Apps taking too long to open
Hi there, I have freshly installed Manjaro 22 Talos xfce and then after installing I got updates and I upgrade the system to manjaro 23. After upgrading, I am facing problem with some apps like Pamac GUI, Firefox and Thunderbird. These apps are taking approx 30 second to open every time. I have also tried to run the system with kernel 6.1 and kernel 6.4 as well but the same problem. I also tried to uninstall the firefox official and installed the firefox flatpak version but still no luck. Anyone else facing the same issue. Please share the solution. It would be a great help. Thank you
known problem. run the following 2 commands in konsole and fix the issue. next time check the mandatory thread of stable/unstable updates where such problems are described including the needed changes.
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
It worked. Thank You
