Razer 2021 touchpad stops working after sleep
I have started an issue on libinput: Razer Blade 15 2021 Touchpad jump after wake (#685) · Issues · libinput / libinput · GitLab
But I thought I would ask here because it works great until the laptop sleeps then the trackpad is dead till a restart.
Hey I’m a newbie, but I experienced hibernation/sleep related issues as wel. For me it was the log in screen and open applications that broke if my computer entered hibernation.
The solution for me was switching the kernel to the latest recommend/lts version. I use version 5.10.70-1 now. Hope it works for you as well.
I have tried many kernels with no luck 5.10 - 5.15
Hey @vbabiy, did you ever find a workaround or fix for this? I have the exact same issue that you describe in the libinput issue.
