[ARM Testing Update] 2021-04-28 - Thunderbird, KDE Gear, SnapD, Uboots and kernels
Hello ARM community.
5.12 kernel got released, together with some other new stuff!
Some highlights:
  • Most of our kernels got updated, linux got to 5.12.0!
  • Thunderbird is updated to 78.10.0
  • Updated KDE Gear gets the applications to version 21.04.0
  • SnapD got a new major release with 2.50
  • Our uboot packages for Odroids got a new update, which fixes the slow ethernet speeds!
  • Lots of Mobile specific packages got updated
  • Some python packages got updated
If anyone wants to test kodi on the rpi:
Change to the unstable or testing branch and install kodi packages:
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
Also by default it uses the vc4-kms-v3d which means fbturbo is not installed.
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip and firewalld requires manual intervention:
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Wed Apr 28 20:04:17 CEST 2021)
  • arm-testing community aarch64: 221 new and 224 removed package(s)
  • arm-testing core aarch64: 20 new and 20 removed package(s)
  • arm-testing extra aarch64: 395 new and 396 removed package(s)
  • arm-testing kde-unstable aarch64: 120 new and 120 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2021-04-23         2021-04-28
                               calls              0.3.2-1  0.3.2+16+g95bde23-1
                              chatty        0.3.0_beta2-10.3.0_beta2+11+gf3227c6-1
                     element-desktop             1.7.25-1             1.7.26-1
                         element-web             1.7.25-1             1.7.26-1
                           feedbackd  0.0.0+git20210125-2  0.0.0+git20210426-1
                      geoclue-mobile              2.5.7-1              2.5.7-2
             manjaro-arm-oem-install           20210328-1           20210427-1
                               phosh 0.10.1+20+g6f8f9b0-1 0.10.1+46+gf2550bf-1
                               snapd             2.49.2-1               2.50-1
:: Different sync package(s) in repository community aarch64
                       acme-redirect              0.4.0-1              0.5.0-1
                               acorn            1:8.1.1-1            1:8.2.1-1
                        ansible-lint              5.0.7-2              5.0.7-3
                                 apm              2.6.1-3              2.6.1-4
                         asciidoctor             2.0.12-2             2.0.14-1
                                  at              3.2.1-3              3.2.2-1
                          autocutsel             0.10.0-3             0.10.1-1
                bash-language-server             1.17.0-3             1.17.0-4
                           bctoolbox              4.5.3-1             4.5.10-1
                           bettercap             2.30.2-1             2.31.0-1
                   bettercap-capletsv20201031.r370.7e20238-1v20210412.r372.2d58298-1
                             binwalk              2.3.0-1              2.3.1-1
                        bitwarden_rs             1.20.0-1             1.20.0-2
                    bitwarden_rs-web           2.19.0.b-1           2.19.0.b-2
                             bladerf              2.2.1-4            2021.03-1
                                 bpf               5.11-1               5.12-1
                              bpytop             1.0.63-1             1.0.64-1
                      budgie-desktop10.5.2+24+g7a5dcfda-1             10.5.3-1
                               bzrtp              4.5.7-1             4.5.10-1
                      cargo-outdated             0.9.14-1             0.9.15-1
                    cargo-spellcheck              0.8.2-1              0.8.3-1
                              ccache                4.2-1              4.2.1-1
               cgroup_event_listener               5.11-1               5.12-1
                              clamtk               6.09-1               6.11-1
                   containers-common             0.36.0-1             0.37.0-1
                              cosign              0.1.0-2              0.3.1-2
                            cpupower               5.11-1               5.12-1
                               cri-o             1.20.2-1             1.21.0-1
                              crictl             1.20.0-2             1.21.0-1
                             critest             1.20.0-2             1.21.0-1
                         debootstrap            1.0.123-1            1.0.124-1
                                deno              1.9.1-1              1.9.2-1
                              drupal              9.0.6-2              9.1.7-1
                              eslint             7.24.0-1             7.25.0-1
                           fcitx-qt5              1.2.5-3              1.2.6-1
                               fcron              3.2.1-4              3.2.1-5
                              fdkaac              1.0.1-1              1.0.2-1
                            feeluown              3.7.6-1              3.7.7-1
                       feeluown-kuwo              0.1.2-2              0.1.3-1
                    feeluown-netease                0.5-1                0.6-1
                    feeluown-qqmusic              0.3.1-2              0.3.2-1
                           fetchmail             6.4.18-1             6.4.19-1
  firefox-extension-https-everywhere          2021.1.27-1          2021.4.15-1
                    firefox-noscript             11.2.3-1             11.2.4-1
                               gajim              1.3.1-1              1.3.2-1
                               geary           1:3.38.2-1             1:40.0-1
                               giada             0.17.0-1             0.17.2-1
                               gitui             0.13.0-1             0.15.0-1
                   gnome-screensaver             3.6.1-17                    -
                          gpio-utils               5.11-1               5.12-1
                           gscan2pdf             2.12.0-1             2.12.1-1
                                gxkb              0.9.0-1              0.9.1-1
                       gxplugins.lv2                0.8-1                0.9-1
                             haproxy              2.3.9-1             2.3.10-1
                            hedgedoc              1.7.2-2              1.7.2-3
                      home-assistant           2021.4.4-2           2021.4.6-1
                              hyperv               5.11-1               5.12-1
                               iaito              5.2.0-1              5.2.2-1
                           iio-utils               5.11-1               5.12-1
                            innernet              1.0.1-3              1.2.0-1
                            ipython2              5.9.0-1                    -
             java-atk-wrapper-common             0.37.1-1             0.38.0-1
            java-atk-wrapper-openjdk             0.37.1-1             0.38.0-1
          java-atk-wrapper-openjdk10             0.37.1-1                    -
          java-atk-wrapper-openjdk11             0.37.1-1             0.38.0-1
           java-atk-wrapper-openjdk8             0.37.1-1             0.38.0-1
                                jrnl                2.8-1              2.8.1-1
                                khal             0.10.2-5             0.10.3-1
                              kstars            1:3.5.2-1            1:3.5.3-1
                             lazygit             0.26.1-1             0.28.1-1
                             libgiac            1.7.0.1-1            1.7.0.3-1
                             libpoly              0.1.8-1              0.1.9-1
                       libtraceevent               5.11-1                    -
                    linux-tools-meta               5.11-1               5.12-1
                            luarocks              3.5.0-1              3.7.0-1
                             mathjax              3.1.2-1              3.1.4-1
                            maui-pix              1.2.1-1              1.2.1-2
                               maven              3.6.3-1              3.8.1-1
                       mediastreamer              4.5.7-1             4.5.10-1
                             menyoki              1.3.0-1              1.4.0-1
                                  mg           20200723-1           20210314-1
                           moreutils               0.65-1               0.65-2
                                 mpv           1:0.33.1-1           1:0.33.1-2
                                muse              3.1.1-2              4.0.0-1
                                  mx 1.4.7+13+g24efb0cc-3                    -
                             mypaint              2.0.0-2              2.0.1-1
                  nextcloud-app-deck            1:1.4.0-1            1:1.4.1-1
                           nicotine+              3.0.4-1              3.0.5-1
                                 nim              1.4.4-1              1.4.6-1
                              nimble           1:0.12.0-1           1:0.13.1-1
                              nodejs            15.14.0-2             16.0.0-1
                                 npm             7.10.0-1             7.11.1-1
                   npm-check-updates             11.5.1-1             11.5.3-1
                              nuitka           0.6.14.1-1           0.6.14.4-1
                            openblas           0.3.13-2.1             0.3.14-1
                           opentoonz              1.5.0-1              1.5.0-2
                                ortp              4.5.7-1             4.5.10-1
                                perf               5.11-1               5.12-1
                        php-igbinary              3.2.1-2              3.2.2-1
                       php7-igbinary              3.2.1-2              3.2.2-1
                        polkit-gnome              0.105-5              0.105-6
                            progress               0.15-1               0.16-1
                               pyrit              0.5.0-4              0.5.0-5
                     python-arpeggio             1.10.1-3             1.10.2-1
                        python-black             20.8b1-6             21.4b1-1
                      python-breathe             4.29.0-1             4.29.1-1
                python-cssbeautifier             1.13.9-1            1.13.13-1
                    python-decorator              4.4.2-3              4.4.2-4
            python-django-compressor                2.4-3              2.4.1-1
            python-django-extensions              3.1.2-1              3.1.3-1
                        python-emoji              0.6.0-1              1.0.1-1
                        python-faker              8.1.0-1              8.1.1-1
                        python-gdspy              1.6.3-1              1.6.4-1
                     python-greenlet              1.0.0-1              1.0.0-2
                   python-hypothesis             6.8.10-1              6.9.0-1
                       python-imdbpy          2020.9.25-3          2021.4.18-1
                    python-intervals              0.8.1-5              0.9.1-1
                    python-ipykernel              5.5.0-1              5.5.3-1
                 python-jsbeautifier             1.13.9-1            1.13.13-1
                     python-jsondiff              1.2.0-6              1.3.0-1
                    python-jsonpatch               1.29-1               1.30-1
            python-jupyterlab_server              2.4.0-1              2.5.0-1
                     python-m2crypto             0.37.1-1             0.37.1-2
               python-more-itertools              8.6.0-3              8.7.0-1
                 python-nest_asyncio              1.4.3-2              1.5.1-1
                     python-objgraph              3.5.0-3              3.5.0-4
                          python-pbr              5.5.1-3              5.6.0-1
                         python-perf              1.6.0-5              1.6.0-6
                  python-pickleshare              0.7.5-5              0.7.5-6
                      python-pikepdf             2.11.1-1             2.11.3-1
                       python-pillow              8.1.2-1              8.2.0-2
                     python-psycopg2              2.8.6-3              2.8.6-4
                   python-py-cpuinfo              7.0.0-3              8.0.0-1
             python-pytest-testinfra              6.2.0-1              6.3.0-1
                      python-pytools           2021.2.3-1           2021.2.6-1
