2-1
firefox-i18n-ro 89.0.1-1 89.0.2-1
firefox-i18n-ru 89.0.1-1 89.0.2-1
firefox-i18n-si 89.0.1-1 89.0.2-1
firefox-i18n-sk 89.0.1-1 89.0.2-1
firefox-i18n-sl 89.0.1-1 89.0.2-1
firefox-i18n-son 89.0.1-1 89.0.2-1
firefox-i18n-sq 89.0.1-1 89.0.2-1
firefox-i18n-sr 89.0.1-1 89.0.2-1
firefox-i18n-sv-se 89.0.1-1 89.0.2-1
firefox-i18n-ta 89.0.1-1 89.0.2-1
firefox-i18n-te 89.0.1-1 89.0.2-1
firefox-i18n-th 89.0.1-1 89.0.2-1
firefox-i18n-tr 89.0.1-1 89.0.2-1
firefox-i18n-uk 89.0.1-1 89.0.2-1
firefox-i18n-ur 89.0.1-1 89.0.2-1
firefox-i18n-uz 89.0.1-1 89.0.2-1
firefox-i18n-vi 89.0.1-1 89.0.2-1
firefox-i18n-xh 89.0.1-1 89.0.2-1
firefox-i18n-zh-cn 89.0.1-1 89.0.2-1
firefox-i18n-zh-tw 89.0.1-1 89.0.2-1
plasma-mobile-nm 5.22.1-1 5.22.2.1-1
plasma-nano 5.22.1-1 5.22.2.1-1
plasma-phone-components 5.22.1-1 5.22.2.1-1
pyside2-es2 5.15.2-4.2 5.15.2-4.3
python-es2-pyqt5 5.15.4-4.2 5.15.4-4.3
qqc2-breeze-style 5.22.1-1 5.22.2.1-1
qt5-es2-base 5.15.2+kde+r199-3.1 5.15.2+kde+r200-1
qt5-es2-datavis3d 5.15.2-3.1 5.15.2-4.1
qt5-es2-declarative 5.15.2+kde+r28-3.1 5.15.2+kde+r29-1
qt5-es2-multimedia 5.15.2-3.1 5.15.2-4.1
qt5-es2-wayland 5.15.2+kde+r28-3.1 5.15.2+kde+r28-4.1
qt5-es2-xcb-private-headers 5.15.2+kde+r199-3.1 5.15.2+kde+r200-1
:: Different sync package(s) in repository extra aarch64
appstream 0.14.3-1 0.14.4-1
appstream-qt 0.14.3-1 0.14.4-1
bluedevil 1:5.22.1-1 1:5.22.2.1-1
breeze 5.22.1-1 5.22.2.1-1
breeze-grub 5.22.1-1 5.22.2.1-1
breeze-gtk 5.22.1-1 5.22.2.1-1
discover 5.22.1-2 5.22.2.1-1
drkonqi 5.22.1-1 5.22.2.1-1
evolution-data-server 3.40.2-1 3.40.2-2
geoip-database 20210427-1 20210622-1
geoip-database-extra 20210427-1 20210622-1
hefur 1.0-3 1.0-4
imagemagick 7.1.0.1-1 7.1.0.2-1
imagemagick-doc 7.1.0.1-1 7.1.0.2-1
kactivitymanagerd 5.22.1-1 5.22.2.1-1
kde-cli-tools 5.22.1-1 5.22.2.1-1
kde-gtk-config 5.22.1-1 5.22.2.1-1
kdecoration 5.22.1-1 5.22.2.1-1
kdeplasma-addons 5.22.1-1 5.22.2.1-1
kgamma5 5.22.1-1 5.22.2.1-1
khotkeys 5.22.1-1 5.22.2.1-1
kinfocenter 5.22.1-1 5.22.2.1-1
kismet 2020_12_R3-4 2020_12_R3-5
kitinerary 21.04.2-1 21.04.2-2
kmenuedit 5.22.1-1 5.22.2.1-1
kosmindoormap 21.04.2-1 21.04.2-2
kscreen 5.22.1-1 5.22.2.1-1
kscreenlocker 5.22.1-1 5.22.2.1-1
ksshaskpass 5.22.1-1 5.22.2.1-1
ksystemstats 5.22.1-1 5.22.2.1-1
kwallet-pam 5.22.1-1 5.22.2.1-1
kwayland-integration 5.22.1-1 5.22.2.1-1
kwayland-server 5.22.1-1 5.22.2.1-1
kwin 5.22.1-1 5.22.2.1-1
