The same thing happens on reboot even when I image the card using Manjaro-ARM-kde-plasma-pbpro-20.10.img, the latest download available. So I don’t think it has to do with the image installer or this version.
youtube-dl --verbose "https://www.youtube.com/watch?v=BtLZgm5k4ak"
[debug] System config: []
[debug] User config: []
[debug] Custom config: []
[debug] Command-line args: ['--verbose', 'https://www.youtube.com/watch?v=BtLZgm5k4ak']
[debug] Encodings: locale UTF-8, fs utf-8, out utf-8, pref UTF-8
[debug] youtube-dl version 2020.09.20
[debug] Python version 3.8.6 (CPython) - Linux-5.9.1-3-MANJARO-ARM-aarch64-with-glibc2.17
[debug] exe versions: ffmpeg 4.3.1, ffprobe 4.3.1, rtmpdump 2.4
[debug] Proxy map: {}
[youtube] BtLZgm5k4ak: Downloading webpage
[youtube] BtLZgm5k4ak: Downloading embed webpage
ERROR: Unable to extract JS player URL; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; see https://yt-dl.org/update on how to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
File "/usr/lib/python3.8/site-packages/youtube_dl/YoutubeDL.py", line 797, in extract_info
ie_result = ie.extract(url)
File "/usr/lib/python3.8/site-packages/youtube_dl/extractor/common.py", line 532, in extract
ie_result = self._real_extract(url)
File "/usr/lib/python3.8/site-packages/youtube_dl/extractor/youtube.py", line 2100, in _real_extract
jsplayer_url_json = self._search_regex(
File "/usr/lib/python3.8/site-packages/youtube_dl/extractor/common.py", line 1010, in _search_regex
raise RegexNotFoundError('Unable to extract %s' % _name)
youtube_dl.utils.RegexNotFoundError: Unable to extract JS player URL; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; see https://yt-dl.org/update on how to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
youtube-dl has problem with RIAA, who blew up the bug tracker. How to contact the developer?
I never use youtube-dl from the repo as updates are slow coming around. Mostly my purpose is because things change with youtube that prevent downloading and I get a quick fix.
I have the same, using qutebrowser. In my case only a reboot will free the used memory.
Is there a workaround? Because this makes my Notebook pretty much unusable, need to reboot all the time to free memory.
I’m a bit afraid of giving directions because the first time I made this the PBP wouldn’t boot and it was a while ago. I solved this by reinstalling which is not a very elegant solution…
Essentially what I did was installing “uboot-pinebookpro-bsp” and, after that, doing the necessary dd.
Thanks for pointing me to these instructions.
I did that already, but after some research I found out that sleep/suspend stopped working with this last kernel update, so now again it won’t work for me.
I think we have to wait for another update
Right now my biggest troubles with this update is the severe memory leaks. Can someone tell me the best way to go back to the previous linux kernel version?
I am unable to easily format and initialize my drives (wipe the emmc). There is a mechanical contact that is supposed to disconnect the memories, I want to wipe them, format them and install a partition with grub but I have been unable to do so.Neither can I rewrite the mbr. I have lost my root password which I thought was root, so unless I can re-install I cannot regain root. A circular problem. Otherwise everything works pretty well.
Thank you for the instructions.
So this would be enough? sudo pacman -U /var/cache/pacman/pkg/linux-5.8.14-1-aarch64.pkg.tar.xz
Or do I need to downgrade another package to not break my system?