                        python-scipy              1.6.2-1              1.6.3-1
                    python-tarantool 0.6.6.r25.gb267643-2 0.6.6.r25.gb267643-3
                      python-trimesh              3.9.1-1             3.9.14-1
                       python-xmlsec              1.3.9-3             1.3.10-1
                         python-yaml            5.4.1.1-1            5.4.1.1-2
python2-backports.shutil_get_terminal_size              1.0.0-4                    -
                   python2-decorator              4.4.2-3                    -
                    python2-greenlet              1.0.0-1                    -
                    python2-m2crypto             0.37.1-1                    -
                    python2-objgraph              3.5.0-3                    -
                     python2-pathlib              1.0.1-5                    -
                         python2-pbr              5.5.1-3              5.6.0-1
                        python2-perf              1.6.0-5                    -
                 python2-pickleshare              0.7.5-5                    -
                    python2-psycopg2              2.8.6-3                    -
                  python2-statistics            1.0.3.5-3                    -
                   python2-tarantool 0.6.6.r25.gb267643-2                    -
                        python2-yaml            5.4.1.1-1                    -
                      quassel-client             0.13.1-5             0.13.1-7
                quassel-client-small             0.13.1-5                    -
                        quassel-core             0.13.1-5             0.13.1-7
                  quassel-monolithic             0.13.1-5             0.13.1-7
                            r2ghidra              5.2.0-1              5.2.1-2
                             radare2              5.2.0-1              5.2.1-1
                              raylib              3.5.0-1              3.7.0-1
               retroarch-assets-glui              1:372-1              1:376-1
              retroarch-assets-ozone              1:372-1              1:376-1
                retroarch-assets-xmb              1:372-1              1:376-1
                                rink              0.6.0-2              0.6.1-1
                            rshijack              0.3.0-3              0.4.0-1
                          ruby-async             1.23.0-3             1.29.0-1
                      ruby-async-dns              1.2.4-3              1.2.5-1
                       ruby-async-io             1.27.0-3             1.30.2-1
                        ruby-net-dns              0.8.0-7              0.9.0-1
                          ruby-nio4r              2.5.4-2              2.5.7-1
                     ruby-rb-inotify             0.9.10-5             0.10.1-1
                          ruby-rspec              3.8.0-4             3.10.0-1
                     ruby-rspec-core              3.8.0-4             3.10.1-1
             ruby-rspec-expectations              3.8.1-4             3.10.1-1
                    ruby-rspec-mocks              3.8.0-4             3.10.2-1
                  ruby-rspec-support              3.8.0-4             3.10.2-1
                           ruby-tilt              2.0.8-5             2.0.10-1
                       rust-analyzer           20210419-1           20210426-1
                              rustup             1.23.1-1             1.24.0-2
                               sbctl                0.2-1                0.3-1
                                shim                 15-5               15.4-1
                               sigal              2.1.1-2                2.2-1
                           sniffglue             0.12.0-1             0.12.1-1
                       speedtest-cli              2.1.2-3              2.1.3-1
                              sqlmap              1.5.2-1              1.5.4-1
                      squashfs-tools                4.4-2          4.4_git.1-1
                            starship             0.51.0-2             0.52.1-1
                           stylelint            13.12.0-1            13.13.0-1
        stylelint-config-recommended              4.0.0-1              5.0.0-1
           stylelint-config-standard             21.0.0-1             22.0.0-1
                    telegram-desktop              2.7.1-1              2.7.3-1
                          terragrunt             0.28.8-1             0.29.0-1
                               tiled              1.5.0-1              1.6.0-1
                               tint2               16.7-3               17.0-1
                                tmon               5.11-1               5.12-1
                             toolame               02l-11               02l-12
                             trojita                0.7-4                0.7-5
                   ttf-sarasa-gothic             0.30.2-1             0.31.0-1
                      ukui-interface            1.0.0a1-1            1.0.0a1-2
                               usbip               5.11-1               5.12-1
         v2ray-domain-list-community     20210419153906-1     20210427111318-1
                         v2ray-geoip       202104220007-1       202104270716-1
                              viking                1.8-6                1.9-1
                            vim-clap               0.24-1               0.25-1
                        vim-nerdtree              6.9.8-1             6.10.9-1
                                wabt             1.0.20-1             1.0.23-1
                           watchexec             1.15.1-1             1.15.2-1
                             web-ext              6.0.0-1              6.1.0-1
                       wireshark-cli              3.4.4-1              3.4.5-1
                        wireshark-qt              3.4.4-1              3.4.5-1
                           wvstreams             4.6.1-16             4.6.1-17
                                xcas            1.7.0.1-1            1.7.0.3-1
                            xcircuit            3.10.28-1            3.10.30-1
                             yoshimi                2.0-1              2.0.1-1
                          youtube-dl         2021.04.17-1         2021.04.26-1
                             beebeep                    -              5.8.4-4
                  budgie-screensaver                    -                4.0-1
                               iptux                    -              0.8.0-1
                          libchardet                    -              1.0.5-1
                       nginx-mod-vts                    -             0.1.18-3
                          nitroshare                    -              0.3.4-3
                   nodejs-source-map                    -              0.7.3-2
                         qhttpengine                    -              1.0.1-2
                         qmdnsengine                    -              0.1.0-2
                      qtdbusextended                    -              0.0.3-1
                   quassel-client-qt                    -             0.13.1-7
                      quassel-common                    -             0.13.1-7
               quassel-monolithic-qt                    -             0.13.1-7
                           termshark                    -              2.2.0-1
                          warpinator                    -              1.1.2-2
:: Different overlay package(s) in repository core aarch64
                               linux            5.11.16-1             5.12.0-1
                       linux-headers            5.11.16-1             5.12.0-1
                     linux-pinephone            5.11.16-1             5.12.0-0
             linux-pinephone-headers            5.11.16-1             5.12.0-0
                          linux-rpi4            5.10.31-1            5.10.32-1
                  linux-rpi4-headers            5.10.31-1            5.10.32-1
                 linux-rpi4-mainline            5.11.15-1             5.12.0-1
         linux-rpi4-mainline-headers            5.11.15-1             5.12.0-1
                      pacman-mirrors             4.19.1-1             4.21.1-2
              raspberrypi-bootloader           20210419-1           20210427-1
            raspberrypi-bootloader-x           20210419-1           20210427-1
                     uboot-odroid-c4            2015.01-4        2015.01.189-1
                    uboot-odroid-hc4            2015.01-4        2015.01.189-1
                     uboot-odroid-n2            2015.01-4        2015.01.189-1
                uboot-odroid-n2-plus        2015.01.112-3        2015.01.189-1
                     uboot-pinephone         2021.01rc4-0       2021.01rc4-0.1
:: Different sync package(s) in repository core aarch64
                           amd-ucode   20210315.3568f96-1   20210315.3568f96-2
                           inetutils              1.9.4-8              1.9.4-9
                             libedit       20210216_3.1-1       20210419_3.1-1
                      linux-firmware   20210315.3568f96-1   20210315.3568f96-2
:: Different overlay package(s) in repository extra aarch64
                            mesa-git21.2.0_devel.138334.c74d93cf018-121.2.0_devel.138660.48d48fbf3c5-1
                              okular            20.12.3-1            21.04.0-1
                           pamac-cli           10.1.1-0.2             10.1.1-1
                        pamac-common           10.1.1-0.2             10.1.1-1
                pamac-flatpak-plugin           10.1.1-0.2             10.1.1-1
             pamac-gnome-integration           10.1.1-0.2             10.1.1-1
                           pamac-gtk           10.1.1-0.2             10.1.1-1
                   pamac-snap-plugin           10.1.1-0.2             10.1.1-1
:: Different sync package(s) in repository extra aarch64
                             akonadi            20.12.3-1            21.04.0-1
                    akonadi-calendar            20.12.3-1            21.04.0-1
              akonadi-calendar-tools            20.12.3-1            21.04.0-1
                    akonadi-contacts            20.12.3-1            21.04.0-1
               akonadi-import-wizard            20.12.3-1            21.04.0-1
                        akonadi-mime            20.12.3-1            21.04.0-1
                       akonadi-notes            20.12.3-1            21.04.0-1
                      akonadi-search            20.12.3-1            21.04.0-1
                      akonadiconsole            20.12.3-1            21.04.0-1
                           akregator            20.12.3-2            21.04.0-1
                            analitza            20.12.3-1            21.04.0-1
                arch-install-scripts                 23-2                 24-1
                  arch-rebuild-order              0.1.1-1              0.1.1-2
                        arch-signoff              0.5.1-2              0.5.2-1
                         archinstall              2.1.3-1              2.1.4-2
                                 ark            20.12.3-1            21.04.0-1
                          artikulate            20.12.3-1            21.04.0-1
                         audiocd-kio            20.12.3-1            21.04.0-1
                       baloo-widgets            20.12.3-1            21.04.0-1
                             blinken            20.12.3-1            21.04.0-1
                              bomber            20.12.3-1            21.04.0-1
                                bovo            20.12.3-1            21.04.0-1
                     calendarsupport            20.12.3-1            21.04.0-1
                              cantor            20.12.3-4            21.04.0-1
                            cervisia            20.12.3-1            21.04.0-1
                            chromium       90.0.4430.85-1       90.0.4430.93-1
                              clamav            0.103.1-1            0.103.2-1
                            composer             2.0.12-1             2.0.13-1
                               conky             1.12.1-1             1.12.2-1
                             dolphin            20.12.3-1            21.04.0-1
                     dolphin-plugins            20.12.3-1            21.04.0-1
                              dragon            20.12.3-1            21.04.0-1
                               elisa            20.12.3-1            21.04.0-1
                          eventviews            20.12.3-1            21.04.0-1
                              ffmpeg            2:4.3.2-6              2:4.4-1