kwrited 5.22.1-1 5.22.2.1-1
layer-shell-qt 5.22.1-1 5.22.2.1-1
libcanberra 0.30+2+gc0620e4-4 0.30+2+gc0620e4-5
libcerf 1:1.15-1 1:1.16-1
libkscreen 5.22.1-1 5.22.2.1-1
libksysguard 5.22.1-1 5.22.2.1-1
libphonenumber 8.12.24-1 8.12.25-1
libva-mesa-driver 21.1.2-1 21.1.3-1
marble 21.04.2-1 21.04.2-2
marble-common 21.04.2-1 21.04.2-2
marble-maps 21.04.2-1 21.04.2-2
marble-qt 21.04.2-1 21.04.2-2
mesa 21.1.2-1 21.1.3-1
mesa-vdpau 21.1.2-1 21.1.3-1
milou 5.22.1-1 5.22.2.1-1
opencl-mesa 21.1.2-1 21.1.3-1
oxygen 5.22.1-1 5.22.2.1-1
perl-alien-build 2.40-3 2.41-1
plasma-browser-integration 5.22.1-1 5.22.2.1-1
plasma-desktop 5.22.1-1 5.22.2.1-1
plasma-disks 5.22.1-1 5.22.2.1-1
plasma-firewall 5.22.1-1 5.22.2.1-1
plasma-integration 5.22.1-1 5.22.2.1-1
plasma-nm 5.22.1-1 5.22.2.1-1
plasma-pa 5.22.1-1 5.22.2.1-1
plasma-sdk 5.22.1-1 5.22.2.1-1
plasma-systemmonitor 5.22.1-1 5.22.2.1-1
plasma-thunderbolt 5.22.1-1 5.22.2.1-1
plasma-vault 5.22.1-1 5.22.2.1-1
plasma-wayland-session 5.22.1-1 5.22.2.1-1
plasma-workspace 5.22.1-1 5.22.2.1-1
plasma-workspace-wallpapers 5.22.1-1 5.22.2.1-1
polari 3.38.0-1 40.0-1
polkit-kde-agent 5.22.1-1 5.22.2.1-1
powerdevil 5.22.1-1 5.22.2.1-1
protobuf 3.16.0-1 3.17.3-1
protobuf-c 1.3.3-4 1.4.0-1
python-pip 20.3.3-1 20.3.4-1
python-protobuf 3.16.0-1 3.17.3-1
python2-pip 20.3.3-1 20.3.4-1
qt5-base 5.15.2+kde+r199-1 5.15.2+kde+r203-1
qt5-declarative 5.15.2+kde+r28-1 5.15.2+kde+r29-1
qt5-xcb-private-headers 5.15.2+kde+r199-1 5.15.2+kde+r203-1
sddm-kcm 5.22.1-1 5.22.2.1-1
sof-firmware 1.7-2 1.8-1
stellarium 0.21.0-1 0.21.1-1
systemsettings 5.22.1-1 5.22.2.1-1
texmacs 1.99.21-1 2.1-1
totem-pl-parser 3.26.5-1 3.26.6-1
usbguard 1.0.0-4 1.0.0-5
vlc 3.0.16-1 3.0.16-2
vulkan-broadcom 21.1.2-1 21.1.3-1
vulkan-headers 1:1.2.180-1 1:1.2.182-1
vulkan-icd-loader 1.2.178-1 1.2.182-1
vulkan-mesa-layers 21.1.2-1 21.1.3-1
vulkan-radeon 21.1.2-1 21.1.3-1
vulkan-swrast 21.1.2-1 21.1.3-1
vulkan-tools 1.2.172-1 1.2.182-1
vulkan-validation-layers 1.2.172-1 1.2.182-1
wireguard-dkms 1.0.20210424-1 -
xdg-desktop-portal-kde 5.22.1-1 5.22.2.1-1
xf86-input-libinput 1.0.1-1 1.1.0-1
sof-tools - 1.8-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.04.2.r12508.g0aa26872d-121.04.2.r12512.ge9f90a3b0-1
akonadi-calendar21.04.2.r1942.g744e395-121.04.2.r1943.g1b0574f-1
akonadi-contacts21.04.2.r3016.g683e2200-121.04.2.r3018.gd44c6a3d-1
