I have about a 6-7 y/o gaming laptop that should be able to functionally run the programs I’m using (i.g. steam downloading and browsing firefox simultaneously) quite easily however the entire system pretty much freezes and forces me to reboot/restart due to unresponsiveness. Ksysguard from what I understand keeps reporting cores being used at around 10-20% and practically have some of them spike to 100% or near that amount when I open programs (some as simple as the terminal for example) which is odd to me. Had four 3 firefox tabs, steam, terraria, discord, and some diagnostic packages/programs such as terminal and as soon as i opened 1 new tab just a few minutes ago, the system also freezed up/stuttered for like a solid 10-20 seconds.
I have tried testing the performance of games like CS:GO and it all seems way under the expected performance line that this laptop used to perform at years ago before I switched to KDE plasma to experiment with Linux as a new user. Even comparing to Windows 10 right before I installed plasma it was arguably less frustrating, albeit slower overall. I don’t really know how to troubleshoot fixing performance issues beyond maybe just switching to XFCE and/or checking ksysguard for any tasks that may be unnecessarily taking up resources and terminate them like I have done for so long when I used Windows 10. Can anyone help here?
inxi --admin --verbosity=7 --filter --width
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=02f32c84-53e5-4995-b929-9f24719ef336 rw quiet
cryptdevice=UUID=62fc1762-64c6-4cd2-be81-85ceb4cea190:luks-62fc1762-64c6-4cd2-be81-85ceb4cea190
root=/dev/mapper/luks-62fc1762-64c6-4cd2-be81-85ceb4cea190 splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Nitro AN515-42 v: V1.18
serial: <superuser required>
Mobo: RR model: Freed_RRS v: V1.18 serial: <superuser required>
UEFI: Insyde v: 1.18 date: 06/18/2020
ID-1: BAT1 charge: 34.9 Wh (100.0%) condition: 34.9/48.9 Wh (71.3%)
volts: 16.5 min: 15.2 model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0x0064
type: Li-ion serial: <filter> status: full
RAM: total: 6.68 GiB used: 5.51 GiB (82.6%)
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2108 high: 2793 min/max: 1600/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2633 2: 2793
3: 1554 4: 1516 5: 1397 6: 1411 7: 2789 8: 2773 bogomips: 31949
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 1002:67ef class-ID: 0380 temp: 37.0 C
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15dd
class-ID: 0300 temp: 44.0 C
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 0408:a060 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: LG Display 0x05d8 built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon Vega 8 Graphics (raven
LLVM 15.0.7 DRM 3.49 6.1.12-1-MANJARO) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 1-1.3:8
chip-ID: 0d8c:0005 pcie: gen: 3 class-ID: 0300 serial: <filter>
speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.1 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0f1 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 51.0 C
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
chip-ID: 04ca:3016 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Device-1: luks-62fc1762-64c6-4cd2-be81-85ceb4cea190 maj-min: 254:0
type: LUKS dm: dm-0 size: 931.21 GiB
Components:
p-1: sda2 maj-min: 8:2 size: 931.22 GiB
Local Storage: total: 931.51 GiB used: 71.05 GiB (7.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
type: HDD rpm: 7200 serial: <filter> rev: A3J0 scheme: GPT
ID-1: / raw-size: 931.21 GiB size: 915.52 GiB (98.32%) used: 71.05 GiB (7.8%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-62fc1762-64c6-4cd2-be81-85ceb4cea190 label: N/A
uuid: 02f32c84-53e5-4995-b929-9f24719ef336
used: 472 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 1CE3-6D89
ID-1: swap-1 type: file size: 512 MiB used: 511.1 MiB (99.8%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-1:7 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 1-1.3:8 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: <filter>
Device-2: 1-1.4:9 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-3: 1-4:3 info: Lite-On type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 04ca:3016 class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-1:4 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: Quanta HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:a060
Hub-6: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.4 C mobo: N/A
GPU: device: amdgpu temp: 36.0 C watts: 6.00 device: amdgpu temp: 42.0 C
Processes: 298 Uptime: 17h 56m wakeups: 4 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1304 libs: 417 tools: octopi,pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
