archlinux-java command not found
I was setting default jdk version, and it was worked just fine few days ago
Suddenly "java" command stop working in bash
So i was thing about changing it again using "archlinux-java status" command
i noticed it also stopped working , i got message command not found
You may accidentally have removed it - reinstall the package
sudo pacman -S archlinux-java
There is no archlinux-java package, the command comes with java-runtime-common:
$ pacman -Qo /usr/bin/archlinux-java
/usr/bin/archlinux-java is owned by java-runtime-common 3-2
So (re)install that package:
$ sudo pacman -S java-runtime-common
You are right - where did I get that idea?
Thanks ,, it worked ,
i reinstalled java with pacman then its worked nicely
Thanks a lot bro!