akonadiconsole21.04.2.r1492.g042c5f5-121.04.2.r1494.g53f2254-1
akregator21.04.2.r6159.g6bd05c73-121.04.2.r6162.g6e37bcd1-1
amazfish 2.0.0.r18.g1997c83-1 2.0.0.r22.g35d2960-1
ark21.04.2.r4544.g754f6818-121.04.2.r4546.gbc4de85d-1
bluedevil1:5.22.0.r2268.g87b46065-11:5.22.2.1.r2268.g87b46065-1
bovo21.04.2.r727.g7c7afb7-121.04.2.r729.gd1776ed-1
breeze5.22.0.r2217.gb81a5be7-15.22.2.r2217.gb81a5be7-1
breeze-grub5.22.0.r11.g63136a9-15.22.2.1.r11.g63136a9-1
breeze-gtk5.22.0.r420.gfccd7df-15.22.2.1.r420.gfccd7df-1
buho 1.2.2.r23.g13ab408-1 1.2.2.r25.g623328b-1
discover5.22.0.r8209.g6c14423c-15.22.2.1.r8210.g982ac596-1
dolphin21.04.2.r6610.g5e79f27ae-121.04.2.r6621.g216068bd7-1
dragon21.04.2.r1000.g4b895d5-121.04.2.r1002.gee142db-1
drkonqi5.22.0.r651.g7de900d3-15.22.2.1.r651.g7de900d3-1
elisa21.04.2.r2725.gc23e3212-121.04.2.r2726.gad91882f-1
eventviews21.04.2.r655.g5c8bca0-121.04.2.r661.gdb38ce8-1
extra-cmake-modules5.83.0.r3325.g65c50ed-15.83.0.r3326.g9e63248-1
granatier21.04.2.r916.g5ba8c3b-121.04.2.r920.g0be7bc4-1
gwenview21.04.2.r6619.g3f269685-121.04.2.r6620.g9763d196-1
index-fm 1.2.2.r62.ga9945a2-1 1.2.2.r67.ge6a4f2f-1
itinerary21.04.2.r1329.gf5e1972-121.04.2.r1331.g142589f-1
kactivities-stats5.83.0.r357.g3423532-15.83.0.r358.gc6c3655-1
kactivitymanagerd5.22.0.r1355.g9cabb88-15.22.2.1.r1355.g9cabb88-1
kalgebra21.04.2.r2033.g7da0ef8-121.04.2.r2034.g8ccd627-1
kapman21.04.2.r596.gb20985d-121.04.2.r597.g4c0e4c3-1
kasts 21.06.r20.gf42c011-1 21.06.r25.g03081ed-1
kate21.04.2.r18230.g553dede89-121.04.2.r18238.gff6318286-1
kblackbox21.04.2.r717.g34d60ce-121.04.2.r719.g2d5a886-1
kbounce21.04.2.r794.g88211ac-121.04.2.r797.gd4295c9-1
kbreakout21.04.2.r849.g9e11d24-121.04.2.r852.g3347459-1
kcalc21.04.2.r1504.gb3b91f3-121.04.2.r1506.g945ab22-1
kclock 21.06.r11.gcde0e5b-1 21.06.r12.g33407ad-1
kconfigwidgets5.83.0.r587.ge48ec4f-15.83.0.r589.gcda5b24-1
kcoreaddons5.83.0.r1231.g6b20aed8-15.83.0.r1234.g885eb01c-1
kde-cli-tools5.22.0.r1845.gddccf63-15.22.2.1.r1845.gddccf63-1
kde-dev-scripts21.04.2.r4134.gf26db2d-121.04.2.r4136.g0d347b0-1
kde-gtk-config5.22.0.r894.g666717b-15.22.2.1.r894.g666717b-1
kdeconnect21.04.2.r3251.gfb8646b3-121.04.2.r3260.g4d868a2e-1
kdecoration5.22.0.r267.g7be8cbb-15.22.2.1.r267.g7be8cbb-1
kdenetwork-filesharing21.04.2.r888.g69c9a4a-121.04.2.r889.g0abade9-1
kdenlive21.04.2.r14524.g185b30362-121.04.2.r14526.gea4527ae1-1