                        ffmpegthumbs            20.12.3-1            21.04.0-1
                           filelight            20.12.3-1            21.04.0-1
                             freetds             1.2.20-1             1.2.21-1
                                gimp            2.10.24-1            2.10.24-2
                       gnome-session               40.0-1               40.1-1
                             gparted              1.2.0-2              1.2.0-3
                           granatier            20.12.3-1            21.04.0-1
                     grantlee-editor            20.12.3-1            21.04.0-1
                       grantleetheme            20.12.3-1            21.04.0-1
                                gtk3          1:3.24.28-4          1:3.24.29-1
                          gtk3-demos          1:3.24.28-4          1:3.24.29-1
                           gtk3-docs          1:3.24.28-4          1:3.24.29-1
                               guile              2.2.6-2              2.2.7-1
                            guile1.8              1.8.8-7              1.8.8-8
                            guile2.0             2.0.14-4             2.0.14-5
                                gvim           8.2.2653-1           8.2.2815-1
                            gwenview            20.12.3-1            21.04.0-1
                               hwloc              2.4.0-1              2.4.1-1
                             hylafax              6.0.7-3              6.0.7-4
                         imagemagick           7.0.11.8-1           7.0.11.9-1
                     imagemagick-doc           7.0.11.8-1           7.0.11.9-1
                     incidenceeditor            20.12.3-1            21.04.0-1
                               irssi              1.2.2-4              1.2.3-1
                           itinerary            20.12.3-1            21.04.0-1
                       jdk11-openjdk         11.0.10.u9-1         11.0.11.u9-1
                        jdk8-openjdk             8.u282-1             8.u292-1
                       jre11-openjdk         11.0.10.u9-1         11.0.11.u9-1
              jre11-openjdk-headless         11.0.10.u9-1         11.0.11.u9-1
                        jre8-openjdk             8.u282-1             8.u292-1
               jre8-openjdk-headless             8.u282-1             8.u292-1
                                 juk            20.12.3-1            21.04.0-1
                                 k3b          1:20.12.3-1          1:21.04.0-1
               kaccounts-integration            20.12.3-1            21.04.0-1
                 kaccounts-providers            20.12.3-1            21.04.0-1
                        kaddressbook            20.12.3-1            21.04.0-1
                             kajongg            20.12.3-1            21.04.0-1
                              kalarm            20.12.3-1            21.04.0-1
                           kalarmcal            20.12.3-1            21.04.0-1
                            kalgebra            20.12.3-1            21.04.0-1
                             kalzium            20.12.3-1            21.04.0-1
                              kamera            20.12.3-1            21.04.0-1
                              kamoso            20.12.3-1            21.04.0-1
                            kanagram            20.12.3-1            21.04.0-1
                              kapman            20.12.3-1            21.04.0-1
                        kapptemplate            20.12.3-1            21.04.0-1
                                kate            20.12.3-1            21.04.0-1
                             katomic            20.12.3-1            21.04.0-1
                             kbackup            20.12.3-1            21.04.0-1
                           kblackbox            20.12.3-1            21.04.0-1
                             kblocks            20.12.3-1            21.04.0-1
                             kbounce            20.12.3-1            21.04.0-1
                           kbreakout            20.12.3-1            21.04.0-1
                              kbruch            20.12.3-1            21.04.0-1
                         kcachegrind            20.12.3-1            21.04.0-1
                  kcachegrind-common            20.12.3-1            21.04.0-1
                               kcalc            20.12.3-1            21.04.0-1
                           kcalutils            20.12.3-1            21.04.0-1
                         kcharselect            20.12.3-1            21.04.0-1
                       kcolorchooser            20.12.3-1            21.04.0-1
                               kcron            20.12.3-1            21.04.0-1
              kde-accessibility-meta              20.12-4              21.04-1
               kde-applications-meta              20.12-4              21.04-1
                     kde-dev-scripts            20.12.3-1            21.04.0-1
                       kde-dev-utils            20.12.3-1            21.04.0-1
                  kde-education-meta              20.12-4              21.04-1
                      kde-games-meta              20.12-4              21.04-1
                   kde-graphics-meta              20.12-4              21.04-1
                 kde-multimedia-meta              20.12-4              21.04-1
                    kde-network-meta              20.12-4              21.04-1
                        kde-pim-meta              20.12-4              21.04-1
                        kde-sdk-meta              20.12-4              21.04-1
                     kde-system-meta              20.12-4              21.04-1
                  kde-utilities-meta              20.12-4              21.04-1
                      kdebugsettings            20.12.3-1            21.04.0-1
                          kdeconnect            20.12.3-1            21.04.0-1
                         kdeedu-data            20.12.3-1            21.04.0-1
              kdegraphics-mobipocket            20.12.3-1            21.04.0-1
            kdegraphics-thumbnailers            20.12.3-1            21.04.0-1
              kdenetwork-filesharing            20.12.3-1            21.04.0-1
                            kdenlive            20.12.3-2            21.04.0-1
                       kdepim-addons            20.12.3-1            21.04.0-1
                      kdepim-runtime            20.12.3-1            21.04.0-1
                    kdesdk-kioslaves            20.12.3-1            21.04.0-1
                 kdesdk-thumbnailers            20.12.3-1            21.04.0-1
                                 kdf            20.12.3-1            21.04.0-1
                             kdialog            20.12.3-1            21.04.0-1
                            kdiamond            20.12.3-1            21.04.0-1
                      keditbookmarks            20.12.3-1            21.04.0-1
                               kfind            20.12.3-1            21.04.0-1
                             kfloppy            20.12.3-1            21.04.0-1
                         kfourinline            20.12.3-1            21.04.0-1
                          kgeography            20.12.3-1            21.04.0-1
                                kget            20.12.3-1            21.04.0-1
                         kgoldrunner            20.12.3-1            21.04.0-1
                                kgpg            20.12.3-1            21.04.0-1
                            khangman            20.12.3-1            21.04.0-1
                         khelpcenter            20.12.3-1            21.04.0-1
                 kidentitymanagement            20.12.3-1            21.04.0-1
                                 kig            20.12.3-1            21.04.0-1
                                kigo            20.12.3-1            21.04.0-1
                            killbots            20.12.3-1            21.04.0-1
                     kimagemapeditor            20.12.3-1            21.04.0-1
                               kimap            20.12.3-1            21.04.0-1
                          kio-extras            20.12.3-1            21.04.0-1
                          kio-gdrive            20.12.3-1            21.04.0-1
                        kipi-plugins            20.12.3-1            21.04.0-1
                    kirigami-gallery            20.12.3-2            21.04.0-1
                              kiriki            20.12.3-1            21.04.0-1
                               kiten            20.12.3-1            21.04.0-1
                          kitinerary            20.12.3-2            21.04.0-1
                        kjumpingcube            20.12.3-1            21.04.0-1
                               kldap            20.12.3-1            21.04.0-1
                           kleopatra            20.12.3-1            21.04.0-1
                            klettres            20.12.3-1            21.04.0-1
                            klickety            20.12.3-1            21.04.0-1
                              klines            20.12.3-1            21.04.0-1
                                kmag            20.12.3-1            21.04.0-1
                           kmahjongg            20.12.3-1            21.04.0-1
                               kmail            20.12.3-1            21.04.0-1
                kmail-account-wizard            20.12.3-1            21.04.0-1
                      kmailtransport            20.12.3-1            21.04.0-1
                               kmbox            20.12.3-1            21.04.0-1
                               kmime            20.12.3-1            21.04.0-1
                              kmines            20.12.3-1            21.04.0-1
                                kmix            20.12.3-1            21.04.0-1
                          kmousetool            20.12.3-1            21.04.0-1
                              kmouth            20.12.3-1            21.04.0-1
                              kmplot            20.12.3-1            21.04.0-1
                        knavalbattle            20.12.3-1            21.04.0-1
                            knetwalk            20.12.3-1            21.04.0-1
                             knights            20.12.3-1            21.04.0-1
                              knotes            20.12.3-1            21.04.0-1
                                kolf            20.12.3-1            21.04.0-1
                           kollision            20.12.3-1            21.04.0-1
                         kolourpaint            20.12.3-1            21.04.0-1
                             kompare            20.12.3-1            21.04.0-1
                           konqueror            20.12.3-1            21.04.0-1
                            konquest            20.12.3-1            21.04.0-1
                             konsole            20.12.3-1            21.04.0-2
                             kontact            20.12.3-1            21.04.0-1
                    kontactinterface            20.12.3-1            21.04.0-1
                            kontrast            20.12.3-1            21.04.0-1
                        konversation            20.12.3-1            21.04.0-1
                              kopete            20.12.3-1            21.04.0-1
                          korganizer            20.12.3-1            21.04.0-1
                       kosmindoormap            20.12.3-2            21.04.0-1
                           kpatience            20.12.3-1                    -
                        kpimtextedit            20.12.3-1            21.04.0-1
                             kpkpass            20.12.3-1            21.04.0-1
                             kpmcore            20.12.3-1            21.04.0-1
                    kpublictransport            20.12.3-1            21.04.0-1
                      kqtquickcharts            20.12.3-1            21.04.0-1
                                krdc            20.12.3-1            21.04.0-1
                            kreversi            20.12.3-1            21.04.0-1
                                krfb            20.12.3-1            21.04.0-1
                  kross-interpreters            20.12.3-2            21.04.0-1
                              kruler            20.12.3-1            21.04.0-1
                             kshisen            20.12.3-1            21.04.0-1
                               ksirk            20.12.3-1            21.04.0-1
                               ksmtp            20.12.3-1            21.04.0-1
                          ksnakeduel            20.12.3-1            21.04.0-1
                          kspaceduel            20.12.3-1            21.04.0-1
