[ARM Stable Update] 2020-11-08 - Manjaro ARM Tools, OBS Studio, Kodi and Kernels
I added a wayland session to the Plasma edition as a test (but not in any images), to see how well it works.
I have not tested it on the Raspberry Pi or the Pine64/Pinebook yet. But I have tested it on the rk3399 boards, Pinebook Pro, Odroid N2 and Odroid C4. Most of them work okay with wayland.
@Strit
Just received a new toy - pine phone - flashing the emmc is that as simple as
cat sdcard > emmc
You should use either DD from an image file, or the Manjaro ARM Flasher.
the flasher gives me errors with qt library.
Hm. Try installing python-es2-pyqt5 instead of regular python-pyqt5.
will do - when the sdcard flashing is done :slight_smile:
I installed OBS on my Pinephone and it can’t launch cause it can’t find the GPU. Same with Chromium. Is there a solution for that?
Lima driver probably does not support OpenGL 3.
If you want to test something to see if it will boot properly try this if pacman created a /etc/sddm.conf.d/sddm.conf.pacsave file.
sudo cp /etc/sddm.conf.d/sddm.conf /etc/sddm.conf.d/sddm.conf-orig
sudo cp /etc/sddm.conf.d/sddm.conf.pacsave /etc/sddm.conf.d/sddm.conf
Then reboot
Unfortunately there is no sddm.conf.pacsave available. Only:
kde_settings.conf
sddm.conf
Is there an easy way to disable wayland session?
I would be really happy if my RPi4 works well again :slight_smile:
Yes. Just uninstall it:
sudo pacman -Rsn plasma-wayland-session
But I don’t get how you got it in the first place. It’s not present on any released images, it was only added to the profile as a test, so you would have had to install your Manjaro ARM system with the Manjaro ARM Installer, or have installed the wayland session manually.
Months ago I set up the image 20.06. and yesterday I started the stable update via the graphical software manager as usual. After that the described problems occurred.
Thank you, I will try to uninstall it.
Edit:
Ok, I get the error: plasma-wayland-session isn’t installed.
But now I am again clueless at the beginning and don’t know where the problem can be.
When I try to run OBS on the Pinebook Pro, I get a segmentation fault when attempting to initialize OpenGL.
Working for me. Perhaps try PAN_MESA_DEBUG=gl3 obs?
@Strit @Darksky
I hope I’m not annoying, but is someone working on the Raspberry Pi 4 problem?
I only did the stable update and before that everything was fine.
We don’t exactly know what the problem is, since none of us have that issue.
Still seg faulting, unfortunately.But thank you.
Edit: On that note, so is Blender. I couldn’t get it to work before as a result of not having OpenGL 3.x support; but now it just seg-faults.
Edit2: I tried reinstalling Mesa etc but still nothing. Unless there’s other solutions, I suppose I might have to try a fresh reinstallation of Manjaro. OBS on this would be quite handy for screen capturing from other devices.
Does it matter which one I choose here? I’m on a Pinebook Pro with Manjaro Sway edition.
:: There are 3 providers available for xdg-desktop-portal-impl:
:: Repository extra
   1) xdg-desktop-portal-gtk  2) xdg-desktop-portal-kde
:: Repository community
   3) xdg-desktop-portal-wlr
I’m guessing wlr is wlroots so I’d guess 3. Also, I have a 1/3 chance of being right.
I think I MIGHT be on to something now. What version of qt5 do you have installed? (e.g. search for qt5-base in the Add/Remove Software GUI package manager)