kdepim-addons21.04.2.r4130.gc6212fc9-121.04.2.r4142.gaa21bb42-1
kdepim-runtime21.04.2.r15122.g84efdeae9-121.04.2.r15126.g18bc7e436-1
kdeplasma-addons5.22.0.r8534.g0a31c9d70-15.22.2.1.r8535.g0bab97f6b-1
keysmith 21.06.r1.gaddd873-1 21.06.r2.ga25a720-1
kgamma55.22.0.r455.gdb6a51b-15.22.2.1.r455.gdb6a51b-1
kglobalaccel5.83.0.r448.gc586603-15.83.0.r449.g05fafb1-1
kguiaddons5.83.0.r370.g897f832-15.83.0.r375.g0cd8751-1
kholidays1:5.83.0.r939.ga040cdc-11:5.83.0.r940.g94f52b4-1
khotkeys5.22.0.r2074.gcaad4c1-15.22.2.1.r2074.gcaad4c1-1
kig21.04.2.r3136.g636c3557-121.04.2.r3137.g532f432d-1
kinfocenter5.22.0.r1851.g144d702-15.22.2.1.r1852.g5b06520-1
kio5.83.0.r4803.geae7e8f5-15.83.0.r4814.gc881bae5-1
kio-extras21.04.2.r7060.g2289e25d-121.04.2.r7062.g932c70eb-1
kipi-plugins21.04.2.r12060.g5fe710f54-121.04.2.r12061.g955fc31c6-1
kirigami25.83.0.r2815.g2965a0bf-15.83.0.r2818.gc7ed245d-1
kitinerary21.04.2.r1808.g15906f3-121.04.2.r1810.ge456b67-1
kjobwidgets5.83.0.r366.g7a542d1-15.83.0.r367.g2206ec1-1
kldap21.04.2.r862.gdd335bc-121.04.2.r863.ga63a231-1
kleopatra21.04.2.r5886.g86365f33-121.04.2.r5896.g3fe2c461-1
kmail21.04.2.r25773.g9b0b0aebe-121.04.2.r25806.g4b85ab9c2-1
kmail-account-wizard21.04.2.r782.g3274386-121.04.2.r783.g62c32d0-1
kmailtransport21.04.2.r1611.g5943484-121.04.2.r1612.gf1ec5f4-1
kmenuedit5.22.0.r968.g2742003-15.22.2.1.r968.g2742003-1
knotes21.04.2.r3462.g472a32b7-121.04.2.r3464.g875e7b1a-1
knotifyconfig5.82.0.r344.gf267604-15.82.0.r345.g38fd196-1
koko 21.06.r8.g2e87dcb-1 21.06.r14.gaee324e-1
kolourpaint21.04.2.r2342.ge42126f9-121.04.2.r2345.g13caa156-1
konqueror21.04.2.r14907.gff02a25ea-121.04.2.r14908.g2e8d30e3e-1
konsole21.04.2.r7838.g10e0abd9-121.04.2.r7854.gc5aa11c3-1
kontact21.04.2.r5324.g116c663c-121.04.2.r5325.g6a52ea45-1
kontactinterface21.04.2.r612.g7dcfd93-121.04.2.r613.gf10a1c5-1
konversation21.04.2.r8972.gf14918f2-121.04.2.r8973.g72499d41-1
korganizer21.04.2.r11388.g459fb1046-121.04.2.r11391.g045966b02-1
kparts5.83.0.r509.g7efe521-15.83.0.r510.g577607c-1
kpeople5.82.0.r1332.g4128996-15.82.0.r1333.gb793989-1
kpeoplevcard 0.1.r12.g04e0c18-1 0.1.r13.gda150a4-1
kpimtextedit21.04.2.r1385.gf98c2e6-121.04.2.r1386.gb4c8fd8-1
kpublictransport21.04.2.r1678.g93a0ac10-121.04.2.r1685.g8c9777f4-1
krecorder 21.06.r2.gb273970-1 21.06.r3.g3976840-1
kruler21.04.2.r687.gb67a000-121.04.2.r688.gfe6e2fe-1
kscreen5.22.0.r1335.ge958e6c-15.22.2.1.r1335.ge958e6c-1