                            ksquares            20.12.3-1            21.04.0-1
                             ksudoku            20.12.3-1            21.04.0-1
                          ksystemlog            20.12.3-1            21.04.0-1
                            kteatime            20.12.3-1            21.04.0-1
                              ktimer            20.12.3-1            21.04.0-1
                               ktnef            20.12.3-1            21.04.0-1
                            ktorrent            20.12.3-1            21.04.0-1
                              ktouch            20.12.3-1            21.04.0-1
                          ktuberling            20.12.3-1            21.04.0-1
                             kturtle            20.12.3-1            21.04.0-1
                             kubrick            20.12.3-1            21.04.0-1
                      kwalletmanager            20.12.3-1            21.04.0-1
                               kwave            20.12.3-1            21.04.0-1
                           kwordquiz            20.12.3-1            21.04.0-1
                              kwrite            20.12.3-1            21.04.0-1
                          libakonadi            20.12.3-1            21.04.0-1
                          libdvdread              6.1.1-1              6.1.2-1
                         libgravatar            20.12.3-1            21.04.0-1
                            libhandy              1.2.1-1              1.2.2-1
                       libjpeg-turbo              2.0.6-1              2.1.0-1
                            libkcddb            20.12.3-1            21.04.0-1
                     libkcompactdisc            20.12.3-1            21.04.0-1
                           libkdcraw            20.12.3-1            21.04.0-1
                         libkdegames            20.12.3-1            21.04.0-1
                           libkdepim            20.12.3-1            21.04.0-1
                  libkeduvocdocument            20.12.3-1            21.04.0-1
                           libkexiv2            20.12.3-1            21.04.0-1
                            libkgapi            20.12.3-1            21.04.0-1
                             libkipi            20.12.3-1            21.04.0-1
                             libkleo            20.12.3-1            21.04.0-1
                        libkmahjongg            20.12.3-1            21.04.0-1
                     libkomparediff2            20.12.3-1            21.04.0-1
                            libksane            20.12.3-1            21.04.0-1
                           libksieve            20.12.3-1            21.04.0-1
                         libktorrent            20.12.3-1            21.04.0-1
                          libmypaint              1.5.1-2              1.6.1-1
                          libplacebo            3.104.0-2            3.120.2-1
                             libtiff              4.2.0-1              4.3.0-1
                             libupnp             1.14.5-1             1.14.6-1
                   libva-mesa-driver             21.0.3-1             21.0.3-2
                            lokalize            20.12.3-1            21.04.0-1
                               lskat            20.12.3-1            21.04.0-1
                          mailcommon            20.12.3-1            21.04.0-1
                        mailimporter            20.12.3-1            21.04.0-1
                              marble            20.12.3-2            21.04.0-1
                       marble-common            20.12.3-2            21.04.0-1
                           marble-qt            20.12.3-2            21.04.0-1
                        markdownpart            20.12.3-1            21.04.0-1
                       mbox-importer            20.12.3-1            21.04.0-1
                                mesa             21.0.3-1             21.0.3-2
                          mesa-vdpau             21.0.3-1             21.0.3-2
                          messagelib            20.12.3-1            21.04.0-1
                              minuet            20.12.3-1            21.04.0-1
                       nginx-mod-vts             0.1.18-3                    -
                         opencl-mesa             21.0.3-1             21.0.3-2
                       openjdk11-src         11.0.10.u9-1         11.0.11.u9-1
                        openjdk8-src             8.u282-1             8.u292-1
                             openvpn              2.5.1-1              2.5.2-1
                            palapeli            20.12.3-1            21.04.0-1
                            pam_ldap                186-6                186-7
                              parley            20.12.3-1            21.04.0-1
                    partitionmanager            20.12.3-1            21.04.0-1
                 perl-image-exiftool              12.16-1              12.25-1
                     perl-net-ssleay               1.88-2               1.90-1
                                 php              8.0.3-2              8.0.5-1
                          php-apache              8.0.3-2              8.0.5-1
                             php-cgi              8.0.3-2              8.0.5-1
                           php-dblib              8.0.3-2              8.0.5-1
                           php-embed              8.0.3-2              8.0.5-1
                         php-enchant              8.0.3-2              8.0.5-1
                             php-fpm              8.0.3-2              8.0.5-1
                              php-gd              8.0.3-2              8.0.5-1
                            php-imap              8.0.3-2              8.0.5-1
                            php-intl              8.0.3-2              8.0.5-1
                            php-odbc              8.0.3-2              8.0.5-1
                           php-pgsql              8.0.3-2              8.0.5-1
                          php-phpdbg              8.0.3-2              8.0.5-1
                          php-pspell              8.0.3-2              8.0.5-1
                            php-snmp              8.0.3-2              8.0.5-1
                          php-sodium              8.0.3-2              8.0.5-1
                          php-sqlite              8.0.3-2              8.0.5-1
                            php-tidy              8.0.3-2              8.0.5-1
                             php-xsl              8.0.3-2              8.0.5-1
                               picmi            20.12.3-1            21.04.0-1
                   pim-data-exporter            20.12.3-1            21.04.0-1
                    pim-sieve-editor            20.12.3-1            21.04.0-1
                           pimcommon            20.12.3-1            21.04.0-1
                               poxml            20.12.3-1            21.04.0-1
                       print-manager            20.12.3-1            21.04.0-1
                              python            3.9.3-1.1            3.9.4-1.1
                  python-archinstall              2.1.3-1                    -
                      python-astroid              2.5.3-1              2.5.4-1
                        python-numpy             1.20.1-1             1.20.2-1
                   python-setuptools           1:54.2.0-1           1:56.0.0-1
                        python-tests            3.9.3-1.1            3.9.4-1.1
                        python-urwid              2.1.1-3              2.1.2-1
                   python-virtualenv             20.4.3-1             20.4.4-1
                  python2-virtualenv             20.4.3-1             20.4.4-1
                         qcachegrind            20.12.3-1            21.04.0-1
                                rocs            20.12.3-1            21.04.0-1
            signon-kwallet-extension            20.12.3-1            21.04.0-1
                           spectacle            20.12.3-1            21.04.0-1
                                step            20.12.3-1            21.04.0-1
                             svgpart            20.12.3-1            21.04.0-1
                             sweeper            20.12.3-1            21.04.0-1
          telepathy-kde-accounts-kcm            20.12.3-1            21.04.0-1
              telepathy-kde-approver            20.12.3-1            21.04.0-1
          telepathy-kde-auth-handler            20.12.3-1            21.04.0-1
               telepathy-kde-call-ui            20.12.3-1            21.04.0-1
      telepathy-kde-common-internals            20.12.3-1            21.04.0-1
          telepathy-kde-contact-list            20.12.3-1            21.04.0-1
        telepathy-kde-contact-runner            20.12.3-1            21.04.0-1
       telepathy-kde-desktop-applets            20.12.3-1            21.04.0-1
  telepathy-kde-filetransfer-handler            20.12.3-1            21.04.0-1
    telepathy-kde-integration-module            20.12.3-1            21.04.0-1
                  telepathy-kde-meta              20.12-4              21.04-1
             telepathy-kde-send-file            20.12.3-1            21.04.0-1
               telepathy-kde-text-ui            20.12.3-1            21.04.0-1
                         thunderbird             78.9.1-3            78.10.0-1
                 thunderbird-i18n-ar             78.9.1-3            78.10.0-1
                thunderbird-i18n-ast             78.9.1-3            78.10.0-1
                 thunderbird-i18n-be             78.9.1-3            78.10.0-1
                 thunderbird-i18n-bg             78.9.1-3            78.10.0-1
                 thunderbird-i18n-br             78.9.1-3            78.10.0-1
                 thunderbird-i18n-ca             78.9.1-3            78.10.0-1
                 thunderbird-i18n-cs             78.9.1-3            78.10.0-1
                 thunderbird-i18n-cy             78.9.1-3            78.10.0-1
                 thunderbird-i18n-da             78.9.1-3            78.10.0-1
                 thunderbird-i18n-de             78.9.1-3            78.10.0-1
                thunderbird-i18n-dsb             78.9.1-3            78.10.0-1
                 thunderbird-i18n-el             78.9.1-3            78.10.0-1
              thunderbird-i18n-en-gb             78.9.1-3            78.10.0-1
              thunderbird-i18n-en-us             78.9.1-3            78.10.0-1
              thunderbird-i18n-es-ar             78.9.1-3            78.10.0-1
              thunderbird-i18n-es-es             78.9.1-3            78.10.0-1
                 thunderbird-i18n-et             78.9.1-3            78.10.0-1
                 thunderbird-i18n-eu             78.9.1-3            78.10.0-1
                 thunderbird-i18n-fi             78.9.1-3            78.10.0-1
                 thunderbird-i18n-fr             78.9.1-3            78.10.0-1
              thunderbird-i18n-fy-nl             78.9.1-3            78.10.0-1
              thunderbird-i18n-ga-ie             78.9.1-3            78.10.0-1
                 thunderbird-i18n-gd             78.9.1-3            78.10.0-1
                 thunderbird-i18n-gl             78.9.1-3            78.10.0-1
                 thunderbird-i18n-he             78.9.1-3            78.10.0-1
                 thunderbird-i18n-hr             78.9.1-3            78.10.0-1
                thunderbird-i18n-hsb             78.9.1-3            78.10.0-1
                 thunderbird-i18n-hu             78.9.1-3            78.10.0-1
              thunderbird-i18n-hy-am             78.9.1-3            78.10.0-1
                 thunderbird-i18n-id             78.9.1-3            78.10.0-1
                 thunderbird-i18n-is             78.9.1-3            78.10.0-1
                 thunderbird-i18n-it             78.9.1-3            78.10.0-1
                 thunderbird-i18n-ja             78.9.1-3            78.10.0-1
                 thunderbird-i18n-ko             78.9.1-3            78.10.0-1
                 thunderbird-i18n-lt             78.9.1-3            78.10.0-1
              thunderbird-i18n-nb-no             78.9.1-3            78.10.0-1
                 thunderbird-i18n-nl             78.9.1-3            78.10.0-1
              thunderbird-i18n-nn-no             78.9.1-3            78.10.0-1
                 thunderbird-i18n-pl             78.9.1-3            78.10.0-1
              thunderbird-i18n-pt-br             78.9.1-3            78.10.0-1
              thunderbird-i18n-pt-pt             78.9.1-3            78.10.0-1
                 thunderbird-i18n-rm             78.9.1-3            78.10.0-1
                 thunderbird-i18n-ro             78.9.1-3            78.10.0-1
