args: Enables a program to get arguments when piped
args in a nut-shell:
#! /bin/bash
echo $(args "${@}")
$ echo "${USER}" | program "My name is"
My name is bond
What's the difference to xargs?
echo "$USER" | xargs echo "My name is"
args goal is to distinguish automatically if the command is piped or not:
$ args echo "This"
This
$ xargs echo "This"
(hangs)
It's not hanging, it's waiting for user input:
$ xargs echo "This"
works
[Press Ctrl+D]
This works
This is the standard behaviour of almost all commands expecting input. If you really also need to run the command from a terminal without piping input into it, a possible solution would be
( [ -t 0 ] || cat ) | xargs echo "This"
This uses cat to relay the input to xargs if run from a pipe. When run from a terminal, [ -t 0 ] evaluates to true, passing an empty input to xargs so that echo "This" is executed.
The idea is to nest any know-how inside commands, instead of documentation.
To turn Bash into an expressive language.
Master Foo and the Shell Tools