kscreenlocker5.22.0.r854.g01ebc2c-15.22.2.1.r854.g01ebc2c-1
kservice5.83.0.r919.g04319a2-15.83.0.r920.gd0b3434-1
kshisen21.04.2.r1191.g4e93806-121.04.2.r1192.ga835d04-1
ksshaskpass5.22.0.r196.gdaa2679-15.22.2.1.r196.gdaa2679-1
ksysguard5.22.0.r3506.g93c4b8e4-15.22.2.1.r3506.g93c4b8e4-1
ksystemstats5.22.0.r174.g0639a7f-15.22.2.1.r174.g0639a7f-1
ktexteditor5.82.0.r2890.g8e45dcd5-15.82.0.r2892.gdb1d2a0a-1
ktimer21.04.2.r462.g217ff99-121.04.2.r464.gd79dbc2-1
ktorrent21.04.2.r2748.g53599a17-121.04.2.r2749.g0e891e0b-1
ktrip 21.06.r16.gb35a850-1 21.06.r17.gb03efd0-1
kunitconversion5.83.0.r366.g5d0b597-15.83.0.r367.gbe47ed6-1
kwallet-pam5.22.0.r248.ge91fcbe-15.22.2.1.r248.ge91fcbe-1
kwalletmanager21.04.2.r1194.g02ed960-121.04.2.r1196.g039e8dd-1
kwayland-integration5.22.0.r178.ge419293-15.22.2.1.r178.ge419293-1
kwayland-server5.22.0.r1338.g125a119-15.22.2.1.r1340.g3481dbc-1
kweather 21.06.r23.gc33b809-1 21.06.r30.gb5e8a76-1
kwidgetsaddons5.83.0.r829.g80771830-15.83.0.r830.g980f2242-1
kwin5.22.0.r19570.g19699e9a2-15.22.2.1.r19589.g6260c0354-1
kwinft5.22.0.r18960.g58b46353e-15.22.0.r18962.gedc9640a2-1
kwrite21.04.2.r18230.g553dede89-121.04.2.r18238.gff6318286-1
kwrited5.22.0.r478.gb687e84-15.22.2.1.r478.gb687e84-1
kxmlgui5.83.0.r781.g5d1001ba-15.83.0.r783.g61eaf5cf-1
libakonadi21.04.2.r12508.g0aa26872d-121.04.2.r12512.ge9f90a3b0-1
libkleo21.04.2.r902.g997bce9-121.04.2.r904.g9207554-1
libksane21.04.2.r537.g1a57ace-121.04.2.r538.g8386ec5-1
libkscreen5.22.0.r1583.gd916c2a-15.22.2.1.r1583.gd916c2a-1
libksieve21.04.2.r1530.g13942b86-121.04.2.r1532.gb4336e9d-1
libksysguard5.22.0.r2241.g2660f2d-15.22.2.1.r2241.g2660f2d-1
libktorrent21.04.2.r516.g36beec0-121.04.2.r517.g852b0b4-1
libquotient r1996.gd20aa00-1 r2001.g466fe1a-1
mailcommon21.04.2.r1039.g1782c4d-121.04.2.r1040.g04587be-1
marble21.04.2.r13311.ga90fcd043-221.04.2.r13313.g06b07adfd-1
marble-common21.04.2.r13311.ga90fcd043-221.04.2.r13313.g06b07adfd-1
marble-qt21.04.2.r13311.ga90fcd043-221.04.2.r13313.g06b07adfd-1
markdownpart21.04.2.r70.g203975d-121.04.2.r71.g3bcb59e-1
maui-clip 1.1.1.r5.gd32d0fd-1 1.1.1.r6.ge2ad9ab-1
maui-nota 1.2.2.r37.gbcc1844-1 1.2.2.r38.gbd9302c-1
maui-pix 1.2.2.r37.g32f5dad-1 1.2.2.r39.ga3c2b86-1
mauikit2.2.2.r91.g39f93829-12.2.2.r100.gd9ba87c9-1
mauikit-filebrowsing 1.2.2.r43.g08ccdca-1 1.2.2.r48.g887cabe-1
messagelib21.04.2.r6040.gd53fb428-121.04.2.r6049.g890724f2-1