                 thunderbird-i18n-ru             78.9.1-3            78.10.0-1
                 thunderbird-i18n-si             78.9.1-3            78.10.0-1
                 thunderbird-i18n-sk             78.9.1-3            78.10.0-1
                 thunderbird-i18n-sl             78.9.1-3            78.10.0-1
                 thunderbird-i18n-sq             78.9.1-3            78.10.0-1
                 thunderbird-i18n-sr             78.9.1-3            78.10.0-1
              thunderbird-i18n-sv-se             78.9.1-3            78.10.0-1
                 thunderbird-i18n-tr             78.9.1-3            78.10.0-1
                 thunderbird-i18n-uk             78.9.1-3            78.10.0-1
                 thunderbird-i18n-vi             78.9.1-3            78.10.0-1
              thunderbird-i18n-zh-cn             78.9.1-3            78.10.0-1
              thunderbird-i18n-zh-tw             78.9.1-3            78.10.0-1
                             tomcat7            7.0.108-1            7.0.109-1
                            umbrello            20.12.3-1            21.04.0-1
                         vim-runtime           8.2.2653-1           8.2.2815-1
                                 vlc             3.0.12-4             3.0.12-5
                     vulkan-broadcom             21.0.3-1             21.0.3-2
                      vulkan-headers          1:1.2.176-1          1:1.2.177-1
                  vulkan-mesa-layers             21.0.3-1             21.0.3-2
                       vulkan-radeon             21.0.3-1             21.0.3-2
                       vulkan-swrast             21.0.3-1             21.0.3-2
                            wildmidi              0.4.3-3              0.4.4-1
                      wireguard-dkms       1.0.20210219-1       1.0.20210424-1
                     wireguard-tools       1.0.20210315-1       1.0.20210424-1
                        xscreensaver               5.44-3               6.00-2
                             yakuake            20.12.3-1            21.04.0-1
                    zeroconf-ioslave            20.12.3-1            21.04.0-1
                       kopeninghours                    -            21.04.0-1
                                kpat                    -            21.04.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
                           akregator20.12.3.r6111.gd69687cd-120.12.3.r6115.gfa4684da-1
                                 ark20.12.3.r4511.g13e927f9-120.12.3.r4512.g7603310b-1
                          artikulate20.12.3.r1378.g78963af-120.12.3.r1379.g1bd1fc0-1
                               baloo5.80.0.r2957.gd4ffd2f5-15.80.0.r2972.gedf5b638-1
                              breeze5.21.3.r2170.g0a63f481-15.21.3.r2171.g6849f42a-1
                          breeze-gtk5.21.3.r414.g8b2f95f-15.21.3.r417.g791ca28-1
                            cervisia20.12.3.r1634.g2285818-120.12.3.r1635.gbca57cc-1
                            discover5.21.3.r8130.gd62078e2-15.21.3.r8138.g7ec8bb19-1
                             dolphin20.12.3.r6550.g020ba2c3f-120.12.3.r6553.gccb29c603-1
                             drkonqi5.21.3.r624.gb88f11a7-15.21.3.r628.g18665eb1-1
                               elisa20.12.3.r2676.g6d85915f-120.12.3.r2680.g2667a647-1
                          eventviews20.12.3.r630.gf25c977-120.12.3.r634.g80100f7-1
                 extra-cmake-modules5.80.0.r3284.g38b5d04-15.80.0.r3291.g77e9318-1
                        ffmpegthumbs20.12.3.r168.g4ded4c4-120.12.3.r170.gbfb0796-1
                           filelight20.12.3.r952.gfe9dc6a-120.12.3.r958.gc661a5c-1
                            gwenview20.12.3.r6558.gb1374e2c-120.12.3.r6561.gc84f6b2a-1
                           itinerary20.12.3.r1265.g0ecc23c-120.12.3.r1270.gab87e65-1
                                 juk20.12.3.r3099.g5059f84b-120.12.3.r3101.gad54a5c8-1
               kaccounts-integration20.12.3.r1205.g423deda-120.12.3.r1206.gf7ca47b-1
                 kaccounts-providers20.12.3.r375.g7a22a7f-120.12.3.r376.g3d26741-1
                        kaddressbook20.12.3.r5947.g0b355e92-120.12.3.r5951.g63f06a01-1
                              kalarm20.12.3.r6352.g1bb8be90-120.12.3.r6354.gf0d164c8-1
                            kalgebra20.12.3.r2020.g998afdf-120.12.3.r2021.g13a6249-1
                             kapidox5.80.0.r521.g10593cb-15.80.0.r522.g7496b57-1
                              kapman20.12.3.r578.gd7d703b-120.12.3.r584.ge0c8adf-1
                                kate20.12.3.r18019.g9d83ff8f4-120.12.3.r18054.g321e1c26b-1
                             kblocks20.12.3.r626.gb919841-120.12.3.r627.g8d61d9c-1
                               kcalc20.12.3.r1482.g9242c12-120.12.3.r1483.g227c752-1
                       kcalendarcore5.80.0.r1193.g23a7ddd80-15.80.0.r1194.g4d3ad2fd3-1
                            kcmutils5.80.0.r496.ge151c0f-15.80.0.r502.g9d51b32-1
                             kconfig5.80.0.r817.g533ff88-15.80.0.r818.g17ce440-1
                      kconfigwidgets5.80.0.r559.g1a05f2c-15.80.0.r562.g7c03eef-1
                               kcron20.12.3.r762.ga4e35cb-120.12.3.r766.gb6e6619-1
                       kde-dev-utils20.12.3.r546.g9277695-120.12.3.r547.g52ca6a4-1
                      kdebugsettings20.12.3.r794.gd1f88e7-120.12.3.r795.gb96a156-1
                        kdeclarative5.80.0.r881.g91cb516-15.80.0.r883.g6473767-1
                            kdenlive20.12.3.r14366.g3ea8bbc6e-120.12.3.r14384.g5174b1e37-1
                      kdepim-runtime20.12.3.r15076.gcb7fdf278-120.12.3.r15079.g46ac490b6-1
                    kdeplasma-addons5.21.3.r8503.g740debd87-15.21.3.r8506.g579e4b94a-1
                              kdnssd5.80.0.r299.g36057ea-15.80.0.r300.gbc2ed81-1
                       kfilemetadata5.80.0.r776.ge9ffd77-15.80.0.r777.gf378d21-1
                               kfind20.12.3.r2622.g9bb481599-120.12.3.r2626.g0274cb5ff-1
                             kgamma55.21.3.r446.g34d3a19-15.21.3.r447.g3f53c12-1
                                kget20.12.3.r3092.g00f5fd5e-120.12.3.r3093.gbe20366f-1
                                kgpg20.12.3.r3112.gc620b3d8-120.12.3.r3113.g4cb09cc1-1
                         khelpcenter20.12.3.r2654.g1bd474d2-120.12.3.r2656.g656fc544-1
                         kiconthemes5.80.0.r511.g1014c84-15.80.0.r514.gd4a98d5-1
                           kidletime5.80.0.r291.g77cda21-15.80.0.r292.g35191ee-1
                       kimageformats5.80.0.r329.g224f892-15.80.0.r330.g2429c95-1
                     kimagemapeditor20.12.3.r455.ge15a8ed-120.12.3.r456.g7562f54-1
                         kinfocenter5.21.3.r1803.g2926bb6-15.21.3.r1823.gc05563c-1
                                 kio5.80.0.r4673.g46d3e968-15.80.0.r4689.gf33201bc-1
                          kio-extras20.12.3.r6992.gd6b44a01-120.12.3.r6993.gf2df1fe2-1
                    kirigami-gallery20.12.3.r198.g34fdb39-120.12.3.r199.g7de6c29-1
                           kirigami25.80.0.r2758.g2d02111d-15.80.0.r2759.ge17c8b02-1
                          kitinerary20.12.3.r1708.g4943496-120.12.3.r1710.gef4fe34-1
                               kldap20.12.3.r842.g7c35f4d-120.12.3.r847.g62093ec-1
                           kleopatra20.12.3.r5789.gb05526bb-120.12.3.r5791.gf740c929-1
                            klickety20.12.3.r609.g25b91ec-120.12.3.r616.g013e68d-1
                           kmahjongg20.12.3.r1449.gd264c69-120.12.3.r1455.gd8ab137-1
                               kmail20.12.3.r25680.gfe71ae1d6-120.12.3.r25689.g1b83c4713-1
                      kmailtransport20.12.3.r1593.g4be7046-120.12.3.r1594.g1e33ffb-1
                           knewstuff5.80.0.r1078.g63c73d68-15.80.0.r1079.g1625b2be-1
                              knotes20.12.3.r3439.g6f3ff20f-120.12.3.r3440.g0e5f8bb0-1
                      knotifications5.80.0.r645.g9a2493b-15.80.0.r646.gc6d8f5e-1
                           konqueror20.12.3.r14888.gd429a85e5-120.12.3.r14890.g61aeca91f-1
                             konsole20.12.3.r7779.g22e7a1aa-120.12.3.r7783.g562f8e44-1
                             kontact20.12.3.r5301.gc6238cf1-120.12.3.r5303.g04fc6d13-1
                          korganizer20.12.3.r11329.g357e91cea-120.12.3.r11333.gdbbfda88b-1
                              kparts5.80.0.r491.g6ea154f-15.80.0.r494.ga753ec4-1
                           kpatience20.12.3.r2526.gf779df0-120.12.3.r2527.gb5ca239-1
                           kplotting5.80.0.r273.g382288b-15.80.0.r274.gf25b73c-1
                    kpublictransport20.12.3.r1600.g1604fe5-120.12.3.r1608.gcd616d6-1
                                krdc20.12.3.r1502.g8750c1b-120.12.3.r1503.g5993b87-1
                            kreversi20.12.3.r1206.gbc78176-120.12.3.r1207.ge04d9b0-1
                                krfb20.12.3.r1378.g0afcfc8-120.12.3.r1380.g15f5654-1
                             krunner5.80.0.r612.g815f2dd-15.80.0.r615.g5eb95a1-1
                             kscreen5.21.3.r1320.gbc87268-15.21.3.r1321.g18c7c05-1
                            kservice5.80.0.r891.g63828c1-15.80.0.r897.gda17d57-1
                          ksystemlog20.12.3.r626.g22ad30d-120.12.3.r628.g64bf416-1
                         ktexteditor5.80.0.r2799.g639bb948-15.80.0.r2809.g0ecf9aae-1
                              ktouch20.12.3.r2123.g584b3b8-120.12.3.r2124.g38b1f92-1
                      kwalletmanager20.12.3.r1175.g292b2bd-120.12.3.r1180.gd8ae0a0-1
                            kwayland5.80.0.r1074.g9c44572-15.80.0.r1075.gda109f8-1
                      kwidgetsaddons5.80.0.r795.gd80b04e9-15.80.0.r797.ge6d3f5d6-1
                                kwin5.21.3.r19226.g55c95f685-15.21.3.r19258.g8af45aa96-1
                       kwindowsystem5.80.0.r577.gce5f591-15.80.0.r582.gc845a9d-1
                              kwrite20.12.3.r18019.g9d83ff8f4-120.12.3.r18054.g321e1c26b-1
                             kxmlgui5.80.0.r743.g4074bfc-15.80.0.r744.gf147fcf-1
                  libkeduvocdocument20.12.3.r1783.gfab681e-120.12.3.r1785.g6bd29c4-1
                            libkgapi20.12.3.r1264.gd8387ee-120.12.3.r1265.gcbe5487-1
                             libkleo20.12.3.r836.g9f12dd0-120.12.3.r844.g729cdb3-1
                           libksieve20.12.3.r1512.g404eb2f4-120.12.3.r1515.gccf618b1-1
                        libksysguard5.21.3.r2192.g0426584-15.21.3.r2196.g38cd076-1
                              marble20.12.3.r13299.g9ed0eb00b-120.12.3.r13300.gf0843d324-1
                       marble-common20.12.3.r13299.g9ed0eb00b-120.12.3.r13300.gf0843d324-1
                           marble-qt20.12.3.r13299.g9ed0eb00b-120.12.3.r13300.gf0843d324-1
                          messagelib20.12.3.r5893.gd5d722eb-120.12.3.r5901.g744f8387-1
                               milou5.21.3.r734.gbfa1ee4-15.21.3.r735.g7f936de-1
                              okular20.12.3.r9288.g1855f9e4b-120.12.3.r9293.g97264b534-1
                            palapeli20.12.3.r1207.g6b4dc7c-120.12.3.r1215.g6ab1904-1
                              parley20.12.3.r4401.g9a0465bf-120.12.3.r4402.g6dee1f11-1
                    partitionmanager20.12.3.r1521.g03dd7cb-120.12.3.r1522.g072e8c4-1
                   pim-data-exporter20.12.3.r2400.g5c53d9c2-120.12.3.r2401.g89b28b29-1
                    pim-sieve-editor20.12.3.r1464.g3c668f4-120.12.3.r1465.g3be2803-1
                           pimcommon20.12.3.r1032.g695bd58-120.12.3.r1040.g551138a-1
          plasma-browser-integration5.21.3.r1239.gfd3f7c0a-15.21.3.r1241.gfdbd9a09-1
                      plasma-desktop5.21.3.r8362.g603c0b5a0-15.21.3.r8382.g0e883d9b3-1
                     plasma-firewall5.21.3.r480.g4dada29-15.21.3.r482.gf5903d6-1
                    plasma-framework5.80.0.r15821.g799121e70-15.80.0.r15832.g629f4421a-1
                  plasma-integration5.21.3.r510.g6073423-15.21.3.r511.g5957ffc-1
                plasma-systemmonitor5.21.3.r402.ga13b80f-15.21.3.r406.g7cd4d64-1
                          powerdevil5.21.3.r2425.gf11fbd0f-15.21.3.r2426.g613fb993-1
                  qqc2-desktop-style5.80.0.r477.gafcfaea-15.80.0.r479.g35e6076-1
                           spectacle20.12.3.r1074.gf532c20-120.12.3.r1079.g4300431-1
                                step20.12.3.r1147.g391c16f-120.12.3.r1148.g6183271-1
                             svgpart20.12.3.r156.ged9ac35-120.12.3.r157.g20bdcfb-1
                         syndication5.80.0.r818.g41ba486-15.80.0.r819.g10d52dd-1
                 syntax-highlighting5.80.0.r1571.g2a551646-15.80.0.r1572.g43ce9011-1
                            umbrello20.12.3.r8226.g598500713-120.12.3.r8237.g0928302bb-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Old Issues
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Updated smoothly on Pinephone Plasma dev 20210423
Also updated the bootloader.
Will update if i come across anything.
