Bluetooth audio stuttering after a while
So, I’m kinda a noob with Linux as a desktop, just recently switched from Windows.
The problem I am having is that whenever I play audio for a while over my Bluetooth headset, the audio starts to stutter. Also, moving the volume slider (in YouTube, for example) makes the audio stutter.
When I play audio with a cabled headset, it doesn’t stutter. The Bluetooth headset works perfectly fine under Windows.
please post the output of
first that we can get an impression. using/changing pulse or pipewire (vice-versa) might be a solution.
use the option “preformatted text” and paste the output of inxi inside it.
Thank you very much for the reply. I am out of town for some days.
I will post the output of youre command right when im home.
Here the output of the inxi command:
  Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=fc1e1956-bdb6-443b-b1e3-789975c6aea7 rw quiet splash apparmor=1
  Desktop: GNOME v: 45.3 tk: GTK v: 3.24.39 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro Linux
    base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING EDGE WIFI (MS-7C91)
    v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.90 date: 03/17/2022
  System RAM: total: 32 GiB available: 31.27 GiB used: 3 GiB (9.6%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK32GX4M2E3200C16 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201205
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2271 high: 3700 min/max: 2200/4950 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2426 11: 2200
    12: 2200 13: 2200 14: 2200 15: 2200 16: 3700 17: 2200 18: 2200 19: 2200
    20: 2200 21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 177686
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
    driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2024-01; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 2b:00.0
    chip-ID: 10de:2504 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: Unknown-1 mapped: DP-0 res: 1920x1080 dpi: 94
    size: 521x293mm (20.51x11.54") modes: 1920x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    memory: 11.72 GiB
  Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
    bus-ID: 2b:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 8086:2725
    class-ID: 0280
  Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
  IF: enp42s0 state: down mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 8087:0032
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
    status: discoverable: no pairing: no
  Local Storage: total: 5.46 TiB used: 56.12 GiB (1.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Western Digital
    model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 620331WD temp: 42.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 4B2QEXM7 temp: 35.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NE001-2MA101
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01 scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 56.12 GiB (6.1%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7 label: N/A
    uuid: fc1e1956-bdb6-443b-b1e3-789975c6aea7
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6 label: N/A
    uuid: 987A-2C41
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 2C16-066D
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 930.73 GiB fs: ntfs label: Windows
    Boot Drive [SSD_01] uuid: ACBE16B8BE167B52
  ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 679 MiB fs: ntfs label: N/A
    uuid: CA4453F34453E0AD
  ID-5: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  ID-6: /dev/sda2 maj-min: 8:2 size: 3.64 TiB fs: ntfs
    label: Data Drive [HHD_01] uuid: 94CAD9F3CAD9D19A
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-5:3 info: Pixart Imaging Gaming Mouse type: mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 093a:2530 class-ID: 0301
  Device-2: 1-8:4 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c91 class-ID: 0300
    serial: <filter>
  Device-3: 1-9:5 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-3:2 info: SteelSeries ApS Apex Pro type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1038:1610 class-ID: 0300
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Device-1: 4-2:2 info: Genesys Logic All-in-One Cardreader
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
    chip-ID: 05e3:0748 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 35.2 C mobo: N/A gpu: nvidia temp: 31 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Processes: 454 Power: uptime: 19m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 0 hibernate: platform
    avail: shutdown,reboot,suspend,test_resume image: 12.5 GiB daemons: upowerd,
    power-profiles-daemon, gsd-power Init: systemd v: 255 default: graphical
    tool: systemctl
  Packages: 1320 pm: pacman pkgs: 1307 libs: 378 tools: gnome-software,pamac
    pm: flatpak pkgs: 13 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash
    v: 5.2.21 default: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.32