milou5.22.0.r744.g01f3b8b-15.22.2.1.r744.g01f3b8b-1
neochat r1770.g211f6004-1 r1774.g92eb06aa-1
oxygen5.22.0.r4416.g0b1b8ff7-15.22.2.1.r4416.g0b1b8ff7-1
pim-sieve-editor21.04.2.r1480.g2e9c771-121.04.2.r1483.g2acd06b-1
pimcommon21.04.2.r1054.g1a059bf-121.04.2.r1055.g5dd16c8-1
plasma-browser-integration5.22.0.r1263.g3f5613ae-15.22.2.1.r1263.g3f5613ae-1
plasma-desktop5.22.0.r8504.g59cf85008-15.22.2.1.r8525.g948fb7d5a-1
plasma-dialer 21.06.r4.gfa1d0ee-1 21.06.r4.gfa1d0ee-2
plasma-disks5.22.0.r215.g1b3667c-15.22.2.1.r218.ga61c07c-1
plasma-firewall5.22.0.r493.g6113381-15.22.2.1.r494.gcdf6465-1
plasma-framework5.83.0.r15886.gb2f821ad2-15.83.0.r15888.g8953e77ec-1
plasma-integration5.22.0.r518.g7b512cc-15.22.2.1.r518.g7b512cc-1
plasma-nm5.22.0.r3058.g52d08d51-15.22.2.1.r3058.g52d08d51-1
plasma-pa5.22.0.r947.g0fdf808-15.22.2.1.r947.g0fdf808-1
plasma-phone-components5.22.0.r1421.gbacfccd3-15.22.2.1.r1421.gbacfccd3-1
plasma-phonebook 21.06.r3.g3a11349-1 21.06.r5.g75158f9-1
plasma-sdk5.22.0.r2270.gc454f236-15.22.2.1.r2271.gfdb53f2b-1
plasma-systemmonitor5.22.0.r453.gcfe7b0d-15.22.2.1.r455.gb7d2634-1
plasma-thunderbolt5.22.0.r133.g176fb93-15.22.2.1.r133.g176fb93-1
plasma-vault5.22.0.r336.g2b49118-15.22.2.1.r336.g2b49118-1
plasma-wayland-session5.22.0.r10409.g018fc0dee-15.22.2.1.r10411.g60ab32584-1
plasma-workspace5.22.0.r10409.g018fc0dee-15.22.2.1.r10411.g60ab32584-1
plasma-workspace-wallpapers5.22.0.r275.g6188c5b-15.22.2.1.r275.g6188c5b-1
polkit-kde-agent5.22.0.r498.g12157d1-15.22.2.1.r498.g12157d1-1
powerdevil5.22.0.r2441.gfe3d1dfb-15.22.2.1.r2441.gfe3d1dfb-1
qqc2-desktop-style5.82.0.r491.gf9598d7-15.82.0.r492.g5a1561c-1
sddm-kcm5.22.0.r586.gf4e241d-15.22.2.1.r586.gf4e241d-1
solid5.83.0.r679.g0e98339-15.83.0.r680.gef0b0df-1
spacebar 21.06.r7.g2ace395-1 21.06.r8.gc6edf0e-1
spectacle21.04.2.r1111.gd6b13e4-121.04.2.r1113.gd5fdfc8-1
syntax-highlighting5.83.0.r1604.g7820533e-15.83.0.r1609.g58a8047f-1
systemsettings5.22.0.r2443.g7b42e31e-15.22.2.1.r2444.gf046054a-1
tokodon 21.06.r7.gf6ff075-1 21.06.r9.g41f79ed-1
vvave 1.2.2.r26.g58b2c24-1 1.2.2.r30.gbf74851-1
xdg-desktop-portal-kde5.22.0.r368.gb17c3e4-15.22.2.1.r369.g0a7996e-1
zeroconf-ioslave21.04.2.r344.g690c9bc-121.04.2.r349.g373ceaa-1
qt5-es2-base - 5.15.2+kde+r203-1
qt5-es2-xcb-private-headers - 5.15.2+kde+r203-1
sddm -0.19.0.r39.ge64a87d-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