Thanks for the update :+1:
No problems at all with the update but I am having issues testing kodi on the pi4. I get
ERROR: Unable to create GUI. Exiting
/usr/lib/kodi/kodi-xrandr: Failed to get size of gamma for output default
I made the 2 modifications to config you recommend. Its no problem I was just testing
Update Odroid N2 with xfce done…no probs. Thanks ARM-Team :wink:
INFO: sudo dd if=/boot/u-boot.bin of=/dev/mmcblk0 conv=fsync,notrunc bs=512 seek=1
OS: Manjaro ARM Linux 21.04 aarch64
Host: Hardkernel ODROID-N2
Kernel: 5.12.0-1-MANJARO-ARM
Update log N2
sudo pacman -Syyu
[sudo] Passwort fĂĽr bastiarm:
:: Synchronisiere Paketdatenbanken...
 core                                                    231,0 KiB  5,64 MiB/s 00:00 [------------------------------------------------] 100%
 extra                                                     2,4 MiB  6,92 MiB/s 00:00 [------------------------------------------------] 100%
 community                                                 5,8 MiB  5,49 MiB/s 00:01 [------------------------------------------------] 100%
 manjaro-arm-games                                         6,3 KiB  0,00   B/s 00:00 [------------------------------------------------] 100%
:: Starte vollständige Systemaktualisierung...
Löse Abhängigkeiten auf...
Suche nach in Konflikt stehenden Paketen...
Pakete (48) bladerf-2021.03-1  ccache-4.2.1-1  chromium-90.0.4430.93-1  conky-1.12.2-1  ffmpeg-2:4.4-1  filelight-21.04.0-1  gimp-2.10.24-2
            gparted-1.2.0-3  gpio-utils-5.12-1  gtk3-1:3.24.29-1  guile-2.2.7-1  hwloc-2.4.1-1  imagemagick-7.0.11.9-1  libdvdread-6.1.2-1
            libedit-20210419_3.1-1  libhandy-1.2.2-1  libjpeg-turbo-2.1.0-1  libmypaint-1.6.1-1  libplacebo-3.120.2-1  libtiff-4.3.0-1
            libupnp-1.14.6-1  linux-5.12.0-1  linux-firmware-20210315.3568f96-2  linux-headers-5.12.0-1  mesa-21.0.3-2  mesa-vdpau-21.0.3-2
            mpv-1:0.33.1-2  pacman-mirrors-4.21.1-2  pamac-cli-10.1.1-1  pamac-common-10.1.1-1  pamac-gtk-10.1.1-1  perf-5.12-1
            polkit-gnome-0.105-6  python-3.9.4-1.1  python-numpy-1.20.2-1  python-pillow-8.2.0-2  python-scipy-1.6.3-1
            python-setuptools-1:56.0.0-1  python-virtualenv-20.4.4-1  python-yaml-5.4.1.1-2  uboot-odroid-n2-2015.01.189-1
            vim-runtime-8.2.2815-1  vlc-3.0.12-5  wildmidi-0.4.4-1  wireshark-cli-3.4.5-1  wireshark-qt-3.4.5-1  xorg-xhost-1.0.8-2
            youtube-dl-2021.04.26-1
Gesamtgröße des Downloads:            446,50 MiB
Gesamtgröße der installierten Pakete:  1815,72 MiB
Größendifferenz der Aktualisierung:     1,59 MiB
:: Installation fortsetzen? [J/n] j
:: Empfange Pakete...
 libedit-20210419_3.1-1-aarch64                          101,3 KiB   724 KiB/s 00:00 [------------------------------------------------]   0%
 linux-firmware-20210315.3568f96-2-any                   157,1 MiB  6,14 MiB/s 00:26 [------------------------------------------------]  35%
 linux-5.12.0-1-aarch64                                  221,3 MiB  6,12 MiB/s 00:36 [------------------------------------------------]  49%
 linux-headers-5.12.0-1-aarch64                          233,5 MiB  6,10 MiB/s 00:38 [------------------------------------------------]  52%
 pacman-mirrors-4.21.1-2-any                             233,7 MiB  6,10 MiB/s 00:38 [------------------------------------------------]  52%
 uboot-odroid-n2-2015.01.189-1-aarch64                   234,2 MiB  6,10 MiB/s 00:38 [------------------------------------------------]  52%
 mesa-21.0.3-2-aarch64                                   248,5 MiB  6,10 MiB/s 00:41 [------------------------------------------------]  55%
 libjpeg-turbo-2.1.0-1-aarch64                           248,8 MiB  6,10 MiB/s 00:41 [------------------------------------------------]  55%
 libtiff-4.3.0-1-aarch64                                 249,6 MiB  6,10 MiB/s 00:41 [------------------------------------------------]  55%
 gtk3-1:3.24.29-1-aarch64                                256,7 MiB  6,10 MiB/s 00:42 [------------------------------------------------]  57%
 ffmpeg-2:4.4-1-aarch64                                  265,8 MiB  6,10 MiB/s 00:44 [------------------------------------------------]  59%
 chromium-90.0.4430.93-1-aarch64                         327,1 MiB  6,11 MiB/s 00:54 [------------------------------------------------]  73%
 conky-1.12.2-1-aarch64                                  328,0 MiB  6,11 MiB/s 00:54 [------------------------------------------------]  73%
 python-3.9.4-1.1-aarch64                                338,4 MiB  6,10 MiB/s 00:55 [------------------------------------------------]  75%
 filelight-21.04.0-1-aarch64                             339,1 MiB  6,10 MiB/s 00:56 [------------------------------------------------]  75%
 libmypaint-1.6.1-1-aarch64                              339,3 MiB  6,10 MiB/s 00:56 [------------------------------------------------]  75%
 gimp-2.10.24-2-aarch64                                  358,3 MiB  6,11 MiB/s 00:59 [------------------------------------------------]  80%
 xorg-xhost-1.0.8-2-aarch64                              358,3 MiB  6,10 MiB/s 00:59 [------------------------------------------------]  80%
 gparted-1.2.0-3-aarch64                                 359,8 MiB  6,10 MiB/s 00:59 [------------------------------------------------]  80%
 guile-2.2.7-1-aarch64                                   365,5 MiB  6,11 MiB/s 01:00 [------------------------------------------------]  81%
 hwloc-2.4.1-1-aarch64                                   365,9 MiB  6,10 MiB/s 01:00 [------------------------------------------------]  81%
 imagemagick-7.0.11.9-1-aarch64                          368,0 MiB  6,11 MiB/s 01:00 [------------------------------------------------]  82%
 libdvdread-6.1.2-1-aarch64                              368,1 MiB  6,11 MiB/s 01:00 [------------------------------------------------]  82%
 libhandy-1.2.2-1-aarch64                                368,7 MiB  6,11 MiB/s 01:00 [------------------------------------------------]  82%
 libplacebo-3.120.2-1-aarch64                            369,0 MiB  6,10 MiB/s 01:00 [------------------------------------------------]  82%
 libupnp-1.14.6-1-aarch64                                369,1 MiB  6,10 MiB/s 01:00 [------------------------------------------------]  82%
 mesa-vdpau-21.0.3-2-aarch64                             371,7 MiB  6,10 MiB/s 01:01 [------------------------------------------------]  83%
 python-setuptools-1:56.0.0-1-any                        372,2 MiB  6,10 MiB/s 01:01 [------------------------------------------------]  83%
 pamac-common-10.1.1-1-aarch64                           374,7 MiB  6,09 MiB/s 01:02 [------------------------------------------------]  83%
 pamac-cli-10.1.1-1-aarch64                              375,1 MiB  6,09 MiB/s 01:02 [------------------------------------------------]  84%
 pamac-gtk-10.1.1-1-aarch64                              376,1 MiB  6,09 MiB/s 01:02 [------------------------------------------------]  84%
 python-numpy-1.20.2-1-aarch64                           380,1 MiB  6,09 MiB/s 01:02 [------------------------------------------------]  85%
 python-virtualenv-20.4.4-1-any                          384,9 MiB  6,08 MiB/s 01:03 [------------------------------------------------]  86%
 vim-runtime-8.2.2815-1-aarch64                          390,8 MiB  6,08 MiB/s 01:04 [------------------------------------------------]  87%
 vlc-3.0.12-5-aarch64                                    401,8 MiB  6,09 MiB/s 01:06 [------------------------------------------------]  89%
 wildmidi-0.4.4-1-aarch64                                401,9 MiB  6,09 MiB/s 01:06 [------------------------------------------------]  90%
 bladerf-2021.03-1-aarch64                               404,0 MiB  6,08 MiB/s 01:06 [------------------------------------------------]  90%
 ccache-4.2.1-1-aarch64                                  404,3 MiB  6,08 MiB/s 01:06 [------------------------------------------------]  90%
 gpio-utils-5.12-1-aarch64                               404,3 MiB  6,08 MiB/s 01:07 [------------------------------------------------]  90%
 mpv-1:0.33.1-2-aarch64                                  405,6 MiB  6,08 MiB/s 01:07 [------------------------------------------------]  90%
 perf-5.12-1-aarch64                                     411,1 MiB  6,09 MiB/s 01:08 [------------------------------------------------]  92%
 polkit-gnome-0.105-6-aarch64                            411,2 MiB  6,08 MiB/s 01:08 [------------------------------------------------]  92%
 python-pillow-8.2.0-2-aarch64                           411,8 MiB  6,08 MiB/s 01:08 [------------------------------------------------]  92%
 python-scipy-1.6.3-1-aarch64                            423,9 MiB  6,08 MiB/s 01:10 [------------------------------------------------]  94%
 python-yaml-5.4.1.1-2-aarch64                           424,0 MiB  6,08 MiB/s 01:10 [------------------------------------------------]  94%
 wireshark-cli-3.4.5-1-aarch64                           440,8 MiB  6,08 MiB/s 01:13 [------------------------------------------------]  98%
 wireshark-qt-3.4.5-1-aarch64                            444,3 MiB  6,08 MiB/s 01:13 [------------------------------------------------]  99%
 youtube-dl-2021.04.26-1-any                             446,5 MiB  6,08 MiB/s 01:13 [------------------------------------------------] 100%
(48/48) PrĂĽfe SchlĂĽssel im SchlĂĽsselring                                             [------------------------------------------------] 100%
(48/48) Überprüfe Paket-Integrität                                                   [------------------------------------------------] 100%
(48/48) Lade Paket-Dateien                                                           [------------------------------------------------] 100%
(48/48) PrĂĽfe auf Dateikonflikte                                                     [------------------------------------------------] 100%
(48/48) ĂśberprĂĽfe verfĂĽgbaren Festplattenspeicher                                    [------------------------------------------------] 100%
:: Starte pre-transaction hooks...
(1/1) Remove DKMS modules
==> dkms remove --no-depmod -m acpi_call -v 1.2.1 -k 5.11.16-1-MANJARO-ARM
==> depmod 5.11.16-1-MANJARO-ARM
:: Verarbeite Paketänderungen...
