So let’s assume for sake of ease (and because it’s accurate) that as far as Manjaro goes, I only barely know the difference between my rear-end and a hole in the ground (and sometimes mix the two up).
Is it possible to install the Argon40 Fan Hat for the Raspberry Pi 3/4 on Manjaro, and if so, how do I do it? Further, will it still work as a power button (which was honestly what primarily caught my interest)?
Without further information, the only Argon I know of is a package manager, and it doesnt appear to wear a hat so you might need to be a bit more explicit and/or include a link.
If you require to use the original software, the short answer, is no. It is not trivial to get the original software to run on Manjaro… but it can be done.
However, if you just want something that works and is pretty easy, yes. But it is in the AUR and not part of Manjaro proper, if that is a concern.
Yes, use the pamac gui and activate the AUR.
Then search for argonone-c-git and click to install it.
To configure it, add something like this to the bottom of your /boot/config.txt file:
Thank you very much, I’ll try it out tonight. I’m not sure why but it didn’t make any sense to me in the other threads. Will it still work as a power button?
One more thing. It makes a detailed log file: /var/log/argononed.log of every thing it does, including when it changes fan speeds and such. It is very helpful if it seems to not be acting as expected.
● argononed.service - Argon One Fan and Button Daemon Service
Loaded: loaded (/etc/systemd/system/argononed.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2021-10-28 22:08:43 CDT; 19h ago
Process: 709 ExecStart=/usr/sbin/argononed (code=exited, status=0/SUCCESS)
Main PID: 711 (argononed)
Tasks: 2 (limit: 8961)
CPU: 2.753s
CGroup: /system.slice/argononed.service
└─711 /usr/sbin/argononed
Oct 28 22:08:43 abbynormal systemd[1]: Starting Argon One Fan and Button Daemon Service...
Oct 28 22:08:43 abbynormal systemd[1]: Started Argon One Fan and Button Daemon Service.