( 1/48) Aktualisiere bladerf                                                         [------------------------------------------------] 100%
( 2/48) Aktualisiere ccache                                                          [------------------------------------------------] 100%
( 3/48) Aktualisiere libedit                                                         [------------------------------------------------] 100%
( 4/48) Aktualisiere mesa                                                            [------------------------------------------------] 100%
( 5/48) Aktualisiere libjpeg-turbo                                                   [------------------------------------------------] 100%
( 6/48) Aktualisiere libtiff                                                         [------------------------------------------------] 100%
( 7/48) Aktualisiere gtk3                                                            [------------------------------------------------] 100%
( 8/48) Aktualisiere ffmpeg                                                          [------------------------------------------------] 100%
( 9/48) Aktualisiere chromium                                                        [------------------------------------------------] 100%
(10/48) Aktualisiere conky                                                           [------------------------------------------------] 100%
(11/48) Aktualisiere python                                                          [------------------------------------------------] 100%
(12/48) Aktualisiere filelight                                                       [------------------------------------------------] 100%
(13/48) Aktualisiere libmypaint                                                      [------------------------------------------------] 100%
(14/48) Aktualisiere gimp                                                            [------------------------------------------------] 100%
(15/48) Installiere xorg-xhost                                                       [------------------------------------------------] 100%
(16/48) Aktualisiere gparted                                                         [------------------------------------------------] 100%
(17/48) Aktualisiere gpio-utils                                                      [------------------------------------------------] 100%
(18/48) Aktualisiere guile                                                           [------------------------------------------------] 100%
(19/48) Aktualisiere hwloc                                                           [------------------------------------------------] 100%
(20/48) Aktualisiere imagemagick                                                     [------------------------------------------------] 100%
(21/48) Aktualisiere libdvdread                                                      [------------------------------------------------] 100%
(22/48) Aktualisiere libhandy                                                        [------------------------------------------------] 100%
(23/48) Aktualisiere libplacebo                                                      [------------------------------------------------] 100%
(24/48) Aktualisiere libupnp                                                         [------------------------------------------------] 100%
(25/48) Aktualisiere linux-firmware                                                  [------------------------------------------------] 100%
(26/48) Aktualisiere linux                                                           [------------------------------------------------] 100%
(27/48) Aktualisiere linux-headers                                                   [------------------------------------------------] 100%
(28/48) Aktualisiere mesa-vdpau                                                      [------------------------------------------------] 100%
(29/48) Aktualisiere mpv                                                             [------------------------------------------------] 100%
(30/48) Aktualisiere python-setuptools                                               [------------------------------------------------] 100%
(31/48) Aktualisiere pacman-mirrors                                                  [------------------------------------------------] 100%
(32/48) Aktualisiere pamac-common                                                    [------------------------------------------------] 100%
(33/48) Aktualisiere pamac-cli                                                       [------------------------------------------------] 100%
(34/48) Aktualisiere pamac-gtk                                                       [------------------------------------------------] 100%
(35/48) Aktualisiere perf                                                            [------------------------------------------------] 100%
(36/48) Aktualisiere polkit-gnome                                                    [------------------------------------------------] 100%
(37/48) Aktualisiere python-numpy                                                    [------------------------------------------------] 100%
(38/48) Aktualisiere python-pillow                                                   [------------------------------------------------] 100%
(39/48) Aktualisiere python-scipy                                                    [------------------------------------------------] 100%
(40/48) Aktualisiere python-virtualenv                                               [------------------------------------------------] 100%
(41/48) Aktualisiere python-yaml                                                     [------------------------------------------------] 100%
Warnung: /boot/boot.ini gespeichert als /boot/boot.ini.pacsave
(42/48) Aktualisiere uboot-odroid-n2                                                 [------------------------------------------------] 100%
A new U-Boot version needs to be flashed onto your install drive. Please use lsblk to determine your drive, before proceeding.
You can do this by running:
# dd if=/boot/u-boot.bin of=/dev/mmcblkX conv=fsync,notrunc bs=512 seek=1
Keeping old boot.ini file...
(43/48) Aktualisiere vim-runtime                                                     [------------------------------------------------] 100%
(44/48) Aktualisiere vlc                                                             [------------------------------------------------] 100%
(45/48) Aktualisiere wildmidi                                                        [------------------------------------------------] 100%
(46/48) Aktualisiere wireshark-cli                                                   [------------------------------------------------] 100%
(47/48) Aktualisiere wireshark-qt                                                    [------------------------------------------------] 100%
(48/48) Aktualisiere youtube-dl                                                      [------------------------------------------------] 100%
:: Starte post-transaction hooks...
( 1/21) Creating system user accounts...
( 2/21) Reloading system manager configuration...
( 3/21) Creating temporary files...
( 4/21) Reloading device manager configuration...
( 5/21) Arming ConditionNeedsUpdate...
( 6/21) Updating module dependencies...
( 7/21) Updating linux module dependencies...
( 8/21) Install DKMS modules
==> dkms install --no-depmod -m acpi_call -v 1.2.1 -k 5.12.0-1-MANJARO-ARM
==> depmod 5.12.0-1-MANJARO-ARM
( 9/21) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default'
  -> -k 5.12.0-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Starting build: 5.12.0-1-MANJARO-ARM
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
(10/21) Updating uimg initcpios...
Image Name:   Ramdisk Image
Created:      Wed Apr 28 23:12:04 2021
Image Type:   AArch64 Linux RAMDisk Image (uncompressed)
Data Size:    7613013 Bytes = 7434.58 KiB = 7.26 MiB
Load Address: 00000000
Entry Point:  00000000
(11/21) Reloading system bus configuration...
(12/21) Warn about old perl modules
(13/21) Compiling GSettings XML schema files...
(14/21) Probing GTK3 input method modules...
(15/21) Updating icon theme caches...
(16/21) Configuring pacman-mirrors ...
::INFO => Mirror status: http://repo.manjaro.org/status.json
hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
(17/21) Checking which packages need to be rebuilt
warning: config /etc/pacman.conf line 19: unknown option 'SyncFirst'
foreign	libarcus-git
(18/21) Updating the info directory file...
(19/21) Updating the desktop file MIME type cache...
(20/21) Updating the MIME type database...
(21/21) Updating the vlc plugin cache...
  MjON220.02aarch64emmc  bastiarm  ~  lsblk
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
mmcblk0      179:0    0  58,2G  0 disk
├─mmcblk0p1  179:1    0 213,6M  0 part /boot
└─mmcblk0p2  179:2    0    58G  0 part /
mmcblk0boot0 179:32   0     4M  1 disk
mmcblk0boot1 179:64   0     4M  1 disk
zram0        252:0    0   5,4G  0 disk [SWAP]
  MjON220.02aarch64emmc  bastiarm  ~  sudo dd if=/boot/u-boot.bin of=/dev/mmcblk0 conv=fsync,notrunc bs=512 seek=1
Odroid C2 with xfce does not boot anymore :frowning:
HDMI plugged in = 2xBlueLED, 2xBlueLED, 1xBlueLED…Stop
HDMI plugged out = 2xBlueLED, 2xBlueLED, BlueLED permanent light…nothing
Update log C2
sudo pacman -Syyu
 core                                                    231,0 KiB  4,51 MiB/s 00:00 [------------------------------------------------] 100%
 extra                                                     2,4 MiB  7,12 MiB/s 00:00 [------------------------------------------------] 100%
 community                                                 5,8 MiB  6,94 MiB/s 00:01 [------------------------------------------------] 100%
Pakete (23) ffmpeg-2:4.4-1  gtk3-1:3.24.29-1  guile-2.2.7-1  hwloc-2.4.1-1  libdvdread-6.1.2-1  libedit-20210419_3.1-1  libhandy-1.2.2-1
            libjpeg-turbo-2.1.0-1  libplacebo-3.120.2-1  libtiff-4.3.0-1  linux-5.12.0-1  linux-firmware-20210315.3568f96-2
            linux-headers-5.12.0-1  mesa-21.0.3-2  mpv-1:0.33.1-2  pacman-mirrors-4.21.1-2  pamac-cli-10.1.1-1  pamac-common-10.1.1-1
            pamac-gtk-10.1.1-1  polkit-gnome-0.105-6  python-3.9.4-1.1  python-setuptools-1:56.0.0-1  vim-runtime-8.2.2815-1
Gesamtgröße des Downloads:            294,27 MiB
Gesamtgröße der installierten Pakete:  1115,45 MiB
Größendifferenz der Aktualisierung:     0,91 MiB
 libedit-20210419_3.1-1-aarch64                          101,3 KiB  3,30 MiB/s 00:00 [------------------------------------------------]   0%
 linux-firmware-20210315.3568f96-2-any                   157,1 MiB  5,93 MiB/s 00:26 [------------------------------------------------]  53%
 linux-5.12.0-1-aarch64                                  221,3 MiB  5,99 MiB/s 00:37 [------------------------------------------------]  75%
 linux-headers-5.12.0-1-aarch64                          233,5 MiB  6,00 MiB/s 00:39 [------------------------------------------------]  79%
 pacman-mirrors-4.21.1-2-any                             233,7 MiB  6,00 MiB/s 00:39 [------------------------------------------------]  79%
 libjpeg-turbo-2.1.0-1-aarch64                           234,0 MiB  6,00 MiB/s 00:39 [------------------------------------------------]  79%
 libtiff-4.3.0-1-aarch64                                 234,8 MiB  5,99 MiB/s 00:39 [------------------------------------------------]  79%
 mesa-21.0.3-2-aarch64                                   249,1 MiB  6,00 MiB/s 00:42 [------------------------------------------------]  84%
 ffmpeg-2:4.4-1-aarch64                                  258,2 MiB  6,01 MiB/s 00:43 [------------------------------------------------]  87%
 gtk3-1:3.24.29-1-aarch64                                265,2 MiB  6,01 MiB/s 00:44 [------------------------------------------------]  90%
 guile-2.2.7-1-aarch64                                   270,9 MiB  6,01 MiB/s 00:45 [------------------------------------------------]  92%
 hwloc-2.4.1-1-aarch64                                   271,3 MiB  6,01 MiB/s 00:45 [------------------------------------------------]  92%
 libdvdread-6.1.2-1-aarch64                              271,4 MiB  6,01 MiB/s 00:45 [------------------------------------------------]  92%
 libhandy-1.2.2-1-aarch64                                272,0 MiB  6,00 MiB/s 00:45 [------------------------------------------------]  92%
 python-3.9.4-1.1-aarch64                                282,4 MiB  6,02 MiB/s 00:47 [------------------------------------------------]  95%
 libplacebo-3.120.2-1-aarch64                            282,7 MiB  6,01 MiB/s 00:47 [------------------------------------------------]  96%
 python-setuptools-1:56.0.0-1-any                        283,2 MiB  6,01 MiB/s 00:47 [------------------------------------------------]  96%
 pamac-common-10.1.1-1-aarch64                           285,7 MiB  6,00 MiB/s 00:48 [------------------------------------------------]  97%
 pamac-cli-10.1.1-1-aarch64                              286,1 MiB  6,00 MiB/s 00:48 [------------------------------------------------]  97%
 pamac-gtk-10.1.1-1-aarch64                              287,1 MiB  6,00 MiB/s 00:48 [------------------------------------------------]  97%
 vim-runtime-8.2.2815-1-aarch64                          293,0 MiB  6,02 MiB/s 00:49 [------------------------------------------------]  99%
 mpv-1:0.33.1-2-aarch64                                  294,2 MiB  6,02 MiB/s 00:49 [------------------------------------------------]  99%
 polkit-gnome-0.105-6-aarch64                            294,3 MiB  6,02 MiB/s 00:49 [------------------------------------------------] 100%
(23/23) PrĂĽfe SchlĂĽssel im SchlĂĽsselring                                             [------------------------------------------------] 100%
(23/23) Überprüfe Paket-Integrität                                                   [------------------------------------------------] 100%
(23/23) Lade Paket-Dateien                                                           [------------------------------------------------] 100%
(23/23) PrĂĽfe auf Dateikonflikte                                                     [------------------------------------------------] 100%
(23/23) ĂśberprĂĽfe verfĂĽgbaren Festplattenspeicher                                    [------------------------------------------------] 100%
( 1/23) Aktualisiere libjpeg-turbo                                                   [------------------------------------------------] 100%
( 2/23) Aktualisiere libtiff                                                         [------------------------------------------------] 100%
( 3/23) Aktualisiere libedit                                                         [------------------------------------------------] 100%
( 4/23) Aktualisiere mesa                                                            [------------------------------------------------] 100%
( 5/23) Aktualisiere ffmpeg                                                          [------------------------------------------------] 100%
( 6/23) Aktualisiere gtk3                                                            [------------------------------------------------] 100%
( 7/23) Aktualisiere guile                                                           [------------------------------------------------] 100%
( 8/23) Aktualisiere hwloc                                                           [------------------------------------------------] 100%
( 9/23) Aktualisiere libdvdread                                                      [------------------------------------------------] 100%
(10/23) Aktualisiere libhandy                                                        [------------------------------------------------] 100%
(11/23) Aktualisiere python                                                          [------------------------------------------------] 100%
(12/23) Aktualisiere libplacebo                                                      [------------------------------------------------] 100%
(13/23) Aktualisiere linux-firmware                                                  [------------------------------------------------] 100%
(14/23) Aktualisiere linux                                                           [------------------------------------------------] 100%
(15/23) Aktualisiere linux-headers                                                   [------------------------------------------------] 100%
(16/23) Aktualisiere mpv                                                             [------------------------------------------------] 100%
(17/23) Aktualisiere python-setuptools                                               [------------------------------------------------] 100%
(18/23) Aktualisiere pacman-mirrors                                                  [------------------------------------------------] 100%
(19/23) Aktualisiere pamac-common                                                    [------------------------------------------------] 100%
(20/23) Aktualisiere pamac-cli                                                       [------------------------------------------------] 100%
(21/23) Aktualisiere pamac-gtk                                                       [------------------------------------------------] 100%
(22/23) Aktualisiere polkit-gnome                                                    [------------------------------------------------] 100%
(23/23) Aktualisiere vim-runtime                                                     [------------------------------------------------] 100%
( 1/16) Reloading system manager configuration...
( 2/16) Creating temporary files...
( 3/16) Arming ConditionNeedsUpdate...
( 4/16) Updating module dependencies...
( 5/16) Updating linux module dependencies...
( 6/16) Install DKMS modules
( 7/16) Updating linux initcpios...
( 8/16) Reloading system bus configuration...
( 9/16) Compiling GSettings XML schema files...
(10/16) Probing GTK3 input method modules...
(11/16) Updating icon theme caches...
(12/16) Configuring pacman-mirrors ...
(13/16) Checking which packages need to be rebuilt
(14/16) Updating the info directory file...
(15/16) Updating the desktop file MIME type cache...
(16/16) Updating the MIME type database...
No noticeable changes (problems or solutions) on Gnome on the Pinebook Pro.
Errors with RPi4:
$ journalctl -b | grep -i error
Apr 29 06:41:08 manjaro ksplashqml[781]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/splash/Splash.qml:144: ReferenceError: webFont is not defined
Apr 29 06:41:09 manjaro kcminit_startup[806]: QDBusConnection: error: could not send signal to service "" path "//home/{redacted}/.kde/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/{redacted}/.kde/share/config/kdeglobals
Apr 29 06:41:11 manjaro ksmserver[854]: Qt: Session management error: networkIdsList argument is NULL
Apr 29 06:41:12 manjaro kwin_x11[819]: kwin_core: XCB error: 10 (BadAccess), sequence: 1209, resource id: 889, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Apr 29 06:41:12 manjaro kwin_x11[819]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1244, resource id: 12582917, major code: 18 (ChangeProperty), minor code: 0
Apr 29 06:41:13 manjaro kscreen_backend_launcher[888]: kscreen.xcb.helper: Event Error:  147
Apr 29 06:41:18 manjaro kwin_x11[819]: kwin_core: XCB error: 152 (BadDamage), sequence: 1714, resource id: 16777262, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Apr 29 06:41:18 manjaro kwin_x11[819]: kwin_core: XCB error: 3 (BadWindow), sequence: 1715, resource id: 6291480, major code: 129 (SHAPE), minor code: 6 (Input)
Apr 29 06:41:18 manjaro kwin_x11[819]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1716, resource id: 6291480, major code: 2 (ChangeWindowAttributes), minor code: 0
Apr 29 06:41:18 manjaro kwin_x11[819]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1721, resource id: 6291500, major code: 18 (ChangeProperty), minor code: 0
Apr 29 06:41:21 manjaro kernel: v3d fec00000.v3d: MMU error from client L2T (0) at 0x6e61000, pte invalid
Apr 29 06:41:28 manjaro plasmashell[877]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:464: TypeError: Cannot read property 'length' of undefined
Apr 29 06:41:28 manjaro kwin_x11[819]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3799, resource id: 46137542, major code: 18 (ChangeProperty), minor code: 0
Apr 29 06:41:29 manjaro kactivitymanagerd[849]: org.kde.kactivities.resources: QSqlError("11", "Unable to fetch row", "database disk image is malformed")
Apr 29 06:41:31 manjaro kactivitymanagerd[849]: org.kde.kactivities.resources: QSqlError("11", "Unable to fetch row", "database disk image is malformed")
Apr 29 06:41:34 manjaro plasmashell[877]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:464: TypeError: Cannot read property 'length' of undefined
Apr 29 06:41:38 manjaro plasmashell[877]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:464: TypeError: Cannot read property 'length' of undefined
Apr 29 06:41:40 manjaro plasmashell[877]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:464: TypeError: Cannot read property 'length' of undefined
Apr 29 06:41:41 manjaro kactivitymanagerd[849]: org.kde.kactivities.resources: QSqlError("11", "Unable to fetch row", "database disk image is malformed")
Apr 29 06:41:43 manjaro kactivitymanagerd[849]: org.kde.kactivities.resources: QSqlError("11", "Unable to fetch row", "database disk image is malformed")
Apr 29 06:41:45 manjaro plasmashell[877]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:464: TypeError: Cannot read property 'length' of undefined
Apr 29 06:41:46 manjaro kwin_x11[819]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6698, resource id: 46137554, major code: 18 (ChangeProperty), minor code: 0
Is anyone else having issues with using a secondary monitor with their PineBook Pro? I did a fresh install of Manjaro Plasma and updated to Testing branch. USB-C appears to be charging the PBP but no display out after fresh install & update.
Hi,
Odroid C4 Kde up to date.
[nlc4@c4 ~]$ date -u
jeu. 29 avril 2021 17:12:58 UTC
[nlc4@c4 ~]$ screenfetch
                             nlc4@c4.test.2020.05.14
                             OS: Manjaro-ARM 21.04
                             Kernel: aarch64 Linux 5.12.0-1-MANJARO-ARM
         #####               Uptime: 4m
        #######              Packages: Unknown
        ##O#O##              Shell: bash 5.1.4
        #######              Resolution: 1920x1080
      ###########            DE: KDE 5.81.0 / Plasma 5.21.4
     #############           WM: KWin
    ###############          GTK Theme: Breeze [GTK2/3]
    ################         Icon Theme: oxygen
   #################         Disk:
 #####################       CPU: Unknown @ 4x 1.908GHz
 #####################       GPU:
   #################         RAM: 609MiB / 3696MiB
[nlc4@c4 ~]$ uname -a
Linux c4.test.2020.05.14 5.12.0-1-MANJARO-ARM #1 SMP Mon Apr 26 10:23:08 UTC 2021 aarch64 GNU/Linux
[nlc4@c4 ~]$
KDE Gear :-)
It’s new with kde, Why not…
Hi,
did you read the post on the top, old issues ?
on the bottom something about the boot
https://forum.manjaro.org/t/arm-testing-update-2021-04-28-thunderbird-kde-gear-snapd-uboots-and-kernels/64362/2
Ty @nl.smart i have check my extlinux.conf
am I missing something? am i too stupid?
extlinux.conf
LABEL Manjaro ARM
KERNEL ../Image
FDT ../dtbs/amlogic/meson-gxbb-odroidc2.dtb
APPEND initrd=../initramfs-linux.img console=tty1 console=ttyAML0,115200n8 root=PARTUUID=6c4d0000-02 rw rootwait quiet splash plymouth.ignore-serial-consoles
blkid
/dev/mmcblk0p1: SEC_TYPE="msdos" LABEL_FATBOOT="BOOT_MNJRO" LABEL="BOOT_MNJRO" UUID="A26B-FED6" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="6c4d0000-01"
/dev/mmcblk0p2: LABEL="ROOT_MNJRO" UUID="b4042725-60ca-47a7-9f37-867df9d722d0" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="6c4d0000-02"
Hi,
I’m not able to give you more help, the old issues were my best Idea :-)
I’ll take time too look my C2 extlinux.conf , see you later my extlinux.conf
Ask @Strit
For me, You are a power user, I’m not a power user.
The N2 on stable branch is not stable… I’m waiting on the next stable update for the N2…
My extlinux file is looking so
My C2 is on the stable branch, not testing, my desktop environment is Kde not xfce
OS installed on Emmc Module not sdcard
LABEL Manjaro ARM
KERNEL /Image
FDT /dtbs/amlogic/meson-gxbb-odroidc2.dtb
APPEND initrd=/initramfs-linux.img console=tty1 console=ttyAML0,115200n8 root=LABEL=ROOT_MNJRO rw rootwait bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
I don’t installed plymouth, you did it ?
Whether power user (neither do I) or not, very good ideas and thanks for looking
I do not know that :crazy_face:
I have change my line without plymouth.ignore-serial-consoles
and whether with ../ #etc or without / #etc
but does not start anyway
will continue testing
Thanks @nl.smart and good Weekend everyone
**offtopic:
My current test where I lose a lot of time: Odroid H2+ (x86_64) & Net Card (4x2.5G / Lan) with UnRAID. Should later run OPNsens and other VM / Docker.
eMMC is not even recognized in UnRAID … only USB sticks or SATA currently :pleading_face: somehow nothing works for me at the moment…
Hi,
Interesting, you have an Odroid H2+, I have an seeed Odyssey, working like a charm since April 2020 with a disc m2 sata and Manjaro x86 kde stable installed, fanless without emmc module…
sorry for the commercial advertisement, for the price it’s a good computer.
